 Old 07-19-2011, 05:08 PM   #1
needforspeed6's Avatar
Posts: 59   (View Stats)
needforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond repute
Default MS6 Rear diff mounts
What are some signs that the rear diff mounts are broke? I am having some vibration issues when accelerating in 2nd gear. Is this a common issue with broken diff mounts? When your diff mounts broke, what problems did you experience?
07 MS6 - Cobb SRI | Cobb TIP | Corksport TMIC | SURE RMM | JBR STSP | Hypertech Tune
needforspeed6 is offline   Reply With Quote
 Old 07-19-2011, 05:12 PM   #2
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
pics?
 Old 07-19-2011, 05:15 PM   #3
I don't have any pics. I am trying to diagnose my vibration issue.
 Old 07-19-2011, 06:14 PM   #4
jroc's Avatar
Posts: 1,482   (View Stats)
jroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the world
Groaned at 6 Times in 6 Posts
youre gonna have to get dirty and look for problems yourself. check all your motor mounts, tranny mount, then go check your rear diff mounts. check the bolts with a small mirror if you have to.
JDMFresh.com 1990 Mazda Miata
NASA Time Trials/Time Attack, Global Time Attack
A miata may be gay, but its probably faster than your car around a track. That's pretty gay.
jroc is offline   Reply With Quote
The Following 2 Users Say Thank You to jroc For This Useful Post:
i8urgti (07-20-2011), MS6FL (04-22-2012)
 Old 07-19-2011, 06:20 PM   #5
patrick failman
Groans: 74
and take pics while you're down there.
 Old 07-19-2011, 06:37 PM   #6
Yeah, I know, I am just trying to isolate the issue by having you guys point me in the right direction. Is there a link to where all the mounts are located so I dont forget to check any?
If I can locate the issue, I will take a pic of it.
Last edited by needforspeed6; 07-19-2011 at 06:37 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-19-2011, 06:49 PM   #7
jroc's Avatar
on top of the tranny underneath the battery tray = tranny mount.
on passenger side, connecting the subframe to engine = passenger mount
underneath engine, looks like a metal dog bone, on the middle back of engine = rear engine mount.
on top of rear diff = upper rear diff mount
on the side hanging down = front diff mount
The Following 3 Users Say Thank You to jroc For This Useful Post:
edmsmallcash (02-06-2013), needforspeed6 (07-19-2011), redmnsterut (04-23-2012)
 Old 07-19-2011, 06:55 PM   #8
Thanks! Regarding the tranny mount, can I access/tighten bolts from under the battery tray or just check for issues?
 Old 07-19-2011, 06:59 PM   #9
jroc's Avatar
i highly recommend you take out the battery/battery tray. your hands and back will thank you for it.
you can barely see the tranny mount bolt underneath the tray. iirc, its a 17mm bolt that faces the front of the car going towards the back of the car.
if you see any rubber pieces hanging off, get a new tranny mount
Last edited by jroc; 07-19-2011 at 06:59 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-19-2011, 07:24 PM   #10
Mistersix's Avatar
Posts: 2,585   (View Stats)
It may be necessary to remove the mounts for proper inspection.
Honestly though, this car greatly benefits from upgraded mounts.
A more thorough explanation of the vibes your getting would help us help you.
 Old 07-19-2011, 09:12 PM   #11
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
If your rear diff front mount is broken (mine was), you'll hear a clunking from the rear of the car when you start moving. That you can inspect easily, since the bolts are on the passenger side of the rear diff casing and are most commonly what breaks. Look like this:
You can see the sheared bolts and the empty brace (black) above it.
WHile under there, you can also inspect the rear diff TOP mount arms. They look like this:
You should be able to run your hand over most of that mount (it has arms on both sides of the diff) and see if you can find any cracks, breaks, etc.
But I don't think vibrations are common for the rear diff top mount breaking either. Some folks have had no symptoms, others have felt some clunking. OThers have broken axles lol.
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline   Reply With Quote
The Following 6 Users Say Thank You to Stealth01 For This Useful Post:
edmsmallcash (02-06-2013), karl-hungus (07-20-2011), KevMS6 (12-13-2012), needforspeed6 (07-20-2011), roman_ (07-20-2011), xfeejayx (05-07-2012)
 Old 07-20-2011, 08:41 AM   #12
This is best explanation I can give for the vibes I am getting: After I shift into second gear (at about 4500 rpms in 1st gear) I get vibes in my accelerator pedal and dash in second gear as I pull from 3000-4000 rpms under moderate to heavy acceleration. This is the only time I get the vibes. I replaced the RMM, but still have the issue which is why I am asking if a broken rear diff mount could cause the vibes that I am experiencing.
