Notices
 Old 10-20-2012, 07:46 PM   #1
speed23's Avatar
Posts: 956   (View Stats)
Default Revised clutch pedal for speed6
So there's a TSB for the shitty clutch engagement on the speed6, which replaces the pedal, and the clutch. Has anyone swapped only the revised clutch pedal and not the rest of the clutch assembly? Was there a significant improvement?
My warranty is expired, so I cant afford to replace all parts, but I figure the revised clutch pedal would go a long way to improving clutch action. I am I correct?
Thanks.
speed23 is online now   Reply With Quote
 Old 10-21-2012, 08:12 AM   #2
jm211's Avatar
Posts: 303   (View Stats)
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
mmhm, I wasn't aware of a replacement clutch pedal assembly -- only the adjustment to level out the spring tension.
have you a link?
Black Mica 2006 Speed6 GT | 57,000 Miles
Cobb AP | Stratified Tune | JBR Stage II Intake | cp-e 3'' Straight Exhaust | cp-e RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Amsoil Fluids | NKG Step 1 | Autotech Internals | Shell T6 Juice
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
 Old 10-21-2012, 09:00 AM   #3
speed23's Avatar
Yes, its quite old. Here's the tsb.
 Old 10-21-2012, 09:40 AM   #4
cnyms6's Avatar
Posts: 18   (View Stats)
cnyms6 has a spectacular aura aboutcnyms6 has a spectacular aura about
never saw this before, but all you need to do is the clutch pedal adjustment elsewhere on this site. a 10 minute job, no parts required, completely changes the way the pedal feels and engages
cnyms6 is offline   Reply With Quote
The Following User Says Thank You to cnyms6 For This Useful Post:
BigjohnB20 (10-24-2012)
 Old 10-21-2012, 10:35 AM   #5
Speeeeeed
06Speed6's Avatar
Posts: 5,758   (View Stats)
I dont know of anyone who actually got this, there are too many other options that dont require ripping the dash out.
2006 Mazdaspeed 6
P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant
06Speed6 is online now   Reply With Quote
 Old 10-21-2012, 11:37 AM   #6
jm211's Avatar
mmhm interesting! I am type A, build number 5774.
Even by adjusting it seems that the total problem couldnt be fixed? I mean why would Mazda say lets replace the entire thing if moving a couple nuts and bolts around could fix the problem.
In what time frame was the simple adjustment TSB released in relation to this 7.5 hour overhaul?
 Old 10-21-2012, 12:36 PM   #7
speed23's Avatar
I have done the clutch adjustment and it helped, but I am still looking for improvement (especially if it only costs $200 or so for a pedal). I am assuming the replacement clutch pedal has even pressure throughout the motion....unlike the uneven, soft then suddenly hard pedal feel of the first one.....
I am I misunderstanding or are you saying that you have to rip out the dash to replace the clutch pedal? looks like mazda quotes less than an hour to replace the pedal.
 Old 10-21-2012, 01:46 PM   #8
jm211's Avatar
mmhmm.
how difficult to just change the pedal? I would think about 2.5 hours?
Im assuming this replaces the spring as well?
Do you have a linky or part # for the entire assembly?
 Old 10-21-2012, 01:57 PM   #9
SSinstaller's Avatar
Posts: 3,619   (View Stats)
Groans: 46
Groaned at 16 Times in 11 Posts
I actually had the entire TSB done. The original setup had a really unpredictable engagement.
It was bad enough that the dealership service manager couldn't get my car out of the parking space when I took it in for them in inspect it. He agreed to do the TSB on the spot...
IIRC my car has a July 05 build date.
06Speed6 (10-22-2012)
 Old 10-21-2012, 04:01 PM   #10
speed23's Avatar
Originally Posted by jm211 View Post
mmhmm.
On the TSB, the pedal part number is GP4L-41-300A.
I am assuming that if mazda pays 7.2 hours to replace the pedal and clutch and only 6.5 to replace the clutch only, then the pedal replacement would be worth .7 hours?
SSinstaller: I have the same problem, had my windshield fixed yesterday and the guy could barely drive the car into the shop...LOL.
Did you find the pedal much better? I know its hard to tell with the other stuff fixed also.....
The Following User Says Thank You to speed23 For This Useful Post:
jm211 (10-22-2012)
 Old 10-21-2012, 07:01 PM   #11
Groans: 46
I'm sure there is a some benifit to the pedal assembly replacement, but the majority of the improvement is most likely due to the revised pressure plate assembly..
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
jm211 (10-22-2012), speed23 (10-21-2012)
 Old 10-22-2012, 04:41 AM   #12
jm211's Avatar
I have a feeling I still have the stock assembly, in total.
Does this PP have any early wear issues? I've noticed i have been having an intermittent pulsating clutch. (comes and goes. IF it is doing it and i pump the clutch it goes away)
I think i can safely assume PP fingers aren't playing nice with the TOB.
 Old 10-22-2012, 06:26 AM   #13
RWDAddict's Avatar
Posts: 260   (View Stats)
RWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the world
I've done that TSB, my assembly was broken in 2-3 places, it was barely holding on. Took 40k on an ACT HD+ PP though. You can tell if you need one if your clutch pedal jiggles more than half an inch left or right. When I put my new one in it was super solid in place.
06 MazdaSpeed6 GT w/Nav. Mods so far: Cobb SRI, RMM, HPFP, ATP 3" catted DP, ETS CBE, Synchronic BOV, AP, CP-E TMIC, SURE TIP, HKS Twin Power, Poly trans mount, PTP fuel injector seals, PCV Fix
RWDAddict is offline   Reply With Quote
 Old 10-22-2012, 11:44 AM   #14
speed23's Avatar
Good to know, thanks!
 Old 10-22-2012, 11:54 AM   #15
2.3speed06's Avatar
Posts: 647   (View Stats)
2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world2.3speed06 is the leader of the world
How many miles on your car can you ha e till they won't fix it?
2006 Black Cherry Mica Mazdaspeed 6 GT
Cobb AP 50/50 FREEKTune/Cobb 3port EBCS/C-PE Nano Intake/C-PE TIP/C-PE TMIC/HKS SQ3 BOV/Auto Tech HPFP/M2 Full Length DP/Custom CB/Denso ITV 22's/Sure RMM/Sure SSP/Sure Shifter Bushings/Custom EGR Kit/TB&IM TIG/MD Stage2 OCC/Stoptech Blanks/EBC Red/Techna-Fit SS Brake Lines/
2.3speed06 is offline   Reply With Quote
 Old 10-24-2012, 06:04 AM   #16
RWDAddict's Avatar
Not sure, I assumed I was out of coverage, I had nearly 100k on my car, figured they wouldn't cover it.
How To: Clutch Pedal Adjustment bova MazdaSpeed 6 - How-To's 11 08-13-2012 02:52 AM
Clutch Pedal Adjustment? 08 MS3 Bulgdoom MazdaSpeed 3 - Engine, Transmission & Driveline 2 01-02-2012 02:52 PM
Clutch Pedal Stop banzairx7 MazdaSpeed 6 - Engine, Transmission & Driveline 2 03-21-2010 04:56 PM
Clutch pedal vibration Overboost3 MazdaSpeed 3 - Engine, Transmission & Driveline 59 04-13-2009 01:48 AM
Clutch pedal to floor. Darksun280 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 11 06-10-2008 07:14 AM
Page generated in 0.39531 seconds with 27 queries
