Notices
Like Tree29Likes
 Old 05-22-2012, 06:24 AM   #1
NATOR Photog
Domino81's Avatar
Posts: 3,920   (View Stats)
Groaned at 61 Times in 26 Posts
Default 40 degrees above ambient... with a CP-e FMIC... Seriously??!
So I'm having a hard time understanding how my newly aquired FMIC is HOTTER, yes, I said HOTTER driving around in morning traffic than my CP-e TMIC. Before doing the coolant bypass mod I was seeing 40 above ambient. Now I HAVE the coolant bypass done AND and I'm seeing 40 above ambient. That being said the MOMENT I'm under boost it shoots down to 90 degrees, and I was around 105 in 67 degree weather this morning. I was seeing pretty consistent 30 above after the coolant bypass with my TMIC.
Anthony D. Christiano
2008 CosmicBlue Mazdaspeed3 - 294whp/335wtq on stock K04, new BNR Stage 3 numbers coming soon...
BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, 3-bar map and connector, PTP injector seals and studs, Kritz 3-port boost solenoid, Sure Return, CP-E FMIC, TWM STS, AutoTech Fuel Pump Internals, James Barone 88-Duro RMM, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 ET48, Cobb Rear Sway Bar, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back. BF Goodrich g-Force Sport 235/40/18's, MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz
June 29th - Syracuse, NY MOD MEAT - Why? Because NATOR.
http://www.mazdaspeedforums.org/forum/f464/june-29th-syracuse-ny-mod-meat-146430/#post2081453
The Following 4 Users Say Thank You to Domino81 For This Useful Post:
BigJimMs3 (05-22-2012), Broxer (05-22-2012), rfinkle2 (05-22-2012), tddvrrn (05-22-2012)
 Old 05-22-2012, 06:27 AM   #2
Posts: 5,921   (View Stats)
Groans: 63
Groaned at 29 Times in 24 Posts
Hmmmm, strange goings on. Meth next?
CorkSport Sponsored driver~~~First amphibious PU~~~World record fastest fully bolted 2013 Pu! Fast Pu is Fast best ET> 12.586 best trap> 114.25. Thanks to all who helped me get back in the Pu!
kritz is online now   Reply With Quote
The Following 2 Users Say Thank You to kritz For This Useful Post:
rfinkle2 (05-22-2012), StayBroke (05-22-2012)
 Old 05-22-2012, 06:30 AM   #3
rfinkle2's Avatar
Posts: 12,648   (View Stats)
Groans: 235
This is a really interesting topic. I've seen this on countless cars, my own included. Another change you'll notice is that the radiator is now blocked some, and your ECT's will be notably higher.
One thing that does help is routing the coolant line that is likely resting on cold pipe connecting to the throttle body away from heating it.
Thanks to username Staybroke for the following thread (the part # listed seems somewhat universal and can be ordered from just about any online auto parts store):
High BAT fix.
Tokay444 and voltron...
Unless you need a very high CFM flowing core, for use with a BT, meth is the most effective way of cooling bat's without a doubt.
kritz likes this.
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
The Following 10 Users Say Thank You to rfinkle2 For This Useful Post:
Alpha (05-22-2012), Broxer (05-22-2012), Bucker (05-22-2012), charlesfist (05-22-2012), Domino81 (05-22-2012), kritz (05-22-2012), SLOWHATCH (05-22-2012), smoogs12 (05-22-2012), StayBroke (05-22-2012), Tokay444 (05-22-2012)
 Old 05-22-2012, 06:35 AM   #4
StayBroke's Avatar
Posts: 1,791   (View Stats)
One more thing is: What core are you using?
I noticed a pretty nice change when going from a pg small core to a bigger core that needs a crash bar.
As stated ALOT, if you plan on staying stock turbo, just get a tmic and be set.
