![]() | | #1 | ![]() |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() Thanks: 2
![]() Join Date: Feb 2011 Location: Colorado Springs
Rep Power: 1012 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 644
Groans: 30
you REALLY need to search. but for my good deed of the day, NEVER ACCELERATE IN 6th!!!!!!!!!!!!!!!!!!!! as for the reason it does it, i'm not sure, but maybe the guru's will chime in.
__________________ ![]() 2008.5 Metropolitan Grey Mica GTX2867r--Cobb AccessPort--CNT Racing Catted DP & Catback Exhaust--Autotech Internals--NGK 1 Step Colder--PTP Injector seals/studs--Sure TIG (Intake Mani)--HTP 3" intake--Grimspeed EBCS--JBR OCC (V2)--TWM STS/Solid Base Bushings--JBR LTD Silver Vein Heavy Knob--JBR 80 duro trillogy--Synapse BPV--Synapse FMIC--Koni Yellow's--H&R springs--JBR Rear Sway Bar getting re-Stratified KO4 - 360 whp/426 wtq Corrected 6600 ASL GTX2867r - we will see....... TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" |
![]() Join Date: Dec 2010 Location: Muncie, Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 933
Groaned at 35 Times in 24 Posts
Its probably the primary dp o2 sensor... I'm on my phone, but there are a couple threads about it if you search... I think one is called "am I the only one concerned about this?" Could also be simple things... Boost/vaccuum leak, dirty maf....
__________________ ... TRADED : 07 MS3 GT Silver... fully bolted w/K04 CURRENT : 06 MS6 GT Silver.... KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6 |
![]() | | #4 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 882 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 400
Groaned at 9 Times in 7 Posts
You don't accel in 6th for longevity rod bending... And no powa?!
__________________ 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Next: TMIC(WTB PM me); meow DP Official 60-100mph Times Official Youtube Channels |
![]() | | #5 | ![]() |
![]() Join Date: Nov 2012
Rep Power: 0 ![]() Thanks: 0
Hi all I have an '08 MS3 and had some issues with stuttering turning right last week. Dealership recalibrated ECM and it went away for 2 days. Today (Sunday of course!) extreme stuttering/misfire going straight or curving/turning right. Seems to go away when turning left. Dealer was stumped..any ideas? Could SWAS be causing my issue if it is malfunctioning? O2 sensor working outside normal range, but likely caused by misfires imo. Thanks for any ideas. Doug. |
![]() | | #6 | ![]() |
Rep Power: 6754 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,366
1) you posted in the ms6 sub forum 2) you posted in a completely different thread 3) you must have searched because you know what SWAS is, but you didnt post in those threads 4) go make an actual thread in the correct area and correct generation 5) win
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
| The Following User Says Thank You to 06Speed6 For This Useful Post: | Don06speed6 (11-25-2012) |
![]() | | #7 | ![]() |
![]() Join Date: Jan 2012 Location: Bradenton, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 206
hyjacking terd nuggit! Go take you post maf hoses apart and look for leaks/cracks. make sure everything is clamped and clamped tight when reinstalling. now try it out. if it still does it clean the MAF. now try it out. if it still does it go buy an AP to see if we can see abnormalities. Yes could be DP sensor. how old r plugs? Only fix 1 thing at a time; or do 1 thing at a time to rule things out. if you fix a bunch of shit and it works you never know what was truly broken!
__________________ Black Mica 2006 Speed6 GT | 57,000 Miles Cobb AP | Stratified Tune | JBR Stage II Intake | cp-e 3'' Straight Exhaust | cp-e RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Amsoil Fluids | NKG Step 1 | Autotech Internals | Shell T6 Juice ms6db.com I'm Registered. Are You? |
| Stock Boost Load Map | Spirry | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 03-19-2012 04:14 AM |
| Stock Boost Load Map | Spirry | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 0 | 03-06-2012 03:43 PM |
| Why is my car stuttering????? | BMSPEED3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 10-08-2009 07:09 AM |
| S S S Still S S Stuttering | Stan-O | Cobb Access Port/Maps | 2 | 11-21-2008 09:05 AM |
| Stuttering at 5K | skubidoobie | MazdaSpeed 3 - Engine, Transmission & Driveline | 10 | 11-18-2008 04:39 PM |
