 Old 05-10-2009, 01:49 PM   #1
spool's Avatar
Posts: 28   (View Stats)
spool is an unknown quantity at this point
Question ATP FMIC
Does anyone have the ATP FMIC or any hard info on it (dyno #'s, AIT's)....Does it fit without problems? And how does it stack up against other FMIC's (Cobb,CP-E,Corksport,Exhaust Depot)? Any info will be appreciated.
spool is offline   Reply With Quote
 Old 05-11-2009, 06:04 PM   #2
spool's Avatar
anyone ?
Mods: TurboXS FMIC, COBB SRI, COBB TIP, AEM Tru-Boost, AEM UEGO, SreetUnit TP, PT-Performance Trans Mount...for now
 Old 05-11-2009, 06:07 PM   #3
aaronc7's Avatar
Posts: 8,037   (View Stats)
Groans: 370
its core is tiny. i would personally not get it. nothing special or great about it really
The Following User Says Thank You to aaronc7 For This Useful Post:
spool (05-12-2009)
 Old 05-12-2009, 09:08 AM   #4
spool's Avatar
I went ahead and got the TXS it was on sale and I've heard no complaints so far.
Thanks aaronc7
 Old 05-12-2009, 09:58 AM   #5
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
I have sold a few ATP FMICs and get complaints about fitment, apparently there is a good amount of 'making it work' involved. The biggest issue seems to be shift weight clearance. The core is also one of the smaller cores on the market however it does use a genuine Garrett core which looks a lot nicer than some of the chinese cores I have seen on bigger name kits. I know that the ATP does not let you reinstall the belly pan without serious modification and the ATP is also not available with a stock bpv flange so you have to get a Greddy or HKS or Tial valve or get your own flange welded.
the ATP also puts the bpv flange on the hot pipe as opposed to the cold pipe like most other brands. This makes it almost impossible to install w/ a cold air intake without relocating the flange. At the ATP price point I usually recommend the TurboXS instead, but if you are getting a good deal on it, go for it.
2007 Mazdaspeed3 Sport, True Red
ElBartoRex is offline   Reply With Quote
 Old 05-12-2009, 10:07 AM   #6
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
I did hear the TXS core is to big and cuases pressure loss.
 Old 05-12-2009, 01:31 PM   #7
wisniaPl's Avatar
Posts: 933   (View Stats)
wisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond reputewisniaPl has a reputation beyond repute
Im lwas like wtf when I first saw my boost gauge going from steady 20 to 16 psi....from 5 to 6 k rpms .... the turbo is just out of breath
wisniaPl is offline   Reply With Quote
 Old 05-12-2009, 01:41 PM   #8
ElBartoRex's Avatar
what you are describing is the boost taper at redline-- a pressure loss from an intercooler is throughout the entire curve, it has to do with the core efficiency.
 Old 05-12-2009, 03:07 PM   #9
wisniaPl's Avatar
so i gues pressure los is not that bad
 Old 05-12-2009, 03:47 PM   #10
ElBartoRex's Avatar
for most FMIC cores the pressure loss will be .5-1.5 psi
 Old 05-12-2009, 06:19 PM   #11
spool's Avatar
Yeah, I talked to TXS today and Mark said the pressure drop is a little bit higher than most, it's at about 2-2.5 but I don't think that's super bad....I think it could be overcome with proper tuning.
 Old 05-12-2009, 07:35 PM   #12
wisniaPl's Avatar
can overcome it with biger turbo
The Following User Says Thank You to wisniaPl For This Useful Post:
Darksun280 (05-12-2009)
 Old 05-12-2009, 08:12 PM   #13
spool's Avatar
wisniaPl, you are correct and since Mazda gave me a gigantic middle finger about my Warranty...trust me it is in the works. Just gotta figure out the set-up and the cash.
 Old 05-15-2009, 01:52 PM   #14
thanotosq's Avatar
Posts: 303   (View Stats)
thanotosq has much to be proud ofthanotosq has much to be proud ofthanotosq has much to be proud ofthanotosq has much to be proud ofthanotosq has much to be proud ofthanotosq has much to be proud ofthanotosq has much to be proud ofthanotosq has much to be proud ofthanotosq has much to be proud ofthanotosq has much to be proud of
Thanks aaronc7
where did you get it?
thanotosq is offline   Reply With Quote
 Old 05-15-2009, 03:26 PM   #15
gsrtype1's Avatar
Groans: 102
thats one thing the ets tmic u lose less pressure than stock and i'm sure with some fmic you lose less than stock too i'm just sayen.
 Old 05-15-2009, 05:12 PM   #16
Buildabong's Avatar
Posts: 3,034   (View Stats)
Buildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the worldBuildabong is the leader of the world
Groans: 213
Groaned at 274 Times in 187 Posts
Ftw!! Get a home made one with 1.5" pipes and a super duper small core like 10x3x1.5 yayaya k04 for the win!! Ftmfw!!
Buildabong is offline   Reply With Quote
 Old 05-16-2009, 07:17 AM   #17
tomsnatchez's Avatar
Posts: 18   (View Stats)
tomsnatchez has a spectacular aura abouttomsnatchez has a spectacular aura about
sub'd
tomsnatchez is offline   Reply With Quote
 Old 05-17-2009, 11:03 AM   #18
spool's Avatar
I got the TXS from Oakos.com and since I'm in Illinois and they're in Michigan it got here next day with ground shipping... HAHA
Cobb FMIC vs Exhaust Depot FMIC mrjoshyman MazdaSpeed 3/6 - Turbo Induction 44 04-20-2009 10:30 AM
Fmic and WI ms3-87 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 10 01-10-2009 11:24 PM
Cobb Ap FMIC map with Cobb FMIC not driveable Unoriginalusername MazdaSpeed 3/6 - ECU Computer Tuning 119 07-20-2008 08:40 AM
Page generated in 0.36562 seconds with 27 queries
