  • 1 Post By Amnesiac
 Old 11-25-2012, 06:43 PM   #1
Amnesiac's Avatar
Posts: 315   (View Stats)
Amnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the worldAmnesiac is the leader of the world
Groaned at 6 Times in 4 Posts
Default Help with a leak between the transmission and PTO
I recently replaced the clutch in my MS6. After that I've found that I'm leaking transmission fluid. It seemed to be coming out between the transmission and the PTO. I now have the PTO off the car and I'm trying to see where the problem might be.
The only visible issue I can see is this rubber ring where the PTO and transmission meet.
It's not easy to see from the picture but it has some cracks in it. Does anyone know if the rubber piece is able to be replaced? I have all the seals between the PTO and transmission from the engine part list thread and none of them are correct.
Amnesiac is offline   Reply With Quote
The Following 2 Users Say Thank You to Amnesiac For This Useful Post:
06Speed6 (11-25-2012), rob ms6gt (11-29-2012)
 Old 11-25-2012, 10:50 PM   #2
Speeeeeed
06Speed6's Avatar
Posts: 6,526   (View Stats)
I just ordered and received all of the trans and pto seals listed in my part number thread, they are supposed to be correct but reading those part diagrams can be really confusing. If a seal isnt correct post the part number, even if you don't know the right one. Hopefully we can get them all sorted out.
That seal can be replaced.
Edit: I think some of the seals may be ms3 seals, there is no easy way to tell a ms3 and ms6 trans diagram apart and that seal should be different between the two cars, the drivers seal should be the same.
2006 Mazdaspeed 6
Amnesiac (11-26-2012), rob ms6gt (11-29-2012)
 Old 11-26-2012, 09:19 PM   #3
Amnesiac's Avatar
I've been staring at parts diagrams all night and the best thing I can come up with is
A61027397. I should have it in hand by the weekend, if it's the right part I'll let you
know so you can add it to the list.
Thanks for the help!
06Speed6 (11-27-2012), rob ms6gt (11-29-2012)
 Old 11-26-2012, 10:46 PM   #4
Eth Fiend
phate's Avatar
Posts: 6,931   (View Stats)
I concur with that part# - A610-27-397 - it's the only one between the pto and trans from the PTO diagram, and the trans diagram doesn't show it.
-06 MS6
-Corn fed 07 MS3 - Sold
06Speed6 (11-27-2012), Amnesiac (04-04-2015), rob ms6gt (11-29-2012)
 Old 04-03-2015, 05:38 PM   #5
iamintown's Avatar
Posts: 8   (View Stats)
iamintown is an unknown quantity at this point
Default how much it cost to replace this seal any idea
how much does it cost to replace the seal on MS6, my ms6 leaking after replacing clutch.
iamintown is offline   Reply With Quote
 Old 04-04-2015, 02:37 AM   #6
Amnesiac's Avatar
If it's the same problem that was mentioned in this thread onlinemazdaparts.com has it listed at $23.21, and your dealer should have it for $29.75.
I never came back to this thread but this did fix the leak I had.
The Following User Says Thank You to Amnesiac For This Useful Post:
rob ms6gt (04-09-2015)
 Old 03-12-2018, 03:09 PM   #7
Sleepin6's Avatar
Posts: 98   (View Stats)
Sleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to behold
Did the gear oil leak inside your transmission bell housing and ruin your clutch?
MS6 GT...REBUILD IN PROGRESS
BOLTED AND BOOST PROVIDED BY...
SPEED1/CORKSPORT...
Sleepin6 is offline   Reply With Quote
 Old 03-12-2018, 03:52 PM   #8
Amnesiac's Avatar
Nope, leaked onto the ground if I recall. Definitely didn't ruin the clutch, that worked until I sold the car ~5 months ago.
Sleepin6 likes this.
 Old 07-08-2018, 06:01 PM   #9
Sleepin6's Avatar
It was a small crack in the bell housing that caused the leak. Right where the little black dot is on that raised up area. I bought a used trans to fix it.
File Type: jpeg D8EB3FEE-5E0A-4A7F-B20B-DF4D7E44A266.jpeg (1.36 MB, 5 views)
SPEED1/CORKSPORT...
Oil Leak jhample MazdaSpeed 3 - Engine, Transmission & Driveline 12 10-25-2012 03:53 PM
Oil leak... Matx MazdaSpeed 6 - Engine, Transmission & Driveline 11 08-17-2011 10:50 AM
OIL LEAK!!! bozzben MazdaSpeed 6 - Engine, Transmission & Driveline 16 04-25-2011 06:02 AM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 01:06 PM
Page generated in 0.34135 seconds with 25 queries
