Like Tree115Likes
 Old 02-10-2012, 12:17 AM   #1
paveltol's Avatar
Posts: 520   (View Stats)
paveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the worldpaveltol is the leader of the world
Groaned at 23 Times in 2 Posts
Neutral  +4 score
Exclamation Injector seals solution. Version A
Hello everyone!
So here is a new tip for all those who face the problem of blown OEM injector seals and don't want to spend hundreds of dollars on OEM or some reinforced seals, there's a solution: The Toyota diesel injector seals. These seals come for every diesel Toyota engine and are proven to be of good quality.
These seals have been tested for more than a year on a number of modified Mazda 2.3 DISI Turbo engines, with different power level (from stock to 400hp) running on awful Russian fuel. None of the seals failed so far. Installation does not require any machining or trimming. They fit perfectly.
Now, the price. It is USD 7.8 per kit. USD 1.9 each.
P/N: 11177-64010
Enjoy.
UPDATE: See the pic attached. There is a comparison of OEM Mazda seals (left) and Toyota diesel seals (right). Mazda seals have rubber-like coating, Toyota seals do look like they are made of brass alloy. Surely they do not look as beefy as CP-E seals, but they are proven to be working on a number of modified cars. Two of them are 370hp and 405hp.
Different alloys have different properties and as you know diesel engines have extreme pressure spikes in the cam. Still it would actually be useful to find out the limit of these seals' tolerance on Mazda DISI engines.
Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc..
paveltol is offline   Reply With Quote
The Following 152 Users Say Thank You to paveltol For This Useful Post:
06Speed6 (02-10-2012), 2k4_8 (03-31-2012), 3dpilot (06-11-2012), 671 grains of reason (02-10-2012), ABSpeed3 (03-12-2012), AJ713 (03-07-2012), ak_spray (02-10-2012), Alpha (02-10-2012), altaprecision (04-17-2015), ant_wailes (03-31-2012), ArcticSpeed3 (02-20-2012), ARES28 (04-09-2012), atvfreek (06-11-2013), aviator79 (02-24-2012), Bemtje (06-29-2012), BigjohnB20 (02-10-2012), BlueStreak (02-10-2012), BobbleHead (03-18-2012), Boosted Beluga (04-13-2012), breakfasteatre (02-11-2012), breakfstincluded (02-10-2012), Broxer (02-22-2012), Cataphract_40 (02-13-2012), charlesfist (02-10-2012), Code Monkey (02-06-2014), codykemmet (01-21-2013), Dano (02-11-2012), dantes5823 (11-11-2012), darkmx-6 (11-06-2017), davychronic (07-07-2015), daztdMS6 (02-27-2012), deadlandxtreme (02-10-2012), djuosnteisn (02-21-2012), Dmurray06 (07-01-2012), doubleflusher (02-21-2012), dougefresh_ (03-05-2012), Easter Bunny (02-22-2012), EdgeAutosport.com (03-06-2012), Eighty8 (04-22-2012), England15j (08-13-2013), Enki (03-01-2012), ESB Jiu JItsu (08-16-2012), f-castrillo (04-06-2012), Fatpig78 (05-27-2014), fishin53 (02-21-2012), forcedinduktion (03-20-2012), forgedzoomzoom (02-11-2012), franz (03-12-2012), fywdyl (02-10-2012), Geo13 (03-07-2012), H3R3TIC (02-10-2012), He Hate Me (12-03-2013), helmetface (07-17-2012), himurax13 (04-21-2012), i8urgti (02-20-2012), Ingle (02-10-2012), IshiKage (02-10-2012), J-Liss (02-29-2012), JayBeeL (05-11-2014), JMEngineer (02-26-2012), jmhinkle (10-29-2012), joey (02-21-2013), josurr (04-21-2012), jracer (02-10-2012), Juyoung (01-27-2013), J_Logik (07-06-2012), keridil (04-14-2013), kmac (02-24-2012), kobberr (03-08-2013), ktms3 (06-15-2012), kunfu (05-28-2012), l4nc3r (04-30-2013), Lex (02-11-2012), LiEast (05-18-2012), Manny3 (04-21-2012), mason (05-19-2012), mg446 (11-07-2013), mh3kgt (05-17-2012), Mizzle (03-07-2012), Monotonous ONE (12-05-2012), MrPrime (06-15-2013), ms3blackmica (07-07-2012), Ms3_Miami (06-14-2012), MS6FL (02-10-2012), MZR165 (02-11-2012), Nataphen (02-20-2012), nighthawk358 (04-13-2012), Nitr0EngiE (02-20-2012), NJSPEED3 (02-21-2012), Nliiitend1 (02-10-2012), NoRegrets (08-23-2012), Pendarus (02-10-2012), phate (02-11-2012), Pointless (07-04-2012), PoMan (03-07-2012), psychophyr (02-10-2012), pzr2874 (03-02-2012), Qwik6 (08-02-2013), QwkEVO (03-22-2012), R4LLY3 (09-04-2013), Rainmens (10-17-2012), RayRay (05-29-2012), redboat (02-11-2013), rfinkle2 (02-10-2012), Rich990 (12-12-2014), rigor (02-25-2012), rob ms6gt (02-11-2012), Rokusek (06-11-2013), Sacrilicious (02-10-2012), Sasuke-kun (02-13-2019), Sid3wayS (02-10-2012), skiptowncat (06-30-2012), SKiZ0TT (02-10-2012), SLOWHATCH (02-11-2012), Snappy (09-18-2015), Snotrocket (03-26-2012), Snyeed (03-20-2014), SofaKingAwesome (02-20-2012), speed23 (02-10-2012), Speed_j23 (04-01-2012), Spoofmastafly (02-10-2012), starscream (03-01-2012), StayBroke (05-30-2012), svd (07-28-2015), tbot (02-10-2012), tddvrrn (11-11-2012), TexasSpeed3 (02-13-2012), thatsmrgimp2u (03-05-2012), The Nut (05-27-2014), thehead (02-20-2012), themytb (02-10-2012), thewheelman (03-07-2012), TiGraySpeed6 (03-07-2012), Toddy22587 (03-09-2012), Tokay444 (02-10-2012), Tomas (03-02-2012), torquemaniac (07-14-2015), Tres3 (08-31-2014), triplejumper18 (02-20-2012), uncorked11 (02-10-2012), Vansquish (03-07-2012), vote4chaos (03-09-2018), WAHBAM (03-07-2012), Willofalltrades (06-08-2012), wolly6973 (02-10-2012), xb2ms3 (03-16-2012), xfeejayx (02-13-2012), xhymer (04-05-2012), xI Leveler Ix (01-21-2013), xxdjfate76xx (03-07-2012), Ziggo (02-11-2012)
 Old 02-10-2012, 12:33 AM   #2
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
your avatar makes me wanna buy the hitman collection on steam
The Following 2 Users Say Thank You to breakfstincluded For This Useful Post:
Fail_6 (03-26-2014), Juyoung (05-05-2013)
 Old 02-10-2012, 12:39 AM   #3
Adog35's Avatar
Posts: 309   (View Stats)
Adog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the worldAdog35 is the leader of the world
Cool man looks like a good solution.
What are the symptoms going to be when the seals are starting to go bad?
2010 MS3
5% REAR 30% FRONT
DDM 5K HID
RMM
CS TIP/SRI
Dizzy Tuned
Autotech Internals
Swift Springs
JBR Rear Sway
Stoptech 309's
First Turbo Car and I love it!
Adog35 is offline   Reply With Quote
 Old 02-10-2012, 04:31 AM   #4
paveltol's Avatar
They either are OK, or get blown. If they are blown, you'll notice the knocking/chattering sound and jerking under boost.
arcowlin likes this.
 Old 02-10-2012, 04:56 AM   #5
psychophyr's Avatar
Posts: 770   (View Stats)
psychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the worldpsychophyr is the leader of the world
wow 8 bucks is wellllll under 190. great find lol
Eighty8 and himurax13 like this.
