  • 1 Post By vbt101
 Old 01-17-2010, 06:57 PM   #1
vbt101's Avatar
Posts: 733   (View Stats)
vbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the worldvbt101 is the leader of the world
Default Oxygen sensor replacement
I need to replace the primary O2 sensor on my MS3. Does anyone know the cheapest place to get this part?
vbt101 is offline   Reply With Quote
The Following User Says Thank You to vbt101 For This Useful Post:
LoganSF (09-22-2016)
 Old 01-17-2010, 07:01 PM   #2
SSinstaller's Avatar
Posts: 3,981   (View Stats)
Groans: 60
Your local dealer will probably match any online price you find.. You just have to ask them too..
Soon to be installed:
 Old 01-17-2010, 07:47 PM   #3
vbt101's Avatar
Thanks. I didn't realize there were aftermarket alternatives for our wideband O2s.
Looks like it'll cost around $150 new.
Bosch Front Oxygen Sensor
Does this seem right? I thought these sensors were in the $300 range.
Emp_ms6 likes this.
 Old 01-17-2010, 08:10 PM   #4
Groans: 60
They were, for the first year or two. I ordered a replacement when I did my first downpipe in 06 and it was about $390..
 Old 01-21-2010, 09:58 PM   #5
vbt101's Avatar
Okay, I'm confused...
Check out the following image:
http://i189.photobucket.com/albums/z...25/zacscar.jpg
The one with the 2 connectors, that's primary O2 sensor, correct? I hope so, because that's how I have mine hooked up. But, now, I bought a replacement one, and it looks like the one with one connector.
After-cat O2 sensor (secondary): Bosch Oxygen Sensor
Pre-cat O2 sensor (the one I bought, primary):
I think I switched my primary and secondary when I installed my DP. Can someone confirm?
 Old 01-21-2010, 10:12 PM   #6
OMGWTFHAX's Avatar
Posts: 445   (View Stats)
OMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the world
Groaned at 26 Times in 25 Posts
What kind of CELs do you have?
Flickr
Originally Posted by Andrew85 View Post
Wow kid... how about LOL @ you for being a piece of garbage without a purpose in life. For one thing, im not really bragging, just sharing an experience. Another thing is that you like men and your opinions dont count cause you take it up the poop shute.
OMGWTFHAX is offline   Reply With Quote
 Old 01-21-2010, 10:16 PM   #7
vbt101's Avatar
Lean at idle. I forget the code #. (which I think is caused by my SB.)
The CEL wasn't the reason that I picked up the new sensor. It's because I stripped the threads, and after rethreading the sensor enough times, it keeps popping out with any real spirited driving.
 Old 01-21-2010, 10:21 PM   #8
OMGWTFHAX's Avatar
Well the secondary 02 has one connector, and I believe the primary has two connectors. You might want to double check your part numbers.
Flickr
 Old 01-21-2010, 10:24 PM   #9
vbt101's Avatar
Can anyone verify? All the primary sensor pics I'm finding on the web are indicating the primary has 2 connectors.
edit: 1 connector*
 Old 01-21-2010, 10:26 PM   #10
OMGWTFHAX's Avatar
I just replaced the secondary last week and there was only one connector. I 99% sure the primary has two connectors.
Flickr
The Following User Says Thank You to OMGWTFHAX For This Useful Post:
vbt101 (01-21-2010)
 Old 01-21-2010, 10:30 PM   #11
vbt101's Avatar
Sweet. So, now I just need to figure out which of those sensors I actually need. The Bosch that I got says wideband a/f sensor on the box, too. So, now I don't know how to get the right sensor, short of spending 2x at the stealership
Proof of what you're saying about the second O2 sensor.
How to cure Cel/Mil from removing cat with Non-Fouler - Mazda Forums
Last edited by vbt101; 01-21-2010 at 10:35 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-22-2010, 06:08 AM   #12
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
Its probably just generic pictures. the primary has 2, the secondary has one.
heres an OEM one for $145:
Online Mazda Parts --- part number search: L33X188G1C
The Following User Says Thank You to socks For This Useful Post:
OMGWTFHAX (01-22-2010)
 Old 01-22-2010, 06:16 AM   #13
OMGWTFHAX's Avatar
Damn socks with the save. Im definitely remembering this thread in case my primary goes out.
Flickr
 Old 01-27-2010, 04:12 PM   #14
vbt101's Avatar
So, the O2 sensor that that company has listed as primary is in fact the wrong one. I ended up taking the suggestion of calling my local dealership and getting them to beat the online price. It ended up being $148 w/ tax...and I didn't have to wait for shipping.
 Old 03-21-2014, 10:39 PM   #15
TheBunk's Avatar
Posts: 18   (View Stats)
TheBunk will become famous soon enough
Groaned at 3 Times in 1 Post
Sorry to bump a super old thread, but if this works, it could save a lot if people $$
BOSCH O2 Oxygen Sensor Mazda 3 Mazdaspeed 2.3L w/ UNIVERSAL WIRING to 1-4-wire sensor:Amazon:AutomotiveBOSCH O2 Oxygen Sensor Mazda 3 Mazdaspeed 2.3L w/ UNIVERSAL WIRING to 1-4-wire sensor:Amazon:Automotive
It's $60 shipped...
