![]() | | #1 | ![]() |
![]() Join Date: Aug 2012 Location: va
Rep Power: 0 ![]() ![]() ![]() Thanks: 8
(Thread Starter) | Not Ranked : 0 score thanks |
| Banned ![]() Join Date: Dec 2009 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,102
Groans: 89
Groaned at 103 Times in 69 Posts
Drain, flush with tap water, then refill with anything (peak, prestone,etc) Are you one to flush/drain once a yr or so? If so the direction above is fine. The Maz fluid is meant for ppl that wait 3-4 yrs b4 draining/flushing. I've been running 75w/25c and have no ill effects. Use common sense and judgement, you will be fine. |
no just doing it because i says to, should i use something else(better)? just owrried about water sitting around somewhere when refilling it with fl22
![]() | | #4 | ![]() |
Groans: 89
Nope, should be fine as long as most of it is out. I think that is why most run full maz fluid because they get pananoid. What year and mileage? |
| The Following User Says Thank You to pzr2874 For This Useful Post: | nsdva (09-07-2012) |
![]() | | #5 | ![]() |
![]() Join Date: Jul 2010 Location: Rowland Heights, California
Rep Power: 111 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 77
remember if u add water to the mix, used distilled water
| The Following User Says Thank You to fredricktsang For This Useful Post: | Coaststarlight (09-07-2012) |
![]() | | #6 | ![]() |
![]() Join Date: May 2009 Location: Kankakee, IL
Rep Power: 7915 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,616
Groans: 121
FL22 is already 45% water. Says so on the bottle. You're told not to add water because FL22 comes prediluted. Tapadatass
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ |
![]() | | #7 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,284
Groans: 211
Groaned at 308 Times in 225 Posts
Ugh.. Wrong section.. Please pay attention to the area you post threads in. Thanks
Welcome To http://www.mazdaspeedforums.org The HARDCORE Of Mazda High Performance Tech! COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |
![]() | | #8 | ![]() |
70k 07 thanks guys and sorry wrong area this why i am a brownie right :P |
| The Following User Says Thank You to nsdva For This Useful Post: | tddvrrn (09-08-2012) |
![]() | | #9 | ![]() |
| thread killer ![]() Join Date: Sep 2009 Location: Oak Pollen Central
Rep Power: 779 ![]() Thanks: 1,885
Groans: 84
Groaned at 6 Times in 4 Posts
They're saying don't ADD water as to dilute it. Just flushing the old crap and having a bit of residual water, not so much an issue. |
![]() | | #10 | ![]() |
| Hair by Voltron ![]() Join Date: Feb 2009 Location: Hillsborough, NJ
Rep Power: 146194 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51,080
Groans: 1,404
Groaned at 310 Times in 292 Posts
You paged me?
__________________ ![]() 11.91 @ 122.48 1.85 60' - 12/4/11 - Atco Raceway 11.85 @ 119.69 1.75 60' - 4/15/12 - Mason Dixon Dragway For Sale Section Rules UPDATED 5-17-2013! Please read before posting! |
| The Following User Says Thank You to doubleflusher For This Useful Post: | tddvrrn (09-08-2012) |
![]() | | #11 | ![]() |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 2880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,186
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score |
| The Following User Says Thank You to lilred For This Useful Post: | doubleflusher (09-07-2012) |
![]() | | #12 | ![]() |
have you guys ever filled it up with water and plugged it back up and turned it over and ran the heat to fully clear it without having problems? i dont think it be the best idea to be mixing coolants! or running the car on just water. Last edited by nsdva; 09-07-2012 at 09:22 PM. | |
![]() | | #13 | ![]() |
how are you guys doing a full flush? i figure the old coolant could become trapped in other parts of the cooling system such as the heater core, radiator and / or oil cooler. i would always use tap but this may cause problem while running the car with the heat on to clear it.
![]() | | #14 | ![]() |
Groans: 211
Yes you run the heater on during the flush process, then drain again.
