 Old 04-28-2012, 12:08 PM   #1
Bratschist's Avatar
Posts: 79   (View Stats)
Bratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud ofBratschist has much to be proud of
Default Upshift without Clutch
So, i was driving my ms6 today and noticed that I can shift gears up without the use of the clutch and without scratching gears. That got me very scared. to be specific this is what happened:
I was driving towards a stop sing and coming to a complete stop when I engaged 2nd gear (I do that at times instead of 1st gear to take off), but this time I couldn't remember if I used the clutch or not. So what I did was, I drove and tried again. Nothing happened, but I then started trying different things. Until I shifted from 3rd gear to neutral without depressing the clutch and almost engaged 4th gear. Which made me try again. So finally I found out that when I shifted from gear x to neutral, the revs would go down slowly and I was able to shift to gear x+1, all without the use of the clutch. Now, I know that some cars like the Nissan 370z has some sort of rev matching technology that allows that to happen. The point is that I never heard of our car having such a thing. Which made me scared because I really dont have money to spend on a new clutch. and even if I did, I would prefer spending it on power adder than that. (yes, I know more power requires better clutch, so please save the rhetoric). Also, I need to point out that I have NEVER had any clutch problem with this car. I'm on 75k now. so, does anyone have this happening to them? any thoughts?
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  3. CorkSport LED light kit
  4. TWM Performance Shifter
  5. SLS Test Pipe
  6. CorkSport FMIC and SR air intake
  7. SURE Motorsport Torq R6
  8. AccessPort Stage 2+ Map
  9. QTP Electronic Exhaust Cut-Out
  10. KMD HPFP Internals Upgrade
  11. CorkSport Downpipe
Bratschist is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Bratschist For This Un-useful Post:
Bucker (05-02-2012), Neverlift (05-06-2012)
 Old 04-28-2012, 12:10 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
People
here
sure
hate
the
use
of
the
return
key.
I'm going to do my part on making up for their.. specialism.
How to Drive a Manual Transmission Vehicle Without Using the Clutch
Last edited by helmetface; 04-28-2012 at 12:10 PM. Reason: MSF Database - Automerged Doublepost
The Following 4 Users Say Thank You to helmetface For This Useful Post:
Alpha (04-30-2012), jeymz (04-28-2012), kritz (04-29-2012), taf0422 (04-29-2012)
 Old 04-28-2012, 12:11 PM   #3
snailD's Avatar
Posts: 3,038   (View Stats)
idk i never tried, i can't imagine there is something wrong with your clutch if you're not even depressing it. i go from gear to neutral all the time without the clutch tho. u just blip the gas so the load is taken off and it will slide right out intro neutral
 Old 04-28-2012, 12:11 PM   #4
frodaddyweez's Avatar
Posts: 988   (View Stats)
frodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the world
You can shift without using the clutch, by rev matching. But I wouldn't recommend it. It wears out your synchros more quickly.
2009 Mazdaspeed3: PTE 5857 25psi etuned by tooslow2010 --> SOLD
2011 Mustang Shelby GT500 w/SVTPP: 2.3L Trinity TVS w/2.4" VMP pulley, L&M NSR cams, JLT 123mm Intake, FRPP CobraJet Twin 65mm Throttle Body, 56# Injectors, VMP Fuel Pump Booster, AFCO Dual Pass Heat Exchanger, FRPP L Springs, BMR Adjustable Panhard Bar, Shaftmasters Aluminum One-piece Driveshaft, Lethal Performance Catless H-Pipe, Flowmaster Outlaw Axleback, 315 NT05r's
Lund Tuned 683whp/622wtq 11/11/16
Upcoming mods: Full-length Headers and ID1300s for E85
1995 Mazda Miata: Stock (daily)
frodaddyweez is offline   Reply With Quote
The Following User Says Thank You to frodaddyweez For This Useful Post:
p057 (04-30-2012)
 Old 04-28-2012, 12:21 PM   #5
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groans: 98
Groaned at 6 Times in 4 Posts
Reminds me of the time my car broke down and @phate drove it back without using the clutch. It was an epic moment.
