  • 1 Post By trifdignn
 Old 01-11-2018, 09:49 AM   #1
Anubis450's Avatar
Posts: 78   (View Stats)
Anubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of light
Default Cylinder Misfires
Hey all,
Did some research on the forum and found some similar situations to what I'm experiencing but no solid definition on that the issue really is.
Had a misfire in cylinder 1 along with hesitation under load, replaced the coil pack since the spring inside was bent to one side and all of the spark plugs with NGK's - the previous ones looked fouled out.
After doing that, I noticed improvement in my cars conditions under load, however now I am experiencing the hesitation again as well as a misfire in Cylinder 2.
I've read it could be the plugs, coil packs, boost leak or injectors.
Anymore insight would be helpful.
I've attached a log and here our my current mods and vehicle info.
2007 MS6 97k miles.
Timing redone,
NGK spark plugs
Catless Downpipe
Autotech HPFP Internals
Forge V1 BPV
Cobb SR Intake
JBR Turbo Inlet
Thanks in advanced
Anubis450 is offline   Reply With Quote
 Old 01-11-2018, 10:28 AM   #2
Jeff23spl's Avatar
Posts: 1,631   (View Stats)
missfire dont just mean spark issur, it can be fuel related or compression related or even be the valve that need a good cleaning with a nut blast....
You checked the first thing but next you could follow by a compression test and if your engine isn't worn out, you can check if it happen at cold start or also while running.
A leaking injector let fuel accumulate on the piston and the car get a very bad iddle but usually once that fuel is burned, the engine would recover and run fine. You can check the DIZI pressure when you stop the engine, it should goes from around 450 to above 1000 and stay above 1000 for a while. If it drop after few minutes at rest, it could be an injector.
97k, if you ran the egr for a long while and your turbo smoke a little bit, you could have your intake valve and runner very dirty to the point of not allowing enough air into the chamber. To know about it, you have to remove the intake or try to check with a snake camera....But it is a common problem with direct injection engine and even worse with turbocharged ones.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 01-11-2018, 11:06 AM   #3
flapjack's Avatar
Posts: 121   (View Stats)
flapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to beholdflapjack is a splendid one to behold
A few questions:
Are you stock tune or on a Cobb OTS tune?
Was your timing redone at a dealer or did you do it?
What gap are your new spark plugs set to?
Do you have any CELs?
Also when you give us a datalog to look at, make sure you do a consistent pull from 3000 RPM to 6000 RPM+ at least. The tiny 900 RPM window of WOT you uploaded isn't worth shit really. I did notice your boost isn't even hitting 15.6 psi which is the stock boost level. I suspect you have a boost leak but it likely isn't the only issue.
Do a boost leak and compression test on all 4 cylinders and report back.
2007 Sunlight Silver Mazdaspeed3
Engine:
\\ JBR Solid RMM \\ AWR PMM \\ TRZ TMM \\ JBR PCV OCC \\ HTP 4" Intake \\ BNR S3 \\ CPE 3.25" TMIC \\ eBay 3" Catless DP \\ Autotech HPFP Internals \\ Ford Transit Van Spin-on Oil Filter Adapter \\ Full EGR Delete \\ Throttle Body Coolant Bypass \\ Corksport Injector Seals \\ Greddy Type FV BPV \\
Tuning:
\\Cobb AP V3\\ Freektune Custom Tune \\
Suspension/Brakes:
\\ BC Racing BR Type Coilovers \\ StopTech Street Pads F&R \\ Centric Drilled & Slotted Rotors \\ OZ Alleggerita Wheels 18x8 et48 \\
 Old 01-11-2018, 04:31 PM   #4
Fstrnyou's Avatar
Posts: 2,149   (View Stats)
He's in Utah. A slight underboost is likely a result of cold temperatures.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
 Old 01-12-2018, 02:35 PM   #5
Anubis450's Avatar
Originally Posted by flapjack View Post
A few questions:
Sorry guys completely uploaded the wrong log, this one is the right log.
In the log you'll see at 3.3 seconds quite a bit of knock, not sure if its related to engine noise.
I am on a COBB OTS Stage 2 tune. I bought this car about 4 months ago and I added the DP and Internals too it.
The previous owner had a local speed performance shop here do the timing.
It wasn't until about a week or two that it started doing this.
I bought the NGK Iridiums- the gap is at .032
The only CEL I have but I reset it with my AP is the cylinder 2 misfire, last week it was cylinder 1 misfire until I replaced that coil pack.
