Like Tree59Likes
 Old 01-15-2013, 10:44 AM   #1
Default Lets Talk About Head Studs
so recently we have seen a few people lifting heads and ive been debating the fact of going back to the ARP2000 studs i have now and switching to the L19 but they are retartedly expensive at ~$500.
@SPEED6 KILLAH; found some h11 studs from a1 for ~$380 which carry the same strength and are alot cheaper. Does anyone any any experience with these?
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
Fail_6 (02-12-2013), jracer (01-16-2013), Realgib3 (01-25-2013), Tomas (02-07-2013), TWOptSL0W (01-25-2013)
 Old 01-15-2013, 10:57 AM   #2
dantes5823's Avatar
Posts: 6,576   (View Stats)
Just got off the phone with arp. I asked them what they think about 25-28 psi setups. He said they are bound to fail at some point and will likely stretch. That boost is a lot for a 10 mm stud. I asked what he thought would be a good amount of boost to run these. 15 is what he came up with.
The Following 10 Users Say Thank You to dantes5823 For This Useful Post:
06Speed6 (01-15-2013), atvfreek (01-15-2013), Downmented (01-15-2013), Easter Bunny (01-15-2013), Fail_6 (02-12-2013), jmhinkle (01-20-2013), jracer (01-16-2013), superskaterxes (01-15-2013), Tomas (02-07-2013), TWOptSL0W (01-15-2013)
 Old 01-15-2013, 11:00 AM   #3
Eth Fiend
phate's Avatar
Posts: 6,943   (View Stats)
ARP laughed at the idea of using anything more than the ARP2000 material for upwards of 6-700hp in a 4 cylinder when I called them. They thought unless it was a nitrous engine, they would be fine.
My machinist thinks some of the folks that pushed water didn't have the surfaces machined properly. They have to be dead flat and significantly smoother than a standard finish. Not something every shop can do.
@Tomas; was going to do some bolt and stud testing. The theory is that ARP's tightening instructions (specific torque value) are not accurate or proper, and may not be producing the same clamping force as our TTY bolts. [Sounds familiar, right?]
My machinist/engine builder, who builds everything from blown alky engines making 2500hp, all the way down to single cylinder diesels was saying some guys actually go down in size on head studs. They do it because they need the port work to extend further than the casting will allow, and 3/8 stud works just fine for their endurance engines.
Lots of anecdotal evidence, but those are the issues I see. Hopefully Tomas will be able to knock that stuff out sooner, rather than later. We'll have definitive evidence at that point.
Did anyone who "lifted a head" measure the studs after it happened? I'd be curious to see if they weren't stretched (not torqued enough) or if they were stretched beyond ARP limits. The latter would indicate either too much torque, or the head actually may have lifted. Knowing torque procedure would give some great insight.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 10 Users Say Thank You to phate For This Useful Post:
06Speed6 (01-15-2013), 802MS3 (01-15-2013), BrianB6 (02-07-2013), Easter Bunny (01-15-2013), Fail_6 (02-12-2013), jmhinkle (01-20-2013), jracer (01-16-2013), silvapain (01-20-2013), Tokay444 (01-15-2013), Tomas (02-07-2013)
 Old 01-15-2013, 11:00 AM   #4
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
BobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the worldBobtailedSnail is the leader of the world
Hmm I thought we had a thread somewhere where gear heads were discussing drilling and retapping for larger studs.
2006 Mazdaspeed 6 GT-unDISI swap in progress
1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5
Skreets be calling...
BobtailedSnail is offline   Reply With Quote
The Following User Says Thank You to BobtailedSnail For This Useful Post:
 Old 01-15-2013, 11:02 AM   #5
Eth Fiend
phate's Avatar
I loathe ARP for this reason alone. They are so damn inconsistent in what they tell people.
