 Old 03-13-2015, 10:09 PM   #1
KingJames's Avatar
Posts: 22   (View Stats)
KingJames is just really niceKingJames is just really niceKingJames is just really niceKingJames is just really niceKingJames is just really nice
Default MS6 Cranks but won't start HELP!!!
Hey guys, I got an 06 speed6. I had a code that said crankshaft position sensor, car shut off. Clip broke so got a new clip for it, soldered the connections in, got a new sensor and the special service tool now the car won't start. It cranks but won't start. Tomorrow I'm going to work on it again check fuel and spark but it has me puzzled.
2006 Pearl White Speed 6
Panda Leather Interior
HPFP
Cobb SRI
KingJames is offline   Reply With Quote
 Old 03-16-2015, 05:15 AM   #2
shnouz's Avatar
Posts: 276   (View Stats)
shnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the worldshnouz is the leader of the world
Assuming you cleared the code and cycled the battery?
07 VRM Speed6 Sport
Cobb AP V2//HTP 3.5"//CPE Catless DP// Corksport CBE // KMD v2s//HKS VTA//Denso ITV22
H&R Springs//Koni Yellows//Corksport RSB//Megan Ladder Brace//UltraRacing Trailing Braces//Michael Rey Rear Camber Arms// CS + SURE rear diff mounts // JBR RMM/TMM/PMM//JBR SSP//JBR Shifter Weight//JBR Shifter Bushings//JBR Heavy Knob//Optima Red in the trunk//GT Leather seat swap
Tuned by boostcreeep + 9/3 E85 mix
shnouz is offline   Reply With Quote
 Old 03-16-2015, 07:26 AM   #3
KingJames's Avatar
I did clear the code, left the battery unhooked for about 20 mins, then hooked it back up and tried again but nothing happened. What did you mean?
I cleared the code, but what would the process of cycling the battery be? I unhooked the negative for about 20 minutes then hooked it back up and tried again.
HPFP
Cobb SRI
Last edited by KingJames; 03-16-2015 at 07:26 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-16-2015, 07:32 AM   #4
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
What special service tool?
Did you line up the crank position sensor correctly while at TDC?
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
 Old 03-16-2015, 07:34 AM   #5
KingJames's Avatar
Yes, in the service manual it says to use a special service tool to align the crank TDC then line up the line on the CPS with the middle of the 20th tooth.
HPFP
Cobb SRI
 Old 03-16-2015, 07:35 AM   #6
WetzMS3's Avatar
Groans: 430
Correct. Do that.
If you replaced the sensor, but did not align it properly, that likely explains your no start issue.
2013 MS3 Black Mica
 Old 03-16-2015, 07:41 AM   #7
KingJames's Avatar
I aligned it correctly, by following all the instructions and double checked, I'm just not getting spark now. I don't understand what the problem is.
Correct. Do that.
HPFP
Cobb SRI
 Old 03-16-2015, 07:45 AM   #8
WetzMS3's Avatar
Groans: 430
So, you had the TDC pin when you first replaced the sensor? I may be misunderstanding the OP.
If so, have you checked all you soldered connections and made sure they are wired properly?
I haven't ever replaced that sensor via soldering, but that would be my guess as to the issue. Unless you've change anything on the fuel or spark end of things.
2013 MS3 Black Mica
 Old 03-16-2015, 07:53 AM   #9
KingJames's Avatar
Originally it threw the code P0335 and would lose connection every now and then and shut off, then it was because the clip to the CPS would come lose, the clip(pigtail) broke so it was replaced with a new one. After that it wouldn't start. I still would get the code so I got a new CPS, when I originally took off that CPS I didn't have the alignment tool, so I ordered one, and when I got it I used it and aligned the CPS correctly. I soldered all my connections and even checked if I was getting any signal/current and if it was sending anything. It is definitely sending current so that isn't the issue. I double checked all my soldering to make sure nothing was wrong on that end. I'm just not sure what my problem is now, I'm at a loss.
HPFP
Cobb SRI
 Old 03-16-2015, 08:23 AM   #10
frothy's Avatar
Posts: 1,067   (View Stats)
Did you verify the air gap between the crankshaft and your new CKP sensor?
EDIT: Switched pics (original pic showed a crankshaft from a regular 3/6)
The Following 4 Users Say Thank You to frothy For This Useful Post:
Easter Bunny (03-19-2015), KingJames (03-16-2015), Micha (03-19-2015), WetzMS3 (03-16-2015)
 Old 03-16-2015, 08:36 AM   #11
KingJames's Avatar
This, I did not, I must have missed this part.
HPFP
Cobb SRI
 Old 03-19-2015, 11:53 AM   #12
KingJames's Avatar
Just found out there is a break in the engine harness and might possibly have to buy a whole new one.
HPFP
Cobb SRI
 Old 03-19-2015, 11:55 AM   #13
WetzMS3's Avatar
Groans: 430
Ouch.
If you go VIP here you could post a WTB thread for it. Someone may have one lying around. Those harnesses are not cheap.
Good luck man.
2013 MS3 Black Mica
 Old 03-19-2015, 11:58 AM   #14
KingJames's Avatar
I might have to do that. I have already found some online. Ebay, certified used from an 06 with 60k on it is $200 and then another site said new for around $360, and the shop wants to charge me $492 for it. I might just go ebay, it's from a used parts dealer and says its guaranteed to work. I just don't know for how long.
Ouch.
Good luck man.
HPFP
Cobb SRI
 Old 03-19-2015, 12:32 PM   #15
scubasteve711's Avatar
Posts: 1,238   (View Stats)
scubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the worldscubasteve711 is the leader of the world
break in the harness? Repair is out of the question?
07' Speed6 Velocity Red Mica
Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP
Anti break stuff: Upper Rear Diff Brace, RMM
Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod
scubasteve711 is offline   Reply With Quote
The Following User Says Thank You to scubasteve711 For This Useful Post:
mxlplx71 (03-19-2015)
 Old 03-19-2015, 03:03 PM   #16
KingJames's Avatar
The shop said they will try to fix it and if not I will have to buy a new one.
HPFP
Cobb SRI
 Old 03-23-2015, 05:38 AM   #17
shnouz's Avatar
If the ebay one is from Fatti Motorworks, it will be fine. He is local and is reputable.
07 VRM Speed6 Sport
Car cranks, won't start 15driley15 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 04-23-2014 03:51 PM
Ms6 cranks but wont start maniospeed6 Mazdaspeed3/6 General Discussion 4 03-26-2013 08:08 PM
Car cranks but doesn't start after valve clean InfamousSpeed6 Mazdaspeed3/6 General Discussion 11 11-29-2012 05:17 PM
Coda cranks up battery-car sales after California 'soft' start Haltech Automotive News 0 09-12-2012 10:40 AM
Toyota cranks up N.A. output Haltech Automotive News 0 08-12-2012 09:10 PM
Page generated in 0.36600 seconds with 24 queries
