 Old 02-15-2013, 05:10 PM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default Neutral trans noise at idle
I figured out that it is a trans bearing, I have the same bearing out on two different transmissions and both of them made that noise. Ill dig up a part number later this weekend.
2006 Mazdaspeed 6
Fatguy729 (02-15-2013)
 Old 02-15-2013, 05:15 PM   #2
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
Are you referring to the noise that everyone has deemed throw out bearing up to this point? The random chatter?
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
 Old 02-15-2013, 07:57 PM   #3
Speeeeeed
06Speed6's Avatar
Yeah, it unloads and loads the input shaft and it makes more noise when its unloaded (clutch not pressed) and at low rpm. At higher rpm it just makes a soild noise that you cant tell from other noises.
2006 Mazdaspeed 6
btstarcher (02-18-2013), Fatguy729 (02-15-2013)
 Old 02-16-2013, 06:14 AM   #4
jm211's Avatar
Posts: 943   (View Stats)
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
Groans: 52
In other words, normal?
At least on this platform...
Black Mica 2006 Speed6 GT | 62,000 Miles
Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
 Old 02-18-2013, 01:48 PM   #5
RWDAddict's Avatar
Posts: 340   (View Stats)
RWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the world
I hear it's the Pilot bearing that makes this noise, unless what you're talking about is the same thing.
06 MazdaSpeed6 GT w/Nav. Mods so far: Cobb SRI, RMM, HPFP, ATP 3" catted DP, ETS CBE, Synchronic BOV, AP, CP-E TMIC, SURE TIP, HKS Twin Power, Poly trans mount, PTP fuel injector seals, PCV Fix
RWDAddict is offline   Reply With Quote
 Old 02-18-2013, 01:54 PM   #6
def not the pilot bearing.
and i have never had this problem either. it seems to only come up with the older ACT kits.
 Old 02-19-2013, 01:40 AM   #7
Speeeeeed
06Speed6's Avatar
The part number is A60117206 and it is not the throw out bearing.
2006 Mazdaspeed 6
 Old 02-19-2013, 02:11 AM   #8
The Panda's Avatar
Posts: 1,229   (View Stats)
Groaned at 8 Times in 7 Posts
My wifes ms6 Tranny is noisy as fuck after the TMM I can hear the flywheel and gears whinning as I drive shit scured me at first. I have had fully mounted cars too but never this loud
2011 BLACK MS3
The Panda is offline   Reply With Quote
 Old 02-19-2013, 07:39 AM   #9
RWDAddict's Avatar
Mine made that noise with an ACT, then a Spec with stock flywheel, then spec with Fidenza flywheel, all made the same noise but goes away when you push the clutch pedal down.
 Old 05-21-2013, 02:09 PM   #10
Guthrie's Avatar
Posts: 54   (View Stats)
Guthrie is a splendid one to beholdGuthrie is a splendid one to beholdGuthrie is a splendid one to beholdGuthrie is a splendid one to beholdGuthrie is a splendid one to beholdGuthrie is a splendid one to beholdGuthrie is a splendid one to behold
@06Speed6
Do you think this bad bearing might also contribute to the issues with notchy shifting that many people are having? Is it part 17-203B on this picture?
MANUAL TRANSMISSION GEARS. Fits: 2007 Mazda MazdaSpeed6 | Jim Ellis Mazda
Guthrie is offline   Reply With Quote
The Following User Says Thank You to Guthrie For This Useful Post:
06Speed6 (05-22-2013)
 Old 05-21-2013, 02:29 PM   #11
Say Chi Sin Lo's Avatar
Posts: 872   (View Stats)
Say Chi Sin Lo has disabled reputation
Groaned at 62 Times in 28 Posts
If it sounds like a loose bag of marbles, it's normal. Sucks and kind of annoying, makes the car sound broken, but normal.
Say Chi Sin Lo is offline   Reply With Quote
 Old 05-22-2013, 02:10 AM   #12
Speeeeeed
06Speed6's Avatar
Originally Posted by Guthrie View Post
@06Speed6
Yeah that is the bearing, but no it has nothing to do with shifting.
The loose marble sound is a bad bearing, I think it is always a bad bearing and bad bearings are sadly pretty normal for this trans. I think that at least part of it is due to improper bearing loading, the bearings that I have seen are all ball bearings and those bearing types arent designed for thrust loading which I think is what they are getting. I also dont understand the sealed design, there is no reason for those bearings to be sealed.