2006 Mazdaspeed6 GT BCM
SpeedPerf6rmanc3 10.6:1 Pistons, PI Fuel Kit, PnP Head, 75mm TB, Pinned Cams/Keyed Crank, 11mm H11 Head Studs \\ PT&E PT6266 CEA BB S-Comp. \\ Manley H+ Rods \\ JMF V2 PI Intake Mani w/ Bosch 1000cc Injectors
Squash Performance Top Hat w/ Dual DW300 Pumps \\ AEM FPR \\ Split Second AIC1 \\ CP-e LRT Ex. Mani, SAFEseals, RDM, EGRD \\ SURE TMM, PMM, Juggernaut, Anchors \\ TiAL MVR, Q \\ Bosch 4 Bar MAP
HTP 4" Intake \\ Autotech HPFP Internals \\ ATP Catless DP \\ ACT HD 6-Puck w/ Streetlite FW \\ Cobb AP \\ Treadstone TR10 \\ Magnaflow CBE \\ MSD Dashhawk \\ JBR SSP, BSD, RMM
Stratified EBCS \\ Corksport SS Braided Clutch Line \\ H&R Coilovers \\ SPC BJs \\ Rotora Drilled/Slotted Rotors \\ H2 Ceramic Pads \\ Enkei EKM3 7.5+45 \\ VG Sharkfin \\ RHO-Plate
Most powerful MS6 720/584 @42psi E42 9Oct13 Tuned by NISHAN
psychophyr is offline   Reply With Quote
The Following 4 Users Say Thank You to psychophyr For This Useful Post:
Broxer (02-22-2012), Fail_6 (03-26-2014), i8urgti (02-20-2012), Juyoung (05-05-2013)
 Old 02-10-2012, 05:05 AM   #6
671 grains of reason's Avatar
Posts: 350   (View Stats)
671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world
im gonna order these next week. its cheap enough to gamble. thanks i love oem style fixes.
2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS
formerly pursuit_special
671 grains of reason is offline   Reply With Quote
The Following User Says Thank You to 671 grains of reason For This Useful Post:
 Old 02-10-2012, 05:12 AM   #7
SleeperHatch's Avatar
Posts: 3,138   (View Stats)
SleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the worldSleeperHatch is the leader of the world
Groans: 52
Groaned at 54 Times in 39 Posts
Link to others using them and no fail?
Sent from my Epic Win Avatar
2009 CWP Speed3
SleeperHatch is offline   Reply With Quote
The Following 3 Users Say Thank You to SleeperHatch For This Useful Post:
ak_spray (02-10-2012), Fobio (02-10-2012), Mizzle (03-07-2012)
 Old 02-10-2012, 05:15 AM   #8
i noticed their is a washer associated do we need that as well.
 Old 02-10-2012, 06:00 AM   #9
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
So if this is used in Toyota Diesels will it be available at dealers here in the US?
Edit: Looked online looks like they are available now what all do we need? I
ll order this today so we can get a good look at it before anyone goes and does it.
07 MS3 Sport
CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP
SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon)
JBR: RSB
Cobb: Accessport
Corksport: TMIC
CNT: Catted Downpipe
ak_spray is offline   Reply With Quote
 Old 02-10-2012, 06:24 AM   #10
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
I am selling kits of these seals for 100.
Good deal bro.
Pm for details.
Monotonous ONE is offline   Reply With Quote
The Following 12 Users Say Thank You to Monotonous ONE For This Useful Post:
ak_spray (02-10-2012), Ckmazdaspeed3 (02-13-2012), Easter Bunny (02-22-2012), f-castrillo (04-06-2012), Juyoung (05-05-2013), karl-hungus (02-29-2012), MS3-a(sore)ASS-rex (02-10-2012), Nataphen (02-20-2012), psychophyr (02-10-2012), rfinkle2 (02-10-2012), TexasSpeed3 (02-13-2012), xfeejayx (02-13-2012)
 Old 02-10-2012, 07:08 AM   #11
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Nice cost effective soloution
just a cursory google search for the part number finds them as low as US1.04 ea
340hp / 371tq
 Old 02-10-2012, 07:26 AM   #12
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
Incredible find if it actually works! I would like to see links to other people running them as well.
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
 Old 02-10-2012, 07:41 AM   #13
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
Haha! CP-E's gettin DICKED on this one! Nice find man!
that1rowdyracer likes this.
