Notices
Like Tree15Likes
 Old 09-27-2012, 08:22 AM   #81
Captain
djuosnteisn's Avatar
Posts: 11,189   (View Stats)
Groans: 79
Originally Posted by Speed_j23 View Post
If you can get it on a lift and have it rolling, check the transfer case...
I did put it in the air and let it roll in first gear. Noise seemed to fit with the driveshaft more so than the wheels. I used an automotive stethoscope to listen to the trans housing, and pto, but it was pretty much inconclusive to which was making the noise.
I suppose it could be the PTO on the pass side, since that's the side where the mount broke. But it's odd that the noise is coming from the driver's side. I'll pop both axles out soon and give em a once over.
Originally Posted by 06Speed6 View Post
Disconnect the driveshaft at the tcase to eliminate that as a source of noise
Good idea man. Thanks.
500awhp 440awtq uncorrected
BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning.
Mounts be popping, and trans be hurting
Check out the hair Salon:
www.permtuning.com
Last edited by djuosnteisn; 09-27-2012 at 08:22 AM. Reason: MSF Database - Automerged Doublepost
jracer (09-27-2012)
 Old 09-27-2012, 09:09 AM   #82
mczimer's Avatar
Posts: 1,135   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
djuosnteisn I ran into the same issue with my AWR rmm. I propped the jack against an edge at a 45 degree angle, and put a 2x4 in place to push the engine forward as I cranked the jack... lets just say the 2x4 didn't stay in place....
CLEANED YOUR VALVES?
mczimer is online now   Reply With Quote
The Following User Says Thank You to mczimer For This Useful Post:
djuosnteisn (09-27-2012)
 Old 09-27-2012, 09:13 AM   #83
Captain
Groans: 79
Do you still have the AWR rear mount installed? Do you think it could be contributing to the noise i'm hearing?
www.permtuning.com
 Old 09-27-2012, 09:19 AM   #84
mczimer's Avatar
I did actually start hearing an odd noise after the install, but it turned out to be my wheel bearings. From what you were saying, your noise is coming from the area I encountered noise as well. If possible, try a listening with a stethoscope; put it to the various suspension components to find the noise. Wheel bearings sound a variety of ways, it could be a culprit...
The Following 2 Users Say Thank You to mczimer For This Useful Post:
djuosnteisn (09-27-2012), Speed_j23 (09-27-2012)
 Old 09-27-2012, 09:53 AM   #85
Captain
Groans: 79
I did stethoscope, mainly focusing on the trans and t-case, but i did poke around a few things on the hub, and didn't hear any glaring issues. Also spun the wheel by hand and checked for play. None.
I'll dig into the beast tonight and find out exactly wtf is going on. At least i hope i will, lol.
www.permtuning.com
 Old 09-27-2012, 10:16 AM   #86
Posts: 10,144   (View Stats)
Groans: 98
seeing as how you really needed to ratchet the motor forward to get the bolts to line up, i would disconnect the RMM completely and drive around and see what happens. The side mounts and TTFMM are more then enough.
I drove like this for about a month one time because i kept hearing this clicking noise and it diddent happen when i disconnected my RMM so i just left it off. when i eventually put it back on the noise was gone =D
KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust
510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs
WWW.SONICTUNING.COM
Certified RichTune e-Tuner
KILLAH BUILT by SPEED PERF6RMANC3
I could cry right now im so proud of you.
djuosnteisn (09-27-2012), mczimer (09-27-2012), Tokay444 (09-27-2012)
 Old 09-27-2012, 10:22 AM   #87
mczimer's Avatar
I agree; the AWR mount is apparently under redesign. I spoke to Tony the other day and they have changed part of the mount assembly. Depending on how Dustin had the car up, if only the front was lifted it makes aligning mounts a real pain.
From Tony:
"We are just going to ship the top section to you, which is the revised part. All you need to do is unbolt it from the head and the mount base and install the new part."
