 Old 04-07-2010, 12:20 AM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,519   (View Stats)
Default Hose barb cap and factory oil cooler hose dia
I need a non philly approved way to block off some factory hose barbs that go to the coolant system. Anyone have some ideas?
I also need the factory hose diameter on the input and output of the oil cooler, I assume they are the same diameter and I assume they are the same diameter as the input of the thermostat, but I want to make sure.
2006 Mazdaspeed 6
 Old 04-07-2010, 12:38 AM   #2
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
don't use a zip tie.
don't put a bolt in and clamp it.
don't substitute a battery for the bolt.
how about a rubber stopper?
or vacuum line caps?
no clue on the id, but if you're talking about the big shit, my guess would be 5/8.
if it's smaller, then 3/8.
The Following User Says Thank You to phillyb For This Useful Post:
06Speed6 (04-07-2010)
 Old 04-07-2010, 12:45 AM   #3
Speeeeeed
06Speed6's Avatar
Thanks Philly =)
2006 Mazdaspeed 6
 Old 04-07-2010, 12:49 AM   #4
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
I've been trying to find some of those rubber caps that were supplied with PTP's IM gasket for the TB coolant bypass, but I can't find them anywhere around town.
 Old 04-07-2010, 12:57 AM   #5
phillyb's Avatar
Groans: 1,940
YearOne Online Shopping
http://tinyurl.com/yk26my3
Moroso 41090 Moroso Vacuum Cap Assortment
:suckit:
madvillain (04-08-2010)
 Old 04-07-2010, 07:32 AM   #6
Speeeeeed
06Speed6's Avatar
Man im afraid that might crack and dump coolant all over the place, I was hoping for maybe a heavy duty version of that.
2006 Mazdaspeed 6
 Old 04-07-2010, 08:28 AM   #7
phillyb's Avatar
Groans: 1,940
i just gave you three links too.
google vacuum cap or something like that.
they come with different sized walls and what not.
shit, you can probably find some really good ones on McMaster-Carr
 Old 04-07-2010, 10:25 AM   #8
masskaos's Avatar
Posts: 262   (View Stats)
masskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond reputemasskaos has a reputation beyond repute
instead of capping the coolant line going to the oil cooler, could you buy a male to male hose barb that is the right diameter and connect the hoses together??? Safe, but not clean looking.
masskaos is offline   Reply With Quote
 Old 04-07-2010, 11:19 AM   #9
Speeeeeed
06Speed6's Avatar
If the coolant hose going into the oil cooler is 5/8" then I dont have to cap anything, I can just cut the oil cooler circuit out completely and go from the coolant pipe that comes from the trans area, straight to the barb on the thermostat, instead of going through the oil cooler as it does now.
2006 Mazdaspeed 6
wht size hose for occ? bombdotcom MazdaSpeed 3/6 - Turbo Induction 3 01-29-2009 09:20 PM
IC hose size??? ATE BALLER Mazdaspeed3/6 General Discussion 2 08-08-2008 06:36 AM
HI! MS3 recirc. hose Jasnall Mazdaspeed3/6 General Discussion 9 06-09-2008 08:46 PM
Page generated in 0.28959 seconds with 23 queries
