 Old 07-13-2010, 08:37 PM   #1
MSP611's Avatar
Posts: 2,291   (View Stats)
Default sometimes rough idle....??
sometimes and only sometimes when i drive the car hard say in the canyons or smashing the freeway or something if i throw it in neutral and let it cost the idle will bounce a little almost like a vacuum leak but when i stop and put it in first at a stop light it will cease to persist. then same thing drive away and throw it in neutral and it will bounce a lil. when im talkin a lil i mean like maybe 200rpm and its only when its hot i think. NE one have an idea?
In progress:
 Old 07-13-2010, 08:49 PM   #2
KayWhy's Avatar
Posts: 752   (View Stats)
KayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the worldKayWhy is the leader of the world
Groaned at 9 Times in 5 Posts
your moving your steering wheel. . . Don't move it and try again
KayWhy is offline   Reply With Quote
 Old 07-13-2010, 09:24 PM   #3
MSP611's Avatar
WAT DOES MOVING MY STEERING WHEEL HAVE TO DO WITH IDLE?
In progress:
 Old 07-13-2010, 09:35 PM   #4
KayWhy's Avatar
go sit in your car after you start it and move it watch what happens - not bullshitting you
 Old 07-13-2010, 09:36 PM   #5
MSP611's Avatar
ok ill try it but i dont think it was tht.
In progress:
 Old 07-13-2010, 09:44 PM   #6
snailD's Avatar
Posts: 3,037   (View Stats)
hahaha, when your using your POWER steering and other utilities that use power you need to get that energy from somewhere. so indeed when u move the steering wheel the idle will raise counteract the charge
 Old 07-13-2010, 10:05 PM   #7
KayWhy's Avatar
DAMNIT I didnt want to tell him!!!! I wanted him to come back going "MY CARS POSSESSED"
 Old 07-13-2010, 10:19 PM   #8
snailD's Avatar
oooooooooops
 Old 07-14-2010, 01:19 AM   #9
m4tic's Avatar
Posts: 4,922   (View Stats)
Sad Tuba
2007 MS6 w/ Cheez
 Old 07-14-2010, 06:36 AM   #10
KayWhy's Avatar
lol - soooooo any word ?
 Old 07-14-2010, 03:19 PM   #11
MSP611's Avatar
its not tht it does it in straight line as well...
In progress:
 Old 07-14-2010, 03:24 PM   #12
sellers's Avatar
Posts: 1,280   (View Stats)
sellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the worldsellers is the leader of the world
Groans: 546
Groaned at 125 Times in 71 Posts
Your car sucks.
sellers is offline   Reply With Quote
 Old 07-14-2010, 03:32 PM   #13
MSP611's Avatar
thx
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
sellers (07-14-2010)
Rough Idle/Acceleration wasntme MazdaSpeed 3/6 - Troubleshoot/Diagnostics 48 07-08-2010 08:05 AM
idle is alittle rough randomly after installing a OCC and bypassing TB coolant? Wenis Prinkle MazdaSpeed 3 - Engine, Transmission & Driveline 14 08-13-2009 05:10 AM
Bogging/rough idle on start up with meth? Meder MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 12 05-16-2009 10:10 AM
rough idle? tbone MazdaSpeed 3/6 - Turbo Induction 13 11-11-2008 05:10 AM
HELP - Rough idle after dp install ccs70 MazdaSpeed 3/6 - Turbo Induction 25 10-14-2008 01:40 PM
Page generated in 0.31553 seconds with 24 queries