-06 MS6
06Speed6 (01-15-2013), socks (02-26-2013), Speed_j23 (02-10-2013), Tomas (02-07-2013)
 Old 01-15-2013, 11:10 AM   #6
dantes5823's Avatar
High hp cars are on 7/16 head studs. You know what we use? @SPEED6 KILLAH;
The Following 4 Users Say Thank You to dantes5823 For This Useful Post:
06Speed6 (01-15-2013), jmhinkle (01-20-2013), lito37 (05-25-2014), SPEED6 KILLAH (01-15-2013)
 Old 01-15-2013, 11:16 AM   #7
I know on DSM tuners there is a thread where they discuss using 1/2 inch studs as well IIRC.
 Old 01-15-2013, 11:16 AM   #8
Eth Fiend
phate's Avatar
Yep. I made the decision to stick with stock size rather than chase down a bigger stud and machine everything. If she pushes water, I'll reconsider that decision
-06 MS6
helmetface (01-15-2013)
 Old 01-15-2013, 11:24 AM   #9
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
I WANT BETTER STUDS FOR PEACE OF MIND. I do not want to have to do this shit again.
@Captain KR;
700HP CLUB
11.479@124mph
#DIX
The Following 3 Users Say Thank You to Downmented For This Useful Post:
BobtailedSnail (01-15-2013), dantes5823 (01-15-2013), impossible (12-16-2013)
 Old 01-15-2013, 11:31 AM   #10
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Has anyone who's lifted the head done so on the oem studs with oem torquing procedure?
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 11 Users Say Thank You to Tokay444 For This Useful Post:
06Speed6 (01-15-2013), atvfreek (01-15-2013), breakfasteatre (02-06-2013), Easter Bunny (01-15-2013), jracer (01-16-2013), lito37 (05-25-2014), phate (01-15-2013), silvapain (01-20-2013), sleepyspeed6 (01-24-2013), Tomas (02-07-2013), trf5000 (01-15-2013)
 Old 01-15-2013, 11:35 AM   #11
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I followed OEM torque procedure on regular ARPs with the larger washers/nuts as provided by Pablo. the washers/nuts are ARP, and the biggest that can fit without machining.
26psi.
07 MS3
The original Genpoo Hater
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
Fail_6 (02-12-2013), phate (01-15-2013), Tomas (02-07-2013)
 Old 01-15-2013, 12:00 PM   #12
Posts: 12,651   (View Stats)
I know @Tomas; is a fan of the OEM studs and their shoulder size.
06Speed6 (01-15-2013), atvfreek (01-15-2013), phate (01-15-2013), Tomas (02-07-2013)
 Old 01-15-2013, 12:02 PM   #13
FWIW i needed an impact gun to get the OEM ones out when i was taking apart my motor lol
Easter Bunny (01-15-2013), phate (01-15-2013), Tomas (02-07-2013)
 Old 01-15-2013, 12:08 PM   #14
Eth Fiend
phate's Avatar
I know Tomas is a fan of the OEM studs and their shoulder size.
Yeah, I think we came to the conclusion that the larger nuts don't really aid in load distribution through the head. I used the Cosworth branded head studs, which I believe are rebranded ARP2000's, and they used the same diameter nut/washer as the bolts.
Yeah, those things are tight as hell. My 4' breaker bar was necessary to crack them loose. I don't remember: does the engine build manual call for any lube on the threads when they're tightened down?
-06 MS6
Tomas (02-07-2013)
 Old 01-15-2013, 12:12 PM   #15
Tokay444's Avatar
Groans: 793
26psi.
I wouldn't have advised you follow the oem tty procedure without knowing the ARP studs are the same material/yield strength as oem.
Demodded.
The Seals
06Speed6 (01-15-2013), superskaterxes (01-15-2013), Tomas (02-07-2013)
 Old 01-15-2013, 12:30 PM   #16
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
I think that some engines call for some engine oil on the threads, but I'm not sure about the DISI specifically.
2006 Mazdaspeed6
 Old 01-15-2013, 12:35 PM   #17
a quick skim doesent say either way
06Speed6 (01-15-2013), phate (01-15-2013)
 Old 01-15-2013, 12:49 PM   #18
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
I have extensively looked into this head stud concern for a little over 9 months now & after evaluating the situation & exhausting a few leads, i beleive that a possible solution is now a reality. Pending a few small details, i will be posting the solution very soon.