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline   Reply With Quote
The Following 3 Users Say Thank You to xtasy For This Useful Post:
helmetface (04-28-2012), kritz (04-29-2012), phate (04-28-2012)
 Old 04-28-2012, 12:33 PM   #6
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
@09Speed3Z
Boob
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
The Following User Says Thank You to Don06speed6 For This Useful Post:
kritz (04-29-2012)
 Old 04-29-2012, 02:45 AM   #7
Coaststarlight's Avatar
Posts: 296   (View Stats)
Coaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the worldCoaststarlight is the leader of the world
Simple, you match the revs as you would normaly and you can engage gears by syncing them to the appropriate engine speed, nothings wrong with your car or clutch, sometimes this is refered to as "Floating Gears" you can do this in just about any Manual transmission, new or old
how ever missing this rev match/forcing it to happen quikly can result in grinding gears, wich of course is bad...
next time be a bit more careful, some things on cars you dont wanna learn the hard way by just "trying stuff out"
Long Block Built by GPwerks and Loose Screw Motor Sports
https://www.gp-werks.com/
http://www.crossoverauto.com
^Any Parts, Great Prices^
Coaststarlight is offline   Reply With Quote
The Following User Says Thank You to Coaststarlight For This Useful Post:
Sid3wayS (04-29-2012)
 Old 04-29-2012, 03:39 AM   #8
Posts: 7,290   (View Stats)
Damn Pu fail thread, oh wait I has teh Pu too. Stop that!
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
Tokay444 (04-30-2012), Vader (05-01-2012)
 Old 04-29-2012, 04:50 AM   #9
Sid3wayS's Avatar
Posts: 6,789   (View Stats)
Groans: 97
First manual car huh? Try driving a big rig with 15 gears, only time you ever touch the clutch is to engage first and reverse. It's completely normal and safe so long as you do it correctly.
TEAM LUXURY
Sid3wayS is offline   Reply With Quote
The Following User Says Thank You to Sid3wayS For This Useful Post:
Vader (05-01-2012)
 Old 04-29-2012, 05:19 AM   #10
World Rally AutoX's Avatar
Posts: 13   (View Stats)
World Rally AutoX can only hope to improve
yeah keep driving without clutch, you will be alright.
Your wallet and your tranny might sing a different tune though.
1st post FTW
World Rally AutoX is offline   Reply With Quote
The Following User Says NO Thank You to World Rally AutoX For This Un-useful Post:
Vansquish (04-30-2012)
 Old 04-29-2012, 11:08 AM   #11
ztnedman1's Avatar
Posts: 338   (View Stats)
ztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the worldztnedman1 is the leader of the world
Opposite. Before the days of syncros you had to rev match to shift, after syncros now you can shift without rev matching. The more you rev match the less work for the syncros.
2010 Velocity Red MS3 (140k+ miles) Intake/Exaust/AP selftuned(313/399 long time ago) - SOLD
2004 Corvette Z06
SCCA Bowling Green Match Tour - GS 1st place
SCCA Wilmington Champ Tour - GS 2nd place
SCCA National Championship - GS 3rd place
SCCA Grenada Match Tour - AS 1st place
ztnedman1 is offline   Reply With Quote
 Old 04-30-2012, 01:49 AM   #12
Bratschist's Avatar
Sorry to disappoint you but no, in fact I have had 4 different cars and they were all manual. The only thing is that I have never tried anything of the genre with my cars. The most I did was power shifting and that's it. even so, I was using the clutch. As I said, I got scared bc I didn't expect that to happen..
Thanks everyone who replied. Great help. BTW, since we are already on the topic, today someone told me the tranny for the speed 6 is the same from RX8. is that true?
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
 Old 04-30-2012, 03:03 AM   #13
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
No.
Power shifting IS NOT using the clutch.
What you are explaining is called power shifting.
Whatever "you've done before" was not power shifting.
"Exclusivity" - CP-enis
Demodded.
The Seals
Sid3wayS (04-30-2012)
The Following User Says NO Thank You to Tokay444 For This Un-useful Post:
Seatime3 (04-30-2012)
 Old 04-30-2012, 03:29 AM   #14
Nope, Ours is a FWD style Trans-axle with two axle shafts and an out put to a transfer case for the drive shaft, an RX8 has a Traditional RWD style Gear Box, one input shaft at the front, one output shaft at the rear
Bratschist (04-30-2012)
 Old 04-30-2012, 08:17 AM   #15
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
I drive like this all the time. rev match FTW
-Wetz
QFT
 Old 04-30-2012, 10:20 AM   #16
Bratschist's Avatar
No.
Damn it. Like I didn't have enough confusions in my life already. LOL
I once went to a trak experience with srt team where I met a guy who drives a viper on the tracks.he was explaining to me that when he shifts during the quarter mile, he doesn't lift his foot from the gas and shift gears normally, I guess the accessport names it flatfoot shifting. the viper guy told me it was called powershifting. I guess not...
