Like Tree2Likes
  • 2 Post By bross2009
 Old 10-07-2011, 10:20 PM   #1
BigjohnB20's Avatar
Posts: 779   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
Default Leaking Rear diff axle seal
So I was doing an oil change tonight and decided to finally get around to putting the Amsoil I got in my rear diff. Well I get back there and shit looks like it is leaking bad around where the axel meets the case. I have some pictures on my phone from like a month or two ago when I first noticed it. I will post them up later if anyone is interested. I was going to do something about it then but didn't. :phillyb:
Anyway it looked quite a bit worse tonight. Residue all over the driver side diff case, sway bar and surrounding area. I went ahead and drained what was in there, and at least quite a bit came out. Wasn''t like I was running dry or anything. I noticed a decent amount of oily metal dust sludge on the drain plug. The oil smelled a little burnt but was actually pretty clear in color. I filled back up with 1.1 qts of amsoil serever gear so at least I am probably good for now.
So what am I looking at here. Can you just replace the seal or will I need a whole new diff? I really have no idea with this. What am I looking at for repair if its just the seal $$ wise? Any thoughts are welcome. Thanks,
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
 Old 10-12-2011, 05:42 PM   #2
BigjohnB20's Avatar
Just thought I would bump this with some pictures. I just stuck my arm under there and snapped these with the celly so they aren't that great but you get the idea. I really would like someone to chime in with thoughts on this. I did end up calling the stealershiop and dude told me that to replace the driver side rear diff seal would be like $480 labor and then like $30 for the seal itself. I have no idea wether that is outrageous or just high. Based on the fact its a Mazda dealership I am guessing pretty high.
2006 BCM MS6 GT
CS SRI/TIP
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
 Old 10-28-2011, 05:28 PM   #3
RAR
RAR's Avatar
Posts: 20   (View Stats)
RAR has much to be proud ofRAR has much to be proud ofRAR has much to be proud ofRAR has much to be proud ofRAR has much to be proud ofRAR has much to be proud ofRAR has much to be proud ofRAR has much to be proud of
It's not a hard job, the part was cheap (I think I snagged two when mine went just 'cause), you have to take the majority of the suspension off the side it's leaking, pull the knuckle off and pop the axle out of the diff, replace the seal then pop it back in and reassemble. The popping back in is hard in a driveway but completely doable. Took maybe 2 hours and 5 beers to get it done.
Find the service manual and it'll show you how to do the job.
Andrew
White 2006 MazdaSpeed6
BNR Stage 1 / H&R / Bilstein HD / SPC CC / SURE Juggernaut, Dreadnaught, ShortCut, SS AGS & CounterShift / AWR RMM / Corksport RSB
RAR is offline   Reply With Quote
The Following 2 Users Say Thank You to RAR For This Useful Post:
BigjohnB20 (10-31-2011), derek13p (01-28-2014)
 Old 10-28-2011, 05:34 PM   #4
RAR
RAR's Avatar
Actually, I had the PDF laying around, I've uploaded it here: http://eiknet.com/diff_removal.pdf
Andrew
The Following User Says Thank You to RAR For This Useful Post:
 Old 10-28-2011, 05:36 PM   #5
Lost hawaiian's Avatar
Posts: 226   (View Stats)
Lost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the worldLost hawaiian is the leader of the world
I had the same problem with my MS6. I changed it and when i was in there I changed the C clip too. the tech at my dealership said the C clips do wear out on MS6's. plus it is only 4-6 bucks for the clip. Buy lots of beer and Have fun...
Lost hawaiian is offline   Reply With Quote
The Following 2 Users Say Thank You to Lost hawaiian For This Useful Post:
BigjohnB20 (10-31-2011), SJP0tato (11-07-2011)
 Old 03-24-2012, 06:01 PM   #6
Mistersix's Avatar
Posts: 2,585   (View Stats)
Just discovered this issue with my car today. I thank these RAR for his research. Though i don't think he/she is apart of this forum anymore.
 Old 03-24-2012, 06:42 PM   #7
memin's Avatar
Posts: 990   (View Stats)
That is really good info , i got check mine as soon i get home!!!
 Old 03-25-2012, 06:09 AM   #8
Mistersix's Avatar
I definitely would if i were you. This car is starting to drive me crazy. Every time i get underneath it i find something wrong. If your car is getting up there in miles it may be time to do more frequent inspections.
 Old 03-25-2012, 09:34 AM   #9
memin's Avatar
yep!! i just hit 60,000 problem free miles ftw. how many miles do you have on yours?
 Old 03-25-2012, 10:06 AM   #10
Mistersix's Avatar
72k i had no problems till after 60k. The PTO started weeping just after the warranty expired. And now this, not to mention a bunch of other dumb shit that keeps cropping up. P0401 codes, exhaust leaks, visor never stays put, etc. She's just showing age now a days.