The Following 24 Users Say Thank You to Alpha For This Useful Post:
06Speed6 (02-10-2012), Angr-E1 (02-20-2012), BobbleHead (03-18-2012), breakfstincluded (02-10-2012), Broxer (02-22-2012), Ckmazdaspeed3 (02-13-2012), daztdMS6 (02-10-2012), Don06speed6 (02-10-2012), Easter Bunny (02-22-2012), Flaverre (04-29-2012), ganque (02-10-2012), impossible (05-22-2016), Mizzle (03-07-2012), Pendarus (02-10-2012), psychophyr (02-10-2012), SKiZ0TT (02-10-2012), Speed_j23 (04-01-2012), TexasSpeed3 (02-13-2012), that1rowdyracer (03-27-2012), thehead (02-20-2012), uncorked11 (05-17-2012), wolly6973 (02-10-2012), xfeejayx (02-13-2012), xhymer (04-05-2012)
 Old 02-10-2012, 07:47 AM   #14
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
fucking awesome I await stateside results.
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
 Old 02-10-2012, 07:50 AM   #15
daztdMS6's Avatar
Posts: 214   (View Stats)
daztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond reputedaztdMS6 has a reputation beyond repute
$1.04 each!!!! Fuck yeah!! Great find Paveltol
MazdaSpeed 6
DashHawk, CorkSport TIP & SRI, CorkSport TMIC, SU RMM, CPE rear diff mount, Perrin EBCS, TurboSmart BPV, TWM Stage 2 STS + metal bushings, Denso ITV-22, SM OCC, JBR EGR deletion & TIG, silicone boost tubes, Bilstein HD shocks, LED light bulbs, TRS clear projectors, 35W DDM Tuning HID foglights, Hawks HPS brake pads, Amsoil in the rear diff, pto & trans, factory navi, XCarLink USB.
daztdMS6 is offline   Reply With Quote
 Old 02-10-2012, 08:09 AM   #16
ak_spray's Avatar
I've got these ordered from my local Toyota Dealer. He said 3-4 days so maybe middle of next week or earlier. At that price if they don't work I'm not out much and we can all see them. I'll post pictures up when I get them. He said they came off of an 84 Corolla diesel.
07 MS3 Sport
JBR: RSB
Cobb: Accessport
Corksport: TMIC
The Following 15 Users Say Thank You to ak_spray For This Useful Post:
06Speed6 (02-10-2012), 671 grains of reason (02-10-2012), BigjohnB20 (02-10-2012), charlesfist (02-20-2012), daztdMS6 (02-10-2012), Easter Bunny (02-22-2012), Fobio (02-10-2012), Mizzle (03-07-2012), Nataphen (02-20-2012), rfinkle2 (02-10-2012), SKiZ0TT (02-10-2012), TexasSpeed3 (02-13-2012), wolly6973 (02-10-2012), xfeejayx (02-13-2012)
 Old 02-10-2012, 08:16 AM   #17
Model
Production Date
Engine
Transmission
Trim
Body
Door
Camry 1983.08-1986.07 4cyl 1.8L MTM DLX SED 4D
Camry 1983.08-1986.07 4cyl 1.8L ATM DLX SED 4D
Camry 1983.08-1986.07 4cyl 2.0L ATM DLX SED 4D
Corolla 1983.08-1985.08 4cyl 1.8L MTM STD SED
Corolla 1983.08-1985.08 4cyl 1.8L MTM DX LB
Corolla 1983.08-1985.08 4cyl 1.8L ATM DX SED
I see Lexus referenced quite a bit too
340hp / 371tq
The Following 4 Users Say Thank You to TiGraySpeed6 For This Useful Post:
ak_spray (02-10-2012), Easter Bunny (02-22-2012), rfinkle2 (02-10-2012)
 Old 02-10-2012, 08:53 AM   #18
ak_spray's Avatar
From the illustration I'm looking at it looks just like a rubber o-ring. There is a seat that fits on the injector but I'm not sure if that would fit our application or not.
In my eyes the major difference from the stock and the CPe seals are the brass looking sleeves that they include in the kit.
