![]() | | #1 | ![]() |
Rep Power: 7491 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
(Thread Starter) | Not Ranked : 0 score An explanation of Dynamic Compression Ratio (DCR) vs Static Compression Ratio (SCR): SCR is calculated from total amount of compression available from the measurement beginning of Bottom Dead Center (BDC) which is the maximum amount of compression mechanicly available. DCR is calculated on the compression stroke after the intake valve closes since you cant really have compression with the valves open. The DCR will always be less than the SCR and the DCR is closer to a real world compression ratio. The only difference between DCR and SCR is that on the DCR the intake valve closing is calculated into the equation. My engine specs with aftermarket cam: Bore = 87.5mm/3.445" Stroke = 94mm/3.701" Rod c/c = 154.75mm/6.092" Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 115* Inlet Valve Closes After Bottom Dead Center (ABDC): 57.5* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.00:1 Dynamic Cranking Pressure: 137.81 PSI Dynamic Boost Compression Ratio: 17.80:1 The dynamic compression ratio for this setup with my aftermarket cams is 8.0:1 which is the middle of the acceptable range of 7.5:1 and 8.5:1 for pump gas engines. Anything less than 7.5:1 is bad for power and torque and anything above 8.5:1 will generally knock on pump gas. If we change only the LSA to the factory cam spec of 108*, we get: Bore = 87.5mm/3.445" Stroke = 94mm/3.701" Rod c/c = 154.75mm/6.092" Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 108* Inlet Valve Closes After Bottom Dead Center (ABDC): 54* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.19:1 Dynamic Cranking Pressure: 141.89 PSI Dynamic Boost Compression Ratio: 18.22:1 Now to Lex's theory, which I generally laughed at: He stated that low rpm torque lead to grenaded engines and the boost and timing ranges needed to be altered to move the peak torque higher in the powerband. I knew Lex was onto something but I also though he was wrong because we have a very long stroke and if our rods were that weak the piston velocities would be grenading engines left and right at high rpm and high boost long before the low rpm torque would do anything. Here is something that struck me today when I was running the numbers and expectially after reviewing Subparpunk03's VVT chart. The variable valve timing advances the intake cam a max of 18* in relation to the exhaust cam, in the higher load ranges of RPMs less than 5000. This cam advance does two things, it moves the powerband of the cam lower so we can have both a low rpm high torque cam and a high rpm high hp cam, but here is the catch: it raises the dynamic compression ratio of the engine in low RPMs to potentially dangerous levels that could induce knock. If we advance the LSA of the 108* cam 18* we get: Bore = 87.5mm/3.445" Stroke = 94mm/3.701" Rod c/c = 154.75mm/6.092" Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 90* Inlet Valve Closes After Bottom Dead Center (ABDC): 45* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.58:1 Dynamic Cranking Pressure: 150.3 PSI Dynamic Boost Compression Ratio: 19.09:1 If we advance the LSA of my 115* cam by 18* we get: Bore = 87.5mm/3.445" Stroke = 94mm/3.701" Rod c/c = 154.75mm/6.092" Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 97* Inlet Valve Closes After Bottom Dead Center (ABDC): 48.5* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.44:1 Dynamic Cranking Pressure: 147.28 PSI Dynamic Boost Compression Ratio: 18.77:1 This dynamic loading could explain why our engines like to knock and grenade at low rpms and almost no one blows at high rpm or high boost. The bottom line is that the closer you get to 8.5:1 dynamic compression the more likely you are to knock and engine reliability goes down the drain. At around 8.58:1 near idle coupled with very advance timing and close to stotch a/f I think we could be walking a razors edge for low rpm knock even with the benefits of direct injection. One final thought after sleeping on everything last night, if we look at that chart and take it as a percentage of the whole 18* of maximum advance, then 30 on the chart would be 30% of 18* which is exactly the nice round number 8.30:1 dynamic compression as evidenced by the following: Bore = 87.5mm/3.445" Stroke = 94mm/3.701" Rod c/c = 154.75mm/6.092" Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 102.6* Inlet Valve Closes After Bottom Dead Center (ABDC): 51.3* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.30:1 Dynamic Cranking Pressure: 144.26 PSI Dynamic Boost Compression Ratio: 18.46:1 The bonus to all of this is that with the proper aftermarket cam, we can have our cake and eat it too because we can run an agressive, lopey cam and still enjoy a smooth idle. Special thanks to Subparpunk03 and Superskaterxes for helping me with this. What are your thoughts?