SPEED6 KILLAH is offline   Reply With Quote
The Following 17 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
06Speed6 (01-15-2013), 802MS3 (01-15-2013), Boosted Beluga (01-15-2013), BrianB6 (02-07-2013), dantes5823 (01-15-2013), Easter Bunny (01-15-2013), Fail_6 (02-12-2013), Jh8909 (01-20-2013), jmhinkle (01-20-2013), jracer (01-16-2013), LittleredMPS (01-25-2013), ms3blackmica (02-26-2013), NJSPEED3 (02-08-2013), rob ms6gt (09-07-2013), superskaterxes (01-16-2013), TWOptSL0W (01-15-2013), Vansquish (02-07-2013)
 Old 01-15-2013, 02:43 PM   #19
Tokay444's Avatar
Groans: 793
Does it involve torquing with an impact gun?
Because mine is not up to the task.
Demodded.
The Seals
Downmented (01-15-2013), phate (01-15-2013), silvapain (01-20-2013)
 Old 01-15-2013, 09:21 PM   #20
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
That was me, I wanted to time-cert my block and run 1/2" studs but thats a $1000 project.
I personally think custom age 625s would be fine and iirc they are cheaper than L19s
2006 Mazdaspeed 6
The Following 3 Users Say Thank You to 06Speed6 For This Useful Post:
jmhinkle (01-20-2013), phate (01-15-2013), Tomas (02-07-2013)
 Old 01-16-2013, 06:25 AM   #21
Downmented's Avatar
Groans: 493
If im not mistaken, the only difference between the custom age 625s and the H11 the corrosion resistance of the 625s. But then the L19s are the same as the H11s but ARP renamed them and now calls them L19s.
So pay a shit ton for L19s and waste your money when you could have purchased the H11s,
OR,
As he said, stick with the 625s and be better than both of them
625>H11>L19
700HP CLUB
11.479@124mph
#DIX
The Following 2 Users Say Thank You to Downmented For This Useful Post:
06Speed6 (01-16-2013), BigRedSpecial (01-16-2013)
 Old 01-20-2013, 01:30 AM   #22
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
jmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the world
Groans: 162
Late to the party, but I need these asap. Sign me up, tell me who to pay and if I need to wear gloves when installing or not.
Might as well throw in the discussion of what PTP's were made of. I've heard rumors they were possibly L19's or H11's as well as having the larger nuts, but no concrete evidence. He had a recent price drop and as much as I hate the guy, if they are either said material it is a source for them right now.
jmhinkle is offline   Reply With Quote
 Old 01-22-2013, 04:19 AM   #23
i need them as bad as you!!!!!!
a bunch of sets are being made right now AFAIK but im not sure what the lead time is on them.
06Speed6 (01-23-2013), jmhinkle (01-22-2013)
 Old 01-24-2013, 07:47 PM   #24
Is anyone else interested in these H11 studs?
 Old 01-24-2013, 08:40 PM   #25
I have PTP head studs on my engine. I have no proof, but they didn't look like anything more than regular ARP2000's with larger nuts. Unfortunately they didn't come with any instructions or documentation at all though.
Easter Bunny (01-25-2013), jmhinkle (01-24-2013)
 Old 01-24-2013, 08:47 PM   #26
Axle Breaker
jmhinkle's Avatar
Groans: 162
I believe that is all they were. They were too cheap for H11's.
The Following 2 Users Say Thank You to jmhinkle For This Useful Post:
silvapain (01-24-2013), superskaterxes (01-25-2013)
 Old 01-24-2013, 08:51 PM   #27
... And too expensive for 2000's.
jmhinkle likes this.
06Speed6 (01-26-2013), Easter Bunny (01-25-2013), superskaterxes (01-25-2013)
 Old 01-24-2013, 08:58 PM   #28
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
I will say this in every thread it gets brought up, till I'm blue in the face so nobody else gets fucked by PTP.
PTP "CUSTOM HEADSTUD KITS" ARE ARP2000's.
If you get ripped off and buy them, at leeeaast please tq them to ARP2000 specs and NOT the 90lbs faggot ass John calls for.
Ask me how I know...