2006 Mazdaspeed 6
Last edited by 06Speed6; 05-22-2013 at 02:10 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-22-2013, 05:08 AM   #13
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
BigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the worldBigRedSpecial is the leader of the world
Groans: 56
Groaned at 6 Times in 6 Posts
I noticed it bigtime when I installed my TMM. I just assumed it was the throwout bearing...
2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's
Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals
Winter Beater: 96 GMC K1500 5 speed 4x4
Needed: Driver mod
BigRedSpecial is offline   Reply With Quote
 Old 05-22-2013, 01:14 PM   #14
Guthrie's Avatar
Any idea what might be causing it then (all gears more or less)? Last time I checked this forum there was no clear answer, just wondering if somone has figured it out?
(sorry for an off topic question).
 Old 05-22-2013, 02:53 PM   #15
Speeeeeed
06Speed6's Avatar
Notchy shifting could be anything between the shifter to the shift fork, common items are the shift cables and shift forks.
2006 Mazdaspeed 6
 Old 05-22-2013, 03:39 PM   #16
jm211's Avatar
Groans: 52
@06Speed6 I assume by passing the clutch switch at start up help reduce thrust bearing failure as it kills that load on the crank?
Edit: Rather, will this help any other bearing described above?
 Old 05-23-2013, 07:48 PM   #17
Speeeeeed
06Speed6's Avatar
Thrust bearings dont really fail on this engine. I think the trans is thrust loading itself and the bearings are not rated for thrust. I had a thought last night that it could be thrusting the trans shafts towards the tapered roller bearings which handle thrust, but as those wear it might be pulling the ball bearings which ruins them. It needs a slippable roller bearing I think.
2006 Mazdaspeed 6
BigRedSpecial (05-24-2013), jm211 (05-27-2013)
 Old 05-28-2013, 03:57 PM   #18
cthomp's Avatar
Posts: 114   (View Stats)
cthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the world
Tons of people complain about this issue at my dealer on all mazda models. As per mazda field reps/tech noise is normal. As a speed owner quite annoying
cthomp is offline   Reply With Quote
The Following 2 Users Say Thank You to cthomp For This Useful Post:
06Speed6 (05-29-2013), jm211 (05-30-2013)
 Old 08-19-2013, 02:02 PM   #19
MPS_Fan's Avatar
Posts: 436   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
Same weird noise here on my genpu since day 1. But it only occures on my speed if I drove it hard before or when it's very hot outside. Sounds like bag of marbles. It seems like bearing clearance changes when it gets hot, so that the main shaft starts rattling. I'm really scared now to upgrade to a one mass flywheel and aftermarket clutch, since this increases the noise. I hate the MS tranny. It can handle a shitload of torque, but it's crazy loud and shifts very notchy.
MPS_Fan is offline   Reply With Quote
 Old 08-19-2013, 02:15 PM   #20
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
Same noise here car shifts fine but I quickly realized I need to be very nice to this stock clutch to make it last. From what I have read its a noise almost everyone gets and its normal. Mine didn't start making this noise till about 16000 miles and I have almost 18000 now. However I am no expert on this car so I would ask one of the senior members if this noise is something that needs to be fixed or is ok.
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
 Old 08-19-2013, 02:21 PM   #21
MPS_Fan's Avatar
Has anybody changed the mentioned bearing? Is a adjustment of bearing clearance necessary? I fucking hate this sound! It seems to occure more often now. I have 18k miles now and don't want to swap clutch and flywheel before I solve this issue.
 Old 08-20-2013, 07:42 PM   #22
Speeeeeed
06Speed6's Avatar
The bearings arent shimmed afaik
2006 Mazdaspeed 6
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f106/neutral-trans-noise-idle-138157/
Forum Mazda Performance Series - Zobacz temat - Sprz?g?o + Dwumasa. Czyli jakie mamy opcje :) This thread Refback 05-23-2013 12:27 PM
Weird noise at idle XerocX MazdaSpeed 3 - Engine, Transmission & Driveline 24 01-05-2014 07:36 AM
Chatter noise in neutral MPS_Fan 2010 MS3 - Engine, Transmission & Driveline 28 12-10-2013 06:02 PM
Noise when coming off clutch at idle stokes620 MazdaSpeed 3 - Engine, Transmission & Driveline 4 11-30-2012 06:20 PM
Transmission noise in neutral radioflyer MazdaSpeed 3 - Engine, Transmission & Driveline 28 04-23-2012 06:03 AM
Strange noise from diff/trans MYspeedEMS3 MazdaSpeed 3 - Engine, Transmission & Driveline 5 01-18-2011 12:16 AM
Page generated in 0.40537 seconds with 31 queries
