![]() | ![]() | #1 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | ![]() ![]() ![]() |
![]() | ![]() | #2 | ![]() |
Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,601
Groans: 244
| ![]() Rods can be plopped in from the bottom, but i dont know about the pistons.
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |
![]() | ![]() | #3 | ![]() |
![]() Join Date: Jul 2008
Rep Power: 1788 ![]() Thanks: 2,239
Groans: 62
Groaned at 156 Times in 148 Posts
![]() | ![]() | #4 | ![]() |
Engineered Tuning ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 12031 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,485
| ![]() ![]() ![]() You have to remove the head. |
![]() | ![]() | #5 | ![]() |
![]() Join Date: Mar 2008 Location: Victoria TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 405
| ![]() ![]() ![]() Step 1.Remove oil pan Step 2.Remove head Step 3.Undo rod caps Step 4.Pull piston and rod assembly out.
__________________ Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW! ![]() |
![]() | ![]() | #6 | ![]() |
Speeeeeed ![]() ![]() Join Date: Mar 2008 Location: Corpus Christi, Tx
Rep Power: 7488 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,190
| ![]() ![]() ![]() You cannot pull the rods out of the bottom of any engine that I know of, and I am 100% certain that you cannot reinstall a new set from the bottom of a engine on any engine ever made after 1940. Problems: #1 the wrist pin #2 the piston cannot be removed #3 the piston rings cannot be compressed and pushed into the cylinder from the bottom #4 the crank is completely in the way #5 if the crank isnt in the way you run a good chance of scratching the rod bearing surface on the crank which would require machining #6 the main bearing girdle is in the way and would have to be removed, this would require a balance shaft delete
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, JBR 80D PMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 2.5" ID 700hp I/A intercooler, Custom DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, SBC Full Face Feramic Clutch Disc, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant, SSP EGR delete plate, JBR EGR IM plug, JGS 40mm Race EWG ![]() |
Display Modes | |
Sq build | Strytnyne | MazdaSpeed 3/6 - Car Audio & Electronics | 10 | 12-18-2008 03:19 PM |
Big turbo kit, build one or not? | ptperformance | Mazdaspeed3/6 General Discussion | 33 | 10-12-2008 02:55 PM |
Update on build. | EvilMonkey | Mazdaspeed3/6 General Discussion | 27 | 10-09-2008 08:56 AM |
Introduction and build | EvilMonkey | MazdaSpeed 3 - Engine, Transmission & Driveline | 20 | 07-18-2008 07:25 AM |
Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 05:20 PM |