The Following 8 Users Say Thank You to Realgib3 For This Useful Post:
06Speed6 (01-26-2013), 802MS3 (02-06-2013), Easter Bunny (01-25-2013), Etipp98 (01-24-2013), jmhinkle (01-24-2013), Mizzle (02-08-2013), NJSPEED3 (02-08-2013), phate (01-24-2013)
 Old 01-24-2013, 09:03 PM   #29
Realgib3's Avatar
Groans: 52
Really can't wait to hear more on this since its the only thing that's got me slightly worried about keepin the head on over 500whp.
The Following User Says Thank You to Realgib3 For This Useful Post:
 Old 02-06-2013, 02:24 PM   #30
Out of curiosity, what are the specs on the OEM fasteners? Have we seen failures with these?
Also was the root cause of the failure identified? Did the ARPs stretch? Was it the shoulder size on the nut? Improper torque?
If the root cause is not identified then throwing a stronger stud on there is not necessarily addressing the problem.
The Following 9 Users Say Thank You to Lex For This Useful Post:
802MS3 (02-06-2013), atvfreek (02-08-2013), BigRedSpecial (02-07-2013), Easter Bunny (02-06-2013), Fail_6 (01-19-2014), phate (02-06-2013), sidekick (02-06-2013), silvapain (02-06-2013), Tomas (02-07-2013)
 Old 02-06-2013, 02:31 PM   #31
sidekick's Avatar
Groans: 47
@SPEED6 KILLAH; is sending some out to have them tested, I believe. So we should know more about the strength and material on the OEM headbolts soon.
2006 Mazdaspeed6
The Following User Says Thank You to sidekick For This Useful Post:
 Old 02-06-2013, 05:28 PM   #32
Tokay444's Avatar
Groans: 793
I also asked if anyone has ever lifted the head off the oem studs.
No one answered.
Demodded.
The Seals
The Following 5 Users Say Thank You to Tokay444 For This Useful Post:
802MS3 (02-06-2013), atvfreek (02-08-2013), BigRedSpecial (02-07-2013), breakfasteatre (02-06-2013), sidekick (02-06-2013)
 Old 02-06-2013, 05:29 PM   #33
no one but @cld12pk2go; is running tons of whp on the stock studs but thats just 1 case.
unless you measured the ARP's beforehand you cant tell if they stretched because their quality control is garbage.
the root cause is ARP2000 are not rated for the kind of cyl pressure we are requesting from them. Call them up and ask and they will tell you.
 Old 02-06-2013, 07:14 PM   #34
You can't call a root cause without any data to back it up. You work in the engineering field correct? - you should know this. You can call it a hypothesis, but not a root cause.
How many people have lifted heads with built motors and ARP studs? Is everyone with a built motor using ARP studs? Did you guys try and measure the studs new to see variance in size? What about after they were pulled?
There are a good number of cars in the 400wtq and whp level on OEM fasteners.
The Following 11 Users Say Thank You to Lex For This Useful Post:
802MS3 (02-06-2013), atvfreek (02-08-2013), BigRedSpecial (02-07-2013), Easter Bunny (02-06-2013), jracer (02-07-2013), Koke382 (10-07-2013), ms3blackmica (02-26-2013), phate (02-06-2013), rkwill (05-11-2015), silvapain (02-06-2013), Tokay444 (02-07-2013)
 Old 02-07-2013, 05:42 AM   #35
so far i know of at least 3 off the top of my head (myself, will, drew) who all were making between 450 and 510whp when it happened.
i only know maby 1 or 2 people with the L19 ARP's and the rest are all ARP2000's because no other studs exist on the market. The ARP2000's are also designed for the I4 Mazda3/6 and not even specifically for the mazdaspeed, it just so happens they share the same stud as us.