 Old 07-20-2011, 08:32 PM   #13
Stealth01's Avatar
Groans: 201
That doesn't sound diff mount-ish to me. That sounds tranny-ish. Anyone?
Stealth01
2006 Mazdaspeed6 GT
 Old 04-20-2012, 11:51 AM   #14
akwayne54's Avatar
Posts: 16   (View Stats)
akwayne54 will become famous soon enoughakwayne54 will become famous soon enough
[QUOTE=Stealth01;944322]If your rear diff front mount is broken (mine was), you'll hear a clunking from the rear of the car when you start moving. That you can inspect easily, since the bolts are on the passenger side of the rear diff casing and are most commonly what breaks. Look like this:
QUOTE]
Hello, I seen you guys are talking about the sheared bolts in the rear diff mount. I currently have this probloem and was wondering what the best way to get those sheared bolts out? Also should I replace the bolts or go with an aftermarket brace to stop this from happening again? Thanks in advance!
akwayne54 is offline   Reply With Quote
 Old 04-20-2012, 11:59 AM   #15
weakdog85's Avatar
Posts: 493   (View Stats)
weakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the worldweakdog85 is the leader of the world
Groaned at 15 Times in 3 Posts
[quote=akwayne54;1372094]
QUOTE]
well after getting the bolts out YES, definitely get some stiffer mounts so this doesn't happen again.
07 MS6 Sport.............
JBR Shifter Bushings * JBR RMM * JBR PMM * SURE SRI * VG Sharkfin Antenna * 20% Tint * Cobb AP * Grimmspeed EBCS * Coolant Bypass * PG TIP * Autotech Internals *
weakdog85 is offline   Reply With Quote
 Old 04-20-2012, 12:33 PM   #16
Stealth01's Avatar
Groans: 201
Best way to get them out is a pair of needle-nose pliers or whatever you can use to grip the stubs that are sticking out. If it's recessed, you'll need a bolt extractor. Good luck.
Stealth01
2006 Mazdaspeed6 GT
 Old 04-20-2012, 03:37 PM   #17
akwayne54's Avatar
Thanks for the advice! i was hoping i would be able to get them out today but unfortunately i ran out of time before work. i think i'm going to have to suffer with the stock bolts for now but the dreadnaught and juggernaught are now on my future wish list. I also read there a two different oem bolts available, is this true?
 Old 04-21-2012, 10:31 AM   #18
akias's Avatar
Posts: 13   (View Stats)
akias will become famous soon enoughakias will become famous soon enough
OP, did you ever figure out what your vibration was? I am experiencing something similar. Vibration in 2nd gear only, above 3000 rpm, only when accelerating quickly.
2007 MS6 Black Mica
akias is offline   Reply With Quote
 Old 04-22-2012, 08:24 AM   #19
Stealth01's Avatar
Groans: 201
THere are upgraded ones and the originals. I don't know the part numbers, but they won't matter without an upgraded mount. If you simply go with harder bolts, you risk cracking the diff casing instead of shearing the bolts.
Get the mounts and install them at the same time. Peace of mind is worth it.
Stealth01
2006 Mazdaspeed6 GT
 Old 04-27-2012, 12:13 AM   #20
akwayne54's Avatar
I just thoughtI would give a little update. I've tried just about everything I can think of to get the bolts out with no luck. I'm going to pull off that front casing so I can actuallytry an extractor. Is there anything I should do or look for while I'm in there? I also plan on taking tons of pics and maybe even doing a step by step if that Would be helpful to anyone else.
 Old 04-28-2012, 02:33 AM   #21
Matx's Avatar
Posts: 1,681   (View Stats)
ouch, this was one of the first mods anyone should do to this car modded or not. good luck with those bolts might be easy to take the case to a shop, took mazda 4 days to get bolts outta my first ms6
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
 Old 04-28-2012, 11:11 PM   #22
tek_88's Avatar
Posts: 93   (View Stats)
tek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to beholdtek_88 is a splendid one to behold
Groaned at 13 Times in 2 Posts
I'm currently stuck in the same situation, I'll be waiting on your write up on taking the front diff case off. Or maybe I'll do a write up if you haven't already in the next couple of weeks (still waiting for my pmm and diff mounts).
tek_88 is offline   Reply With Quote
 Old 05-01-2012, 05:42 PM   #23
No, unfortunately I never figured it out. It got a little better after I had my tires balanced, but vibes are still there. Let me know if you figure it out.
 Old 05-06-2012, 08:09 PM   #24
Stealth01's Avatar
Groans: 201
Damn, I feel lucky. I had my sheared bolts out in about 10 minutes with vice grips and a set of pliers.