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 09-22-2009 at 08:36 AM. |
| The Following 38 Users Say Thank You to 06Speed6 For This Useful Post: | 802MS3 (09-22-2009), AmillieMS6 (09-21-2009), AndyMS3 (09-23-2009), bioevolve (09-21-2009), BobtailedSnail (11-26-2011), Caldazar (12-27-2009), Coaststarlight (03-04-2011), Code Monkey (01-12-2013), Constantin (04-27-2012), Dahouse702 (05-31-2013), djuosnteisn (09-22-2009), Downmented (06-15-2012), Fobio (09-22-2009), GQ_WhiteMS3 (09-21-2009), harryclay (11-05-2011), JmkC (09-22-2009), labikesrcool (09-21-2009), leon78 (01-16-2013), Lex (09-21-2009), MarkyMark (09-21-2009), mexicant (09-21-2009), Mfinlay04 (11-06-2009), MSFer87 (06-03-2011), nighthawk358 (09-21-2009), paveltol (01-16-2013), RC08MS3 (09-21-2009), rigor (12-13-2010), shpankey (01-27-2010), spals (03-11-2013), speedsiks (02-19-2010), SpeedSixxx (10-02-2009), spike589 (03-23-2010), spnkr21 (11-06-2009), Swearingen (04-19-2010), tozfeekum (09-21-2009), Twofer (01-16-2013), Yatta (01-16-2013), yearzero (04-02-2010) |
| NEC ![]() Join Date: Mar 2008
Rep Power: 473 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 129
Groaned at 6 Times in 6 Posts
| Not Ranked : 0 score I'm not understanding something... Am I reading that correctly that adding 30* to the intake cam advance means lowering the static compression ratio? I think I'm missing something here, can you take a step back and for my benefit explain how the intake cam advance effects the dynamic compression ratio with all other factors unchanged?
__________________ 2006 Lotus Elise: Toy car 1999 B4000: DD / Parts hauler / SC Project 2007 Mazdaspeed 3: *sold* 2005 Corolla XRS: *sold* |
(Thread Starter) | Not Ranked : 0 score The valve is open longer with the extra 30* of intake cam timing so the piston is higher in the bore by the time the intake valve closes. Increasing the lobe seperation angle allows more air into the engine at higher rpms, but lowers the effective compression ratio because you cant compress the air in the cylinder if the intake valve is open. On a normal engine the intake valve will always be open for the first part of the compression stroke. Dynamic compression ratio starts the calculation once the piston reaches a point in the bore where the intake valve is closed and actual compression can begin. Static compression ratio starts the calculation from the very bottom of the bore. The static compression ratio is unchanged.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 09-21-2009 at 03:33 PM. |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | BobtailedSnail (11-26-2011) |
![]() | | #4 | ![]() |
| Miembro ![]() Join Date: Jun 2008 Location: Puerto Rico
Rep Power: 420 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,095
Groans: 27
| Not Ranked : 0 score damn...we need more people like u 06speed6
__________________ 2008.5 MS3 Metro Gray...slow |
| The Following 2 Users Say Thank You to nighthawk358 For This Useful Post: | AmillieMS6 (09-21-2009), BobtailedSnail (11-26-2011) |
![]() | | #5 | ![]() |
| Not Ranked : 0 score My bad, I meant DYNAMIC compression ratio... so more increase in the intake cam means LESS dynamic compression... so we are running more increased VVT in the mid-load/part-throttle area, so wouldn't lowering the dynamic compression there be a good thing? and does the VVT increase the length of time that the intake cam is open, or just change the time at which the valve begins to open? If the valve opens earlier but stays open for the same length of time, I am picturing it in my head that increasing intake cam advance would increase the dynamic compression ratio... I'm still confuzzled.
![]() | | #6 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 300
| Not Ranked : 0 score so....ok......what do we do about this to keep the CEL's (change engine lights) at bay?
__________________ ![]() 07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107 TOTALED 11/2/09 ![]() 04 SRT4 - sold - trapped 120+ |
![]() | | #7 | ![]() |
![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 761
Groans: 190
Groaned at 53 Times in 32 Posts
| Not Ranked : 0 score So if I understand this correctly, we could benefit from a VVT delete or mod?