We also only have a 10mm stud which is insanely rare in the performance world. Evo, subi, SRT4, BMW, ford, all have 11mm studs stock. An 11mm stud is already 25% stronger (read higher tensile strength) then a 10mm stud with all other things equal. Thats why you never see head stud problems on those platforms because people just upgrade the material of their studs (aka to H11) and they have no problem holding tons of power.
pablo did try and measure the length of the studs afterwards, but they are considered stretched at like .0005" from their original size. There was enough variance in the length that you couldent tell if any of them had been stretched because they were so different. This is just poor quality control on the part of ARP. Now that people have recognized this failure we know to start measuring studs BEFORE they go in so we can track the problems related to head lifting failures.
if your not trying to break ~450whp the ARP2000's will be just fine. As soon as you cross that border your going to be in unknown territory. there arent enough cars over this HP level to determine the absolute breaking point but the few people who have crossed this line and who CONSISTENTLY drive their cars hard are the ones seeing failures.
you could prob go years on the ARP2000's making 500whp if you only went WOT once a month. but for those of us who are going to the track regularly, and taking WOT logs almost daily, its a whole different world when it comes to head bolt strength.
its just like the stock rods, its not if, its when........
The Following 6 Users Say Thank You to superskaterxes For This Useful Post:
atvfreek (02-08-2013), dantes5823 (02-07-2013), Fail_6 (02-12-2013), ms6mil (02-02-2015), robry (02-08-2013), sidekick (02-07-2013)
 Old 02-07-2013, 05:52 AM   #36
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
So i take it there are alot of 11mm studs out on the market.
if you are already going for that much power you are obviously having a decent amount of machine work done to the motor. Why not just machine the 10mm stuck studs to 11mm. Then you can buy studs for one of the other many platforms running 11mm studs.
Granted lengths will be different, but if you know what platform you want to buy from you could possible my the stud hole a bit deeper if there is room to do so.
Just a thought I am not as well versed as almost everyone in this thread just thought i would through that out there
Damond Built Speed 6
Deldran is offline   Reply With Quote
 Old 02-07-2013, 06:09 AM   #37
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
To measure the length accurately you could take new studs and have the ends ground on a surface grinder at a machine shop. so the ends are nice and flat so you have a nice surface to take measurements from. I am only talking grinding enough to clean up the end.. it wouldn't affect the stud in any way..strength wise
maybe grind them all the same length. measure before and after.
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
The Following 2 Users Say Thank You to jracer For This Useful Post:
superskaterxes (02-07-2013), Tokay444 (02-07-2013)
 Old 02-07-2013, 06:15 AM   #38
dantes5823's Avatar
One can probably do that now. But it's all about cost. And then you have people like me who's already up and running and dropping the block off to get machined isn't an option. Swapping head studs is much easier. Granted still have to pay for labor but it's not labor plus machining plus downtime. And the price difference of the studs isn't a whole lot more.
The Following 3 Users Say Thank You to dantes5823 For This Useful Post:
atvfreek (02-08-2013), Fail_6 (02-12-2013), superskaterxes (02-07-2013)
 Old 02-07-2013, 06:21 AM   #39
Axle Breaker
jmhinkle's Avatar
Groans: 162
So old DSM's are also on 10mm if I remember correctly. One issue they were seeing with upgrading to 11mm is that some people have pulled them out of the block at that point. It can be a possible weak point if we were to go that route. My issue with the ARP2000's is that they were designed for the original MZR and grandfathered to us. I don't think there was any form of proper torque calibration done for our motor. 60lb/ft is awfully low. I believe the stock bolt are far above that with the stock procedure.
The Following 6 Users Say Thank You to jmhinkle For This Useful Post:
atvfreek (02-08-2013), Fail_6 (02-12-2013), jracer (02-07-2013), superskaterxes (02-07-2013), Tokay444 (02-07-2013), Tomas (02-07-2013)
 Old 02-07-2013, 06:22 AM   #40
Deldran's Avatar
Groans: 118
well of course in that situation, i am really anal about trying to plan everything for the future so thats the angle i was coming from. If you already have a built motor then i agree would be alot easier just to change studs.
I agree with @Lex; though would be nice to get some data on how much the stock studs can take.
Lets talk Compressor AR superskaterxes MazdaSpeed 3/6 - Turbo Induction 16 03-30-2012 09:54 AM
Lets talk clutches Death-From-A-Mile MazdaSpeed 3 - Engine, Transmission & Driveline 4 11-03-2008 07:37 PM
Page generated in 0.63236 seconds with 36 queries