I suggested back in the Injector Seal thread that VW 2.0T injector seals might work too. From the pictures I've seen of the CPe seals and the VW seals I have in hand they look the same.
07 MS3 Sport
JBR: RSB
Cobb: Accessport
Corksport: TMIC
 Old 02-10-2012, 08:55 AM   #19
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Nice find man
2006 Mazdaspeed 6
 Old 02-10-2012, 09:07 AM   #20
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
Excellent! Thanks for sharing!
Sent from my Galaxy Nexus using Tapatalk
 Old 02-10-2012, 09:08 AM   #21
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
WASHER 2.5M NOZZ SEAT x 10 | Darwen Diesels Ltd | Common Rail Diesel Spare Parts
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 02-10-2012, 09:09 AM   #22
708
Erich's Avatar
Posts: 4,274   (View Stats)
So this is a washer style solution?
Erich is offline   Reply With Quote
 Old 02-10-2012, 11:41 AM   #23
ak_spray's Avatar
According to the Toyota illustration that I have it just looks like a rubber o-ring but it may be wrong. I had the dealer fax me a copy of it so I could look at it before I received them.
07 MS3 Sport
JBR: RSB
Cobb: Accessport
Corksport: TMIC
 Old 02-10-2012, 11:49 AM   #24
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Subbed
2015 Mazda 6
 Old 02-10-2012, 11:58 AM   #25
1fastspeed's Avatar
Posts: 38   (View Stats)
1fastspeed is a splendid one to behold1fastspeed is a splendid one to behold1fastspeed is a splendid one to behold1fastspeed is a splendid one to behold1fastspeed is a splendid one to behold1fastspeed is a splendid one to behold1fastspeed is a splendid one to behold1fastspeed is a splendid one to behold
Hmm, interesting. I do see a short lifespan on these seals if they are made of rubber/teflon. VW and Audi use a very similar seal but the injector has a step inside of it for it to seal to seat on.
1fastspeed is offline   Reply With Quote
 Old 02-10-2012, 11:58 AM   #26
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Group buy anyone?
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
The Following User Says Thank You to ganque For This Useful Post:
 Old 02-10-2012, 12:01 PM   #27
Jake5713's Avatar
Posts: 1,775   (View Stats)
this is seriously amazing if it works!!
Jake5713 is offline   Reply With Quote
 Old 02-10-2012, 01:11 PM   #28
Etipp98's Avatar
Posts: 1,947   (View Stats)
They look brass to me
Etipp98 is offline   Reply With Quote
 Old 02-10-2012, 02:24 PM   #29
ak_spray's Avatar
I looks like it has a "Seat" that might be brass so do you think they would pair two brass seals/o-rings together? Not sarcasm that's a real question.
07 MS3 Sport
JBR: RSB
Cobb: Accessport
Corksport: TMIC
 Old 02-10-2012, 03:31 PM   #30
kngeducate's Avatar
Posts: 190   (View Stats)
kngeducate is the leader of the worldkngeducate is the leader of the worldkngeducate is the leader of the worldkngeducate is the leader of the worldkngeducate is the leader of the worldkngeducate is the leader of the worldkngeducate is the leader of the worldkngeducate is the leader of the worldkngeducate is the leader of the worldkngeducate is the leader of the worldkngeducate is the leader of the world
subbed
Huh?
kngeducate is offline   Reply With Quote
 Old 02-11-2012, 09:58 AM   #31
robertof's Avatar
Posts: 405   (View Stats)
robertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the worldrobertof is the leader of the world
subbed
robertof is offline   Reply With Quote
 Old 02-11-2012, 11:27 AM   #32
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Yea this is interesting.
2012 WRX HB w/mudflaps yo!
 Old 02-11-2012, 11:32 AM   #33
SJP0tato's Avatar
Posts: 322   (View Stats)
SJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the world
I'm curious to see the outcome of this as well.
