 Old 12-07-2012, 06:21 AM   #1
Dizzy Turbo's Avatar
Posts: 2,173   (View Stats)
Dizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the worldDizzy Turbo is the leader of the world
Default Random misfires after compression test
So I did a compression test and the results were 185-180-185-185. After buttoning everything back up the car misfires. My ap is currently at Cobb, but the cel flashes which I believe means random cyl misfire. I am going to double check everything when I get back home, but does anyone have an idea to what my problem is? Car is an 06 speed6 with 56k on the stock plugs. The tips were white which I believe is normal. Thanks for any input
Dizzy Turbo is offline   Reply With Quote
 Old 12-07-2012, 06:25 AM   #2
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
Messed up or forgot to plug a coil back in? Messed up a plug reinstalling?
Sent from my balls via my penis
The Following User Says Thank You to G26 For This Useful Post:
Chimmike (12-07-2012)
 Old 12-07-2012, 08:04 AM   #3
That's what I'm hoping haha I'll get to check in like 2 hours
 Old 12-07-2012, 08:52 AM   #4
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
^^^^^^^that^^^^^^^
340hp / 371tq
G26 (12-07-2012), speedms6 (12-09-2012)
 Old 12-07-2012, 12:04 PM   #5
Yup, ordered ngk, picking them up tomorrow and seeing if that solves it.
 Old 12-07-2012, 12:05 PM   #6
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
why wouldn't you go back and inspect the plugs and coils first before posting this? Shouldn't it be obvious that it's a 99% chance related to what you fucked with?
07 MS3
The original Genpoo Hater
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
Keko (12-07-2012), Nitr0EngiE (12-07-2012), uncorked11 (12-07-2012)
 Old 12-07-2012, 12:33 PM   #7
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
it has to be a coil pack or spark plug failure or installed wrong lol
 Old 12-07-2012, 12:50 PM   #8
I wouldn't have been hone for hours and it was on my mind. I'll keep it to myself next time..
The Following User Says Thank You to Dizzy Turbo For This Useful Post:
jm211 (12-09-2012)
 Old 12-09-2012, 05:25 PM   #9
jm211's Avatar
Posts: 943   (View Stats)
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
Groans: 52
Good.
"jk"!
Black Mica 2006 Speed6 GT | 62,000 Miles
Cobb AP | Stratified Tune Stage 1 OTS | JBR Stage II Intake | cp-e 3'' Straight Exhaust | JBR RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Redline Fluids | Shell T6 | Forge V1
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
Compression test Dahouse702 MazdaSpeed 3 - Engine, Transmission & Driveline 44 10-30-2018 07:22 PM
Not so good compression test paulwalll MazdaSpeed 3 - Engine, Transmission & Driveline 39 11-25-2015 01:11 PM
can u perform a compression test while engine is out of car aviator79 MazdaSpeed 3 - Engine, Transmission & Driveline 20 06-17-2014 08:16 PM
P0300 Random / Multiple Cylinder Misfires txmedic83 CX-7 > Issues & Troubleshooting 9 08-13-2013 12:45 PM
Compression test done.. SharkDiver MazdaSpeed 3 - Engine, Transmission & Driveline 3 03-25-2009 03:28 PM
Page generated in 0.34976 seconds with 25 queries