2007 Mazdaspeed 3 Cosmic Blue
HPS CAI | SURE Turbo Inlet | CX Racing FMIC | Borla Catback | Cobb AP V3 | M2 DP | CP-E HPFP | Greddy Type RS BPV | SURE RMM | CS Springs/Struts | H&R Springs | TSW Donington 18s | NGK IX Iridium | JBR SSP and Bushings | SURE AGS 621g Knob | Yellow Lamin-X fog covers | MPT Dyno Tune with E85 | SURE OCC | AEM Meth Kit | Painted Roof, Grill, Front/Rear Bumpers, Scrape Pads, Side Mirrors, Calipers |
TheBunk is offline   Reply With Quote
 Old 04-01-2014, 02:13 PM   #16
YEAHRIGHTXXX's Avatar
Posts: 10   (View Stats)
YEAHRIGHTXXX has a spectacular aura aboutYEAHRIGHTXXX has a spectacular aura aboutYEAHRIGHTXXX has a spectacular aura about
It's $60 shipped...
That's gonna work for the second o2 but for the primary o2 it seems theres no aftermarket way to go with can someone correct me if im wrong?Cauze I will do my dp this week end and im probably gonna end up buying a new o2. thx
Mazdaspeed 3 2013 BM (AP v2,Sure SRI/TIH,Autotech HPFP,Corksport TMIC,corksport dp,corksport cbe,Forge v2 BPV,Corksport SSP/Bushing,CP-E RMM,UR strut tower bar,Tanabe Under brace,corksport rear sway bar,XXR 527 8.75 +35,swift spring,corksport mud flap,jdm goodies rain guard,JBR heavy shift knob,redline hood strut,Yellow del DRL 6000k.)
YEAHRIGHTXXX is offline   Reply With Quote
 Old 04-01-2014, 02:57 PM   #17
SJP0tato's Avatar
Posts: 322   (View Stats)
SJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the worldSJP0tato is the leader of the world
You're wrong: NTK 24354
Previous post:
aftermarket o2 sensors
Part:
Amazon.com: NTK (24354) Air/Fuel Ratio Sensor: AutomotiveAmazon.com: NTK (24354) Air/Fuel Ratio Sensor: Automotive
SJP0tato is offline   Reply With Quote
The Following User Says Thank You to SJP0tato For This Useful Post:
YEAHRIGHTXXX (04-01-2014)
 Old 07-01-2016, 07:14 PM   #18
Worbit's Avatar
Posts: 2,552   (View Stats)
Groans: 142
*bump*
Has anyone bought the sensors that SJP0tato and TheBunk posted? How were the results after install?
Zoom-Zoom-Coons on 05/10/16
BUILT BY CORKSPORT
 Old 07-03-2016, 07:30 AM   #19
rob ms6gt's Avatar
Posts: 416   (View Stats)
rob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the world
Groaned at 11 Times in 2 Posts
Originally Posted by Worbit View Post
*bump*
I used the NTK 24354. It fits and works perfectly.
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline   Reply With Quote
 Old 10-28-2016, 01:08 PM   #20
Lex2007's Avatar
Posts: 568   (View Stats)
Anyone know that size the threads and diameter on the upstream O2 sensor is?
Reason I ask is because I had to remove mine and the O2 sensor threads got totally destroyed in the process and left some metal inside the cast iron downpipe threads. I wanted to chase the threads with a tap. I know they are 1.5 thread pitch or count (?) but I dont know what the diameter is. According to my micrometer the diameter is ~17.5mm around the O2 sensor threads. I have an 18mm 1.5 pitch tap but it seems too big. 16mm tap is way small. 17mm tap is not common size.
 Old 10-28-2016, 11:03 PM   #21
frothy's Avatar
Posts: 1,067   (View Stats)
M18 x 1.5mm, it's pretty much a set standard.
 Old 11-28-2016, 10:36 PM   #22
Allaboutthesnail3's Avatar
Posts: 29   (View Stats)
Allaboutthesnail3 is on a distinguished road
Default The upstream O2 sensor
I wanna know if this O2 sensor has ever fixed the P2187 Lean at idle code... currently having trouble with this code and I've checked all other things like vacuum, ignition, fuel delivery..
Allaboutthesnail3 is offline   Reply With Quote
 Old 11-28-2016, 10:49 PM   #23
Varomnia's Avatar
Posts: 459   (View Stats)
Varomnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the worldVaromnia is the leader of the world
Yeah if you have bad sensors it might. I had to get a etune to get my code to go away.
ETS TMIC, Cobb TBE, Intake, TIP, AT Internals, JBR trilogy mounts, EBCS, EGR Delete/blockoff, Bosch 3.5 MAP Bar sensor, Stripped interior #racecar
Varomnia is offline   Reply With Quote
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 02:30 PM
Does Ethanol Affect Fuel Economy, Replacing An Oxygen Sensor, How Plug-in Vehicles Work, Preventing Moisture Inside Wind Haltech Automotive News 0 02-18-2009 10:30 AM
Oh how I hate oxygen sensors... Averia MazdaSpeed 3 - Engine, Transmission & Driveline 4 06-13-2008 04:54 PM
Page generated in 0.44612 seconds with 32 queries
