 Old 11-24-2013, 11:45 PM   #1
Kiwipaulie's Avatar
Posts: 12   (View Stats)
Kiwipaulie is an unknown quantity at this point
Default Strange rattle
So i have some strange rattle coming from my engine, sounds like its coming from the top of the engine. When i turn the air con off, it doesnt make the noise.
I have had an air con guy look at it and he doesnt think its the bearing or the ac compressor.
His guess is possibly an alternator?
To me it sounds like the chain.
The strange thing is that it always does it when i start the car, then goes away and comes back. I never hear it when i drive off or am driving, only when stationary.
Any ideas???
Kiwipaulie is offline   Reply With Quote
 Old 11-25-2013, 04:19 AM   #2
Goodrich27's Avatar
Posts: 678   (View Stats)
Goodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the worldGoodrich27 is the leader of the world
My guess is bearing I've worked ac and no Part of a commercial or residential ac uses a bearing so I wouldn't trust him to dismiss that it could be a bearing. Compressor yes but not a bearing.
Sent from my phone whilst bojanglen.
Go fasters:Manley H beams and Wiseco 87.5mm Forged pistons with stock compression, GTX3076 with Tial 38mm EWG, Full Race exhaust manifold w/2000* ceramic coating, MD meth injection TB spacer and Devils Own DC30 WMI with DO14 nozzle, Cobb 3 port ebcs, Ultimate Racing V2 Catless DP, Relentless Customs PNP IM with VTCS delete, TR11 core with HTP under route piping,ACT 6 puck, Corksport catless RP and CBE, CPE Stage II RMM,Cpe side mounts, perm plate with MD sealed and VTA OCC, HTP 4in Intake,ISC N1 coilovers, CS RSB, Tial BPV, Auto tech internals, Cobb ap v3, CPE injector seals,ngk step colder plugs, JBR throttle body TIG and coolant bypass, Corksport polyurethane exhaust hangers, Motorcraft unicorn juice, t6 rotella, Stoptech slotted and drilled front rotors with posi quiet pads.
Rice:corksport led fogs, Corksport eyelids, Corksport hood struts ,blacked out genpu rims, red evil M front and rear, red calipers, Corksport black mud flaps, Corksport shift knob, powder coat red valve cover, Intercooler pipes, and black gloss intake manifold A pillar gauge mount w/ AEM AFR, Oil temp, and Oil pressure gauges.
Goodrich27 is offline   Reply With Quote
 Old 10-11-2018, 09:27 AM   #3
driver-wsh's Avatar
Posts: 18   (View Stats)
driver-wsh is a jewel in the roughdriver-wsh is a jewel in the roughdriver-wsh is a jewel in the rough
I think my a/c compressor bearing may also be failing now. Sigh.
driver-wsh is offline   Reply With Quote
What is this RATTLE!!! Crazyspeed3 Mazdaspeed3/6 General Discussion 20 04-15-2013 11:20 PM
Rattle at WOT mhebert2001 Gen2 MS3 General Discussion 4 07-29-2012 06:06 AM
rattle can!?! littlered Appearance - BLACK 14 03-27-2012 08:12 AM
Rattle expoz3d MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-16-2011 09:50 AM
Strange Rattle kingpin748 Mazdaspeed3/6 General Discussion 15 12-12-2008 07:23 AM
Page generated in 0.24105 seconds with 22 queries
