 Old 07-20-2010, 06:43 AM   #1
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Default Metalon - Maybe a Zoom Zoom Boom solution?
Hi everyone,
Last weekend I spoke with a guy who works as a boat mechanic engineer. And we started to talk about engine differences between cars and ships... Then he told me about this "Metalon" stuff... and I was like "Oh! Did you meant Methanol?" and he was like "No! It's metalon..."
It's a product that it's been used since a few decades on boats. It's somekind of oil additive that makes any type of metal to compress making it stronger and avoid from breaking. Like a reinforcement.
I know what you guys are going to say... "Bah! It's a mexican product, I rather get some burritos from Taco Bell!" lol, but I'm starting to believe in this shit.
Here's some info I got from their website:
What is METALON?
METALON is an antifriction product whose main ingredient is Teflon.
METALON is not additive for oil. It adheres to all microporosities of the
metals, giving the surfaces exposed to friction a treatment, preventing them and
getting as result longer useful life of your equipments. Is resistant to
temperatures up to 700°F (370°C), and the only thing that can remove it is the
abrasion caused by oil contaminated by carbon, dust, metalline debries, etc., as
well as for higher temperatures
How it works?
METALON works everywhere is friction, that produces, by which
it adheres to the metal, forming a lubricant film that remains
for an indefinite period of time.
What is its use?
METALON is used to lubricate by oil to any type of equipment lubricated by oil
or grase, any type of internal combustion engine, as of gasoline, diesel or gas, as
well as any component of industrial machinery: transmissions, differentials,
reduction housings of any type or size, hydraulic systems, as well as bearing
grease for industrial type equipments, construction, agriculture, marines, etc.,
with very attractive benefits.
How is it applied?
METALON is very easy and simple to apply, because of its proper
presentations, duly bottled for any engine or component. The base material is
dosed and dissolved in lubricant oils as mean, to be added to the engine or
component. We supply presentations with the proper dose of METALON for
every oil capacity of the system, according to your needs.
With what frecuency has to be applied?
METALON, once applied, is recommended to use in the following way:
construction, mining, agricultural engines, every 2,500 hours of service:
marine engines every 3,000 hours; automotive engines, every 25,000 miles
(40,000 kilometers); components of industrial equipments, every 4,000 hours.
Which are the benefits?
Using METALON you will get benefits as:
*Better fuel output
*Longer useful life of your engine or component
*More power
*Better availability of your equipments
*Less cost of maintenance
*Less frequent oil changes
Why?
METALON is one the finest lubricants known, and once adhered it prevents
touches metal against metal in critical moments, and when in cold operation
protects your engine against wrong procedures as cold accelerations,
excess of RPM, stops of the engine when is very hot, etc.
METALON helps you to control normal operating temperatures, because
prevents the friction.
Why do you save by using METALON?
You will note reductions in fuel consumption, maintenance expenses of your
units or machinery, as well as for better availability of your equipments,
for not having the necessity to visit the shop for maintenances.
With all our infrastructure we are able tl offer our services to the following
industries:
*Heavy-Duty Diesel-Gas engines and their components, of low, medium
and high speeds (industrials, marines and automotives), and parts supply
per your choice upon request.
*Marine and vessels industry: merchant, passenger fishing, suppliers,
tankers, ferries, construction, and oil rigs (rigid and submarine).
*Other industries: textile, paper, glass, plastics, press and printing,
chemical, electronic, cement, steel, petrochemistry, electric generation,
mining, construction, etc.
Link:
Metalon Industries, S.A. de C.V.
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
 Old 07-20-2010, 06:48 AM   #2
corbs's Avatar
Posts: 4,066   (View Stats)
corbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the worldcorbs is the leader of the world
Groans: 336
Groaned at 121 Times in 71 Posts
hmmm very very curious.. i still dont get how exactly this is applied. just like adding oil?
haters phailyb|haltech|wakeboarddude|bykeryder4life
corbs is offline   Reply With Quote
 Old 07-20-2010, 06:57 AM   #3
Police
ganque's Avatar
My friend told me that you have to add 4 cm2 (cubic centimeters) for every liter your engine gets... So that'll be like:
1.57480315 in for every 0.264 galon
TEH MEXICAN'T PERM!
 Old 07-20-2010, 07:08 AM   #4
volodya84's Avatar
Posts: 1,552   (View Stats)
volodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the world
Groans: 42
check out militec-1 in this case.
