Like Tree8Likes
 Old 02-22-2012, 12:43 AM   #1
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
Default Wheel bearing
Need to replace my front wheel bearings . I am at 103xx miles .
Do you think I will need hubs ? I am thinking just bearings ..
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 02-22-2012, 05:14 PM   #2
Matx's Avatar
Posts: 1,681   (View Stats)
If your going to do this do a HOW-TO
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
The Following 3 Users Say Thank You to Matx For This Useful Post:
JacksonMS30 (02-22-2012), mr.speedy3 (11-20-2014), Neverlift (06-06-2012)
 Old 02-22-2012, 05:19 PM   #3
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
im think replacing hub will be best i was told there is a risk of doing bearings and that it might vibrate.
 Old 02-22-2012, 05:27 PM   #4
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,162   (View Stats)
Groans: 793
I think you'll be hard pressed to find just the bearing.
You'll likely have to buy the entire hub with abs sensor and all.
I feel sorry for your asshole.
"Exclusivity" - CP-enis
Demodded.
The Seals
IshiKage (02-22-2012), super_pablo_ (04-05-2013)
 Old 02-22-2012, 05:39 PM   #5
Matx's Avatar
Bearings are easy to find its the HUB thats a bitch.
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
The Following User Says Thank You to Matx For This Useful Post:
Tokay444 (02-22-2012)
 Old 02-22-2012, 05:48 PM   #6
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
I've done a front wheel bearing on my old MS6.
You can buy just the bearing, for around $55, no need to replace the hub. If you're doing it yourself, you'll need an impact gun to loosen the hub nut(36mm IIRC), and the 2 lower ball joint nuts(22mm IIRC).
You'll need a press to get the bearing out. First press out the hub from the spindle/bearing, then the bearing from the spindle.
This will almost certainly happen, where the inner race is stuck on the hub:
You basically want to cut into the race, deep enough to crack it with a chisel. This is all pretty well explained in the shop manual for the MS6.
Remember to buy new hub nuts.
Current Fail:
MATT DAMOND is offline   Reply With Quote
The Following 5 Users Say Thank You to MATT DAMOND For This Useful Post:
Constantin (11-05-2013), jracer (02-23-2012), rb25guy (11-06-2014), super_pablo_ (04-05-2013), Tokay444 (02-22-2012)
 Old 02-22-2012, 06:00 PM   #7
Tokay444's Avatar
Groans: 793
Sweet.
That actually makes me really happy.
Fuck all the one piece bull shit.
Demodded.
The Seals
 Old 02-23-2012, 02:09 AM   #8
jracer's Avatar
Groans: 89
Thanks Matt !!!!
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-24-2012, 06:47 AM   #9
jracer's Avatar
Groans: 89
ordered a OEM mazda bearing..$80 bucks shipped
could have gotten it cheaper from NAPA or another place but its a job i dont wanna do again.. so ill get the good stuff !
I am pretty sure its the front right so ill try that first and if the noise doesnt go away ill do the other side..
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
 Old 02-24-2012, 02:58 PM   #10
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
fuck mazda parts. i bought it from bumper-2-bumper, works like a champ. paid $50 to get the bearing swapped once i had the spindle out. $110 with tax and all.
You can loosen that nut without air tools, just need leverage or smarts. I put a breaker on it and used a jack to turn the breaker bar.
ConnerSpeed6 likes this.
-Wetz
QFT
The Following User Says Thank You to xfeejayx For This Useful Post:
jracer (02-25-2012)
 Old 02-24-2012, 03:17 PM   #11
Speeeeeed
06Speed6's Avatar
Posts: 6,527   (View Stats)
Cheap wheel bearings arent cheap when it craps out and your hub welds itself to the spindle. Dont ask me how I know that.
I only use Timkin or oem.
2006 Mazdaspeed 6
jracer (02-25-2012), laxplayermjd (02-26-2012)
 Old 02-24-2012, 07:31 PM   #12
I broke 2 breaker bars. Use air tools.