The Following User Says Thank You to Mistersix For This Useful Post:
 Old 11-14-2016, 12:42 PM   #11
rpetrenko's Avatar
Posts: 10   (View Stats)
rpetrenko has a little shameless behaviour in the past
what are the part numbers for the seal and clip?
thanks
rpetrenko is offline   Reply With Quote
The Following User Says NO Thank You to rpetrenko For This Un-useful Post:
SSinstaller (11-14-2016)
 Old 11-14-2016, 06:45 PM   #12
SSinstaller's Avatar
Posts: 3,826   (View Stats)
Groans: 48
thanks
Are you just spamming to get your post count up? The last post is four fucking years old.
Soon to be installed:
ST manifold w/ port injection : Raduim Engineering PCV Plate : Radium Engineering PCV valve : Radium Engineering Fuel filter : Aeromotive FPR : DCR VVT : TI Automotive F90000262 Fuel Pump : NX 15718 : Split Second AIC
 Old 11-14-2016, 08:36 PM   #13
rpetrenko's Avatar
no! this is my second day on the forum!!!!
why everybody here is so sarcastic and impatient????
obviously, i don't have your experience and don't know how many *dump* questions have been asked before by newbies, BUT!!!! i used to be a teacher, and i know the power of being patient. It all pays off, believe me!
no, i don't care about thread count! just looking for answers.
P.S. i'm a real person, and very grateful to everyone who posted nice tutorials here. Unfortunately, the complete solution is scattered around in different threads, that's a bit frustrating. We probably should create mazdaspeed WIKI from all the knowledge of these posts (just an idea).
 Old 11-15-2016, 09:58 AM   #14
Thor Hammer's Avatar
Posts: 1,396   (View Stats)
Groans: 127
Mazda MazdaSpeed6 Genuine Parts | Jim Ellis Mazda Parts
You're welcome. Now be gone with thine spoon and delve deep into the wonderful abyss of the interweb young recruit....
Waiting for Install: BNR S3/HTP 3.5 Intake/Damond OCC/ CS Injector Seals/ WMI/MAPerformance Rev3 Intake Manifold
 Old 07-01-2017, 06:16 PM   #15
bross2009's Avatar
Posts: 50   (View Stats)
bross2009 is just really nicebross2009 is just really nicebross2009 is just really nicebross2009 is just really nice
Groaned at 4 Times in 2 Posts
Default Rear axle seal replacement
I been doing research about replacing the rear axle seals on a speed 6
So I'll give a step by step guide that I used to get mine done
Tools needed 17mm deep socket
17mm box wrench a few pry bars to remove axle out
Also a 12mm socket and ratchet to remove the wheel speed sensor cable off the bracket ( not in the hub
You do not need to remove the 32mm axle
Step one jack car off the ground
Step two take the wheel off
Step three remove the brake caliper bracket with caliper still on it
Step four remove rotor
Step five there is a 12mm nut that holds the wheel speed sensor on a little bracket
On the lower control arm remove this will give you enough slack with out damaging the sensor
Step six remove the 17mm bolt and nut on the upper control arm
Step seven remove the 17mm lower control arm bolt
Step eight remove the 17mm bolt on the toe adjuster on the inner portion (that's the one I removed but you can use either one
Step nine now go underneath and pry the driveshaft out of the differential (just enough that it is popped out
Step ten go back to the hub and pull it towards you (you will need a pry bar to help separate the control arms from the knuckle
Step eleven go back underneath and finish prying the axle out of the differential
Now you will have enough room to move it up words next to the differential to access the seal
Step twelve take a flat head screw driver put electric tape around it so it won't damage the housing when prying the old seal off
Step thirteen install new seal slightly hammer it in once it is seated by hand
Step fourteen install axle back into differential and put back together in reverse order
rpetrenko and ChristopherB like this.
bross2009 is offline   Reply With Quote
The Following 2 Users Say Thank You to bross2009 For This Useful Post:
rpetrenko (08-30-2017), speed23 (07-01-2017)
Rear diff locks while turning after SURE diff mount and brace install wettoast MazdaSpeed 6 - Engine, Transmission & Driveline 46 04-23-2018 10:10 AM
axle seal Sal's_MS6 MazdaSpeed 6 - Engine, Transmission & Driveline 9 08-17-2015 09:11 AM
rear diff "stiff diff" brace vs. rear diff front mount giordanos4 MazdaSpeed 6 - Engine, Transmission & Driveline 18 03-03-2011 07:38 AM
Leaking turbo seal after catted DP install (surprise, surprise) -cj- MazdaSpeed 3/6 - Troubleshoot/Diagnostics 9 02-16-2010 10:03 PM
Page generated in 0.35630 seconds with 29 queries
