 Old 03-12-2019, 05:22 PM   #1
Izapyou's Avatar
Posts: 40   (View Stats)
Izapyou has a spectacular aura aboutIzapyou has a spectacular aura about
Default Rear CV Boots (Aftermarket Replacement Options)
Just in case I have to rebuild my axles does anyone know where to get new cv boots minus the dealer. If so can you please leave the part #'s. Thanks
Izapyou is offline   Reply With Quote
 Old 03-12-2019, 06:06 PM   #2
NEED MORE FASTS
SyntheticAtmosphere's Avatar
Posts: 179   (View Stats)
SyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond reputeSyntheticAtmosphere has a reputation beyond repute
Many of the aftermarket rear inner boot options might interfere slightly with the rubber for the swaybar frame mount. The shape of the inner used by the factory only had a couple of folds/ribs with a flat section to clear the swaybar bushings. I think the aftermarket commonly are only concerned with the cup and shaft diameters and assume the boots will clear other components.
SyntheticAtmosphere
'06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP&trans mount insert, Forge v1, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit
If it feels good, do it...Even if you shouldn't!
SyntheticAtmosphere is offline   Reply With Quote
 Old 03-12-2019, 07:03 PM   #3
Izapyou's Avatar
Damn so no go on the inner then? What about the outers?
 Old 03-13-2019, 06:51 PM   #4
NEED MORE FASTS
I believe the outters can be had aftermarket without issue.
I have an aftermarket boot on my left inner cup. The shaft was rebuilt and the tech used standard looking boots found on most other CVs. When I installed the shaft I took a hacksaw blade and had to remove a small amount of the rubber that sticks out from under the swaybar frame bushing. Although they werent in contact at the time, it was close enough if the boot were to expand from centrifugal force or the shaft changing angle from suspension movement. I however have not had any issues with the modification to the bushing. Probably will never be a problem, I just dont like hack substitutions.
SyntheticAtmosphere
Aftermarket Headlight Options Klapamos MazdaSpeed 3/6 - Appearance 0 06-16-2017 07:48 PM
MS6, Any aftermarket TB options? Knight F Mohawk Mazdaspeed3/6 General Discussion 2 10-19-2014 06:32 PM
Clutch replacement options seanmiller09 MazdaSpeed 3 - Engine, Transmission & Driveline 9 04-20-2014 12:58 PM
replacing rear halfshaft and cv boots mlamp89 MazdaSpeed 6 - Engine, Transmission & Driveline 2 06-06-2012 05:25 PM
Rear O2 Sensor Replacement Options DarkPasseng3r Gen2 MS3 General Discussion 0 02-06-2012 01:22 PM
Page generated in 0.24935 seconds with 21 queries
