  • 1 Post By Solarsurge
 Old 04-11-2011, 07:21 PM   #1
RWDAddict's Avatar
Posts: 340   (View Stats)
RWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the world
Default Ticking noise
I find examples of ticking noises through the search. Sounds just like mine but I find issues causing it like the A/C or chain tensioner. The problem is i've had the chain tensioner replaced and this issues doesn't need the A/C on to be present. Sure it gets slighly louder with the A/C on but that's because it drops the RPM's a bit lower before idle compensation. So i'm stumped.
Video:
mazdad.mp4 video by RWDaddict - Photobucket
06 MazdaSpeed6 GT w/Nav. Mods so far: Cobb SRI, RMM, HPFP, ATP 3" catted DP, ETS CBE, Synchronic BOV, AP, CP-E TMIC, SURE TIP, HKS Twin Power, Poly trans mount, PTP fuel injector seals, PCV Fix
RWDAddict is offline   Reply With Quote
 Old 04-12-2011, 09:47 AM   #2
RWDAddict's Avatar
Bump
 Old 04-12-2011, 10:02 AM   #3
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
it's normal is the fuel pump and injectors. thats all i can hear.
 Old 04-12-2011, 10:46 AM   #4
RWDAddict's Avatar
The only problem I have with the noise is that two months ago it wasn't nearly as loud. My car sounds like an 80's diesel now.
 Old 04-12-2011, 10:52 AM   #5
bova's Avatar
Groans: 45
thats how direct injection is, very noisy. only difference in this video is my upgraded cdfp rattles at tip in which several others have and haven't found to be a problem.
http://youtu.be/LsRmSA0YWXU
 Old 04-12-2011, 12:41 PM   #6
RWDAddict's Avatar
Also only happens when it's warmed up. Does that make a difference?
 Old 04-12-2011, 12:46 PM   #7
bova's Avatar
Groans: 45
it is fine, unless there i something i'm not hearing in your video. if you don't believe me take it to the dealer.
 Old 04-19-2011, 09:34 AM   #8
RWDAddict's Avatar
I just changed the oil and the noise went down a bit, not as loud. (i'm using Rotella t6 5w-40) I just can't believe the injectors make that much racket. Why didn't they make that much noise when i bought the car with 56k on it? Why did it show up around 70k?
 Old 04-19-2011, 10:04 AM   #9
bova's Avatar
Groans: 45
why why why, i don't know, get over it. parts wear over time shit gets louder, maybe you are just now listening in for it.
 Old 04-20-2011, 04:43 AM   #10
zer010gic's Avatar
Posts: 401   (View Stats)
zer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the worldzer010gic is the leader of the world
long shot and dont know if this will help but some have said that when they changed there plugs they got quieter (denso plugs) I have not done this my self so I cant testify to how true this is but your coming up on 75k so its worth a shot.
2006 Mazdaspeed6
Autotech Internals | ETS TMIC | Cobb AP | JBR Tru-3.5" Wide Path Aluminum | JBR RMM | JBR TMM | JBR PMM | JBR Short Shift Plate | Fidanza Flywheel | TWM Weighted Shift Knob | Hawk HPS 5.0 Pads | Techna-Fit Brake Lines | RedLine Fluids and Unicorn Blood | NGK 1 Step Colder | Damond OCC | TurboSmart Duel Port | CP-e SafeSeals | JBR TIG | JBR TBG | Damond EGR Delete
Miltuned!!!
Ready to Install
ATP Downpipe
zer010gic is offline   Reply With Quote
 Old 04-20-2011, 05:07 AM   #11
kmac's Avatar
Posts: 1,792   (View Stats)
Without seeing it in person It's hard to diagnose a noise through a speaker and locating and exact point of origin, bit that noise is to loud to be normal. I'd rather not give a diagnosis on it without seeing it , but I'd get it checked.
 Old 04-20-2011, 05:34 AM   #12
Post pwned's Avatar
Posts: 799   (View Stats)
Post pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the worldPost pwned is the leader of the world
Groans: 52
Groaned at 16 Times in 12 Posts
Get comfortable with strange noises,
This car makes more sounds than a whore getting pounded in a haunted house.
It only gets Worse in the winter....
2010 Mica Black
RMM/RSB/SRI+TIP
Post pwned is offline   Reply With Quote
 Old 05-05-2011, 11:20 AM   #13
RWDAddict's Avatar
Riddle me this children.
The noise goes away when i push down the clutch pedal!!!!!!!!
 Old 05-05-2011, 11:24 AM   #14
Post pwned (05-05-2011)
 Old 05-05-2011, 12:47 PM   #15
Post pwned's Avatar
Groans: 52
Could be your valves.
The trans always amps the sounds in the motor.
...Well that's what I've noticed with my car.
2010 Mica Black
RMM/RSB/SRI+TIP
 Old 05-15-2011, 04:58 PM   #16
slvrMPS6's Avatar
Posts: 34   (View Stats)
slvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to beholdslvrMPS6 is a splendid one to behold
yeah if you turn my car off without touching the clutch it sounds pretty clunky, otherwise its silent. i have that same noise you're talking about but the clutch makes no difference. best fix IMHO is turn up the radio and keep driving.