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
 Old 04-30-2012, 02:27 PM   #17
Tokay444's Avatar
Groans: 793
If you're driving a viper, you don't really know very much about cars to begin with. So you would be correct.
Power shifting is what truckers do. Shifting without the clutch.
Flat foot shifting is not lifting the gas when you use the clutch.
Demodded.
The Seals
 Old 04-30-2012, 02:41 PM   #18
2k4_8's Avatar
Posts: 684   (View Stats)
2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world2k4_8 is the leader of the world
Groans: 64
Groaned at 18 Times in 6 Posts
Powershifting and floating the gears are not the same. Powershifting is forcefully shifting and just jamming it in...which is not what any trucker that has any sense does. Floating the gears you have to feel for the gear still...although in trucks with synchros...this normally isn't much of an issue. Powershifting you are not waiting for the synchros to work and generally fucking up your synchros and or bending shift forks.
In either case OP, although I have done this just out of habit from work (I have also tried to turn off my air brakes in the car after a long day lol) there is no purpose to floating the gears in your car. It's not necessary or recommended. Just because you can, doesn't mean you should.
COBB AP, CPE STAGE 2 RMM, CS SRI/TIP, AT HPFP INTERNALS, CNT CATTED DP, CP-E TRITON, JBR RSB, SWIFT SPRINGS, CS CAMBER ARMS
2k4_8 is offline   Reply With Quote
The Following User Says Thank You to 2k4_8 For This Useful Post:
xfeejayx (04-30-2012)
 Old 04-30-2012, 09:18 PM   #19
Bratschist's Avatar
sorry, but if you are insinuating that vipers aren't great cars, then I am sorry but I cannot agree with you. if I had the money I would have the viper any time over my speed 6, and I love my speed6. The best car I have ever had, but seriously, saying that driving a viper means you don't know cars is not a valuable argument for me. IMO
from Wikipedia:
Powershifting (also known as; full-throttle shifting, flat-shifting, or speed shifting) is a method of shifting used with manual transmissions to reduce the time where the driving wheels are not powered.
Unlike a normal gearchange, in a powershift the driver does not let off the accelerator. The clutch is briefly depressed while the shift lever is rapidly shifted into a higher gear, keeping the engine in its power band. This helps the car accelerate faster, but increases the wear on the clutch and the transmission beyond normal levels and shortens the expected life of these components. Flat-shifting may also increase fuel consumption. In most cases, there is a method of cutting the ignition and/or fuel delivery, in a similar fashion to a rev-limiter, which prevents the engine from over-revving when the load from the transmission is removed. Many aftermarket[1] engine management systems provide this functionality as either a standard feature or as an option, usually combined with launch control.
The technique lends itself especially well to sequential transmissions as found on most motorcycles and some race cars.
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
Last edited by Bratschist; 04-30-2012 at 09:18 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-30-2012, 09:28 PM   #20
grantmm's Avatar
Posts: 826   (View Stats)
grantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the world
Groaned at 8 Times in 5 Posts
I upshift and downshift without the clutch all the time while driving to work. Just be gentle and don't force it if it doesn't want to go. Nothing wrong if you're quick.
grantmm is offline   Reply With Quote
 Old 05-01-2012, 02:53 AM   #21
Tokay444's Avatar
Groans: 793
Because Wikipedia is know for 100% true and factual info.
Viper=Chrysler. Need I go on?
Demodded.
The Seals
 Old 05-01-2012, 10:38 AM   #22
Bratschist's Avatar
Viper = my speed6 to dust. That's what matter. Also, I'm using Wikipedia to show that my argument is not out of the blue
Upgrades so far:
  1. Window Tint 20%
  2. Ipod Integration
  5. SLS Test Pipe
The Following User Says NO Thank You to Bratschist For This Un-useful Post:
 Old 05-02-2012, 05:12 AM   #23
Tokay444's Avatar
Groans: 793
Speed 6=dust until viper tries to take a corner and spins out. Or breaks.
Both are inevitable.
Demodded.
The Seals
Clutch Karmat Mazdaspeed3/6 General Discussion 1 03-27-2011 12:01 AM
Clutch TSB FWD=WWD MazdaSpeed 6 - Engine, Transmission & Driveline 18 03-08-2010 08:59 PM
clutch vibration at top of clutch PLEASE HELP livetoskate06 MazdaSpeed 3 - Engine, Transmission & Driveline 84 03-06-2010 05:53 PM
Might have f'd up my clutch? redspeeeed3 Mazdaspeed3/6 General Discussion 1 11-11-2008 11:38 PM
Page generated in 0.43535 seconds with 34 queries