SJP0tato is offline   Reply With Quote
 Old 02-11-2012, 11:47 AM   #34
BGofMD's Avatar
Posts: 312   (View Stats)
BGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond reputeBGofMD has a reputation beyond repute
Groaned at 40 Times in 12 Posts
subbed
BGofMD is offline   Reply With Quote
 Old 02-11-2012, 11:58 AM   #35
Jarods7920's Avatar
Posts: 1,415   (View Stats)
interesting
2008 MazdaSpeed 3 AWD big turbo...blah blah blah
Jarods7920 is offline   Reply With Quote
The Following User Says Thank You to Jarods7920 For This Useful Post:
richt2831 (04-16-2017)
 Old 02-11-2012, 12:11 PM   #36
Eth Fiend
phate's Avatar
Posts: 6,943   (View Stats)
Awesome sauce. I love being cheap.
-06 MS6
-Corn fed 07 MS3 - Sold
BobbleHead (03-18-2012), cld12pk2go (02-11-2012), GLORIFIEDBOZO (02-21-2012), Speed_j23 (04-01-2012), TexasSpeed3 (02-13-2012)
 Old 02-11-2012, 12:12 PM   #37
MS6FL's Avatar
Posts: 1,753   (View Stats)
MS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the worldMS6FL is the leader of the world
Groans: 43
subbed
“From a business standpoint, the Boss 302 shouldn’t have happened. But it happened. My dream for the car was that it would make a lot of money for a guy street racing. It should be a car that winds up on YouTube doing something illegal. I’ve been waiting 20-plus years to launch a car like this.”-Jim Farley
MS6FL is offline   Reply With Quote
 Old 02-11-2012, 12:16 PM   #38
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Awesome sauce. I love being inexpensive.
Fixed.
The Following 7 Users Say Thank You to Enki For This Useful Post:
cld12pk2go (02-11-2012), djuosnteisn (02-12-2012), Fail_6 (03-26-2014), impossible (05-22-2016), IshiKage (02-11-2012), TexasSpeed3 (02-13-2012), TiGraySpeed6 (02-11-2012)
 Old 02-11-2012, 12:22 PM   #39
Posts: 9,484   (View Stats)
badassness!
 Old 02-11-2012, 01:59 PM   #40
Matx's Avatar
Posts: 1,681   (View Stats)
Fuck and I just bought the cpe seals like 2weeks ago.....
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f106/injector-seals-solution-version-104815/
AP stage question - Page 4 - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 04-13-2014 01:21 PM
2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums - View Single Post - AP stage question This thread Refback 03-14-2014 09:30 PM
<![CDATA[OzMPSclub - Australia's fastest growing Mazda MPS forum]]> This thread Refback 02-20-2014 03:36 PM
Injector seals, my woes, and apparently Toyota to the rescue? This thread Pingback 02-20-2014 06:32 AM
Thoughts on the Toyota Injector Seals This thread Refback 02-02-2014 02:27 AM
Injecteur Mazdaspeed 3 2007 et mécanicien - Mazda 3 Quebec This thread Refback 05-22-2013 10:22 AM
? View topic - wanted injector seals This thread Refback 01-23-2013 01:23 PM
Mazda MPS Owners Club &bull; View topic - Thoughts on the Toyota Injector Seals This thread Refback 06-13-2012 03:02 PM
AP stage question - Page 4 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 04-29-2012 07:12 AM
Cheap Injector Solution? This thread Refback 03-26-2012 03:58 PM
CPE Safe Seal - Replacing Injectors - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-26-2012 08:55 AM
VersaTune &bull; View topic - Knock issue This thread Refback 02-15-2012 02:39 AM
Possible Injector Seal Alternative? This thread Refback 02-10-2012 09:59 AM
Injector seals solution. paveltol 2010 MS3 - Fuel, Nitrous & Water Injection 404 11-22-2016 02:39 AM
Injector seals solution. Version B paveltol MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 463 11-12-2016 08:30 AM
Injector seals solution. paveltol 2010 MS3 - Engine, Transmission & Driveline 397 07-25-2014 07:34 PM
Injector seals solution - Gen 2 paveltol MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline 397 09-19-2012 01:50 PM
Injector seals solution. paveltol MSF KB - Mazdaspeed 3/6 - Fuel 401 09-19-2012 12:49 PM
Page generated in 0.60450 seconds with 53 queries
