 Old 04-20-2015, 11:39 AM   #1
Douggievee's Avatar
Posts: 71   (View Stats)
Douggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really niceDouggievee is just really nice
Question Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal?
My clutch pedal sticks to the floor about 15-20% of my shifts. Very sporadic. I just use my foot to pull the pedal back up and its fine again for a while. Is this a common characteristic of a lightweight flywheel?
2006 Mazdaspeed6 GT: Autotech Fuel pump, GT3071R, Cobb AP FreakTune, 3" Custom Magnaflow Turboback Dual Exhaust, Mazdaspeeed intake/turbo inlet tube, NGK XI 1 step colder plugs, Fidanza Flywheel, EGR/VTCS Delete, Cobb EBC, Cross drilled rotors, Corksport BPV, TSW Nurburgrings, Techna-Fit SS Clutch Line
Douggievee is offline   Reply With Quote
 Old 04-20-2015, 11:54 AM   #2
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Make sure to check your pedal for cracks.
MECP
2012 BM
Rfinkle tune in progress
 Old 04-20-2015, 12:14 PM   #3
Jeff23spl's Avatar
Posts: 2,114   (View Stats)
nothing to do with FW weigt, it is probably the pedal mechanism or a bad slave cylinder...
As long as everything got installed correctly during clutch replacement... Are you seeing it since day1 of install or just recently ? Did you put mixed new and old parts without checking to stay inside specs ? Sometimes if the height of FW blocs isn't compatible with PP travel and disc thickness, you may experience that kind of issues. But usually you would see the clutch forks to be loose or needing alonger travel to operate...
I would check the slave for leaks first...i had to replace mine right after a clutch job and it wasn't funny to manage into traffic with a dead clutch pedal.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 04-20-2015, 12:24 PM   #4
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
My oem/fidanza combo doesn't do that, got almost 19K on it now.
340hp / 371tq
 Old 04-20-2015, 04:46 PM   #5
Douggievee's Avatar
I have checked on the past but I'll get down and look at the pedals again. I bought the 6 modded so I don't know if the slave was ever changed but maybe that's a good place to start.
And I would say it's been doing it a few months now so not since day 1 of the clutch flywheel install which were both new a year ago.
Last edited by Douggievee; 04-20-2015 at 04:46 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-20-2015, 05:01 PM   #6
AlecMS3's Avatar
Posts: 69   (View Stats)
AlecMS3 has much to be proud ofAlecMS3 has much to be proud ofAlecMS3 has much to be proud ofAlecMS3 has much to be proud ofAlecMS3 has much to be proud ofAlecMS3 has much to be proud ofAlecMS3 has much to be proud ofAlecMS3 has much to be proud ofAlecMS3 has much to be proud of
Other than the chatter after driving for a while while not on gear, i've never experienced anything worth mentioning after doing the OEM clutch/Fidanza flywheel combo and especially no clutch issues like the ones you mention. It's probably on your best interest to get a new slave and master cylinders based on your mileage though.
__________________________________________________ ____________________________
2008 BM Mazdaspeed3 / Fidanza Flywheel / E-Focus RMM / Bone Stock
AlecMS3 is offline   Reply With Quote
 Old 04-20-2015, 09:41 PM   #7
93GTS's Avatar
Posts: 486   (View Stats)
93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world
Maybe corrosion around master cylinder push rod. I've had a 626, several probes, and a ranger do it. The common factor was that none were driven regularly.
93GTS is offline   Reply With Quote
 Old 04-20-2015, 11:22 PM   #8
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Mattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the world
Yo Alec! You got the OEM clutch Fidanza setup? I have to come over and check it out very soon. My clutch is fried and I am on the fence.
Mattyhawk1 is offline   Reply With Quote
 Old 04-21-2015, 06:27 AM   #9
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
bleed - fail
replace slave, bleed - partial victory
adjust pedal - win
my experience. Not with findanza, but I don't think the flywheel has anything to do with your issue.
-Wetz
QFT
 Old 04-21-2015, 07:48 AM   #10
Douggievee's Avatar
Ok, im gonna have to look into geting the master and slave replaced and see if it clears up
 Old 04-21-2015, 08:40 AM   #11
Jeff23spl's Avatar
make sure to get the upgraded slave with mazda part # finishing by a ''B'' you can search here for full #.
Wife drive 2010 CX7
Douggievee (04-21-2015)
 Old 04-21-2015, 10:28 AM   #12
AlecMS3's Avatar
Sure man. Just got your PM check your inbox.
 Old 05-14-2015, 08:35 AM   #13
shmallz92's Avatar
Posts: 11   (View Stats)
shmallz92 has a little shameless behaviour in the past
my clutch went, car is in the shop for over a week now because only one mazda dealer around and going for OEM clutch.. anyway.. my flywheel may possibly be fuked as well but we wont know until the clutch comes and and we start taking shit apart... if so, i would LOVE to know if the OEM clutch and fidanza combo is safe and that there will be no problems... i really do not want to spend more for an oem flywheel and im sure no one does...
THANKs
shmallz92 is offline   Reply With Quote
 Old 05-14-2015, 10:25 AM   #14
Jeff23spl's Avatar
start looking right now because the oem isn't suppose to be re-usable with a new disc. When i look for one, the price was between 800-1500$ for just the OEM Luk FW...
You will have a hard time to find someone to re-manufacture it like we could be used too with, ordinary clutch system, The chance that the FW isn't worn with a failed disc is very thin...
Some have found places that work on the oem LUK fw but i think most goes with an aftermarket solid 1 piece FW...Just make some search on msf and you will find manny thread about clutch kits...
You will also heard about pro and cont of using a lightweigt FW on the DD use.
I have an ACT but i won't suggest it for a stock use...
Wife drive 2010 CX7
 Old 05-14-2015, 10:44 AM   #15
AlecMS3's Avatar
THANKs
OEM LuK clutch and Fidanza FW combo is very safe. I've had this setup for 8 months now with no problems. You might want to replace your master and slave cylinders too while you are at it. Each one will set you back about 100 dlls each but its a better way to prevent any follow up issues in your tranny.
The LuK clutch with Fidanza Flywheel Combo CaseyBueno Mazdaspeed3/6 General Discussion 22 05-14-2015 08:30 AM
New OEM Clutch with Fidanza Flywheel Soft Clutch Feel zer010gic MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-15-2014 11:12 PM
Page generated in 0.35006 seconds with 28 queries
