 Old 08-13-2011, 02:34 PM   #1
rrussell50's Avatar
Posts: 35   (View Stats)
rrussell50 is a jewel in the roughrrussell50 is a jewel in the roughrrussell50 is a jewel in the rough
Default Transfer Case won't refill
I just finished changing the fluid on my rear diff, and now I moved onto the transfer fluid,
I drained it and attempted to refill it but not even after 1/4 of a bottle or redline did it start oozing out the fill hole!!
I then took off the drain plug and let it drain again and some came out so I plugged up the drain hole and began to fill again and same result
What am I doing wrong?
and with the little amount in it is my car safe to drive until Wednesday when I take it to the dealership for an unrelated problem?
rrussell50 is offline   Reply With Quote
 Old 08-13-2011, 03:53 PM   #2
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
No, it's not safe to drive..
Make sure your fill tube isn't plugging the entire fill hole on the transfer case, unless the bottle and the transfercase can vent you won't move any fluid...
It's annoying and messy to fill, but you'l know it when it's really full...
06Speed6 (08-13-2011)
 Old 08-13-2011, 04:02 PM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Off the top of my head, it does take more than a full bottle, I seem to remember using two bottles.
2006 Mazdaspeed 6
 Old 08-13-2011, 09:14 PM   #4
burntmushu's Avatar
Posts: 128   (View Stats)
burntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond repute
i put a long hose over the from the bottle feeding it through the top of the engine bay then crawling under sticking the hose in as much as i could...i think it went in about two inches... anyways after doing so i started squeezing the bottle empty from topside. until i saw it oozing out. then i crawled back under and put the plug back in. and when you say transfer you are talking about the one that bolts to the transmission that links to the rear end and passenger side cv? and the drain plug is right under it not on the side of it. and the filler plug is mounted on the side.
burntmushu is offline   Reply With Quote
 Old 08-13-2011, 10:02 PM   #5
i8urgti's Avatar
Posts: 1,660   (View Stats)
i8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the worldi8urgti is the leader of the world
Groans: 267
MS6 Fluid Notes & DIY Pictures - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
according to this, its 1.3 qts.
2006 LPM MS6 GT (totaled)
0-60 mph : 4.2 second (as per DH)
12.83 @ ???MPH 1.67 60ft
2002 Miata Se (convertible whore)
i8urgti is offline   Reply With Quote
The Following User Says Thank You to i8urgti For This Useful Post:
MS6 Alan (08-15-2011)
 Old 08-14-2011, 09:36 AM   #6
rob ms6gt's Avatar
Posts: 416   (View Stats)
rob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the worldrob ms6gt is the leader of the world
Groaned at 11 Times in 2 Posts
Is the car jacked up level front and back?
ROB MS6GT
2006 Liquid Platinum Metallic Mazdaspeed 6
Stratified Tune, Stratified GA V2, Cobb AP V2, GTX3071R, HTP 4" Intake, Synchronic Diverter Valve, 3 bar MAP, Stratified Boost Dial, Corksport Injector Seals, Autotech Internals, Ebay DP, Custom TR8 FMIC, DevilsOwn Meth, Damond Catch Can, JBR 70 Duro Trilogy, TT front diff mount, Penis Eater top diff mount, Cut OEM Springs, Koni Yellows
rob ms6gt is offline   Reply With Quote
 Old 08-14-2011, 09:16 PM   #7
rrussell50's Avatar
thanks for the replies, i was only using a 1 qt bottle of Redline. After hours of trial and error I realized that a less was spilling out than was actually going in. I switched to a clear tube and attached it to the funnel and watched as the majority of it went inside and just a little bit was leaking out.
I think the car was level ... I was under it but my jack stands were all even ... either way I need to find an easier way to do this... the rear diff was easy no problems at all this one was a PITA
thanks
 Old 08-15-2011, 07:22 AM   #8
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
the T/C really is a pain. I had the same issue, couldn't tell if it was filling, or when it was full. I put about 1 3/4 bottles into it before we decided that it HAS to be full at this point. that was like 10K miles ago, no issues,
-Wetz
QFT
 Old 08-15-2011, 07:55 AM   #9
this thing sucks to fill. theres something right in the way of the fill hole.
you need to go REALLY slow with the pump and wiggle the fill tube around till it stops leaking out after 1/4 bottle. ive had this problem many times
 Old 08-15-2011, 08:51 PM   #10
Mistersix's Avatar
Posts: 2,585   (View Stats)
A long tapered nozzle or tip at the end of the hose really helps. This way you can get it in far enough without plugging the hole and blocking air flow.
Hello 2 everyone! MS6 Transfer Case Reinforce? paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 266 07-09-2015 02:32 AM
My Transfer case/PTO is done... LoresonDE MazdaSpeed 6 - Engine, Transmission & Driveline 10 02-24-2010 05:09 PM
My Transfer case/PTO is done... LoresonDE MazdaSpeed 3 - Engine, Transmission & Driveline 5 02-08-2010 09:41 PM
transfer case pic 06speed MazdaSpeed 6 - Engine, Transmission & Driveline 9 01-11-2010 07:13 AM
Page generated in 0.30978 seconds with 28 queries