Current Fail:
The Following 2 Users Say Thank You to MATT DAMOND For This Useful Post:
06Speed6 (02-25-2012), jracer (02-25-2012)
 Old 02-24-2012, 08:27 PM   #13
Noddaford's Avatar
Posts: 198   (View Stats)
Noddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond reputeNoddaford has a reputation beyond repute
Groaned at 48 Times in 7 Posts
Unless it's that cheap China crap, it doesn't matter rather it's from Mazda or NAPA or where ever. It will be the same bearing.
'06 MS6 GT
Wild Wonderful, West Virginia
Cobb AP, Magnaflow Catback, Underbody Cat Delete, ETS TMIC, Corksport SRI & TIP, Spyder LED Tail Lights, HKS BPV, Drilled & Slotted Rotors front and rear w/Ferro Carbon pads, 35% Tinted Glass
Noddaford is offline   Reply With Quote
 Old 02-24-2012, 09:53 PM   #14
LOL I just remembered that the warranty I had covered wheel bearings. My dealer knew I tracked my car, and I didn't want to deal with the hassle of "tracking caused them to fail, warranty void" so I did it myself.
Current Fail:
 Old 02-26-2012, 05:18 AM   #15
xfeejayx's Avatar
Groans: 78
Buy better tools.
Obviously if you have air use it. But you should at some point use a wrench to tighten, with torque specs and all.
-Wetz
QFT
 Old 06-03-2012, 08:34 AM   #16
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
For future searching-
Speed6 front wheel bearing - Timken part# 510063
I found the pair for $67 shipped/38 each
TIMKEN BALL BEARING,510063 - WheelBearingWarehouse.com
340hp / 371tq
The Following 7 Users Say Thank You to TiGraySpeed6 For This Useful Post:
iLLin (04-21-2013), jracer (06-03-2012), laxplayermjd (06-03-2012), Neverlift (06-06-2012), Nitr0EngiE (12-07-2012), phate (10-29-2012), Tokay444 (06-03-2012)
 Old 09-15-2012, 11:44 AM   #17
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
well my front bearings are shot.... mechanic wants 588.71+tax....
mczimer is offline   Reply With Quote
 Old 09-15-2012, 11:49 AM   #18
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
I felt like a fuckin idiot when Greg and I did my brakes earlier this week. Im thinking the wheel bearing was just like domestics, so i will simply remove it and repack it... Spun off the 23mm hub nut only to find zelcho.. Fuckin Fail.. Figured out the hub needed to come off... Fuck that... Bearing Repack Mission... Aborted.
UnknownSuperhero (09-15-2012)
 Old 09-18-2012, 12:26 PM   #19
mczimer's Avatar
INFO FOR PEOPLE IN THE FUTURE:
Wheel bearing choices for the MS6:
Timken 510063Timken 510063
National/MOOGNational/MOOG
**KEY IS 510063 - AWD
I paid 25 bucks each from ebay to my door. Also, the front wheel bearings seem to only be sold seperately, and not as a hub/bearing kit, unless you go OEM. Also, the rear bearings are availible as a kit for Timken/National/MOOG.
The Following 6 Users Say Thank You to mczimer For This Useful Post:
aviator79 (09-23-2013), Constantin (07-31-2013), jracer (09-20-2012), memin (10-30-2013), TiGraySpeed6 (09-18-2012), Tokay444 (09-18-2012)
 Old 09-18-2012, 12:35 PM   #20
Tokay444's Avatar
Groans: 793
Yup, rock auto has timken, national and skf.
Just wondering how much the dealer would have charged if it wasn't warranty work.
There should still be a price breakdown on the receipt.
Demodded.
The Seals
 Old 09-20-2012, 07:34 AM   #21
mczimer's Avatar
Currently my car sounds like metal popcorn in the wheel-well...can it cause further damage to the hub or other components if I keep driving for another week? I am not able to get it into a shop to use a press until next saturday, so I need some good advice here.