I will update once I install it
 Old 09-27-2012, 10:33 AM   #88
Captain
Groans: 79
From Tony:
I have the updated pass mount (which is what tony is talking about there afaik). I haven't heard anything about a redesigned rear motor mount, just the pass.
www.permtuning.com
 Old 09-27-2012, 10:37 AM   #89
mczimer's Avatar
What tony and I have discussed is the RMM. Not sure what exactly the change may be, but I'll post a pic once I get it
 Old 09-27-2012, 12:09 PM   #90
Captain
Groans: 79
That makes no sense at all, lol. The rear mount is a single piece, no "top section". The pass mount has a top section, and has recently been re-designed.
Either you or tony is confused. Or i'm on a different planet entirely (feels that way more often than not).
I just tried removing the rear motor mount and took a trip around the block during lunch. No dice. Noise still there. The only changed mount now is the PMM. I really don't think it's a mount issue.
www.permtuning.com
 Old 09-27-2012, 12:50 PM   #91
mczimer's Avatar
I agree; I have no clue what Tony is talking about, but I will find out soon enough hehe.
 Old 09-27-2012, 08:26 PM   #92
Captain
Groans: 79
Trans is le fooked. Maybe not raw dog butt fooked, but at least titty fooked.
Drained fluid, stuck a magnet like half inch into the drain hole, and pulled out metal stew:
I really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really really do not want to pull the trans again.
So i'm not. I'm just gonna flush it with some shit dick walmart fluid a couple times, then give it hell. If it's coming out, it needs to give me a better reason than this. This will probably be my fluid schedule:
shit fluid, drive 1 mile, drain
shit fluid, drive 50 miles, drain
shit fluid, drive 100 miles, drain
shit fluid, drive 300 miles, drain
good fluid, drive several thousand, and back to powa, drain
good fuild, and hope it holds.
or something to those regards.
Also, this is far from the "torque limits of the transmission" imho. This is all due to a failed motor mount. So if anything, i've simply reached the "torque limits of the shitty PMM".
www.permtuning.com
The Following 14 Users Say Thank You to djuosnteisn For This Useful Post:
06Speed6 (09-28-2012), BlueStreak (09-27-2012), BrianB6 (09-28-2012), cld12pk2go (09-28-2012), Crarrs (09-28-2012), Dano (10-05-2012), Don06speed6 (09-27-2012), EdgeAutosport.com (09-28-2012), jracer (09-28-2012), MPSdriver (09-29-2012), NJSPEED3 (09-28-2012), psychophyr (10-02-2012), silvapain (09-27-2012), Tokay444 (09-28-2012)
 Old 09-27-2012, 08:35 PM   #93
Don06speed6's Avatar
Posts: 1,844   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 58
That sucks, maybe source a euro trans for the future?
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
The Following User Says Thank You to Don06speed6 For This Useful Post:
 Old 09-27-2012, 08:36 PM   #94
Posts: 9,612   (View Stats)
Bummer dude. I do love the line: "you can hear something chewing" ... like a hamster?
So does it still pop out of gear. Since what you're pulling out is magnetic, you might have partially stripped a gear when the mount let go since it saw a good amount of shock.
 Old 09-27-2012, 08:53 PM   #95
Captain
Groans: 79
I have a spare trans, just needs a seal. If this one assplodes, it'll probably receive either gen pu or possibly euro gears.
The euro gears are TALL, and this car will probably always rock a big turbo... so i have to be careful not to completely neuter the off boost torque. Short gears are nice for dd when your turbo doesn't spool til 4300 rpm in 3rd gear.
Lol @ me mentioning dd.... sigh.
After the socket removal, it seems to hold in gear a bit better. I do think i was able to get it to pop out of 3rd by pushing back on it a lil bit. Wasn't "easy"... but wasn't "normal" either.