Corksport TMIC // Denso ITV22s .028" // COBB SRI // Corksport TIP // Forge V1 BPV // COBB AP // JBR SSP // TWM Bushings // Prosport Boost Gauge // CS Interior LED kit
"ban post whoring brownies"
Forge v1
volodya84 is offline   Reply With Quote
 Old 07-20-2010, 07:13 AM   #5
8.5MS3's Avatar
Posts: 4,636   (View Stats)
Groans: 326
6 quarts = 5.68 liters
5.68*4cc = 22.7cc
22.7cc = ~1.5 tablespoons
seems like very little to go round inside an engine
 Old 07-20-2010, 09:42 AM   #6
Speeeeeed
06Speed6's Avatar
Posts: 6,527   (View Stats)
You couldnt pay me to put teflon inside of my engine.
2006 Mazdaspeed 6
I<3Groceries (07-21-2010)
 Old 07-20-2010, 12:53 PM   #7
dizzin9's Avatar
Posts: 1,807   (View Stats)
dizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the worlddizzin9 is the leader of the world
Groans: 77
Groaned at 39 Times in 27 Posts
sweet! i can finally floor it in 6th @ 1000 rpm!!!
2008.5 MAZDASPEED3 GT TRUE RED ***GONE***
2012 FORD MUSTANG GT >>> 400A Premium _ Performance White _ 6MT _ 3.73 _ HID & Security Pkg
Koni Yellows _ Whiteline FSB & RSB _ FRPP K-Springs w/ Bump Stops, Boss 302 Strut Tower Brace, GT500 Strut Mounts, GT500 RCA, GT500-style AB
J&M PHB _ Eibach Camber Bolts _ Avant Garde M510 Satin Silver 19x9.5 40ET _ Hankook Ventus S1 noble2 275/40/19
dizzin9 is offline   Reply With Quote
The Following 2 Users Say Thank You to dizzin9 For This Useful Post:
corbs (07-21-2010), I<3Groceries (07-21-2010)
 Old 07-20-2010, 01:43 PM   #8
SJP0tato's Avatar
Posts: 322   (View Stats)
SJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the world
Sounds like the same snake oil as Slick 50, Prolong, Motor UP, Z-Max, Dura Lube.
I'm sure the literature/testimonials of those products are similar to this, where either the claimed gains are difficult to quantify using any kind of standardized testing or the drawbacks outweigh the benefits at best.
SJP0tato is offline   Reply With Quote
 Old 07-21-2010, 01:32 PM   #9
rremente's Avatar
Posts: 49   (View Stats)
rremente has a spectacular aura aboutrremente has a spectacular aura about
Stay away form Teflon. If you have ever owned a set of Teflon pots and pans, you know that they are great when new, but it starts to chip with age. Those chips eventually clog your oil system.
rremente is offline   Reply With Quote
 Old 07-22-2010, 12:41 AM   #10
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
ehh i dont know if thats just a hot idea
 Old 07-22-2010, 05:53 AM   #11
Police
ganque's Avatar
I'ma gonna try it
TEH MEXICAN'T PERM!
 Old 07-22-2010, 06:03 AM   #12
eliminator's Avatar
Posts: 282   (View Stats)
eliminator is the leader of the worldeliminator is the leader of the worldeliminator is the leader of the worldeliminator is the leader of the worldeliminator is the leader of the worldeliminator is the leader of the worldeliminator is the leader of the worldeliminator is the leader of the worldeliminator is the leader of the worldeliminator is the leader of the worldeliminator is the leader of the world
Meh, I'm gonna wait and see if someone tries n. If it's so great, I'm sure someone role have been/will be all over this
2007 Mazdaspeed3 GT Cosmic Blue Mica
eliminator is offline   Reply With Quote
The Following User Says Thank You to eliminator For This Useful Post:
ganque (07-22-2010)
Almost Zoom Zoom..BOOM?? Rcn_MPS3Zoom MazdaSpeed 3 - Engine, Transmission & Driveline 46 06-29-2010 08:23 AM
Zoom Zoom BOOM - I joined the blown up club. flyrevs2 MazdaSpeed 3/6 - Turbo Induction 85 09-27-2009 02:54 PM
MAZDA5 HYDROGEN RE HYBRID A FRESH APPROACH TO THE FUTURE OF ZOOM-ZOOM Haltech Automotive News 0 06-10-2008 01:18 AM
Page generated in 0.33162 seconds with 29 queries
