Like Tree9Likes
  • 8 Post By Mazdazilla6
  • 1 Post By phate
 Old 02-18-2014, 10:18 PM   #1
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Default Our Rear Diff
I'd like to start by saying thanks to @Funkster777; for giving me this opportunity. After replacing his diff he gave me his old one to diagnose what went wrong as well as tear it down to see what it looks like.
So to start here is our rear diff:
The easy way to explain how our drivetrain works is that the center and rear diff are mashed together. The "center diff" is the front half of the whole diff which holds the coupling unit while the rear half holds the LSD. The two halves separate where you see the bolt holes going around the diff kind of in the middle (in picture above).
Let's start from the rear for sake of simplicity (and because I love going in from behind). The rear diff uses a clutch plate style limited slip diff and has a 2.92 gear ratio when mated to our pinion gear. The LSD is held into the housing by two bearing caps on either end, like most diffs. Our pinion gear is an overhung type meaning that the pinion is held in by two ball bearings and the gear teeth hang over the end bearing.
Also the diff temp sensor is housed right behind the pinion (it's that little shiny bar in that tunnel):
Now regarding this certain diff I have reason to believe that at some point the oil was overheated/ran low (Probably before Funkster had the car). As seen here the bearing caps have a bit of scoring on them as if the bearings started to eat into them a little. I'll talk more about this later.
Moving forward, the rear half and front half share a common fluid as seen by this passage that goes from the front to the rear half (the shiny part in the hole is the coupling).
In the front half of the diff there is the coupling. Here is what it looks like separated from the rear half and the coupling removed:
Here is the coupling:
Here is the front of the rear half with the front half removed. Note the big ass staked nut on the pinion lol.
The shaft on top of the coupler is easily removed by taking off the top four bolts.
Here is the back of the coupling which faces the rear half of the diff. There are two snap rings that are on the back but I already had them removed when I took this picture.
Okay now is time for the fun part. The coupling. I would first like to say it is a total bitch to take apart and second I will say that you will NOT be able to put the coupling back together should you decide to take it apart. On the last picture I posted you can see there are two spot welds that hold in the coupling bottom to the housing. But I also found out that the whole area where it is raised in the rear is all threads, so the whole coupling bottom threads into the housing. The only way I was able to get the coupling bottom unthreaded was to use a cold rolled punch and punch off the casing (which is made of a brittle aluminum so be care of metal splinters) with the threaded part after throwing it in a vice. Even with most of the threading and spots welds punched off I still had to use a massive ass pipe wrench and spin it until the rest of the threads were out.
Caution: Opening up the coupling you might die due to the smell. No really, this shit stinks. How bad was it? My hall director came by my door telling me that he could smell it on the second floor (I live on the third) and he could smell it all the way down the hallway, more than 50 yards away. And that was after I had thrown out the oil and had cracked a window more than a half hour later. Literally everyone in my hall has stopped by my door telling me how much they hate me (okay only a few people).
On to the juicy details. The coupling is a viscous coupling, which has clutch plates in it:
As well as metal plates that fit between the clutch plates:
Together they layer like this:
The metal plates are splined to the housing and the clutch plates are splined to the shaft in the middle of the housing which rotates on a ball bearing:
So the shaft which was held on to the top by the four bolts is splined to the driveshaft flange which is obviously connected to the driveshaft and thus is always spinning. The shaft in the coupling which the clutch plates are splined to is splined to the pinion gear. So when the clutch plates engage the metal plates (think of them locking together on the faces) power is able to be flowed from the driveshaft to the LSD and ultimately to the wheels.
Now what determines how/when the plates engage is dependent on the rest of what's in the coupling. On top of the layers of clutch and metal plates are a ball and ramp assembly which has six balls. The bottom plate which holds the balls looks like this (backside facing the clutch and metal plates is first pic):
Balls sit between the bottom plate and the top plate (both of which have ramps for the balls). Pic of top plate (bottom side):
Note the alignment marks on top of the top plate line up with slots in the plates between the top and bottom plates:
Now the plates in between are friction plates. One kind of plate is splined to the housing:
And the other plates are splined the the top plate:
The surface of both plates looks to be the same:
So when the bottom of the coupling is removed it looks like this (also there is a torrington bearing that rides on the small silver plate on top of the top ramp plate):
I'm not sure how the solenoid physically acts when it is energized but this is what I believe how it works (if someone would like to fill this in they can). When the solenoid is energized, the friction plates will spin which will cause the top ramp plate to move and the balls will be forced to move up the ramp which will force the bottom ramp plate downward causing the metal plates and the clutch plates to engage and allow power to be transferred through the coupling.
