Notices
 Old 09-18-2012, 06:30 PM   #1
Chriscote's Avatar
Posts: 883   (View Stats)
Chriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the world
Groans: 137
Groaned at 17 Times in 7 Posts
Default Trans Fluid, Lucas SAE 75W-90?
A friend is looking to sell me 4 32 oz bottles of Lucas Synthetic SAI 75w-90 Gear Oil / trans and diff lube for extremely cheap that he has laying around. I am just curious as if this will work for my transmission flush. Not very knowledgeable on the subject so i come to MSF.
thanks
2010 LMB 135i. kwv1, DCI/JB4
RIP 06 WWP MS6 GT Fully Bolted/AP, DIZZY, Stock Turbo... Roll Tide
Chriscote is offline   Reply With Quote
 Old 09-18-2012, 06:41 PM   #2
Constantin's Avatar
Posts: 2,371   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Personally, I would not be cheap with any fluids in the car. Especially trany oil!
Last weekend I put in
MOTUL MOTUL GEAR 300 SYN HYPOID - 317811MOTUL MOTUL GEAR 300 SYN HYPOID - 317811
It is based on natural components (Easter) there for in creates a much better coating then conventional oil (per MOTUL specifications).
So far, I have noticed a smother gear change, especially on low speeds. Nothing major, but you should not expect dramatic differences.
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arm | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
 Old 09-18-2012, 06:46 PM   #3
captain slow's Avatar
Posts: 1,655   (View Stats)
captain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the world
Groans: 306
Groaned at 44 Times in 29 Posts
Most people use redline mt90 or the motorcraft stuff.
Go with one of those.
2007 Sunlight Silver MS3 GT
CP-E SRI / CP-E TIP / Cobb AP Stage 1 slightly tweaked by me / JBR 88 RMM, SSP, SSB, Heavy Knob / Turbosmart Dual Port BOV 50/50 / Autotech internals
_______________________________________________
Sitting in my garage: ......
To be ordered: CorkSport TBE
captain slow is online now   Reply With Quote
The Following User Says Thank You to captain slow For This Useful Post:
Chriscote (09-18-2012)
 Old 09-18-2012, 07:01 PM   #4
Posts: 5,598   (View Stats)
Groans: 121
IIRC, the transmission uses 75w90 GL-4 fluid, so that should work.
I highly recommend the Motorcraft XT-M5-QS fluid with 1/3 bottle of the Ford XL3 friction modifier though. I've run four or five different types of oil in my transmission, and that setup is BY FAR the best I've used.
silvapain is online now   Reply With Quote
 Old 09-18-2012, 07:06 PM   #5
qweedqwag's Avatar
Posts: 221   (View Stats)
qweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the worldqweedqwag is the leader of the world
Groaned at 22 Times in 10 Posts
What makes it better ??? I call bullshit.
qweedqwag is offline   Reply With Quote
The Following 3 Users Say NO Thank You to qweedqwag For This Un-useful Post:
mczimer (09-19-2012), Mizzle (09-18-2012), silvapain (09-18-2012)
 Old 09-18-2012, 07:14 PM   #6
Mizzle's Avatar
Posts: 2,578   (View Stats)
Groans: 297
Groaned at 186 Times in 102 Posts
The cst values are retarded-high on that stuff. It will be like shifting in molasses in winter.
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
Chriscote (09-18-2012), silvapain (09-18-2012)
 Old 09-18-2012, 07:16 PM   #7
Groans: 121
I had that issue with the Royal Purple fluid I ran. I've always thought that the OE fluid viscosity spec was way too high.
 Old 09-18-2012, 07:53 PM   #8
Chriscote's Avatar
Groans: 137
add the modifier before or between motorcraft bottles?
 Old 09-18-2012, 08:16 PM   #9
fastest 3-cyl MS3
btstarcher's Avatar
Posts: 1,663   (View Stats)
When I drained/filled I didn't use any friction modifier...is this bad?
JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, HKS BPV, SSP OCC, JBR TIG's, JBR EGR delete, Cobb AP, Kenne Bell BAS, PTP HPFP internals, Steedspeed turbo manifold, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Cobb RSB, Whiteline Anti Lift Kit, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, PTP BSD
Dizzy Tuned by Boost_creep in progress
hopefully soon: GTX2867R or GTX3076R
 Old 09-18-2012, 09:43 PM   #10
Constantin's Avatar
Did you have a chance to run MOTUL oil? And how do check which oil is better?