2010 MS3 SOLD
2006 MS6 WWP fully loaded
Eagle rods, Wiseco pistons .020, cast topmount mani, catless dp, 4in intake, custom fmic, treadstone tr1035, pte 6262, turbosmart 38mm wastegate, 3.5bar map, egr delete, occ, e cutout, turbosmart vta bov, autotech hpfp, full awr motor mount 88duro, cpe rear diff, turbine tech diff mount, denso itv24, ported stock mani, 06speed6 clutch/flywheel, turbosmart boost t, aux fan controller, motor craft tranny jiz, neo liquid gold
StayBroke is online now   Reply With Quote
The Following 7 Users Say Thank You to StayBroke For This Useful Post:
Alpha (05-22-2012), Broxer (05-22-2012), kritz (05-22-2012), rfinkle2 (05-22-2012), smoogs12 (05-22-2012), tddvrrn (05-22-2012), Tokay444 (05-22-2012)
 Old 05-22-2012, 07:02 AM   #5
NATOR Photog
Domino81's Avatar
Guess what I never got as part of the deal? CP-e makes a re-routed hose...
 Old 05-22-2012, 07:05 AM   #6
reachin' around
adlpb's Avatar
Posts: 6,039   (View Stats)
Groans: 575
Groaned at 29 Times in 27 Posts
My BAT's sitting in traffic, on a hot day (~90 degrees) with the gen2 cp-e FMIC are around 130. As soon as I start moving they drop to 120's, and if I go wot they stay around 105-110. These numbers are considerably lower than with my TMIC, or any comparable aftermarket TMIC for the genpu.
2012 Evolution X GSR - 394awhp / 378awtq
K&N Intake -|- ETS FMIC + UICP + LICP -|- OBX DP/TP -|- Invidia N1 Sinlge Tip CBE -|- Grimmspeed 3-port EBCS -|- FIC 1100cc Injectors -|- Walbro 255lph FP -|- Forge BPV -|- Innovate Wideband AFR / Boost Gauge -|- GoldenEvo E85 Tune -|- TEIN Monoflex Coilovers -|- Hotchkis 32mm RSB -|- Whiteline Rear Endlinks -|- Cusco Front Strut Bar -|- Hawk HP+ Pads -|- Goodridge SS Brake Lines -|- Motul RPF600 Brake Fluid -|- XXR 527 18x9.75 -|- Hankook Z214 C91 275/35/R18 Racing Slicks
The Following User Says Thank You to adlpb For This Useful Post:
 Old 05-22-2012, 07:18 AM   #7
dubunderpar's Avatar
Posts: 829   (View Stats)
Last night when we were driving it around after the clamp issues, I was surprised to see those temp numbers since it was only mid-upper 60's. I see meth in your future....
dubunderpar is offline   Reply With Quote
The Following 2 Users Say Thank You to dubunderpar For This Useful Post:
 Old 05-22-2012, 07:30 AM   #8
thread killer
p057's Avatar
Posts: 1,431   (View Stats)
p057 has disabled reputation
Groans: 87
Groaned at 14 Times in 7 Posts
This is what I would probably do, since I spend a lot of time thinking about doing the FMIC on my car.... one day.
Make sure all your pipes are sufficiently away from heat sources (coolant hoses, etc.) and if your intercooler is bumping uglies with your radiator, find some way to put spacers or some sort of material between the two to keep them apart and not touching so you're not constantly warming up the core, defeating its purpose. You can even try header wrap or heat reflection tape on most of the pipes you can get to so you can keep heat away from them.
My plan when going FMIC eventually is to wrap as much of my piping as possible with some sort of reflection tape, some sort of insulator, and then more reflection tape to make sure that any heat that tries to get through just doesn't. If you cant relocate a pipe, put something between it like a wider cut piece of silicone tubing. Doesn't transfer heat as much as direct contact, i'd think.
Good luck.
'07 MS6
GT3071R
Originally Posted by Claudekfoury View Post
pull down your pants and lets talk man to man.
