 Old 01-25-2011, 02:58 AM   #1
Circas313's Avatar
Posts: 4   (View Stats)
Circas313 will become famous soon enough
Default Rough shifting & Slipping Transmission?
So, i just bought my 06' ms6, high mileage unfortunatly, its got 110k...but ive been living in alaska for a year now and it was only the second one id seen for sale up here. I luckily got it pretty cheap. Anyways, it shifts into second kinda rough...nothing horrible and nothing grinds, but its just not as smooth as the rest of the gears, also...every once in a blue moon when im giving it some gas in 5th or 6th gear, especially if im going up hill it seems like it will just lose all power to the wheels for a split second...im not sure what this is, so i was hoping someone could enlighten me. Thanks...
Circas313 is offline   Reply With Quote
 Old 01-25-2011, 03:25 AM   #2
spike589's Avatar
Posts: 295   (View Stats)
spike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond reputespike589 has a reputation beyond repute
Groaned at 6 Times in 3 Posts
hey is this king and donate.
Corksport 3in catback resonator removed, Turbo XS catless downpipe, Cobb AP Stage 2 ots map, COBB SRI, RPMC inlet, Ported/ Rebuilt Ko4, ported exhaust manifold, ported and ects delete, JBR EGR delete, JBarone passenger, rear and tranny mount, JBarone SSP/ knob/ bushings,DDM HID low/high/fogs, Snow performance stage 2 MAF meth kit, Matt Damond OCC and check valve, Tenzo Concept-9 wheels, Turbosmart 50/50, Denso ITV-22, Tinted tailights-reflectors-corners, prosport boost gauge, DIY FMIC, Carbon hood wrap, NRG shorty antenna
spike589 is offline   Reply With Quote
 Old 01-25-2011, 03:39 AM   #3
speedtoz's Avatar
Posts: 453   (View Stats)
speedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the worldspeedtoz is the leader of the world
welcome to msf. enjoy your stay.
oh and donate
^^^My fail boats^^^
2006 mazdaspeed 6: fujita CAI, PG TIP, Turbosmart dual BOV, ITV22, Corksprt TBE, Cobb AP, SURE front/rear diff mounts(FTW), whiteline RSB
1978 280z(s30): currently needs some love....and going turbo o.0
1990 300zx: 850cc injectors, 300degree fuel rail, aeromotive FPR, garrett gt 28's twin turbo upgrade(@19psi), stillen IC's, CZP's 3in dp and mid pipe, Selin dual intakes, GTR R32 brakes, Nismo clutch, HKS hi-power exhaust, megan coil-overs, SPL full titanium suspension parts, z1 boost tubes, 2 AEM AFR's, AEM boost guage
RWHP:???? RWTRQ: 475@4500 rpm. needs new clutch(blown).
2008 350z HR: Greddy dual Ti-C, Carbonetics LSD, Nismo diff, GTM TP's, Stillen CAI's
(waiting on full metal CSC and carbonetic clutch and light wieght flywheel, then it's TT time!) currently on hold due to needing new clutch and flywheel/metal csc and master. wanting skyline manifold.
speedtoz is offline   Reply With Quote
 Old 01-25-2011, 06:28 AM   #4
Circas313's Avatar
shouldnt both you guys be working?
 Old 01-25-2011, 06:40 AM   #5
Speed13's Avatar
Posts: 497   (View Stats)
Speed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the worldSpeed13 is the leader of the world
going uphill in 5or6th? at what rpms? u might wanna drop a gear, go into 4th and then go up your hill. dont wanna blow your engine. also think about changing transmission fluid, sometimes that makes a difference
2006 Mazdaspeed6 Black Mica GT w/ Navi ~34k miles Sold
2008 Mazdaspeed3 Black Mica GT~55k miles
NATOR PA IS NUMERO UNO
Speed13 is offline   Reply With Quote
 Old 01-25-2011, 09:39 AM   #6
speedtoz's Avatar
This is my job
^^^My fail boats^^^
 Old 01-25-2011, 09:44 AM   #7
oh10speed3's Avatar
Posts: 1,119   (View Stats)
oh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the worldoh10speed3 is the leader of the world
Groaned at 74 Times in 30 Posts
This.
Drop a gear for sure. How cold is it in Alaska?
Sent from my Droid using Tapatalk
//Stage 1 & Done\\
oh10speed3 is offline   Reply With Quote
 Old 01-25-2011, 11:19 AM   #8
spike589's Avatar
Its about 22 degrees
 Old 01-25-2011, 03:57 PM   #9
Speeeeeed
06Speed6's Avatar
Posts: 6,526   (View Stats)
The stumble in 5th and 6th is prolly fuel cut. You need an upgraded fuel pump.
The 2nd gear thing is prolly the syncro. Do a search for motorcraft trans fluid on here and order some and swap it in. It might make it better and it might make that syncro last longer. That trans fluid is made by Castrol in Germany for Ford for use in certain very difficult to shift Getrag transmissions, we dont have a Getrag transmission, but its fine. Also its pricy but it works very well and will likely last forever in a street driven car.
2006 Mazdaspeed 6
I<3Groceries (01-25-2011), paveltol (01-28-2011)
 Old 01-25-2011, 09:13 PM   #10
I<3Groceries's Avatar
Posts: 1,988   (View Stats)
[/THREAD] .
The Following User Says Thank You to I<3Groceries For This Useful Post:
06Speed6 (01-25-2011)
 Old 01-26-2011, 11:35 AM   #11
spike589's Avatar
He doesnt have enough parts for fuel cut to be a issue the other as far as synchro might be on point. It might also be that. U need to adjust your ahifter cable or buy some shifter bushhings since the car does have some miles on it
 Old 01-26-2011, 11:52 AM   #12
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
my MS3 is pretty new and it shifts rough into 2nd...I wouldnt worry too much.
as for 5th and 6th...its most likely your clutch is slipping, at 110k, its about time to have it changed...it makes me think its clutch even more because you say it acts up when you go up hills (turbo spools...more torque on a tall gear...more slip)
cesaros is offline   Reply With Quote
 Old 01-26-2011, 02:28 PM   #13
Speeeeeed
06Speed6's Avatar
A stock ms6, with 29* air temps, can fuel cut.
I have 114k on my 06 and the clutch is just fine, when a clutch goes out it starts to slip and the rpms jump under load. He didnt describe anything like that.
2006 Mazdaspeed 6
speedtoz (01-31-2011)
My car is acting up badly.. it has rough acceleration(hesitates)and idles rough..What can it be? HELP PLEASE!!? Jamhour MazdaSpeed 6 - Engine, Transmission & Driveline 25 06-24-2015 04:06 PM
Buick Century Rough Shifting, Splashing Oil, Resetting Computer After Tire Rotation on Cadillac Deville, DIY Plastic Bum Haltech Automotive News 0 07-10-2008 11:10 AM
Buick Century Rough Shifting, Splashing Oil, Resetting Computer After Tire Rotation on Cadillac Deville, DIY Plastic Bum Haltech Automotive News 0 06-10-2008 02:12 AM
S-Tronic Test Run: Shifting the gears of Audi's new seven-speed twin-clutch transmission Haltech Automotive News 0 03-30-2008 11:11 PM
Page generated in 0.34818 seconds with 27 queries