Stealth01
2006 Mazdaspeed6 GT
 Old 10-17-2012, 04:30 PM   #25
SpICeZ's Avatar
Posts: 145   (View Stats)
SpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond reputeSpICeZ has a reputation beyond repute
Can also try welding a shorter bolt to those stubs, then using a ratched to get it all out. Takes 5 mins... if you have a welder.
2007 Mazdaspeed 6 - CP-E CAI, CS Internals, Cobb AP (Custom 91 tune, 19psi), Test pipe, JBR RMM, Sure Juggernaught, H&R Coilovers, JBR SSP & Bushings, 17x8 w/235-45-17 tires (Hankook RS-3), Hawk HP+ pads all around, DBA 4000 discs,
SpICeZ is offline   Reply With Quote
 Old 12-13-2012, 12:19 PM   #26
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
subd for later
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
 Old 01-17-2013, 01:41 PM   #27
smokeys36shop's Avatar
Posts: 147   (View Stats)
smokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond reputesmokeys36shop has a reputation beyond repute
i have a question. Last month i did a semi launch. Broke something in the rear diff because i heard a loud snap/bang. While driving the car home it felt like the rear diff was loose because it was clunking around in the rear. i no doubt broke the rear diff mounts but along with the clunking noise i was getting a lot of a grinding noise. Could breaking the rear diff mounts also cause these grinding noises? Like a metal on metal noise similar to when your break pads wear down to nothing.
I know its been a month but since it happened before christmas i had to wait to fix it. I will be taking it to someone next month when i have more money.
smokeys36shop is offline   Reply With Quote
 Old 01-17-2013, 02:21 PM   #28
batou079's Avatar
Posts: 82   (View Stats)
batou079 has much to be proud ofbatou079 has much to be proud ofbatou079 has much to be proud ofbatou079 has much to be proud ofbatou079 has much to be proud ofbatou079 has much to be proud ofbatou079 has much to be proud ofbatou079 has much to be proud ofbatou079 has much to be proud of
^ sounds bad. I would be too paranoid to drive my car with that kinda possible dmg and noise going on. Im shocked you havent at least lifted the rear to see if you could see any obvious dmg so you could at least order parts yourself. Best of luck getting it done, i suggest ASAP. Are you pushing more power or stock-ish?
i was doing 0-60 pulls but she felt solid. this thread is making me feel paranoid lol.
Mebe time to upgrade pre-emptively! I had some nasty shakes last month, it turned it it was just one of my stock mounts that busted its nut all over the place, liquid capsule popped. Replaced it, and felt solid again... Also, time for solid mount upgrades eh? heh.
2006 Mazdaspeed6 GT BCM #508 || Cobb AP (OTS Stage+1) || MS CAi || HTP TiP || Turbosmart BPV || Denso Iridium ITV20 || Spin-On Oil Conversion || Magnaflow Catback || Jbarone SSP & Bushings || Corksport Front Strut & Rear Brace || RPM Street Springs || MSR 045 +35offset || +random laundry list of other superficial mods
batou079 is offline   Reply With Quote
 Old 01-17-2013, 04:09 PM   #29
Matx's Avatar
Might have broken the rear dif casing itself get under and look
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
 Old 01-18-2013, 06:19 AM   #30
i haven't touched the car since it happened. I will go out to start it once a week but i haven't driven the car since the incident. When the weather gets warmer i plan to take a look with a buddy. The speed 6 isn't my daily driver so i can live without it and save money to then order the parts. i am in no rush during the winter season since i don't drive it normally.
As for if i am pushing more power? At the time of the incident i was on my 8th tune with Jason ( boost_creep ) I was just about to start my E85 tuning as well. So i would say the car was pushing a lot more power over stock.
 Old 01-18-2013, 06:59 AM   #31
v8 convert
p057's Avatar
Posts: 1,782   (View Stats)
p057 has disabled reputation
Groans: 220
Axle maybe, with that grinding sound....
 Old 01-18-2013, 07:28 AM   #32
Caligula's Avatar
Groans: 185
Yup, people have fucked their rear axles after failure of the diff mount(s). The sound may indicate this is the case for you. If so, that sux bro, its not going to be cheap to fix. This is why I rarely launch my car.
 Old 01-18-2013, 08:04 AM   #33
v8 convert
p057's Avatar
Groans: 220
i'm fully mounted with SURE mounts and i still dont launch my car..
but that's why i'm known as Tampa-NATOR's "captain slow"
 Old 01-18-2013, 09:00 AM   #34
batou079's Avatar
gotcha, glad to hear its not your daily. im sure its nagging you everyday you see it in the garage about working on it. 8th tune eh? You dyno recently, or have any virtual dyno #s ?