__________________ My mission is to go fast. ![]() Currently Designing: The golden girdle of the gods The CF "fuck your face" IM |
![]() | | #8 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 631
Groans: 40
| Not Ranked : 0 score this is over my head... where do i go to read up on this shit?! good work 06speed6, i can't wait until i understand this! |
![]() | | #9 | ![]() |
(Thread Starter) | Not Ranked : 0 score Man I really need to reread the shit I type... I edited my second post.
The VVT doesnt increase the total amount of time the valve is open, it just moves its timing to a place that is more favorable to higher rpm power. Im also saying advance as: moving the valve opening and closing event forward in the combustion event.
Buy a engine design book, the thicker it is and the more forumulas it has the better.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 09-21-2009 at 03:43 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #10 | ![]() |
| Not Ranked : 0 score OK, lets take a specific scenario. Here's what the VVT table looks like in ATR... we're running 30* of intake cam advance the second we get over 100% calculated load until we hit 4500 rpmsish. ![]() That means we're opening the intake valves sooner when its more advanced, right? So that also means that the intake valves close earlier in the compression stroke, thus higher dynamic CR?
![]() | | #11 | ![]() |
(Thread Starter) | Not Ranked : 0 score No they open and close later with higher advance. I guess I am using it the opposite of ignition advance. I havent seen the VVT table before, I love it. Im going to look it over. Stupid double post shit: That chart is really counter intuitive, the VVT timing should advance in some linear fashion with rpm. Thats really weird shit.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG |
![]() | | #12 | ![]() |
| Not Ranked : 0 score so....since advancing the intake cam lowers DCR....(if i read right), adding a little advance in the areas we all see knock, (the lowerish loads in the 3k rpm area)....may help? ....potentially excited
![]() | | #13 | ![]() |
Stupid load based crap, im going to need to think about this some more. Perhaps we could lower the load threshold for cam advance, but the whole chart seems backwards.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG | |
![]() | | #14 | ![]() |
The mid range intake advance on the other hand seems to mitigate a high DCR ... in an attempt to reduce knock in the meat of the torque band - but once again relying on stock restrictions. Perhaps an increase in intake advance at lower loads is further needed when opening up the intake and exhaust. Good info! EDIT: Small FYI on LSA: http://74.125.155.132/search?q=cache...&ct=clnk&gl=ca | |
![]() | | #15 | ![]() |
__________________ ![]() 07 cb Ms3 - MS cai / Vibrant exhaust / TurboXS DP / Cobb AP - trapped 107 TOTALED 11/2/09 ![]() 04 SRT4 - sold - trapped 120+ | |
![]() | | #16 | ![]() |
(Thread Starter) | Not Ranked : 0 score Just for shits and giggles, if we changed the direction of cam advance of a 108* LSA cam we get: Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 78* Inlet Valve Closes After Bottom Dead Center (ABDC): 39* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.81:1 Dynamic Cranking Pressure: 155.29 PSI Dynamic Boost Compression Ratio: 19.6:1 Then the low and mid rpm, higher load parts of the chart would make less sence because the timing advance would make the LSA more agressive, but it would explain why our engines would blow.
![]() | | #17 | ![]() |
Groans: 79
06speed6, muchos gracias for introducing me to this concept. Makes damn good sense!
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
![]() | | #18 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score does anyone know our stock LSA? someone needs to start playing with this table to reduce low end power and open that shit up in the higher RPM's
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner |
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Coaststarlight (03-04-2011), djuosnteisn (09-21-2009) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score I'm still really struggling with this for some reason. Is the following true: Intake valves open at the tail end of the exhaust stroke Stay open for the duration of the intake stroke close slightly after the beginning of the compression stroke Now, if you are running 0* advance or 30* advance the intake valves always remain open for the duration of the intake stroke and what changes is how long they are open during the exhaust and compression strokes. What you are saying is MORE advance means the intake valves are open for more of the compression stroke, and less advance means they're open for more of the exhaust stroke.
![]() | | #20 | ![]() |
| Not Ranked : 0 score on another MORE CRITICAL note whats the max and min values of this table and when will u begin to see interference? is there anyway to calculate this knowing valve length/travel?
