![]() | | #201 | ![]() |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 625 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,688
Groaned at 8 Times in 5 Posts
| Not Ranked : 0 score
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
![]() | | #202 | ![]() |
![]() Join Date: Feb 2012 Location: Los Angeles, CA
Rep Power: 768 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 912
Groans: 34
Yet another stoopid question. Is the final drive from a regular manual gen one the same?
__________________ "Stockish" Black Mica 2010 MS3 Genpu
![]() | | #203 | ![]() |
| Monk Tuning ![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 872 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,032
I read all 6 pages of this thread and I have still been unable to find the answer regarding Genpus. For folks who are using a GEN2 transmission, do the gen 1 final drives swap directly in, thus effectively giving us slightly longer gearing...or is it not a simple direct swap. Thanks yall. Nice work.
__________________ 2011 Speed3-CP-E Stage 2 RMM, JBR TMM, JBR SSP, JBR SSB, 3.5" JBR WP, DDM 55w 6000k, Hoen Fog Lights, Autotech Internals, Enkei 17x8.5 RPF1, TIGs, EGR Delete, OCC, Treadstone TR8, FoMoCo Trans Fluid, Swift Springs, BSD and Baffle Kit, Ported Intake Manifold ala Driver311, CPE Injector Seals,PTP injector stud kit, RB Fabrication Ex Manifold, PTP 1950 Rail valve, ITV22s, Cordova Throttle Body, E85 blend Tuned by ME!!! Waiting to install- JTMS3 SUB BOX!!! TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #204 | ![]() |
Rep Power: 6708 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,342
You cannot mix any of the final drive parts and the shafts must be swapped as well. The gears are made in matched sets so the smaller one gear is the bigger the other must be to cover the distance between the shafts.
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
| The Following 3 Users Say Thank You to 06Speed6 For This Useful Post: |
![]() | | #205 | ![]() |
Groans: 34
| Not Ranked : 0 score So this whole thread is purely theoretical and is just an act of futility?
![]() | | #206 | ![]() |
Im guessing that you didnt actually read this thread, there is a crap ton of info in it including how to swap the gears.
![]() | | #207 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 1939 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,593
Groans: 297
Groaned at 186 Times in 102 Posts
| Not Ranked : 0 score |
![]() | | #208 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh NC
Rep Power: 813 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 831
Groans: 35
Groaned at 25 Times in 14 Posts
I understand that final drives can't be mixed, but will a full trans gear from a gen2 match to a full final drive gear set from a gen1?
__________________ 2007 Black Mica MS3 Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion | |
| The Following User Says Thank You to anavrinIV For This Useful Post: | himurax13 (01-28-2013) |
![]() | | #209 | ![]() |
Nope Edit: well maybe... if you take the gen two gears and syncros off and put them on the gen one shafts it might. Im not sure that anyone has tried that.
![]() | | #210 | ![]() |
![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 2015 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,134
| Not Ranked : 0 score nope it won't work I try it already.
__________________ ![]() |
| The Following 5 Users Say Thank You to SPEED6 KILLAH For This Useful Post: | 06Speed6 (01-29-2013), Easter Bunny (01-29-2013), pixelNate (03-05-2013), silvapain (01-29-2013), Tomas (01-31-2013) |
![]() | | #211 | ![]() |
That answers that question, so its complete gear assemblies or nothing
| Gear Ratios Table | bova | Cobb ATR Support | 10 | 12-08-2010 02:29 PM |
| longer gear ratios | michi-bazi | MazdaSpeed 6 - Engine, Transmission & Driveline | 20 | 01-14-2010 02:08 PM |
| Transmission Ratios...... | JMEngineer | MazdaSpeed 6 - Engine, Transmission & Driveline | 33 | 09-29-2009 10:35 AM |
| A/F ratios and ltft's | dread | Cobb ATR Support | 7 | 05-01-2009 04:37 PM |
| A/f Ratios selected by what gear you're in? | Laloosh | MazdaSpeed 3/6 - ECU Computer Tuning | 7 | 06-09-2008 11:42 AM |
