 Old 06-15-2019, 09:59 AM   #1
Tadeusz's Avatar
Posts: 6   (View Stats)
Tadeusz has a spectacular aura aboutTadeusz has a spectacular aura about
Default MS6 torque spec - PTO to Transmission
I have been looking for the torque spec everywhere and can only seem to find the torque spec for the actual bell housing bolts to the motor, not the transfer case to the transmission. I did find on one post something like ~120ft/lbs and that seems extreme when the bell housing bolts are only around 38. Maybe its correct, but just rebuilt my transfer case seals/caps and hoping for some help on this. I definitely don't want to screw that up.
For further clarification, I'm talking about the 17mm bolts (5) that hold the transfer case to the transmission.
Thank you in advance.
Tadeusz is offline   Reply With Quote
 Old 06-15-2019, 11:26 PM   #2
SSinstaller's Avatar
Posts: 3,985   (View Stats)
Groans: 60
I think it's 47-65 ft# if I'm looking at the right bolts in the diagram.
Intake Manifold Torque Spec kdxracer CX-7 > Engine, Transmission & Driveline 2 01-06-2016 03:37 PM
Replacing head need torque spec jerrodraven MazdaSpeed 6 - Engine, Transmission & Driveline 1 05-15-2015 06:42 PM
rmm torque spec 2011 MS3 Undefeated1975 2010 MS3 - Torque Specs & information 4 09-24-2011 01:01 AM
ARP main torque spec 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 5 03-10-2009 06:22 AM
Page generated in 0.23489 seconds with 21 queries