![]() | | #21 | ![]() |
![]() Join Date: Jan 2009 Location: Andover, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,936
Groans: 192
| Not Ranked : 0 score ohh this looks good..subscribing!
__________________ precision gen2 5862 coming soon [SIZE="1"]07 MS3 GT.. Engine:Cobb V3,GTX3076r EWG,Wiseco Pistons/Manley Rods, L19's,JMF, Bosch 3.5bar MAP,CS cat-back,M2 DP, full race manifold,FP internals,FREEK 4",CP-E flange HKS,DO Stage II ss lines,Cobb piping,TR8L,MD RMM&TMM,JBR RSB & FSB,JBR SST,JBR knob,ACT 6puck,JBR EGR delete,CPE Seals,Grimmspeed EBC,JBR BSD,MD Catch Can.Looks:yellow lamin-x fogs,chrome turn signals,side moldings removed,20% tint,CS wheelSuspension/Wheels:Enkei RPF1 17x9,Eibach 5mm spaces H&R springs,koni yellows. GTX3076r --- 479/412 S4-460/400 Highest HP BNR S3 BNR-S3 424/397 |
![]() | | #22 | ![]() |
Groans: 79
| Not Ranked : 0 score If the 0's in the table correspond to the higher DCR, i guess it could be feasible that mazda did it intentionally at the high rpm / high load areas, counting on the cooling characteristics of DI to keep detonation at bay. It would also explain the knock at our infamous part throttle zone.
![]() | | #23 | ![]() |
![]() Join Date: Oct 2008 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,083
Groans: 365
Groaned at 594 Times in 575 Posts
| Not Ranked : 0 score we do.. his twin and long lost brother LEX
__________________ Mazdaspeed ![]() |
| The Following User Says NO Thank You to AmillieMS6 For This Un-useful Post: |
![]() | | #24 | ![]() |
Groans: 79
| Not Ranked : 0 score Oh and one more bit of input from me. I've been playing with the VVT table and looking at my maf curve, and with lower VVT values at high load / high rpm, power (and maf g/s) seems to increase. It's just butt dyno data, but another possibly helpful tidbit. I don't recall my table going all the way to zero though. I'll check when i get home.
![]() | | #25 | ![]() |
I assumed that more advance is keeping it open for more of the compression stroke, but that should decrease overlap which would make the cam more favorable to high boost. Removing the advance would make it more favorable to n/a, low boost, and low rpms. You know, I had this shit figured out in my head until you started talking
![]() | | #26 | ![]() |
| Not Ranked : 0 score Also remember that there is a response time to VVT. It's not instantaneous. Another note, 06speed6, are you sure on your definition of advance? Is advancing the intake cam same as advancing timing - in other words moving it further away from TDC or is it advancing it towards TDC? Last edited by Lex; 09-21-2009 at 04:51 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score I thought it would be advancing it towards the compression stroke TDC, not towards the exhaust stroke TDC. This is where the confusion is. EDIT: Regardless of which direction, that chart still doesnt make even the slightest bit of sence. Because if we flip my definition of "advance" around, we would start with a 8.2:1 compression engine at low rpm/low load and move to ~8.8:1 compression for low rpm/high load, and we would maintain 8.2:1 compression for all high rpm loads. If we use my definition of "advance", we start with 8.2:1 compression at low load/low rpm and move to progressively lower compression as load increases and according to the chart, retain 8.2:1 compression at high rpm for all loads.
![]() | | #28 | ![]() |
Groans: 79
| Not Ranked : 0 score I would imagine overlap would be desired in higher rpm, so lower values in the table correspond to intake valves opening earlier. Perhaps that table should be named VVT intake cam retard??? I think mazda was stuffing all those 0's in the PT KR zone of death for a reason. And maybe after some breather mods, their coverage isn't enough. Maybe low numbers need to be expanded into the higher load areas. eh, i don't know. Time to let the experts work.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com Last edited by djuosnteisn; 09-21-2009 at 05:18 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #29 | ![]() |
Also using that logic, moving the max lift area to the begining of the intake stroke and having it overlap more into the exhaust stroke would give more overlap but on a normal high overlap cam you would also have higher duration which is where the power is, I think we should have less total power like this because our duration is unchanged, but I could be wrong.