I bet i gave a few teeth a hair cut when it popped out of gear at 450+ ftlbs and high rpms, hahaha.
But honestly, it goes into each gear great, and comes out just as easy. So i think i'll just rock it. I'm gonna put all my stupid vibrator mounts back on tomorrow night, and fill up with the first dose of walmart shit oil (cough syrup for a sick trans).
www.permtuning.com
The Following 6 Users Say Thank You to djuosnteisn For This Useful Post:
06Speed6 (09-28-2012), Don06speed6 (09-27-2012), Easter Bunny (10-02-2012), EdgeAutosport.com (09-28-2012), MPSdriver (09-29-2012), silvapain (09-27-2012)
 Old 09-27-2012, 09:08 PM   #96
greg08's Avatar
Posts: 408   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
Groaned at 19 Times in 12 Posts
noo..
hmm, try the flushes but it may not work. Those could just be metal flakes from the filler/drain plug.. idk.
Last edited by greg08; 09-27-2012 at 09:08 PM. Reason: MSF Database - Automerged Doublepost
greg08 is offline   Reply With Quote
The Following User Says Thank You to greg08 For This Useful Post:
djuosnteisn (09-28-2012)
 Old 09-28-2012, 08:41 AM   #97
mczimer's Avatar
Why and how would a fill or drain plug produce metal shavings such as that?
The Following 4 Users Say Thank You to mczimer For This Useful Post:
06Speed6 (09-28-2012), burn813 (09-28-2012), djuosnteisn (09-28-2012), theurgy (09-28-2012)
 Old 09-28-2012, 01:40 PM   #98
Speeeeeed
06Speed6's Avatar
Posts: 5,754   (View Stats)
Long straight flakes are probably gear teeth
2006 Mazdaspeed 6
P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant
The Following 4 Users Say Thank You to 06Speed6 For This Useful Post:
bcmurphy87 (09-28-2012), djuosnteisn (09-28-2012), NJSPEED3 (09-28-2012), Tokay444 (09-28-2012)
 Old 09-28-2012, 01:46 PM   #99
Captain
Groans: 79
One day, when the trans has completely shit the bed, i'll open it up and take a look. Til then, i'm gonna give it hell.
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
BigjohnB20 (09-28-2012), MPSdriver (09-29-2012), ms3blackmica (09-28-2012), Tokay444 (09-28-2012)
 Old 09-28-2012, 01:52 PM   #100
can't take out voltron
ms3blackmica's Avatar
Posts: 3,857   (View Stats)
i am a fan of the way you think lolz
"if it dont fit, force it...if it breaks, it probably had to be replaced anyway!"
2009 MS3 GT: Stock HID's and an NJSPEED3 Mani
"NJ Nator the home of makeshitfit technology" - voltron
"I didn't build it hoping for your approval...I built it because it meets mine."
ms3blackmica is online now   Reply With Quote
The Following 2 Users Say Thank You to ms3blackmica For This Useful Post:
ASHMS3 (10-05-2012), djuosnteisn (09-28-2012)
 Old 09-28-2012, 02:01 PM   #101
bcmurphy87's Avatar
Posts: 1,294   (View Stats)
bcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the world
Group buy on Euro gears please!!!!!!!!
06 Speed 6- Built, working on a PERM tune.
In progress dyno 476/410
just bang out the tight spots.
bcmurphy87 is offline   Reply With Quote
The Following 5 Users Say Thank You to bcmurphy87 For This Useful Post:
Alpha (09-29-2012), djuosnteisn (09-28-2012), mczimer (09-28-2012), NJSPEED3 (09-28-2012), RichieRichness (10-03-2012)
 Old 09-28-2012, 02:59 PM   #102
mczimer's Avatar
Free shipping and install at Dustin's house and I'm down!
 Old 10-01-2012, 08:11 AM   #103
Captain
Groans: 79
So i did a 5 mile cycle, and 100 mile cycle with garbage oil, and then switched back to amsoil good stuff.