![]() | | #15 | ![]() |
i think im going to just run coolant for a flush, im so paranoid about damage untill its clear being the coolant's capacity is only being 7.5L
![]() | | #16 | ![]() |
Groans: 211
Once it's clear, shut the motor off and allow the rest of the water to drain. Once drained, cap the drain plug and start adding the coolant. You could premix it or add it raw. Once it tops off on the radiator, fill up the resevoir with coolant. Leave the cap off and start the motor. This will do two things.. 1) allows the coolant to circulate and mix the new coolant and 2) pushes the air out. Add more and more coolant.. Don't forget to burp the system by squeezing the radiator hoses. Once you can't add anymore coolant, cap it and go for a drive. Come back and top it off. I usually add a bottle of water wetter when I refill.
Welcome To http://www.mazdaspeedforums.org The HARDCORE Of Mazda High Performance Tech! COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
| The Following User Says Thank You to Haltech For This Useful Post: | nsdva (09-08-2012) |
![]() | | #17 | ![]() |
Groans: 89
Adding water wetter with most coolants will "gel" your shit up over time. Of course if you anal. |
![]() | | #18 | ![]() |
Groans: 211
| What the hell are you talking about? That is complete and utter bullshit
| The Following User Says Thank You to Haltech For This Useful Post: | silvapain (09-08-2012) |
![]() | | #19 | ![]() |
![]() | | #20 | ![]() |
![]() Join Date: Jul 2012 Location: Elizabethtown, PA
Rep Power: 67 ![]() Thanks: 77
A engine machining teacher at UNOH (a school with a pretty extensive high performance program) once told me that he swears by adding 1 tbsp of pine sol to his coolant. Said it works just like water wetter. He also said that you could use a dash of dish detergent instead of other additives because it breaks down the surface tension of the water and helps promote better cooling. Anyone ever heard of any of this? I kinda wanna try it out, this dude was straight old school and owns some pretty impressive cars. Ps, sorry for the minor thread jack.
__________________ Hers: 06 MS6, 53 Pontiac Cheiftan Sedan His: 53 Ford Business Coupe |
![]() | | #21 | ![]() |
but im using fl22 it say do not add water flushing with water makes this complicated!!
![]() | | #22 | ![]() |
Groans: 89
Coolant (most) mixed with water wetter WILL cause (gumming/gel) Silicates in the coolant will cause this when mixed with WW (for coolants with silicates) WW is meant as a WATER additive, not a coolant additive. This is the coolent ppl should be using : http://shop.edoperformance.com/evans...FWVgTAod9QYAfw Shameless plug as i've been using it for 2 yrs on this platform. But IMHO if you do your flushes every yr, there isn't a need for it. |
![]() | | #23 | ![]() |
Groans: 211
Come look at my coolant... There's no "gel" or "gumming" and ive been using it since 1990 when it was availbe only in crystal form then requiring dilution with water and filtration via cheesecloth before adding to coolant.
![]() | | #24 | ![]() |
Groans: 89
You sexy beast, i'm not going to come look at it. I've seen BS on the webz is all. And seen the gumming. Like I said, with some/most coolants.... The silicates mixed with the WW is where they had the issues. Here's where I get my fluid info http://www.bobistheoilguy.com/forums...Number=1255926 |
![]() | | #25 | ![]() |
Groans: 211
I've never had negative effects from using it with coolant. I use it exclusively in my water to air intercoolers which is distilled water and ww.
| The Following User Says Thank You to Haltech For This Useful Post: | pzr2874 (09-08-2012) |
![]() | | #26 | ![]() |
.... anyone use fl22 here...
![]() | | #27 | ![]() |
![]() Join Date: Jan 2012 Location: Bradenton, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 205
i flushed with FL22. step one: empty coolant. Step two: fill with water (distilled if your scared) step three: run engine until thermostat opens, flushing the cores and block. step four: empty. step five: refill with fl22, straight from bottle. step six: run until heater core opens and leave uncapped. (just burped the system) FL22 is good for about 100,000 ISH miles. I changed mine at 50k. they say dont add water because it dilutes the coolant which lowers the boiling point. a couple ounces of water in the black |
| Need advice on BNR S3 | Cool1Net6 | MazdaSpeed 3/6 - Turbo Induction | 46 | 06-09-2012 04:29 PM |
| Flushing brakes | aviator79 | CX-7 > Wheels, Tires, Brakes & Suspension | 0 | 04-20-2012 12:52 PM |