 Old 09-20-2012, 07:43 AM   #22
Baloo's Avatar
Posts: 229   (View Stats)
Baloo is the leader of the worldBaloo is the leader of the worldBaloo is the leader of the worldBaloo is the leader of the worldBaloo is the leader of the worldBaloo is the leader of the worldBaloo is the leader of the worldBaloo is the leader of the worldBaloo is the leader of the worldBaloo is the leader of the worldBaloo is the leader of the world
Yes... you can do much more damage. Best case is the bearing packs up and you have to replace the hub along with the bearing. Worst case is the wheel and hub take off when driving and you get the fun task of replacing the brake rotor and whatever else got ruined when the wheel took off.
Baloo is offline   Reply With Quote
 Old 09-20-2012, 08:29 AM   #23
Considering the castle nut holds the assembly together, if it separates you've really fucked up
Start shopping cost for hubs. About 40% of the time the hub gets replaces because it's damaged when trying to press out the bearing that has seized itself into the hub.
Bonus, if you get hubs you can have the bearings pressed in advance and just swap out the hubs. Only take about an hour, and would suggest an alignment afterwords...
340hp / 371tq
mczimer (09-20-2012)
 Old 09-20-2012, 09:20 AM   #24
mczimer's Avatar
Any suggestions for hubs? I have only found Dorman and OEM....
DORMAN Part # 930004 ~80 each
OEM Part #GP9A33060A ~$115 each
I was under the impression Hubs would not need to be replaced, but it would be good to have them on hand in case the stockers are damaged...
 Old 09-20-2012, 09:32 AM   #25
damnit, now I'm not positive if it's knuckle or hub.....
I want to say hub, and that's what I remember reading about
But, I was thinking knuckle when I typed up my previous post...
061 is the hub,
020 is the knuckle
3300A - FRONT AXLE. Fits: 2006 Mazda MazdaSpeed6 | Jim Ellis Mazda
340hp / 371tq
 Old 09-20-2012, 09:48 AM   #26
trf5000's Avatar
Posts: 2,290   (View Stats)
Harbor freight sells a tool set to service these type of bearings without a press. It basically uses a big nut and bolt to manuever them in and out of the knuckle. I have done them on the car without removing the knuckle with this tool, assuming you have enough room with the wheels turned to get the axle out of the knuckle.
Took about 2.5 hours and only cost me the 80 bucks for the tool and the 60 or so for the bearing. You can also use a slide hammer and a socket to get the hub out of the bearing.
2010 MS3 - Sold
2015 CX-5 GT AWD - Current
The Following User Says Thank You to trf5000 For This Useful Post:
Don06speed6 (09-22-2012)
 Old 09-21-2012, 11:07 AM   #27
mczimer's Avatar
Having an O SHIT moment... my car is at the shop to get the bearings swapped, and I just got a call saying the left front axle is not releasing from the hub... which would mean I would have to buy a new hub and a new axle!
Ideas, help me please. The shop guy says this is common for mazdas, on this very spot apparently....
 Old 09-21-2012, 11:22 AM   #28
Not sure what to tell ya- you're paying "pros" to do the work so you don't have to deal with these kinds of issues.
Spin the nut back on upside down so the big ass washer part of the bolt is flush with the end of the axle, have one person pulling out on the knuckle to keep some of the impact from being transferred to the trans, and smack/shock the hell out if it with a pony sledge.
do not apply heat to the axle, that will swell the axle & make it worse.
340hp / 371tq
mczimer (09-21-2012)
 Old 09-21-2012, 11:46 AM   #29
mczimer's Avatar
The mechanic managed the get the fucker off... hopefully I can drive around now!
TiGraySpeed6 likes this.
 Old 09-22-2012, 09:32 AM   #30
Tokay444's Avatar
Groans: 793
You'd have to sheer the axle off for the wheel to come off.
