-   MazdaSpeed 6 - Engine, Transmission & Driveline (http://www.mazdaspeedforums.org/forum/f106/)
-   -   Knock Knock! (http://www.mazdaspeedforums.org/forum/f106/knock-knock-65824/)
theschrum 11-28-2010 09:55 AM
Knock Knock!
Last month I installed my AEM meth kit (running alky). I tried to use the test button but it would not go in. The kit has been working properly until today.
I used my Thanksgiving break to install my GT2871. The install went smooth and I was able to take the car out for a run last night.
http://i316.photobucket.com/albums/m...m/IMG_1191.jpg
http://i316.photobucket.com/albums/m...m/IMG_1194.jpg
http://i316.photobucket.com/albums/m...m/IMG_1183.jpg
Boost was staying at 18psi and I would see no more than a 18.9psi spike. AFRs were not lean, and actually pretty close to where I want them to be.
Today I was supposed to drive my wife to Hagerstown and on the way I stopped to check my fluid levels (5 miles after I left). Coolant was a little low so I added more then drove another 10 miles.
I stopped to check it again while I left my car running and the coolant level was still good. I got back into my car to continue our travel. I start to accel (no more than 1300 rpm) and the car stalls. I try to crank the car and I hear a KNOCK KNOCK KNOCK. Then my alky injection level light pops on.
I open the hood and hear my alky pump running so I pull one my power source from its QD. I am now able to smell the alky and it was forming a puddle on the ground dripping from one of my couplers.
I will be pulling off the oil pan today to get a look at my rods. I think that I may have a bent rod or 2. I know for a fact I wasn't in boost at 1300 rpm. My theory is that that the meth controller switched on the pump (probably from the test button) and when I started to accel the alky when into the combustion chamber and caused it to hydrolock. Or it may have just caused it to stall and the hydrolock was caused when I tried to restart it. Not too sure.
Has anyone heard of a similar case?
SIXual Panda 11-28-2010 10:00 AM
in for info on meth and im interested.... hope everything works out.
Amazon 11-28-2010 10:15 AM
Retard
Retard who?
speed23 11-28-2010 10:37 AM
Sorry dude, that sucks.
AEM meth controllers are shit, and I could easily see that little test button getting stuck. I went through 2 failed AEM controllers before moving onto a snow controller, which as been working great.
theschrum 11-28-2010 11:01 AM
Yeah. I like the size since it fit perfectly in my fusebox. I never had a problem w/ my coolingmist controller, but it was huge.
theschrum 11-29-2010 11:43 AM
Pulled off the oil pan. To my suprize there were no bent rods. I needed to check since it could've caused more damage if I didn't before further testing. Going to put it back together and see if the knock is still there with all of the alky out of the system. Any ideas?
Page generated in 0.17782 seconds with 11 queries