Going back to this certain diff's failure. Other things that lead me to believe the oil was overheated/ran low is that it was extremely black on everything it covered inside the diff. Not only that but we pulled out shards of the clutch plates from the LSD which makes me think they were overheated (possibly due to lack of lube) until failure. The last thing that leads me to believe it failed because of this is that there is no damage to anything else; the coupling was solid before I pulled it apart, the ring and pinion had zero damage on the teeth and the wear was fine from what I saw looking at them, and like I said before the bearing caps have a bit of scoring on them. Also on the diff casing itself I noticed that the case was clean (meaning silver) on the top and bottom, yet the sides were black which makes me think oil was leaking from the half shaft seals and too much could have made it out. I'm going to tear down the LSD to get a better look at it hopefully next week maybe the week after. Also I'm going to test the temp sensor on the diff to see if it's fried as that may have given false/no readings to the ECU and allowed the oil to overheat.
I think that just about sums up the operation of our rear diff. If anyone has anything to add, thoughts or insight, all is welcome. Also I'd love to hear what you guys think could have caused the diff to fail. If anything seems vague or you want me to grab any more pictures just let me know and I'll add them.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
The Following 34 Users Say Thank You to Mazdazilla6 For This Useful Post:
6ixof1 (02-19-2014), Alpha (02-20-2014), alphasaur (02-18-2014), aviator79 (09-15-2015), Axel907 (02-28-2014), BigjohnB20 (02-19-2014), chaser27 (02-18-2014), Code Monkey (02-18-2014), dale_gribble (02-19-2014), Doucems6 (04-24-2016), Funkster777 (02-19-2014), iCooper (02-24-2014), Jh8909 (02-19-2014), KevinK2 (02-19-2014), KusteLokal (02-21-2014), Lost hawaiian (02-20-2014), Micha (02-24-2014), MTLspeed6 (02-20-2014), Muzzybud (04-14-2016), mxlplx71 (09-14-2015), Neverlift (03-23-2016), phate (02-18-2014), PhillyCheese (02-20-2014), RE-ACTIONENGSPEED3 (09-14-2015), redboat (02-23-2014), Rich990 (05-12-2014), rymanmazda (02-19-2014), sidekick (02-18-2014), siegsuwa (08-19-2015), speed23 (02-19-2014), TiGraySpeed6 (02-19-2014), Tomas (03-25-2016), Vader (02-19-2014), xI Leveler Ix (02-19-2014)
 Old 02-18-2014, 10:27 PM   #2
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Very interesting to see how complex the rear diffs in our cars are. Thanks for posting this.
2006 Mazdaspeed6
The Following User Says Thank You to sidekick For This Useful Post:
phate (02-18-2014)
 Old 02-18-2014, 10:50 PM   #3
Eth Fiend
phate's Avatar
Posts: 6,945   (View Stats)
The rear diffs are so freakin sweet in this car. I have come across the Mazda documentation for the coupling and solenoid, but can't ever recall where it's at when I need it. The ball and ramp assembly works when there is a difference in speeds - if there is a difference in speeds, the ball moves away from center, causing the plates to get squished together. The more speed difference, the more pressure (because it's farther up the ramp supplying more pressure). The solenoid, from what I remember, just applied even more pressure to that assembly or allowed the ball and ramp to work more effectively.
-06 MS6
-Corn fed 07 MS3 - Sold
Axel907 (02-28-2014), chaser27 (02-18-2014), Mazdazilla6 (02-18-2014), rymanmazda (02-19-2014), sidekick (02-18-2014)
 Old 02-18-2014, 11:30 PM   #4
sidekick's Avatar
Groans: 47
It's a gift and a curse. Lol. The PTO/rear diff seem to be some of the biggest/most common problems on the MS6, not to mention the cost of replacement. AWD is only an advantage if it actually works.
2006 Mazdaspeed6
The Following 2 Users Say Thank You to sidekick For This Useful Post:
PhillyCheese (02-20-2014), redboat (02-23-2014)
 Old 02-19-2014, 07:44 AM   #5
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Excellent to see an autopsy done on one of these finally!
I'm especially tickled to see the ball bearing set-up in the front section in real life compared to the tech training documentation which makes it look like there are only two balls.
340hp / 371tq
sidekick (02-19-2014)
 Old 02-19-2014, 08:20 AM   #6
Funkster777's Avatar
Posts: 1,254   (View Stats)
Funkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the world
Thanks for doing this. So now I know why it failed. Will make sure it will not happen again with new one.
Funkster777
2010 Black Cherry Metallic Mazda 6 DD (well as needed)
2006 Black Mica Mazdaspeed6 Sport
Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.
Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS
Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails
Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod
Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port?
Funkster777 is offline   Reply With Quote
The Following 2 Users Say Thank You to Funkster777 For This Useful Post:
Mazdazilla6 (02-19-2014), sidekick (02-19-2014)
 Old 02-19-2014, 06:05 PM   #7
KevinK2's Avatar
Posts: 907   (View Stats)
Nice work! The ball cam part of it is exactly like how my dry clutch is engaged on my '76 Triumph Motorcycle, and the e-brake on my 83 saab 900 (rip).
I also found the same coupling design was used on awd 626's.
From Delaware
 Old 02-19-2014, 07:29 PM   #8
KevinK2's Avatar
It's a sticky in this forum: MS6 Training Manual starts at page #35 .
Or you can see it here transfer-case-disassembly-has-anyone-done
Actually, there is a pilot clutch, shown in the later pics above with a carbon-fiber look, that is 1st engaged by the electromagnetic coil, with a load ~proportional to the solenoid duty cycle. The primary clutch plates are as described by Mazdazilla6, except the ones with the ID teeth are fitted into an extension of the first cam plate, and not the pinion shaft. They are pushed forward against the cam plates, and against the main clutch in the front of the case. The cam ramps move relative to each other, in proportion to the duty cycle but also amplified by the cam action, and increase the main clutch grab.
A speed difference between the drive shaft and pinion shaft is needed to supply substancial torque to the rear wheels, as you noted.
How did it behave when it failed?
From Delaware
Last edited by KevinK2; 02-19-2014 at 09:03 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to KevinK2 For This Useful Post:
Tomas (02-21-2014), xI Leveler Ix (02-19-2014)
 Old 02-19-2014, 08:20 PM   #9
Fine. I was getting 4wd light on and off so @Mazdazilla6; and I drained it and noticed the black ooze and the parts.
It was then replaced. Still had problems and replaced transfer case.
Funkster777
 Old 02-19-2014, 08:43 PM   #10
KevinK2's Avatar
I think that came from the tapered friction rings that are behind the side bearings, inside the diff carrier.
Lifted this great coupling illustration from one of your posts:
From Delaware
 Old 02-20-2014, 02:49 PM   #11
KevinK2's Avatar
... I drained it and noticed the black ooze and the parts.
This "Mt Fuji" LSD is shown to have friction cones on top of the side gears, acting a bit like a sycro ring in a trans. But based on those parts, the lsd is more like a preloaded clutch style, with the clutch plates and discs behind the side gears. Like this:
Note the 2 tabs per clutch plate.
From Delaware
jm211 (02-20-2014), Tomas (02-21-2014)
 Old 02-20-2014, 03:09 PM   #12
KevinK2's Avatar
Originally Posted by Mazdazilla6 View Post
... On to the juicy details. The coupling is a viscous coupling, which has clutch plates in it: .....
Not quite right . VW made the viscous coupling famous (to me) as a center diff. It is as simple as it gets. All the clutch plates and discs are enclosed in the spinning housing with next to zero axial play.It is FWD or RWD until there is a big speed difference at the F vs R wheels. This heats up the silicone based fluid that gets so viscous it locks the plates together. ATF is not that special oil.
Viscous_coupling_unit Viscous_coupling_unit
From Delaware
 Old 02-20-2014, 04:03 PM   #13
I have my suspicions it my not be ATF. I've never seen ATF look this brown/black color and I've never smelled ATF that is this horrible smelling.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 02-21-2014, 03:11 PM   #14
KevinK2's Avatar
Did you get a chance to pull the diff center housing apart ? The clutch type rings behind the side gears could be the main broken parts.
From Delaware
 Old 02-21-2014, 11:41 PM   #15
You mean the LSD? No I haven't torn it down yet but I believe that's what it is too. I may have it apart this or next week.
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 02-24-2014, 07:51 AM   #16
iCooper's Avatar
Posts: 11   (View Stats)
iCooper is just really niceiCooper is just really niceiCooper is just really niceiCooper is just really nice
I really wish I saw this last weekend before removing the center diff, this wouldve made me alot more comfortable with it, great write up though. Its nice to actually see whats going on in there.