I will do a a boost leak and compression test this weekend. I have also attached the correct log in the interim.
Thanks for the fast responses!
I know I need to adjust my AFR's and such I have an old version of ATR from years ago that still works, I just cant edit the OTS maps with it unfortunately so I will need to start from scratch and re tune it once I get the following issue(s) resolved.
 Old 01-12-2018, 03:08 PM   #6
trifdignn's Avatar
Posts: 11   (View Stats)
trifdignn will become famous soon enough
Gap the plugs at .026 - 0.28 and report back.
siraynot likes this.
trifdignn is offline   Reply With Quote
The Following User Says Thank You to trifdignn For This Useful Post:
MSMS3 (01-14-2018)
 Old 01-14-2018, 10:25 AM   #7
MSMS3's Avatar
Posts: 2,329   (View Stats)
Groans: 126
Agree. .032 is way too large. I'm surprised OP is not getting spark boost blow out. High boost and big gap = boost blowing out the spark, causing misfire.
At stage 2, even .028 may be too large. Set them at .026.
 Old 01-15-2018, 09:01 AM   #8
Anubis450's Avatar
Gap fixed it. I put them at .026.
Damn I feel like an idiot.
Thanks for all your help!
 Old 01-15-2018, 06:34 PM   #9
Marcus's Avatar
Posts: 776   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
In the random event you experience more misfires or specifically the p0302, lucas oil fuel system cleaner cleared mine up for the past two years or so. There's three bottles available, the mid sized one technically treats up 3 tanks worth of gas so something to consider if you using it is the concentration levels. It'll work though. And you should notice half way through the tank a smoother running engine.
2006 Moist Metallica Silver Speed6 GT #6557 @ 260,670km
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
Still thinking about Flowmasters
Marcus is offline   Reply With Quote
The Following User Says NO Thank You to Marcus For This Un-useful Post:
Thor Hammer (01-16-2018)
 Old 01-16-2018, 09:14 AM   #10
Thor Hammer's Avatar
Posts: 1,766   (View Stats)
Groans: 198
WTF? He just said he fixed it. LOL.
The Following User Says NO Thank You to Thor Hammer For This Un-useful Post:
Marcus (01-16-2018)
 Old 01-16-2018, 12:24 PM   #11
Marcus's Avatar
Like I said, in the random event he gets a misfire code again. Reeeelax.
 Old 09-11-2018, 12:53 AM   #12
Shredhead86's Avatar
Posts: 19   (View Stats)
Shredhead86 has a spectacular aura aboutShredhead86 has a spectacular aura about
My six has gotten to the point where it misfires on a cold start. But if I shut it of and immediately on again it runs fine. One of my friends suggested it may be the vvt solenoid. I put new plugs in it back in April. Iridium IXs gapped at .032 (I think). It didnít start this problem until maybe the last month. I donít know whens the last time the VVT was serviced as Iíve only had the car for about a year. Any help would be much appreciated.
Shredhead86 is offline   Reply With Quote
 Old 09-11-2018, 07:43 AM   #13
Jeff23spl's Avatar
Before trying a 1000$ VVT job, i would recheck your plug gap. The speed are sensitive to it. Especially if you aren't not sure about it.
missfire at cold start could often be a leaking injector if it return to normal when the car is warmed up....( colder plug wouldn't help it either.)
Once at it, check engine compression.
I'm not sure how a failing VVT would react at cold but if it is loose enough to affect timing, it would also affect compression test...
Wife drive 2010 CX7
Shredhead86 (09-11-2018)
Random misfires after new plugs mrjoshyman MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 06-27-2016 10:03 AM
cylinder misfires and KR Jaxon MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 09-03-2015 06:41 PM
CEL during road trip, random cylinder misfires? AveryPlaysBass 2010 MS3 - Engine, Transmission & Driveline 0 10-06-2014 10:06 AM
MS6 P0302 CEL, other misfires, stuttering. SirChodesly MazdaSpeed 3/6 - Troubleshoot/Diagnostics 16 08-28-2014 12:28 PM
P0300 Random / Multiple Cylinder Misfires txmedic83 CX-7 > Issues & Troubleshooting 9 08-13-2013 01:45 PM
©Copyright 2008 ; 2018 Cymru Internet Services LLC | FYHNô Autosports HQ
Page generated in 0.36941 seconds with 29 queries