 Old 05-22-2012, 07:35 AM   #9
rfinkle2's Avatar
Groans: 235
They do?
adlpb.. I agree our core is big enough to do some pretty serious cooling, but it is still ass backwards that a fmic, which you would expect to be better @ avoiding heatsoak due to its location, is exactly the opposite. LOL
adlpb (05-22-2012), Tokay444 (05-22-2012)
 Old 05-22-2012, 07:38 AM   #10
NATOR Photog
Domino81's Avatar
FWIW... it's DEFINITELY touching the lower radiator hose.
In fact, I had to shove it to the side to get the pipe to take up the same real estate the lower hose usually occupies.
The Following 2 Users Say Thank You to Domino81 For This Useful Post:
rfinkle2 (05-22-2012), Tokay444 (05-22-2012)
 Old 05-22-2012, 07:42 AM   #11
reachin' around
adlpb's Avatar
Groans: 575
They do?
In what way does it act the opposite?
I'm getting logs from TMIC Gen2's with BAT's in the 140's-160's after heat soaking. And their temps while sitting in traffic are worse than mine.
I don't think core size really makes a difference when you're sitting in traffic. If there's no airflow then the heat is going to be conducted through the metal. Once you get moving, convection will clear that out.
The cp-e design is strange.
A friend of mine who has the same car/FMIC has the radiator hose touching. Mine is about 1.5-2 inches away. It might all depend on how the user installs the hoses...
Sid3wayS likes this.
Last edited by adlpb; 05-22-2012 at 07:42 AM. Reason: MSF Database - Automerged Doublepost
 Old 05-22-2012, 07:44 AM   #12
rfinkle2's Avatar
Groans: 235
I don't see that type of heat soak with a tmic most of the time, but you are in sunny FL, so maybe when the hotter weather hits, I'll be brutally reminded.
IIRC, my tmic bat's were < fmic bat's after sitting in traffic .
 Old 05-22-2012, 07:47 AM   #13
reachin' around
adlpb's Avatar
Groans: 575
Really?
Hmm...what are your BAT's sitting in traffic? Mine have never gone over 135 and that's pushing it.
With my OEM TMIC they were higher for sure.
The Following 2 Users Say Thank You to adlpb For This Useful Post:
rfinkle2 (05-22-2012), skeeter149 (05-22-2012)
 Old 05-22-2012, 07:49 AM   #14
uncorked11's Avatar
Posts: 1,153   (View Stats)
Groans: 159
Mine does the same thing. I do believe it drops in tempature faster the the stock TMIC. I have also adjusted the coolant pipe that used to rest on the cold pipe.
EDIT: I average about 95-105 on 55 mph roads during a 40 minute drive. In traffic I will see 120 dropping to 95 between stoplights
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
uncorked11 is online now   Reply With Quote
The Following User Says Thank You to uncorked11 For This Useful Post:
 Old 05-22-2012, 07:49 AM   #15
rfinkle2's Avatar
Groans: 235
Really?
Maybe I just suck. That is totally possible. LOL.
In the summer, I can definitely hit 140* with 212 ect's fml.
I can't remember what my tmic was, but after heatsoaking, they were very close.
adlpb (05-22-2012)
 Old 05-22-2012, 07:52 AM   #16
NATOR Photog
Domino81's Avatar
Might be time to run water with water wetter or Royal Purple ice.
 Old 05-22-2012, 07:52 AM   #17
reachin' around
adlpb's Avatar
Groans: 575
Interesting. I was sitting in line after running AutoX this past weekend, so the engine was being pushed. BAT's 135, ECT's 205, ambient around 85.
 Old 05-22-2012, 08:05 AM   #18
rfinkle2's Avatar
Groans: 235
Do you or adlpb have any experience running distilled water or a cooling agent like water wetter?
I'd like to do it if it helps in the summer time for sure.
 Old 05-22-2012, 08:06 AM   #19
(Toe-kay)
Tokay444's Avatar
Posts: 9,782   (View Stats)
Groans: 525
Do not run water wetter in this car.