![]() | | #30 | ![]() |
| Not Ranked : 0 score ok heres the chart again from page 1 ![]() and heres a nearly stock dyno of MS6 (I/TP/BOV) ![]() i would say the MEAT of the RPM with uber torque is in that fat range of 30's and 20's in the table. this would mean its SUBTRACTING from the LSA and u can also see HP peaks at the end where the table goes right to 0's.
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score I just took apart the VVT mechanism I have laying here, it advances towards the exhaust stroke which would be a lower LSA number. Ironicly it also doesnt advance 30*, the max is 18* on my degree wheel. Lets run the numbers again with this in mind... Assume stock LSA is 108*, then: Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 108* Inlet Valve Closes After Bottom Dead Center (ABDC): 54* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.19:1 Dynamic Cranking Pressure: 141.89 PSI Dynamic Boost Compression Ratio: 18.22:1 And with 18* max advance: Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 90* Inlet Valve Closes After Bottom Dead Center (ABDC): 45* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.58:1 Dynamic Cranking Pressure: 150.30 PSI Dynamic Boost Compression Ratio: 19.09:1 Discuss in relation to the VVT chart.
![]() | | #32 | ![]() |
| Not Ranked : 0 score can u measure the stock LSA for us or no
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score I dont have a stock cam set, my aftermarket one is 115*, the stock evo is 108 or 110 I forget which. 115* is fairly high for a turbo cam except now that I know I can subtract 18* from it at idle... oh the possibilities. With my cam it is: Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 115* Inlet Valve Closes After Bottom Dead Center (ABDC): 57.5* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.00:1 Dynamic Cranking Pressure: 137.81 PSI Dynamic Boost Compression Ratio: 17.80:1 With -18* LSA... Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 97* Inlet Valve Closes After Bottom Dead Center (ABDC): 48.5* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.44:1 Dynamic Cranking Pressure: 147.28 PSI Dynamic Boost Compression Ratio: 18.77:1 I still stay under the magic 8.5:1 ratio.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG Last edited by 06Speed6; 09-21-2009 at 06:31 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #34 | ![]() |
| The Kamikaze King! ![]() Join Date: Jun 2008
Rep Power: 1829 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,794
Groans: 754
| Not Ranked : 0 score It seems there is some confusion regarding direction, this may help. EFFECTS OF ALTERING CAMSHAFT TIMING Advancing Begins Intake Event Sooner Open Intake Valve Sooner Closes Intake valve Sooner Builds More Low-End Torque Decrease Piston-Intake Valve Clearance Retarding Delays Intake Closing Event Keeps Intake Valve Open Later Builds More High-RPM Power Increase Piston-Intake Valve Clearance Not sure which lowers Dynamic compression, I will leave it to you guys to sort that part out. We cannot retard past 0, and cannot advance more than 30* I believe.
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. Last edited by FreeFlyFreak; 09-21-2009 at 07:07 PM. |
| The Following 2 Users Say Thank You to FreeFlyFreak For This Useful Post: | speedsiks (02-19-2010), subparpunk03 (09-21-2009) |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score Advancing raises dynamic compression Retarding lowers dynamic compression We also only advance to 18*, not 30*.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | subparpunk03 (09-22-2009) |
![]() | | #36 | ![]() |
Groans: 754
Just for reference. I go into positive boost right around 84 load, 2-3 psi is right about 100, right where it hits max advance and max dynamic compression. Funny thing is though for me (SRI and AP only), I dont get the partial throttle knock everyone talks about. All mine is WOT 4500-5700 unless I add octane booster to my Cali 91 octane. But I presume that is because I am pushing less psi than he fully bolted guys.
"Table values are the degrees of timing advance (shown in camshaft degrees) the VVT system will attempt to target. Higher values mean more intake camshaft advance, lower values mean less advance. You cannot retard (use a value less than zero) the intake camshafts." The max value I see in any table is 30* Maye we are talking at cross purposes here, 30* from what?? Im guessing 30* from the unadvanced position, whatever that is, but it could be relative to something else. You are saying 18*, but 18* from what?, maybe we are talking the same thing really? EDIT: I missed your post #31 ,so I dunno then??!!
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. Last edited by FreeFlyFreak; 09-21-2009 at 07:35 PM. | |||
![]() | | #37 | ![]() |
| Not Ranked : 0 score after talking to john from PTP the stock LSA is 103 or 104.
