 Old 12-23-2011, 06:41 AM   #1
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
Default Leaking clutch line
So I recently swapped out my stock clutch line for the corksport ss one. The piece is high quality, except the one I got seems to have a leak. I noticed my fluid level was down while changing my oil the other day and then noticed some of the ate super blue on the clutch line.
Needless to say Corksport has been great and got a new one sent out to me which will be here today.
Here is a pic of where the leak is coming from, you can see the blue brake fluid around where the hose meets the flange.
jracer (12-23-2011)
 Old 12-23-2011, 07:46 AM   #2
671 grains of reason's Avatar
Posts: 350   (View Stats)
671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world671 grains of reason is the leader of the world
good service on corksport's part.
2006 MAZDASPEED6 // SURE R6 // SURE AEROS & TIH // COBB AP // JBR TIG // SURE ANCHORS & SHORTCUT // SURE DREADNAUGHT // WHITELINE RSB // RACING BEAT E.L. // ULTRA GAUGE // AMSOIL FLUIDS
formerly pursuit_special
671 grains of reason is offline   Reply With Quote
 Old 12-23-2011, 09:04 AM   #3
Jake5713's Avatar
Posts: 1,775   (View Stats)
Corksport customer service FTMFW
-Jake
Jake5713 is offline   Reply With Quote
 Old 12-23-2011, 10:09 PM   #4
bova's Avatar
Groans: 45
Got the new one today and replaced it. All is good so far.
SS Clutch Line MattJackson86 MazdaSpeed 3 - Engine, Transmission & Driveline 9 08-07-2015 09:36 PM
SS Clutch line lifeownedme MazdaSpeed 6 - Engine, Transmission & Driveline 4 07-15-2011 04:23 AM
Emergency Clutch line FYI RWDAddict MazdaSpeed 6 - Engine, Transmission & Driveline 2 07-14-2011 12:11 PM
Bleeding clutch line bova MazdaSpeed 6 - Engine, Transmission & Driveline 1 03-20-2011 10:31 AM
KO4 TURBO ON MS6 LEAKING OIL RETURN LINE GAMISTAD Mazdaspeed3/6 General Discussion 9 01-27-2011 01:06 AM
Page generated in 0.26455 seconds with 23 queries