2006 Speed6 - Liquid Platinum Metallic - Cobb SRI, SU TMIC+boost tubes, CP-E dogbone mount, Cobb AP on stage 1 93 w/LC+FFS, Denso ITV22's, JBarone Short Shift Plate, metal shifter bushings, Prosport Boost gauge in vent pod, Apexi TT, Yokohama S-Drive rubbers, DDM 35w 4500k HID fogs, various LEDs, JDM Mazda window visors, Shark fin antenna, Xcarlink IPhone 4 connection
slvrMPS6 is offline   Reply With Quote
 Old 03-07-2013, 03:28 PM   #17
Absolut1l's Avatar
Posts: 170   (View Stats)
Absolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond reputeAbsolut1l has a reputation beyond repute
Old thread I know... But mine is making the same exact sound. I'm at 74k miles. I think it's just normal.
Absolut1l is offline   Reply With Quote
 Old 03-08-2013, 01:40 PM   #18
RWDAddict's Avatar
This thread is more up to date
Grinding noise relating to clutch
The Following User Says Thank You to RWDAddict For This Useful Post:
Absolut1l (03-10-2013)
 Old 03-10-2013, 07:18 PM   #19
Absolut1l's Avatar
oooh thanks!
 Old 07-27-2018, 02:11 AM   #20
Bmatthews352's Avatar
Posts: 2   (View Stats)
Bmatthews352 can only hope to improve
Groaned at 5 Times in 2 Posts
Default rude
man you are being rude as hell to someone who is asking legitimate questions. Maybe you should just keep your mouth shut if you have nothing intelligent to say.
Did you ever think his microphone is not great and you are not able to hear the noise hes hearing VIA the video?
"why why why..." stop mocking people and use your brain, if you have one....
Bmatthews352 is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Bmatthews352 For This Un-useful Post:
djern (07-28-2018), Thor Hammer (08-06-2018), Vansquish (07-27-2018)
 Old 07-27-2018, 09:21 AM   #21
Db09ms3's Avatar
Posts: 486   (View Stats)
Db09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the worldDb09ms3 is the leader of the world
Groans: 94
Shits old scrub
Stockish
The Following User Says Thank You to Db09ms3 For This Useful Post:
 Old 07-27-2018, 09:37 AM   #22
Police - Grammarhead
Vansquish's Avatar
Groans: 1,901
Check yourself. You're being butthurt on someone else's behalf almost 8, and you're more than 7 years late to the party.
 Old 07-27-2018, 10:29 AM   #23
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,805   (View Stats)
I am undoubtedly convinced Bova will come here any minute now and beg forgiveness for his uncouth behavior back in the good ol 11 given that B Matthew with 2 posts under his belt has taken offense to it. Jesus is my witness.
 Old 07-27-2018, 11:53 AM   #24
Solarsurge's Avatar
Posts: 571   (View Stats)
I did not originally notice the offensiveness of bova's response, and it seems no one else was offended by it, either. But now that the offensiveness has been pointed out to me, I am offended that I didn't notice the offensiveness before. Now that someone has been offended, I am offended that it took this long for that offensiveness to be pointed out. I am also offended I should have been offended this whole time, but it took this long for someone to be offended enough to point out how offended I should have been and that no one else was offended enough to realize how offensive this post was. I'm WAY more offended now than I ever would have been which, frankly, I find highly offensive.
Db09ms3 likes this.
 Old 07-28-2018, 08:57 AM   #25
Db09ms3's Avatar
Groans: 94
Off ended
Stockish
 Old 08-06-2018, 05:57 AM   #26
bova's Avatar
Groans: 45
aw what the fuck, haven't had my speed6 in 6 years (may she RIP) and I get notified I'm being quoted by some asshat who says I was rude 7 years ago. There I go again being rude.
 Old 08-06-2018, 11:31 AM   #27
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
I dunno, given the circumstances I thought asshat was pretty nice.
monkey.bones.007 (08-10-2018)
Ticking noise our engines make Spoolme MazdaSpeed 3/6 - Troubleshoot/Diagnostics 27 08-26-2014 09:23 AM
Clicking/ticking noise sQwiReL MazdaSpeed 3 - Engine, Transmission & Driveline 8 01-12-2011 07:17 PM
Lotus and Harman partner on noise-cancelling, noise-creating tech Haltech Automotive News 0 04-16-2009 04:00 PM
Me Too! Maybe.... engine ticking... JimmyMac MazdaSpeed 3 - Engine, Transmission & Driveline 58 12-03-2008 12:12 AM
Dodge Magnum Makes Ticking Noise, Perpetual Motion Electric Car, Fuel Vapor Enhancer, Coasting and MPG: Mike Allen's Wee Haltech Automotive News 0 08-01-2008 02:50 PM
Page generated in 0.45698 seconds with 33 queries
