![]() | | #1 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 17 ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score
So i am driving on the freeway and all of a sudden i notice that my "check engine light" comes on...Does anyone know if this is for service or if something is wrong?? I tested out the engine and gave it some oomph, the power band seems fine....I dont notice any knocking, im stumped..My car info is on the bottom. Please help! thanks! Mods: Mazdaspeed CAI, SU test pipe. Miles: 39,XXX Car: 2007 Mazdaspeed6 sport last oil change: 2 weeks ago... | ||||||||
![]() Join Date: Apr 2008 Location: Utah
Rep Power: 289 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 109
Im sorry us feeble mortals cannot directly read from your ECU what your check engine light is for. | ||||||||
| The Following User Says Thank You to JumpingJackson For This Useful Post: | kgb (03-26-2010) |
![]() Join Date: Jan 2009 Location: NJ
Rep Power: 188 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 750
Groaned at 34 Times in 22 Posts
go to ur local autozone or somewhere where they can read cel codes for free.
__________________ 06 MS6, Cp-e Xcel NANO, PG tip, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback... | ||||||||
![]() | | #4 | ![]() |
| Lurkers |
the CEL usually comes on when your about to blow ur motor.... IM jk
![]() | | #5 | ![]() |
| Not Ranked : 0 score | ||||||||
![]() | | #6 | ![]() |
![]() | | #7 | ![]() |
Good lord take it to the dealership
![]() | | #8 | ![]() |
| Fastest MS6 in the USA ![]() Join Date: Mar 2008 Location: DC Metro
Rep Power: 1099 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,014
Groans: 53
Groaned at 68 Times in 50 Posts
you need to clean your EGR. but by the sound of your post it doesent sound like your very tool friendly
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 GT3076R BITCHES ~ TXS BOV ~ Custom 3" MAF SRI w/ giant AEM filter ~ AP PROtune'd ~ MBC ~ Custom Side-to-Side FMIC w/Treadstone TR8 Core ~ CPE DP ~ DNP Mani w/Tial 38mm MV-S EWG VTA'd~ CPE BT TIP ~ TWM Stage 1 Short Shifter ~ CPE RMM ~ TTFMM ~ CPE RDM ~ BC CO's slammed ~ SPC BJ's ~ EBC Red's ~ Stoptech's ~ Technafit SS Lines ~ Autometer Boost & STRI EGT in Custom Built Vent Pod ~ 20% Tint ~ LED Tails ~ Denso ITV-24's ~ Xtra Shorty Antenna ~ Dashhawk ~ CPE Dual CBE ~ Custom Strut tower bar ~ Whiteline RSB ~ PnP'd IM ~ CDFP Internals ~ labonte meth kit ~ VC tapped OCC ~ 310WHP/350WTQ on a MD ~ 12.6@111 2.0 60' <- worlds fastest MS6 | ||||||||
![]() | | #9 | ![]() |
| says hi! ![]() Join Date: Jan 2009 Location: York, PA
Rep Power: 98 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
Groans: 31
Groaned at 7 Times in 6 Posts
I would just take the test pipe off and take it up to the dealer and have them fix it for you...Theres a write up around here some where..I guy just did his and took pictures. But..You're not modded heavily so just take it in
__________________ 2007 Comsic Blue MS3 GT... no mods what so ever To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #10 | ![]() |
So i called the dealer today to see if the issue was covered under warranty. It turns out that it is not..since its a 3 year/36000 mile covered. So now i am screwed....My options are basically to pay for the dealer to fix it or leave it as it is? does anyone know if this is a serious issue?
![]() | | #11 | ![]() |
| Speed6 Enthusiast ![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 508 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 465
Groaned at 28 Times in 27 Posts
someone just posted up a how to on fixing this issue, just need to clean our your egr. but it doesn't seem that you are up to it based off your knowledge so its probably best you let the dealer do it.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #12 | ![]() |
![]() Join Date: Mar 2008 Location: NC
Rep Power: 823 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 525
Don't the 07 mazdaspeeds have a 5yr 60K powertrain warranty?
__________________ My car has issues.... | ||||||||
![]() | | #13 | ![]() |
| Speeeeeed ![]() Join Date: Mar 2008 Location: Corpus Christi, Tx
Rep Power: 1151 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,649
No the 2006 is ~3yr/45,000 and the 2007 is 3yr/36,000 miles. Thats why I bought a 2006.
__________________ 2006 Mazdaspeed 6 First Ever P&P, flow benched, big valve 2.3L DISI head with inconel exhaust valves and welded EGR First Ever MZR DISI Cams - Exhaust: .348 lift with 204° @ .050" & Intake: .398 lift with 216° @ .050"; LSA = 115° First Ever crankcase breather with integrated air/oil seperator First Ever CNC AN-12 ORB block oil adapter and too much other stuff to list. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #14 | ![]() |
![]() | | #15 | ![]() |
![]() Join Date: Mar 2010 Location: TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
Groaned at 19 Times in 2 Posts
umm wrong 07 is 5yr/60k miles powertrain. however you p0401 is the code i just got. but im guessing the autozone scan tool is using generic description. on my scan tool it was evap flow and i took it in under warranty and replaced a sticking purge valve. easily something you could do youself, just double check on the mazda code number description 1st
| Thread Tools | |
| Check Engine Light is on | armarine04 | MazdaSpeed 3 - Engine, Transmission & Driveline | 9 | 09-21-2009 10:37 AM |
| Check Engine Light on '09 MS# | FXT&MS3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 05-17-2009 07:45 AM |
| Oh No Check Engine Light! | thabigo | MazdaSpeed 6 - Engine, Transmission & Driveline | 8 | 04-04-2009 12:57 PM |
| PLEASE HELP! Trouble with engine light and check oil! | spd6rcr08 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 10-01-2008 09:00 AM |
| Check engine light??? | supergoose | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 07-20-2008 06:42 AM |