Not much more metal drained out with the flushing, so i think it may be as good as it gets for now. It still makes a pretty bad noise at low speeds, but it's not as loud as it was before. We'll see how it does in a few thousand miles, lol. I'll swap the oil again in a like 3k-5k miles, if nothings blown up by then.
I want to get some work done on my 3 now, so i'll just baby the 6 around for now. When the 3 is back up and running, i'll start boosting the 6.
www.permtuning.com
NJSPEED3 (10-02-2012)
 Old 10-01-2012, 08:15 AM   #104
Speeeeeed
06Speed6's Avatar
When I tore apart my spare trans friday I noticed that metal flakes had embedded thenselves in various different parts, I wonder if that is what is making the noise in yours.
2006 Mazdaspeed 6
djuosnteisn (10-01-2012)
 Old 10-01-2012, 08:18 AM   #105
Captain
Groans: 79
Won't know for sure until i tear it down completely. I kinda want to say the noise is coming from the diff, since it only happens when both front wheels are spinning the same direction. If you spin one wheel by hand, letting the opposite one spin in the opposite direction, there's no noise.
www.permtuning.com
 Old 10-02-2012, 04:09 PM   #106
Captain
Groans: 79
Just an update....
My trans still kicks me out of gear. Random gears too, 2nd, 3rd, and even 4th once or twice. I tried a 3rd gear pull yesterday, and made it like half way til i was kicked out. I can feel positive indents when shifting into gears, so what exactly could be kicking me out? AFAIK, the sprung balls that fit into the shaft indents are the only thing that "holds" the trans in a gear, and they feel like they're engaging fine. I wonder if they could just be gummed up with metal possibly.
Are they easy to pull out while the trans is on the car? isn't there just a plug you un bolt, and then use a magnet to pull the spring and ball out? Do i have to drain the fluid before doing so?
Car still drives fine, easy in / out with ever gear, just randomly spit out of gears.
www.permtuning.com
 Old 10-02-2012, 04:32 PM   #107
Groans: 98
does it pop out on accel or decel? cruise?
mine only comes out of 2nd on decel between 2000 and 1500 rpms
WWW.SONICTUNING.COM
djuosnteisn (10-02-2012)
 Old 10-02-2012, 04:51 PM   #108
Just an update....
Maybe you "clearanced" a bearing or race and you're getting flex in one of the shafts.
 Old 10-02-2012, 07:25 PM   #109
Captain
Groans: 79
Accel typically. Haven't had it pop out on decel yet. It'll almost certainly pop out if i go wot.
Man, that would have to be a hell of a clearance increase, lol. If i can't go wot on this trans, then it's kinda worthless... and the priority of pulling it will be significantly bumped up.
I'm gonna start prepping the other transmission for the swap.
www.permtuning.com
ms3blackmica (10-02-2012), Speed_j23 (10-02-2012)
 Old 10-03-2012, 11:04 AM   #110
PapaSmurf's Avatar
Posts: 6,304   (View Stats)
Groans: 89
Groaned at 56 Times in 30 Posts
Just hold it into the tranny like a boss when WOT
Let me know when u need a hand swapping and my unicorn hands will come wrench.
Sent from my flying tapadildo
Twinscroll GT3582R
PERM Tuned/Built Genpu Dragon
565whp/543wtq corrected at 5500ft asl
476whp/458wtq uncorrected at 5500ft asl
PapaSmurf is online now   Reply With Quote
The Following User Says Thank You to PapaSmurf For This Useful Post:
djuosnteisn (10-03-2012)
 Old 10-03-2012, 11:19 AM   #111
The "ski man" himself
aaron_-01's Avatar
Posts: 111   (View Stats)
aaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond reputeaaron_-01 has a reputation beyond repute
Splash gaurd above your wheels rubbin? I know you're not stupid but I had that happen to me.