Also, the tmic design on this car in both Genwon and pu, is very effective and efficient. Albiet the core itself isn't that efficient, the placement and ducting do work extremely well even after you factor in that the core sits on top of a giant heat source.
I'm still trying to design a heat shield that goes under the core, and seals at the front, and is open and has a doward radius at the back, to promote the vacuum effect already present with the ducting and undertray, and isolate the core from that big heat source called an engine.
Demodded.
Mwho?
The Following 8 Users Say Thank You to Tokay444 For This Useful Post:
3mazdaspeed (05-22-2012), daafisch (05-22-2012), Easter Bunny (05-22-2012), kritz (05-22-2012), rfinkle2 (05-22-2012), SLOWHATCH (05-22-2012), themytb (05-22-2012), TiGraySpeed6 (05-22-2012)
 Old 05-22-2012, 08:07 AM   #20
rfinkle2's Avatar
Groans: 235
Because of the coolant used from the factory and it's inability to mix?
 Old 05-22-2012, 08:11 AM   #21
NATOR Photog
Domino81's Avatar
If you use pure water, that alone from what I understand has a bigger coefficent of heat transfer.
 Old 05-22-2012, 08:13 AM   #22
reachin' around
adlpb's Avatar
Groans: 575
rfinkle2 Another reason why logically seeing FMIC's having equal/higher traffic BAT's than TMIC is that they have a larger surface area (specifically in piping). The piping sits all around the hot parts of the engine, which is more prone to absorb the heat. While the TMIC sits on top of the valve cover, but has considerably less piping. Just a thought.
Of course all this is negligible once you get moving and convection takes place.
The Following 3 Users Say Thank You to adlpb For This Useful Post:
p057 (05-22-2012), rfinkle2 (05-22-2012), SLOWHATCH (05-22-2012)
 Old 05-22-2012, 08:14 AM   #23
rfinkle2's Avatar
Groans: 235
I think Tokay may be referring to the Mazda specific coolant that is factory fill in this car. I have read that water wetter and other coolant additives can gum the coolant system up if mixed with it.
(speaking for Tokay when I shouldn't be / don't have the engineering smartz LOL).
 Old 05-22-2012, 08:15 AM   #24
NATOR Photog
Domino81's Avatar
I suspect it's like mixing green and orange coolants...
rfinkle2 (05-22-2012), themytb (05-22-2012)
 Old 05-22-2012, 08:16 AM   #25
(Toe-kay)
Tokay444's Avatar
Groans: 525
Yes.
We get sludge, and people instantly assume they've blown a head gasket.
At 217 the fan kicks on anyway. It's if you start seeing coolant temps in the 230's you ought to be worried.
Putting tape, insulation, silicone in front of the radiator or behind the fmic core, is only going to limit air flow through those areas as well. Don't do it.
Demodded.
Mwho?
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
adlpb (05-22-2012), Domino81 (05-22-2012), rfinkle2 (05-22-2012), SLOWHATCH (05-22-2012)
 Old 05-22-2012, 08:16 AM   #26
Grumpyjap's Avatar
Posts: 1,618   (View Stats)
(speaking for Tokay when I shouldn't be LOL).
yeah water wetter mixed with coolant created a gummy residue. If you don;t completely flush all the coolant out it will react. I know from experience lol.