![]() | | #38 | ![]() |
| Not Ranked : 0 score So with an LSA or 104, we have the following: Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 104* Inlet Valve Closes After Bottom Dead Center (ABDC): 52* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.28:1 Dynamic Cranking Pressure: 166.22 PSI Dynamic Boost Compression Ratio: 18.42:1 And with 18* max advance: Static Compression Ratio (SCR): 9.5:1 Lobe Seperation Angle (LSA): 86* Inlet Valve Closes After Bottom Dead Center (ABDC): 43* (Lash not factored in) Test Boost Pressure: 18psi Altitude: Sealevel Dynamic Compression Ratio: 8.67:1 Dynamic Cranking Pressure: 176.38 PSI Dynamic Boost Compression Ratio: 19.29:1 |
| The Following User Says Thank You to Lex For This Useful Post: | 06Speed6 (09-21-2009) |
![]() | | #39 | ![]() |
| Not Ranked : 0 score also your not going to be able to see a full 18 deg just because of the physical limitations of the VVT. also 18 deg is ALOT of overlap and you might even run into piston interference or start touching the exhaust valves.
![]() | | #40 | ![]() |
Groans: 754
"Staying below 8.25 DCR is probably best for trouble free motoring" : for reference linky: http://www.empirenet.com/pkelley2/DynamicCR.html Am I reading it right??? Beuller? Beuller? My brain hurts. I need booze......... it helps me think more clearly. What are you guys using to calculate these numbers. For my reference: EFFECTS OF CHANGING LOBE SEPERATION ANGLE (LSA) Tighten (smaller LSA number) Moves Torque to Lower RPM Increases Maximum Torque Narrow Power band Builds Higher Cylinder Pressure Increase Chance of Engine Knock Increase Cranking Compression Increase Effective Compression Idle Vacuum is Reduced Idle Quality Suffers Open Valve-Overlap Increases Closed Valve-Overlap Increases Natural EGR Effect Increases Decreases Piston-to-Valve Clearance from here: http://www.compcams.com/Technical/FAQ/LSAproperties.asp
__________________ BB code url is no longer allowed.........so..... http://www.fuelly.com/driver/FreeFlyFreak/speed-3 ![]() http://www.fuelly.com/driver/FreeFlyFreak/speed-3 Suspension: OEM --> FSD 4040 --> FSD 4040 with cut stops --> MS Coils --> FSD 4045's --> FSD4045 with cut stops --> Bilstein Sports Yes, that is me in the avatar. Last edited by FreeFlyFreak; 09-21-2009 at 08:05 PM. | |
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f106/dynamic-compression-ratios-blown-engines-38323/ | ||||
| Versatuner on Gen 2 Experience | This thread | Refback | 04-25-2013 06:29 PM | |
| Problem/Noise/Rattle *Video* ? Mazda MPS Owners Club | This thread | Refback | 01-17-2013 12:27 PM | |
| VersaTuner: ????????, ??????????, ????? ?????? | This thread | Refback | 03-30-2012 06:07 AM | |
| Good reading for the Speed6 guys! | This thread | Refback | 01-13-2012 02:24 PM | |
| AZMazda3.com - Your Arizona Mazda3 Community | This thread | Refback | 04-02-2010 08:19 PM | |
| Good reading for the Speed6 guys! - AZMC - Arizona Mazda Club | This thread | Refback | 04-02-2010 10:29 AM | |
| The uphill battle of the Mazdaspeed - Page 2 - College Park Tuning :: Try and Keep up! | This thread | Refback | 09-30-2009 09:41 AM | |
| My heap - Page 2 - College Park Tuning :: Try and Keep up! | This thread | Refback | 09-23-2009 07:35 PM | |
| albuquerque nm mazda 6 owners - Mazda6 / Atenza | This thread | Refback | 09-22-2009 04:44 PM | |
| Compression test done.. | SharkDiver | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 03-25-2009 04:28 PM |
| engine compression? | bombdotcom | Mazdaspeed3/6 General Discussion | 12 | 09-23-2008 04:06 AM |
| Honda Zest Sports G now more dynamic, special | Haltech | Automotive News | 1 | 05-16-2008 10:21 AM |