After I put MOTUL, I do feel smother shifting, especially during lower speeds, but that is about it. Difference is there, but nothing dramatic. If you can tell me what I should be looking for, it will be great!
 Old 09-18-2012, 10:31 PM   #11
Groans: 121
You don't have to use the friction modifier, but it does make a noticeable difference if you do. You can add it after filling the transmission completely with fluid; the bottle is only 4 fl.oz. and you only use 1/3 of it. We're not talking a lot here.
btstarcher (09-20-2012), Chriscote (09-18-2012)
 Old 09-18-2012, 10:34 PM   #12
Groans: 121
The friction modifier especially helps the synchros function much more smoothly. I use a stock shift knob with a short shift plate and NO weight, and before using the friction modifier I could feel an initial resistance putting the transmission into gear when moving, even with the Motorcraft transmission fluid. That resistance is the synchros matching gear speed before letting the gears mesh. With the modifier, it's super smooth.
btstarcher (09-20-2012), Constantin (09-19-2012)
 Old 09-19-2012, 05:36 AM   #13
Constantin's Avatar
Thx. I'll try to find out if the friction modifier is a good idea with MOTUL oil I have now. If it is, I'll definitely add it.
So, all your really are looking for is how smooth the gear change is? Are there any other things you can be on a lookout for to see difference in fluids?
 Old 09-19-2012, 05:51 AM   #14
guitarzan134's Avatar
Posts: 473   (View Stats)
guitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the worldguitarzan134 is the leader of the world
This is something I've been looking into recently, so I greatly appreciate the info, too.
My shifter mods/mm are in my sig, and I have a weighed knob on it's way... I still get some grind when doing hard shifts. My transmission was rebuilt by Mazda @~59k, so i'm assuming they used new gear oil afterwards, but since then I've noticed more resistance than it had pre-rebuild. I'm at 81k now and am serious about getting this to perform smoothly. It's a bummer to time my 0-60, only to miss 1-2 or 2-3 and have to start over.
~$20/qt, @ 3 qts, for the MC? And ~1.5oz FM... Right?
Thanks to the OG's.
2007 Mazdaspeed3 GT Black Mica
-~Corksport CBE, SRI, & TIP - Ultimate Racing TP - Autotech FP Internals - Forge V1 - NGK 1 step colder - Cobb RSB - Cobb AP - EBC Red Stuff/Stoptech Posiquiet - JBR SSP, SSB, & 88a RMM - Full GT-Spec chassis bracing - Rota Grids 18x8.5 - Michelin PSS 235/40~-
guitarzan134 is online now   Reply With Quote
 Old 09-19-2012, 06:25 AM   #15
Groans: 121
Viscosity and API ratings are important. Too thin an oil will shear and won't protect the transmission components. Too thick and it won't flow well and you'll have a hard time changing gears. The API GL-4 rating identifies what additives are included for detergents and to prevent shear (see above).
Motorcraft XT-M5-QS is 75w-90 GL-4 as specified by Mazda. I have also ran Pennzoil Synchromesh fluid, which is 75w-80 GL-5 without problem.
 Old 09-19-2012, 06:50 AM   #16
Eth Fiend
phate's Avatar
Posts: 4,250   (View Stats)
phate has disabled reputation
I'm using the Lucas stuff in the trans of the other 6 right now. Seems to work fine Shifts better than my 6, but who knows what's in it, lol.
I'll likely use the Motorcraft fluid in mine, but the Lucas seems to be a good contender so far. I liked it in my 3, with a bit of friction modifier.
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now   Reply With Quote
silvapain (09-19-2012)
 Old 09-19-2012, 06:56 AM   #17
Groans: 121
I will add that I ran the Motorcraft stuff without friction modifier for a while, and even then it was still the best I've used.
I haven't tried the Lucas fluid, though.
POLL: which trans fluid and other general Q's bast525 MazdaSpeed 3 - Engine, Transmission & Driveline 33 02-10-2012 06:42 AM
lucas oil synth dr_banano 2010 MS3 - How-To's 1 05-28-2011 09:38 PM
Fomoco trans- axle fluid kritz 2010 MS3 - Engine, Transmission & Driveline 22 05-08-2011 06:25 PM
Chevy Suburban Transmission Fluid, Using CO2 to Fill a Tire, How To Unclog Windshield Wiper Fluid Spouts, Dead Battery A Haltech Automotive News 0 05-15-2009 03:10 PM
Page generated in 0.40845 seconds with 28 queries
