 Old 06-03-2011, 08:51 PM   #1
Sal's_MS6's Avatar
Posts: 187   (View Stats)
Sal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond reputeSal's_MS6 has a reputation beyond repute
Default shaking when accelerating
would it be the u-joint or carrier bearing ( if it has 1) that could be causing the shaking? it only does it when im accelerating but when im just cruising it feels normal
Sal's_MS6 is offline   Reply With Quote
 Old 06-03-2011, 08:54 PM   #2
4G63's Avatar
Posts: 1,479   (View Stats)
4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world4G63 is the leader of the world
Groans: 123
Groaned at 157 Times in 79 Posts
Fuel pump
2003 Evo VIII
BUILD PLANS: LR 2.0/2.4, 6466, 800+whp. Shooting for 9s at full weight. Time is on my side, gonna take forever.
Old: 2009 White MS3. Fully bolted and tuned. Sold
4G63 is offline   Reply With Quote
 Old 06-04-2011, 08:14 AM   #3
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
only during WOT acceleration or even casual acceleration?
 Old 06-04-2011, 08:15 AM   #4
predapio's Avatar
Posts: 8,939   (View Stats)
Groans: 309
Can it be the differential?
What a lovable bunch we are!!
 Old 06-04-2011, 12:38 PM   #5
Sal's_MS6's Avatar
its a little while casual driving but barely noticeable
 Old 06-09-2011, 05:03 PM   #6
rob ms6gt's Avatar
Posts: 416   (View Stats)
rob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the world
Groaned at 11 Times in 2 Posts
Same problem here. I suspected the driveshaft as well. Haven't had the cash to take care of it yet but I'm gonna replace the u joints and have the DS balanced. I suspect the excessive engine/diff movement in our cars fucks up the driveshaft after a few hard launches. This is all speculation tho. Please let us know if you find anything.
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline   Reply With Quote
The Following User Says Thank You to rob ms6gt For This Useful Post:
MPSdriver (06-10-2011)
 Old 06-12-2011, 02:08 PM   #7
meh, no ideas
Jedyboyrokr's Avatar
Posts: 528   (View Stats)
Jedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the worldJedyboyrokr is the leader of the world
Groaned at 20 Times in 4 Posts
had this issue, under accel, try doing one click on your e-brake does it go away? we put the car up on the rack and ran it to about 60-75ish with the ebrake off and it looked like the rear diff to be moving all over the place...so i ordered some solid inserts from SU, but they never came in so cant confirm if that fixed it or not.....still waiting on my refund actually
89 toyota supra 1JZ Twin Turbo---Sold
2006 MS6 GT few mods ---Sold
Monaco White '13 Genesis 2.0T R-Spec-- ISIS downpipe/testpipe, Agency Power CBE, Injen SRI, Forge BOV, JBR Heavy Shift knob should be 240ish wheel right now, tune coming April 27th
Jedyboyrokr is offline   Reply With Quote
 Old 06-12-2011, 03:38 PM   #8
needforspeed6's Avatar
Posts: 59   (View Stats)
needforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond reputeneedforspeed6 has a reputation beyond repute
I have this issue as well, but I only seem to get the vibration during spirited driving. I feel the vibration mostly in the pedals after shifting into second and accelerating between 3-4k rpms. Replacing the rmm helped, but I am still getting the vibration.
07 MS6 - Cobb SRI | Cobb TIP | Corksport TMIC | SURE RMM | JBR STSP | Hypertech Tune
needforspeed6 is offline   Reply With Quote
 Old 06-12-2011, 03:42 PM   #9
jroc's Avatar
Posts: 1,482   (View Stats)
jroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the world
Groaned at 6 Times in 6 Posts
so you were going to go through all the hassle of taking off the stock mount, popping out the stock bushings, putting in new inserts, and the whole stock shitty designed mount back on? and not get an upgraded mount?
JDMFresh.com 1990 Mazda Miata
NASA Time Trials/Time Attack, Global Time Attack
A miata may be gay, but its probably faster than your car around a track. That's pretty gay.
jroc is offline   Reply With Quote
The Following 2 Users Say Thank You to jroc For This Useful Post:
Docnox (06-12-2011), rob ms6gt (06-22-2011)
 Old 06-12-2011, 03:59 PM   #10
2011speed's Avatar
Posts: 1,497   (View Stats)
2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world2011speed is the leader of the world
Had the same issue on one of my previous cars. Turns out it was the axle
2013 Velocity red Mazdaspeed 3 tech. BT
2011 Velocity red Mazdaspeed 3-SOLD.
FreeKtuned
fitty fitty
2011speed is offline   Reply With Quote
 Old 06-13-2011, 06:06 PM   #11
meh, no ideas
i had read on here in a few places of people just replacing the inserts and being fine, plus i dont abuse my car hard enough to be worried about breaking it
car shaking Fermion MazdaSpeed 3/6 - Troubleshoot/Diagnostics 19 02-02-2011 04:03 PM
shaking above 45 shawn. MazdaSpeed 3/6 - Troubleshoot/Diagnostics 7 01-25-2011 01:56 PM
Wierd Stutter/shaking in 3rd @2.5-3K BigjohnB20 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 05-21-2010 08:22 AM
shaking apart the car k0m MazdaSpeed 3 - Engine, Transmission & Driveline 22 06-03-2009 07:31 AM
Car is shaking violently above 55 6-Speed-6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 14 12-26-2008 06:23 PM
Page generated in 0.36213 seconds with 28 queries