cp-e-FMIC/cp-e-HPFP/cp-e-Xcel Nano Intake/cp-e-Nviscid TIP/cp-e-BOV Kit/cp-e-Stage2 RMM/cp-e-xFlex Passanger & Driver Motor Mounts/cp-e-catted DP/cp-e-Nexus cat-back exhaust/cp-e-tow plate/cp-e-Tripple Gauge Pod/Rally Armor-Mud Flaps/TWM-Base Bushings/TWM-Shift Weight/Street Unit-Washer Fluid Cap/Street Unit-Oil Cap/Konig-Milligram/Corksport-Rear Sway Bar/Corksport-Aluminum Skidplate/Corksport-SS Brakelines/GTSpec-rear v-brace/GTSpec-link reinforecement panel/GTSpec-rear lower tie bar/GTSpec-4 points ladder brace/Lamin-x-Headlight film/Lamin-x-Taillight film/TWM-Full replacement shifter/TWM-Big Type R knob & Hybrid Knob/TWM-Shift boot/3M-1080 Matte Dark Grey Wrap/3M-1080 Brushed Steel Wrap/HKS-SSQV BOV/DG Motorsports-CF front lip/DG Motorsports-CF Rear wing extention/H&R-Coilovers/COBB Tuning-AccessPort/
Grumpyjap is online now   Reply With Quote
The Following 3 Users Say Thank You to Grumpyjap For This Useful Post:
 Old 05-22-2012, 08:21 AM   #27
f-castrillo's Avatar
Posts: 1,379   (View Stats)
I had more heatsoak on my CS TMIC vs. stock, until I installed the TIGs. I did the TB coolant bypass as well, but I don't think it had as significant an impact as the TB and IM TIGs did. I'm guessing the extra heat soak on the CS TMIC was due to the bigger core size... once it's heated up, that's a bigger mass of metal to cool off.
I still get the issue, actually, even with the TIGs and coolant bypass, if I drive somewhere, park for 20-30 mins, and drive off. My cruising BATs are easily over 120F under those conditions, and while the meth brings things down quickly for a moment, it heats back up pretty quick since the metal hasn't been given sufficient time to cool. Once it's cooled off, my cruising BATs aren't much different than IAT, which isn't that much higher than ambient.
JBR RSB, Stage2 OCC, Stage 2 SSP, IM TIG, 70D RMM, 70D PMM // DevilsOwn Stage 2 WMI kit + DO7 nozzle (MSF-prize) // COBB AP (Self-tune), XLE BPV // Corksport TMIC, SRI, TIP // Racing Beat Cat-back Exhaust // Denso Iridium ITV22 Spark Plugs // SURE TB TIG // CNT Catted DP // KMD HPFP Internals // TSW Nurburgring 18x7.5 ET45 Matte Black // SWIFT Spec-R Lowering Springs //
IN PROGRESS/FUTURE: Not sure
f-castrillo is online now   Reply With Quote
The Following User Says Thank You to f-castrillo For This Useful Post:
 Old 05-22-2012, 08:28 AM   #28
MSF Leg Humper
Monotonous ONE's Avatar
Posts: 3,343   (View Stats)
Groans: 727
Groaned at 78 Times in 59 Posts
TIGs make an insane difference
get them asap
Monotonous ONE is offline   Reply With Quote
The Following 2 Users Say Thank You to Monotonous ONE For This Useful Post:
chuckms6 (05-22-2012), rfinkle2 (05-22-2012)
 Old 05-22-2012, 08:29 AM   #29
NATOR Photog
Domino81's Avatar
What are TIG's?
 Old 05-22-2012, 08:30 AM   #30
reachin' around
adlpb's Avatar
Groans: 575
What are TIG's?
Mazdaspeed 3 : James Barone Racing, Custom Fabrication
Some say they work, some say they don't. If you have to remove your manifold for injector seals/porting/cleaning, you might as well put them on.
 Old 05-22-2012, 08:32 AM   #31
amoosenamedhank's Avatar
Posts: 1,208   (View Stats)
Groans: 45
Groaned at 27 Times in 20 Posts
Regardless of which Air/Air intercooler setup you choose, if you aren't moving, there's no airflow..... and if there's no airflow, then there isn't going to be a cooling effect.