Ya, those rear diffs of ours. Axle failure i have read about from various guys doing repeated launches from a dig. Vroom, CRACK, CLUNK, *grind grind grind grind*... I badly want a rear diff mount upgrade as well, but frankly i only make 2-3 parts purchases a year, the AP being the first big one this year. i definitly drive my card a bit too hard for daily driving, luckily the only persistent issue has been power steering pump/lines leakage... just sprung another one recently lol.
Had a rear axle seal pop a few months into ownership back in 09, replaced it with a buddy and thankfully not a single related issue so far. *knocks on wood*
 Old 01-18-2013, 09:39 AM   #35
dyno numbers? nope. Virtual dyno numbers? i would have to ask jason what he was seeing. The day i took the car out was the strongest its ever felt in my opinion. Just sad it broke when it did. Oh well shit happens and im just saving money to have it all fixed. The reason i haven't jumped into it yet is because i plan on doing both rear diff mounts from Sure and a rear sway bar. Right there is $700. Then i have to pay someone to install it along with maybe an axel as well. All said and done i am looking close to $1300 all the way to $2000 for everything most likely. Its sad being my car only has 23,800 miles on it. Guess the car didn't enjoy its new power. Maybe because i don't drive it enough
With that said i am in the same boat as you. The wife and i will be buying a house this year and saving for that is also important as well. So after i do this fix i wont be buying anything else this year. i had hoped to get my turbo early this year but shit like this happens so its gonna have to wait a while.
batou079 ....you the same guy from the mazda247 forum? i haven't talked to you nor been to that site in ages. Glad to see you have your car and are still modding it.
 Old 01-18-2013, 10:04 AM   #36
Caligula's Avatar
Groans: 185
Also, I dont think there is a set "limit" to how much power these mounts can take. Example: I've seen stock MS6s have this issue, yet Im making a bajillion times more tq than a stock 6, am still on my stock mounts and haven't had an issue. If anything Id say its how you drive the car versus how much power you make.
 Old 01-18-2013, 10:28 AM   #37
v8 convert
p057's Avatar
Groans: 220
If you do those three together, make sure to get a different rear rear diff mount than the SURE v2 mount. Get the CPE one or the older SU one because they aren't as thick and don't get in the RSB's way.
IF you do decide to get the v2 anyways, get RSB adjustable endlinks to preload the bar some and stop the two parts from smacking into each other.
The Following User Says Thank You to p057 For This Useful Post:
redboat (02-19-2013)
 Old 01-18-2013, 11:15 AM   #38
batou079's Avatar
Dyamn so LOW miles and these issues? Sorry to hear it! Aint willing to do the work yourself? HAHA i do not blame you, dropping the rear subframe in our cars is freaking painful. And new turbo, wow... Stock replacement for a busted one? Or going big turbo, i assume...
Ya man thats me, i stopped going there for ages cause well, it died. I was an MS6 mod even, but lost my mod status cause i hadn't logged on for like a year, LOL!!! 2012 was mostly repairs and maintenance, i had lots of catching up to do to get her in shape for another year of modding. So 2013 is back to mods. I even pulled the trigger to donate here, almost exclusively to get on the FOR SALE section... which i got my Cobb AP from the very same day i donated. MSF is good to me. I been back to posting various comments on m247 (waiting for m247 hate posts, haha) just to help answer all those unanswered MS6 posts...
Aye, i know that past a certain torque rating it is suggested to upgraded to reinforced mounts is all. And it is definitly a big factor in how you drive it, launching every so often, probably not a big deal. Launching hard everyday, especially with higher than stock torque... probably risky in the long run.
 Old 01-18-2013, 11:35 AM   #39
Caligula's Avatar
Groans: 185
agreed. I need to upgrade but it sounds like u know why I havent done that yet lol.
 Old 01-18-2013, 04:10 PM   #40
Fillups66's Avatar
Posts: 75   (View Stats)
Fillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud ofFillups66 has much to be proud of
Groaned at 17 Times in 2 Posts
Live a little and launch that car, it wants to be driven. As long as you launch correctly you should be fine. I've launched the car plenty of times and the stock mounts are holding up strong and at 86k on the car!
Fillups66 is offline   Reply With Quote
Rear diff locks while turning after SURE diff mount and brace install wettoast MazdaSpeed 6 - Engine, Transmission & Driveline 46 04-23-2018 10:10 AM
rear diff "stiff diff" brace vs. rear diff front mount giordanos4 MazdaSpeed 6 - Engine, Transmission & Driveline 18 03-03-2011 07:38 AM
Inspecting Rear Diff Mounts Stealth01 MazdaSpeed 6 - Engine, Transmission & Driveline 4 01-03-2011 10:35 AM
Page generated in 0.58891 seconds with 36 queries