Edit* excuse my ignorance to the situation at hand
aaron_-01 is offline   Reply With Quote
The Following User Says Thank You to aaron_-01 For This Useful Post:
 Old 10-03-2012, 11:29 AM   #112
At this point it's just speculative but the end result still sucks
 Old 10-05-2012, 08:29 AM   #113
Captain
Groans: 79
Welp.... that didn't take long:
I lost pretty much every gear on way home yesterday. Took that vid thinking it was kinda funny, and about 30 seconds afterwards, it became very unfunny. Had to literally hold the shifter into first gear, and limp the car home. First gear was the only one that i could really somewhat keep the gears engaged.
Trans comes out tonight / tomorrow. Spare trans gets cleaned up and seal replaced tonight and installed tomorrow.
www.permtuning.com
The Following 15 Users Say Thank You to djuosnteisn For This Useful Post:
86azms3 (10-09-2012), ASHMS3 (10-05-2012), BlueStreak (10-05-2012), burn813 (10-05-2012), Easter Bunny (10-05-2012), EdgeAutosport.com (10-05-2012), helmetface (10-11-2012), Lex (10-05-2012), Monotonous ONE (10-05-2012), MS3-a(sore)ASS-rex (10-05-2012), ms3blackmica (10-05-2012), psychophyr (10-05-2012), Realgib3 (10-05-2012), SilverDemon (10-05-2012), Tokay444 (10-05-2012)
 Old 10-05-2012, 08:42 AM   #114
Stage GINGER
burn813's Avatar
Posts: 2,443   (View Stats)
Trans toast - YouTube
Hahaha you got walked by an exploder!
2008 MS3 gt
383whp 380tq on 22psi vdyno results
HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 PERM TUNED
burn813 is offline   Reply With Quote
The Following 5 Users Say Thank You to burn813 For This Useful Post:
djuosnteisn (10-05-2012), Easter Bunny (10-05-2012), jreiden1 (03-08-2013), Monotonous ONE (10-05-2012), Realgib3 (10-05-2012)
 Old 10-05-2012, 09:06 AM   #115
Hunting for teh Fastz
BlueStreak's Avatar
Posts: 1,408   (View Stats)
Being bleeding edge is expensive.
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
djuosnteisn (10-05-2012), silvapain (10-05-2012)
 Old 10-05-2012, 09:11 AM   #116
Posts: 5,620   (View Stats)
Groans: 121
Damn.
 Old 10-05-2012, 09:25 AM   #117
Casper is awesome!
 Old 10-05-2012, 09:38 AM   #118
Captain
Groans: 79
Casper is awesome!
He's annoying as hell, hahaha.
I'll crack the case open when the trans is out, and exorcise that lil bastard out. I think Pablo has a set of pu gears he may be willing to sell me, so i'll at least be able to get the bad trans back up into working order, and swap it back in down the road.
Will be awesome having a pu geared ms6
www.permtuning.com
BlueStreak (10-05-2012), silvapain (10-05-2012)
 Old 10-05-2012, 09:58 AM   #119
Its like driving an automatic but half as good lolol
sorry to hear man
but your deff prepared for this well!
 Old 10-05-2012, 10:04 AM   #120
(Toe-kay)
Tokay444's Avatar
Posts: 9,552   (View Stats)
Groans: 503
Garage nurse needs to pull double duty as gear selector holding nurse.
Demodded.
Mwho?
chimmike (10-05-2012), djuosnteisn (10-05-2012), Easter Bunny (10-08-2012)
17*9 30+ torque mazdamx3freak MazdaSpeed 3/6 - Wheels & Tires 13 08-09-2011 06:49 PM
Torque Wars: 2011 Ford Super Duty Now Tops GMC Sierra 2500 with 400 hp and 800 lb-ft of Torque Haltech Automotive News 0 08-03-2010 06:30 AM
Page generated in 0.63303 seconds with 35 queries
