 Old 08-13-2019, 02:12 AM   #1
devindusza12's Avatar
Posts: 6   (View Stats)
devindusza12 is an unknown quantity at this point
Default Need help
I have a 2007 mazdaspeed6 and owned it for about a month now. Yesterday the check engine light popped on and the car started running really rough. I got home as soon as possible open the hood and there is oil everywhere. The main culprit was the catch can I just installed had overflown but I just put it on 2 days before so it should not have been full already. Then I hooked up my scanner and the cel was on because cylinder 3 was misfiring bad. I did a compression test and cylinder 3 has almost no pressure so I believe a piston went bad. There is mods on the car but I want to know if someone can tell me if I was missing something I should have had on the car. Plz message if u know any info and I will explain more on what the car has done to it. Thx
devindusza12 is offline   Reply With Quote
 Old 08-13-2019, 06:14 AM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,906
Did you do a leakdown test?
Page generated in 0.22966 seconds with 20 queries
