  • 1 Post By helmetface
 Old 05-14-2013, 04:44 PM   #1
Mzrpower's Avatar
Posts: 7   (View Stats)
Mzrpower is on a distinguished road
Groaned at 4 Times in 1 Post
Default motor limit
i have a 2006 Mazdaspeed 6 and recently went stage 2 ( Autotech HPFP internals , corksport intake with inlet , corksport DP and exhaust . i upgraded my rear axles with the CPE diff mount. Im running Cobb's accessport and hitting 19.50 psi . my question is , can my engine internals handle that safely ?
Jesse
MZR_POWER
Mzrpower is offline   Reply With Quote
The Following 4 Users Say NO Thank You to Mzrpower For This Un-useful Post:
alphasaur (05-14-2013), Easter Bunny (05-14-2013), smoogs12 (05-14-2013), stlskater92 (05-14-2013)
 Old 05-14-2013, 04:46 PM   #2
alphasaur's Avatar
Posts: 2,847   (View Stats)
alphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the worldalphasaur is the leader of the world
Groans: 235
Groaned at 60 Times in 48 Posts
get a tune brownie.
/91 miata with basic suspension bits
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/possessed speed 6- dead ((((((
/lol nator.
alphasaur is offline   Reply With Quote
The Following 2 Users Say Thank You to alphasaur For This Useful Post:
SLOWHATCH (05-14-2013), smoogs12 (05-14-2013)
 Old 05-14-2013, 04:49 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Stage 2?
Bro, wait for stage 6
Shit gets outta this world.
Don't worry about the Miata fag above you, I mean shit, he drives a Miata..and he's probably super old and smells.
alphasaur likes this.
The Following 9 Users Say Thank You to helmetface For This Useful Post:
alphasaur (05-14-2013), ckMS3 (05-14-2013), Easter Bunny (05-14-2013), himurax13 (05-14-2013), kgb (05-20-2013), Mzrpower (05-15-2013), rfinkle2 (05-14-2013), smoogs12 (05-14-2013), TWOptSL0W (05-14-2013)
 Old 05-14-2013, 04:51 PM   #4
6Y MAZDA's Avatar
Posts: 1,775   (View Stats)
6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world
jesus christ...
1996 Miata
SOLD 2006 Black Cherry Mica MS6 Grand Touring #00584
CP-E 3" Straight Pipe Exhaust. CP-E TMIC. StreetUnit TP. Street Unit RMM. HTP 3" TIP. Custom 3.5" MAF SRI. PTP HPFP Internals. Cobb AP. RichTuned. Denso ITV22. Forge V1 BPV. Blox Shift Knob. VEI Boost Gauge. 18x8.75 +33 XXR 530. Nitto Motivo 225/40/18. Megan Racing Springs.
SOLD: 2009 Mazda 6i GT. 6-Speed MT.
6Y MAZDA is offline   Reply With Quote
The Following 3 Users Say Thank You to 6Y MAZDA For This Useful Post:
kgb (05-20-2013), rfinkle2 (05-14-2013), smoogs12 (05-14-2013)
 Old 05-14-2013, 04:52 PM   #5
btstarcher's Avatar
Posts: 4,850   (View Stats)
Groans: 112
You called?
SnailTune in progress
The Following 3 Users Say Thank You to btstarcher For This Useful Post:
Easter Bunny (05-14-2013), rfinkle2 (05-14-2013), smoogs12 (05-14-2013)
 Old 05-14-2013, 04:53 PM   #6
mxlplx71's Avatar
Posts: 3,262   (View Stats)
Groans: 128
the etunes make more power and are tuned to run safer aswell
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
 Old 05-14-2013, 04:53 PM   #7
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
OP. In the future, most of your logging questions for ots maps can be found here.
http://accessecu.com/support/docs/su...0Guidance.html
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
ckMS3 (05-14-2013), mxlplx71 (05-14-2013), Mzrpower (05-15-2013), SLOWHATCH (05-14-2013), smoogs12 (05-14-2013)
 Old 05-14-2013, 04:54 PM   #8
himurax13's Avatar
Posts: 4,582   (View Stats)
Groans: 255
Pickles Tune in progress
 Old 05-14-2013, 05:08 PM   #9
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
No you fucked your motor. Better stock out and trade for a Honda.
I hugged rfinkle2
Little John (05-14-2013), rfinkle2 (05-14-2013)
 Old 05-14-2013, 05:20 PM   #10
stlskater92's Avatar
Posts: 78   (View Stats)
stlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond repute
Apex seals go bad every 10k miles with is setup. So it's your choice.
White 2009 MS3:
100k mile pig
HTP built
gt3076r powered
6th port fueled
Tuned by Nishan
Black 2008 MS3:
under construction
#700orbust
stlskater92 is offline   Reply With Quote
The Following 6 Users Say Thank You to stlskater92 For This Useful Post:
anavrinIV (05-14-2013), btstarcher (05-14-2013), ckMS3 (05-14-2013), Easter Bunny (05-14-2013), Fatguy729 (05-14-2013), smoogs12 (05-14-2013)
 Old 05-14-2013, 05:26 PM   #11
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
Buy a ko3 for teh fasts
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
The Following User Says Thank You to ckMS3 For This Useful Post:
 Old 05-14-2013, 05:34 PM   #12
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
LOL rotary swap eh?
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
The Following User Says Thank You to Fatguy729 For This Useful Post:
 Old 05-14-2013, 06:22 PM   #13
Flipboi89's Avatar
Posts: 342   (View Stats)
Flipboi89 is the leader of the worldFlipboi89 is the leader of the worldFlipboi89 is the leader of the worldFlipboi89 is the leader of the worldFlipboi89 is the leader of the worldFlipboi89 is the leader of the worldFlipboi89 is the leader of the worldFlipboi89 is the leader of the worldFlipboi89 is the leader of the worldFlipboi89 is the leader of the worldFlipboi89 is the leader of the world
Groaned at 5 Times in 1 Post
Ls1...
2008 Mazdaspeed 3 GT Black Mica
[*] Forge Bpv
[*] Corksport Stage II Sri
[*] Corksport Interior Led's
[*] Corksport Shift Bushings
[*] Jbr Rmm
[*] RallyArmor Mud Flaps
[*] 20% Tint
[*] Denso Itv20 Spark Plugs
[ ] Defi Racer Boost Gauge
Keeping the Mazda, but no more modding.. Trying to..
Flipboi89 is offline   Reply With Quote
The Following 2 Users Say Thank You to Flipboi89 For This Useful Post:
ckMS3 (05-14-2013), himurax13 (05-14-2013)
How much higher will I be able to set the rev limit mituc MazdaSpeed 3 - Engine, Transmission & Driveline 31 03-05-2013 06:00 PM
LC Rev Limit value through AP spoof3r 2010 MS3 - ECU Computer Tuning 31 12-03-2011 06:33 AM
Rev limit launch and cel turd burglar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 18 06-01-2011 12:01 AM
Flashing Limit? 100? Fobio
Cobb ATR Support
4 04-29-2009 07:19 PM
what is the limit??? protur03 MazdaSpeed 3 - Engine, Transmission & Driveline 4 10-18-2008 05:47 PM
Page generated in 0.33541 seconds with 32 queries
