Notices
 Old 08-20-2012, 04:21 PM   #1
Matx's Avatar
Posts: 1,630   (View Stats)
Default trans pto rear diff build
Ok so I want to regear transmission rear diff pto. stronger and longer gears. Anyone know a shop that does this type of custom work around TX?
Mods: Come find out
"Man, ya'll have those dam scaners! we needs somo thos"
"FYMSN" - Honda
"its not yall its me."
 Old 08-21-2012, 12:33 PM   #2
RWDAddict's Avatar
Posts: 284   (View Stats)
RWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the world
Too small of a market for our car, so either you have to do a crap load of research and have custom gears cut or buy a different car. My one gripe with this car are 1-3 gears. Even 6th could stand to be longer as well. If somebody made a kit for a reasonable price i'd be all over it.
06 MazdaSpeed6 GT w/Nav. Mods so far: Cobb SRI, RMM, HPFP, ATP 3" catted DP, ETS CBE, Synchronic BOV, AP, CP-E TMIC, SURE TIP, HKS Twin Power, Poly trans mount, PTP fuel injector seals, PCV Fix
RWDAddict is offline   Reply With Quote
 Old 08-22-2012, 12:27 AM   #3
Matx's Avatar
Anyone know the specs of the gear ratio for the pto and the rear diff?
I was also thinking about going on the same gear ratio for the 2012 mustang seeing that it puts it in a prime boost zone after shifts, only thing I would change is maybe the 6th ratio. But as of right now I have alot of shit to research I may know a shop that can do the gears will have to see.
Mods: Come find out
"FYMSN" - Honda
 Old 08-22-2012, 02:46 AM   #4
Matx's Avatar
Ok read the thread Just wondering how it feels.... But sounds like the plan lol
Mods: Come find out
"FYMSN" - Honda
 Old 08-24-2012, 09:11 AM   #5
Jh8909's Avatar
Posts: 1,025   (View Stats)
Jh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the worldJh8909 is the leader of the world
Groans: 111
Groaned at 7 Times in 6 Posts
SPEED6 KILLAH pablo has done this with good results
06 Black Cherry Mica MS6 GT: Cobb AP, Cobb SRI, CP-E TIP, CP-E FMIC
CP-E Tow Plate, JBR RMM, MD OCC, Step Colder Plugs, AT FP Internals, HKS BPV
Ceramic Coated ex. mani & turbo, Ceramic Coated M2 DP, Custom 3" catback, EGR Delete
H&R springs, Morimoto clear projector retrofit, 18x8 TD HS 1.2's
GT3076r/Brand New Motor build coming soon
Jh8909 is offline   Reply With Quote
The Following User Says Thank You to Jh8909 For This Useful Post:
Don06speed6 (08-24-2012)
 Old 08-24-2012, 12:22 PM   #6
Matx's Avatar
Plans fell throu on the extra transmission and motor
Mods: Come find out
"FYMSN" - Honda
Rear diff locks while turning after SURE diff mount and brace install wettoast MazdaSpeed 6 - Engine, Transmission & Driveline 37 06-10-2013 06:04 AM
Suggestions (ECU, trans, rear end, etc) for MZR build DarkPasseng3r Gen2 MS3 General Discussion 5 06-06-2012 03:54 PM
Rear diff module fail takes out the rear diff coupling 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 7 10-24-2011 10:19 PM
rear diff "stiff diff" brace vs. rear diff front mount giordanos4 MazdaSpeed 6 - Engine, Transmission & Driveline 18 03-03-2011 07:38 AM
Page generated in 0.27653 seconds with 22 queries