White 2006 MS6 GT - Custom Intake - Straight Exhaust - Slotted Rotors - Hawk Pads - TurboXS Hybrid Valve - Cobb AP - Fidanza Lightweight Flywheel
Nator TN/KY
iCooper is offline   Reply With Quote
 Old 03-23-2016, 05:18 PM   #17
calinflorinalexandru's Avatar
Posts: 90   (View Stats)
calinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud ofcalinflorinalexandru has much to be proud of
Groaned at 32 Times in 15 Posts
For sure those pieces are the tabs from the "taper ring". The Miata guys faced same problem with Tochigi Fuji diffs. Me also I found a piece like that when I changed my rear diff oil. In 1 month I'll be at home and I will brea apart the diff. I have a spare one waiting to be fitted. Here you have the link with plenty information
http://www.mx5oc.co.uk/forum/yaf_pos...-from-diff.asp
Another thread from Australia fellows
http://www.ozmpsclub.com/forum/drive...nging-oil.html
Silver Mazda 6 MPS /Built Engine/ GramLights 57xtreme 18x8.5 et45 \ Vredestein Ultrac Vorti 225x40R18
calinflorinalexandru is offline   Reply With Quote
 Old 04-14-2016, 04:59 AM   #18
Cdnspeed6's Avatar
Posts: 139   (View Stats)
Cdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond reputeCdnspeed6 has a reputation beyond repute
Groaned at 4 Times in 2 Posts
Great post! I thought we had a torsen rear diff but always suspected it to be a plate diff, esp with how tail happy these cars can be (if you have enough power and skinny tires lol)
there is No pump in the clutch pack? is it just a direct solenoid to control the lock up?
It'd be handy to run a diff cooler in the rear, the plate coupling and the plate diff would really cook fluid on the track, speaking of which I should go change my rear diff fluid now.. lol
2007 Speed6- Cp-e RMM, M2 Downpipe, BNRS3V2, HKS SSQV
CS FMIC, CS TIP, CS SRI, CS HPFP, H&R coilovers
Cdnspeed6 is offline   Reply With Quote
 Old 04-14-2016, 07:55 AM   #19
KevinK2's Avatar
I think clutch pack LSD's like this and the Torson and Quaif gear type work based on friction, so at a road course with many turns you really cook the lsd oil, as well as the stinky coupling oil. With the RX7 I tracked, the torsen rear diff oil would turn black from heat after a few sessions, while the trans oil looked new. I always changed the diff oil once or twice a year. Also changed the trans oil after a couple seasons, and shifting felt better. I suspect the trans oil sheared down over time, but did not overheat.
If you hit the overheat switch, the coupling will de-couple for the rear in the MS6, and revert to FWD. I think oil changes will do, unless you hit the temp switch often.
Thanks to OP for excellent thread.
From Delaware
 Old 04-14-2016, 08:12 AM   #20
Eth Fiend
phate's Avatar
For some reason, I remembered @Tomas; talking about cucumbers in reference to his diff...
Dildo Blitz
-06 MS6
Tomas (04-14-2016)
 Old 04-14-2016, 08:41 AM   #21
Cdnspeed6's Avatar
Torsen and Quaife are the same style of diff, they don't cook oil like Clutch packs do. but there is always a ton of load in the rear diffs so its not an easy life for fluid either way lol
the Clutch pack diffs work on Load the more load there is the more lock up you get. where as a torsen will transfer power to another wheel based on load, its hard to explain but a Clutch pack diff is definitely a better unit in almost every performance way
 Old 04-14-2016, 10:39 AM   #22
KevinK2's Avatar
You are correct about Torsen's transferring power based on load, but it's more of a lack of load.
My experience was the gear type also creates a ton of heat. The way they experience lock-up has to do with worm gears on the axle ends that can't be driven by the outer spur gears, which locks both wheels up when one side is on a loose surface. In this case as well as with a fully locked up clutch type diff, no heat is generated as there is no slippage.
The heat generation in both occurs when on the gas in a corner and wheels are spinning at different speeds. The heat source with the clutch type is obvious. With a Torsen, the video shows power being transferred through the outer gears. Those gears are body fit in the metal center section, with NO bearings. The mesh separating forces, and the axial thrust load are resisted by frictional contact between the outer gear and the metal housing that captures it. With the big worm gears on the axle ends, the thrust load is taken by relatively stationary metal surfaces with friction.
This video is an excellent, simple explanation of a Torsen:
Torsen Video
I've seen the equations explaining all this, and at the beginning you have a coefficient of friction for these sliding metal contacts. Using this, I cured a problem I had with the Torsen locking-up too quickly on wet roads, trying to cause a spin-out. I simply added an extra small bottle of friction modifier, that decreased the friction, and was much better on wet roads, but still ok on the track.
From Delaware
 Old 04-14-2016, 12:35 PM   #23
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
The rear diff on the MS6 is a cone clutch type with tapered/cone gears. Same as the front MS3 lsd. The whole carrier assembly on the MS6 is made of awesome sauce. It is probably the most bullet proof component on the car together with engine block structural stiffness and will probably never overheat unless you run it at the 24 hrs of Le Mans or something.
