 Old 09-29-2009, 11:41 AM   #1
Police - Grammarhead
Vansquish's Avatar
Groans: 1,777
Groaned at 43 Times in 24 Posts
Default Stereo makes popping noise when I hit the brakes.
Here's a bit of an odd problem which I believe has to do with the EM shielding on the speakers on BOSE-equipped Mazda6 1st-gen and MS6's.
If I have the stereo on but muted and am at relatively low speed, every time I touch the brake pedal an audible "pop" seems to emanate from the sub behind the rear seats and to a lesser extent, from the speakers around the car.
I had a Mazda6 V6 Manual with the Bose system in 2004 and it had the same problem. I remember having had to take it to my dealer and have them work on it, but within a few days of receiving the car back from them, the noise began to happen again, and rather than pay through the nose to have the issue resolved, I decided to simply ignore it, as it's really only a minor annoyance.
In any case, the '06 MS6 that I just bought is having the same issue, has anyone else run into it, and if so, have you figured out how to fix it?
 Old 10-01-2009, 08:37 AM   #2
shakespeare's Avatar
Posts: 48   (View Stats)
shakespeare is a splendid one to beholdshakespeare is a splendid one to beholdshakespeare is a splendid one to beholdshakespeare is a splendid one to beholdshakespeare is a splendid one to beholdshakespeare is a splendid one to beholdshakespeare is a splendid one to behold
Hey mate, mine makes a noise similar to what you describe when I switch to key to ON prior to starting, from memory it happens when the stereo is off, I've also got the BOSE equipped MS6, hasn't really caused me too much concern, but will look into it.
shakespeare is offline   Reply With Quote
 Old 10-01-2009, 09:11 AM   #3
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Groans: 166
its not a fix, but........instead of muting, just hit the power. it takes the same amount of time and energy.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
Originally Posted by Say Chi Sin Lo View Post
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
OEM MS3 brakes = Volvo S60 brakes? levitron MazdaSpeed 3/6 - Suspension & Brakes 109 03-02-2012 06:14 PM
2009 MS3 brakes vs. 2010 MS3 brakes Driver72 2010 MS3 - Suspension & Brakes 11 11-21-2009 10:34 AM
Popping and hesitaton at wot boosted3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 05-31-2009 04:32 PM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 05:00 PM
Dodge Magnum Makes Ticking Noise, Perpetual Motion Electric Car, Fuel Vapor Enhancer, Coasting and MPG: Mike Allen's Wee Haltech Automotive News 0 08-01-2008 03:50 PM
Page generated in 0.25488 seconds with 22 queries
