 Old 05-29-2009, 04:07 PM   #1
nic464's Avatar
Posts: 6   (View Stats)
nic464 is an unknown quantity at this point
Default 5th-6th gear boost
Hello, i think i have a problem with my 5-6 gear. I can't get full boost in 5 gear when i floor it at 3500rpm.(Same with the 6th) I peak at 14psi and it goes to 12.5-13. Is it a protection from my ecu or is it anormal and what could be the cause ? I think 3rd and 4th gear are ok they peak at 18psi and go to 16psi.
Here's my mod : Cobb sf intake,cobb accesport and catback mazdaspeed
Thanks!
nic464 is offline   Reply With Quote
 Old 05-29-2009, 04:10 PM   #2
wakeboarddude's Avatar
Posts: 860   (View Stats)
wakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the worldwakeboarddude is the leader of the world
I had pretty much the same prob but only in 6th gear. I just copy and pasted my 5th gear boost load table into my 6thgear and now it works perfect! Hope that helps!
09 CWP Speed3 GT- CP-e Nano, Speedie6 TIP, CP-e Catless Downpipe, ED FMIC w/ GodSpeed core, Devils Own Stage 2 Meth Injection Kit, KMD v2 fuel pump internals, HKS BPV, SU full motor mounts & shifter bushings, Cobb Springs, 1 res delete in cbe, HID Fogs, AutoMeter Cobalt boost gauge, Michi OCC, Denso 1 step colder plugs, MSD DH, COBB AccessPort V105 Stage 2+sf 93 fmic
[Today 11:50 PM] aaronc7: i just measured mine, a little over 12
wakeboarddude is offline   Reply With Quote
 Old 05-29-2009, 04:24 PM   #3
nic464's Avatar
In ATR i guess you're talking the Boost comp in boost tables ?
 Old 05-29-2009, 04:53 PM   #4
ya sorry i dont have it on this computer so i cant remember the exact words. Its were it has boost for normal BATs and High BATs!
 Old 05-29-2009, 05:06 PM   #5
nic464's Avatar
ok! please can you confirm when you will be on your computer. Just want to make sure i'm not messing with the bad things hehe.
 Old 05-30-2009, 05:15 PM   #6
alright! It'll be on monday cause im out of town this weekend!
 Old 05-31-2009, 08:15 AM   #7
AFcadet's Avatar
Posts: 937   (View Stats)
AFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the worldAFcadet is the leader of the world
Um...I wouldnt suggest going WOT in 5th or 6th gear at only 3,500...thats putting a HUGE amount of load on the engine in that high of a gear. I don't go WOT in 5th or 6th unless im at like 4500 or above. If your around 3,500-4,000 in 5th or 6th, just downshift so your not putting all that load on your engine.
And wakeboarddude is refering to the "Req. load Gear X" table...
AFcadet is offline   Reply With Quote
The Following 2 Users Say Thank You to AFcadet For This Useful Post:
nic464 (06-03-2009), wakeboarddude (06-02-2009)
 Old 06-02-2009, 03:43 PM   #8
Thanks AFcadet..it is the Throttle Req. Load Gear X..and make sure to adjust it in one of the Normal BAT table!
The Following User Says Thank You to wakeboarddude For This Useful Post:
nic464 (06-03-2009)
 Old 06-03-2009, 05:20 AM   #9
nic464's Avatar
Alright thank you guys 1!!
 Old 06-03-2009, 07:16 AM   #10
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Groans: 166
um....at 3500rpm in 6th gear, youre going 80mph. The reason that you dont load the car in low rpm's is the fuel pump not keeping up with the boost that comes with that load. The next time im on the highway, i'll be sure to note what the fp is at 3500rpm. I bet its just fine.
There were plenty of other posts about people going WOT in 5th or 6th gear at VERY LOW speeds (40mph) which is not good, but at 3500rpms at 80mph is a different story.
 Old 06-03-2009, 12:34 PM   #11
phantom6294's Avatar
Posts: 255   (View Stats)
phantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the worldphantom6294 is the leader of the world
Actually 6th gear @ 3,500 RPM should be 93 MPH. That's by the numbers. For me, there is a 200 RPM discrepancy between my tachometer and DashHawk reading; my tachometer reads 200 RPM high.
phantom6294 is offline   Reply With Quote
 Old 06-04-2009, 03:28 PM   #12
AFcadet's Avatar
No.
Fuel Pressure has nothing to do with putting excessive load on your engine. You really shouldnt go WOT on ANY car when you are in a high gear, low RPM...period. It puts a huge amount of uneeded load on your engine.
I mean if you want to think its all about fuel pressure...go for it. But this is a general rule for all cars, it puts a huge amount of uneeded load. WOT + Low RPM + High Speeds = No No
Boost gauge vs. AP boost reading.. which is correct? Unoriginalusername MazdaSpeed 3/6 - Turbo Induction 13 05-23-2011 05:41 PM
6th gear boost variation ispypsi MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 04-08-2009 09:48 PM
fixed boost psi vs boost table settings? johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 8 02-03-2009 04:05 PM
Gear Oil Phantom MazdaSpeed 3 - Engine, Transmission & Driveline 5 09-01-2008 09:28 PM
Page generated in 0.36824 seconds with 24 queries