LSD Swap out
The Following 6 Users Say Thank You to Tomas For This Useful Post:
Cdnspeed6 (04-15-2016), Code Monkey (04-17-2016), KevinK2 (04-14-2016), Mazdazilla6 (10-09-2016), phate (04-14-2016), WetzMS3 (04-14-2016)
 Old 04-14-2016, 02:50 PM   #24
KevinK2's Avatar
Originally Posted by Tomas View Post
The rear diff on the MS6 is a cone clutch type with tapered/cone gears......
Thanks for the correction, I assumed the OP who appeared to have taken one apart was correct. You have lots of great input on the OEM rear LSD, which is clearly identified as a cone type in the MS6 "Training manual" sticky.
Doe you think it can lock up completely, thanks to the shallow cone taper (not quite a Morse tool taper) ?
Some of your test temperatures from your post that Phate linked above:
1. Engine oil: Temps stabilize at around 240F to 250F during track work. The large oil cooler helps a lot.
2. Transfer case: I was surprised how fast the oil in the transfer case rises to temp and stays there. It rises almost as fast as engine oil temps and much faster than transmission temp. It will climb to about 190F during regular highway driving and stay around that temp. During track work it goes up to about 250 and stays there.
3. Transmission: Temps in the tranny rise very slowly but they also take a long time to come down once hot. Highway cruising stays at around 190F and during track work they will go as high as 260F. I would have thought the tranny on the 6 would run cooler than the 3 due to the lack of an LSD but that does not seem to be the case.
4. Rear diff: Very pleasant surprise here! This thing runs cool as a cucumber. It barely goes above 140F when cruising and at the track it never hit more than about 190F after lots of punishment. I am confident that thing will never need additional fluid cooling even at higher levels of power.
From Delaware
 Old 04-17-2016, 07:01 PM   #25
Bob Ross Fanclub
Tomas's Avatar
Yes, I think it can lock up completely.
KevinK2 (04-17-2016)
 Old 07-24-2018, 06:07 AM   #26
Eth Fiend
phate's Avatar
Differential breakdown pictures attached. That was the only thing missing from this thread.
driver-wsh likes this.
-06 MS6
Code Monkey (07-24-2018), Db09ms3 (07-27-2018), driver-wsh (10-11-2018), monkey.bones.007 (07-24-2018), Thor Hammer (07-24-2018), Tomas (07-27-2018)
 Old 07-27-2018, 11:19 AM   #27
Bob Ross Fanclub
Tomas's Avatar
Is there something wrong with it?
 Old 07-27-2018, 11:21 AM   #28
Eth Fiend
phate's Avatar
Nope, just a spare I have lying in the garage.
-06 MS6
 Old 07-27-2018, 11:31 AM   #29
Bob Ross Fanclub
Tomas's Avatar
You playin doctor with the diff? She shows you hers you show her yours?
 Old 07-27-2018, 11:35 AM   #30
Eth Fiend
phate's Avatar
Nah, just wanted something to do other than fix the car. I hadn't seen one of these taken apart, so it was a few minute job to tear this down.
The stock rear diff works great in the 6, really. No need to modify, as of now.
-06 MS6
 Old 07-30-2018, 11:50 AM   #31
Bob Ross Fanclub
Tomas's Avatar
I have heard it is the same unit as the RX8s use.
 Old 07-30-2018, 11:51 AM   #32
Eth Fiend
phate's Avatar
I've heard the same, but no confirmation.
-06 MS6
 Old 07-30-2018, 09:15 PM   #33
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Since you're bored between races...
Ponder on this:
My diff coupler occasionally "sticks" engaged. Usually after a hard pull in 1st or 2nd gear. Sometimes it's stuck for several days.
3, 2, 1, GO!
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f106/our-rear-diff-164822/
Metal Pieces From Rear Case - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 11-10-2015 05:54 AM
Rear diff locks while turning after SURE diff mount and brace install wettoast MazdaSpeed 6 - Engine, Transmission & Driveline 47 11-04-2018 04:50 PM
Rear diff mount and rear sway bar bcmps MazdaSpeed 6 - Engine, Transmission & Driveline 16 03-25-2014 06:33 PM
Rear diff module fail takes out the rear diff coupling 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 7 10-24-2011 11:19 PM
rear diff "stiff diff" brace vs. rear diff front mount giordanos4 MazdaSpeed 6 - Engine, Transmission & Driveline 18 03-03-2011 08:38 AM
Page generated in 0.58394 seconds with 31 queries