The intercooler design should be judged by its ability to recover and bring your BATs back down once you've started moving again.
amoosenamedhank is online now   Reply With Quote
The Following 6 Users Say Thank You to amoosenamedhank For This Useful Post:
chuckms6 (05-22-2012), Easter Bunny (05-22-2012), kritz (05-22-2012), rfinkle2 (05-22-2012), SLOWHATCH (05-22-2012), themytb (05-22-2012)
 Old 05-22-2012, 08:34 AM   #32
NATOR Photog
Domino81's Avatar
The moment I posted then closed the thread I thought of that...
adlpb (05-22-2012), rfinkle2 (05-22-2012)
 Old 05-22-2012, 08:49 AM   #33
(Toe-kay)
Tokay444's Avatar
Groans: 525
I see bat's in the 170's in situations where I drive, park, and drive again.
Demodded.
Mwho?
 Old 05-22-2012, 08:52 AM   #34
rfinkle2's Avatar
Groans: 235
I hope this doesn't come out douchey, but I'd rather have an intercooler that heat soaks to 140, and can only cool to 120, than have a core that heatsoaks to 200 but has the ability to cool down to 120, but I totally understand where you are coming from.
I'm most interested in time spent / bat.
 Old 05-22-2012, 09:01 AM   #35
NATOR Photog
Domino81's Avatar
Gaawwwwddd, Rob... what a douchey thing to say... :scoff:
 Old 05-22-2012, 09:31 AM   #36
sick_role's Avatar
Posts: 765   (View Stats)
sick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the worldsick_role is the leader of the world
Groaned at 6 Times in 3 Posts
not trying to derail here; but why aren't more people spraying their top mounts? I know a few on here have done it but I thought there'd be more. Has it been decided that it's not worth the effort of adding a jug, a few nozzles, and tapping/running a switch to a power source?
To me, that seems a lot easier than even installing a front mount...then again I'm not good at smarts.
"Also you cannot do anything "like a boss" in a srt4. If you ever get a job where the boss drives a neon, go somewhere else. Apparently that job has no future." - themytb
Oh you mean dogs. Yeah I like dogs. I drive a Hyundai.
sick_role is offline   Reply With Quote
 Old 05-22-2012, 09:33 AM   #37
rfinkle2's Avatar
Groans: 235
Spray the actual intercooler for water evaporation or meth into the cold pipe?
 Old 05-22-2012, 09:43 AM   #38
sick_role's Avatar
The actual intercooler w/ water & alc. or is that equal work to meth into CP for less reward?
 Old 05-22-2012, 09:47 AM   #39
rfinkle2's Avatar
Groans: 235
Spraying meth (or h20) into the intake tract is definitely going to have a greater effect than on top of the intercooler, BUT, that doesn't mean that spraying the actual IC with water wouldn't help.
IIRC, previous generation WRX STI's actually came with an IC sprayer stock.
If I was going to get a spray bar though, I'd spray C02 on the intercooler rather than h20.
The kit is pretty cheap too.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
m249saw (05-22-2012), sick_role (05-22-2012), Vader (05-22-2012)
 Old 05-22-2012, 09:55 AM   #40
No friends from 9-5
ricknm's Avatar
Posts: 766   (View Stats)
ricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the worldricknm is the leader of the world
I had that problem too until I realized that throughout my very anal job of making sure every clamp was tight, I somehow managed to forget to check the last coupler that attached to the turbo. DUH. boost leak = high bats. I fixed that the next day. But I do still see high bats as well.
2012 CRYSTAL WHITE PEARL
tuned by RFINKLE2 w/ 4gallon E85 mixture
soon to be BNR powered
ricknm is offline   Reply With Quote
The Following User Says Thank You to ricknm For This Useful Post:
Ambient Temp Sensor 802_Anthony Mazdaspeed3/6 General Discussion 15 06-27-2011 05:02 PM
0 degrees of toe Biggs MazdaSpeed 3/6 - Suspension & Brakes 5 05-08-2011 07:49 PM
Do Ambient Temps Effect Boost ? Scatt Nasty MazdaSpeed 3/6 - Turbo Induction 14 02-27-2009 05:24 AM
Page generated in 0.63461 seconds with 34 queries