Demodded.
The Seals
 Old 09-22-2012, 04:41 PM   #31
mczimer's Avatar
Just to update, I bought National bearings, which are 100% identical to MOOG and TIMKEN. I bought them on eBay from the following seller: Gage40981
I received them without the individual boxes, but still wrapped, which was not a biggie, but I told the seller, and the guy responded by giving them to me & refunding the entire purchase.... Recommend this seller
http://www.ebay.com/itm/National-USA...item4844c2bc16
57 shipped for two of them!
The Following User Says Thank You to mczimer For This Useful Post:
 Old 09-22-2012, 04:46 PM   #32
Jonny Quest's Avatar
Posts: 365   (View Stats)
Jonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the worldJonny Quest is the leader of the world
Groans: 43
Groaned at 111 Times in 19 Posts
what requires you to change them? i still have a wheel tick. lol
Jonny Quest is offline   Reply With Quote
 Old 09-22-2012, 04:57 PM   #33
mczimer's Avatar
Thumpy feel in pedals while crushing, ticking noise, metal popcorn from wheels... If you put all 4 wheels in the air and put the car in 1st gear makig all 4 wheels spin, you can put a stethoscope to the hub and hear if it's not smoothly turning too...
 Old 09-22-2012, 04:58 PM   #34
Groans: 43
looks like im changing those when i go in for rods lol
 Old 09-22-2012, 05:12 PM   #35
Tokay444's Avatar
Groans: 793
Wub wub wub wub faster and faster with speed.
tbcota25 likes this.
Demodded.
The Seals
 Old 09-22-2012, 10:44 PM   #36
Groans: 43
mine isn't faster with speed its constant speed but it gets louder...
 Old 09-23-2012, 06:34 AM   #37
mczimer's Avatar
Same difference. Do what I said above and listen
 Old 09-23-2012, 03:23 PM   #38
IlleztImportz's Avatar
Posts: 169   (View Stats)
IlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond reputeIlleztImportz has a reputation beyond repute
I'll be replacing my wheel bearings this weekend. I'll just be removing the hub and taking it in to a machine shop to have pressed in. Bought my bearings from wheelbearingwarehouse as @TiGraySpeed6 mentioned. $67 shipped for 2.
I'm not getting a 'popcorn/tick' sound though, instead it sounds more like a low 'drone' that starts at about 30-35mph and only gets louder the faster I go. From my experience, if you have the car in the air and shake/wiggle the wheel at 12&6 o'clock you could determine if its a bad bearing. Unfortunately mine doesn't budge but hopefully the new wheel bearings will fix it
IlleztImportz is offline   Reply With Quote
The Following 2 Users Say Thank You to IlleztImportz For This Useful Post:
TiGraySpeed6 (09-23-2012), Tokay444 (09-24-2012)
 Old 09-23-2012, 03:37 PM   #39
mczimer's Avatar
Cost is $57 shipped if you buy from the seller I noted above... but to all his own, good luck!
 Old 09-24-2012, 03:31 AM   #40
Tokay444's Avatar
Groans: 793
24-34 bucks in rock auto.
Get the retaining clip too. 2.49
Demodded.
The Seals
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f106/wheel-bearing-105904/
Weird noises - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 07-10-2013 12:09 PM
Throw Out Bearing letzleta 2010 MS3 - Troubleshoot/Diagnostics 11 06-20-2016 09:26 AM
MS3 wheel bearing going out??? buckeyepost MazdaSpeed 3/6 - Suspension & Brakes 22 01-07-2013 03:07 PM
Bad Wheel Bearing?? emag remrofni MazdaSpeed 3 - Engine, Transmission & Driveline 4 01-15-2012 09:43 PM
wheel bearing info davidjacob MazdaSpeed 6 - How-To's 0 06-19-2010 09:05 PM
Page generated in 0.60368 seconds with 35 queries
