Notices
Like Tree98Likes
 Old 09-25-2012, 09:51 AM   #241
rfinkle2's Avatar
Posts: 12,564   (View Stats)
Groans: 235
Originally Posted by eric@edgeautosport View Post
So it looks to be a combination of factors to cause smokey turbos.
LOL. Definitely a few things going on @ once.
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
 Old 09-25-2012, 10:13 AM   #242
Tabasco69's Avatar
Posts: 439   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
Yeah but increased boost should also help the oil seals keep the oil in the chra.
The oil pump should have a internal pressure regulator, that could be a possible failure point and not the pump itself, I mean the pump's output is directly related to how fast the pulley turns/engine rpm.
I run a -3an braided ptfe oil feed with a .035 restrictor off a filter oil plate and a -10an return, I had major problems with both the hot and cold side pushing massive amount of oil past the seals when the RETURN line came apart internally, modern qaulity oil has additves that supposedly minimize foaming issues but all you have to do is look at the 3 layer cocktail you get when dumping a catch can to see a different picture.
The crankshaft will turn at a maximum on most mzr's at @ 6700rpm versus the 170,000-200,000 rpm of the chra's common shaft, if the oil can be whipped/frothed by the engine's rotating assembly you can bet the common shaft is going to do the same.
If there is a problem that can cause backpressure anywhere inside of the engine the potential for oil loading pipes will come about, this includes the pcv system both under vacuum and positive pressure states, I think we are all aware there are 2 distinct vent systems for the crankcase, under vacuum it is the lower sealed tract that is assisted by vacuum from the intake manifold, that shuts down during positve manifold pressure and leaves the valve cover vent to do the job of venting.
Tabasco69 is offline   Reply With Quote
The Following User Says Thank You to Tabasco69 For This Useful Post:
RayRay (09-25-2012)
 Old 09-25-2012, 10:54 AM   #243
rfinkle2's Avatar
Groans: 235
Found some pressure numbers for an ms6 (not sure of the factory specs, but will check the manual @ home tonight).
A problem with oil pressure. Need Help. - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum
1000 RPM - 20 psi
2000 RPM - 40 psi
3000 RPM - 60 psi
4000 RPM - 63 psi
5000 RPM - 66 psi
6000 RPM - 70 psi
(from the ms6 thread)^
"Oil pressure entering a ball-bearing turbocharger needs to be between 40 psi and 45 psi at the maximum engine operating speed."
from Garrett's site^
Couple that with many of us running 40 weight oil and you probably have roughly 2x's the recommended oil pressure running through the turbo.
The Following 6 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (09-29-2012), doubleflusher (09-25-2012), helmetface (09-29-2012), jmhinkle (09-25-2012), Pointless (11-11-2012), trf5000 (10-17-2012)
 Old 09-25-2012, 11:25 AM   #244
EdgeAutosport.com's Avatar
Posts: 4,535   (View Stats)
Groaned at 9 Times in 7 Posts
1000 RPM - 20 psi
2000 RPM - 40 psi
3000 RPM - 60 psi
4000 RPM - 63 psi
5000 RPM - 66 psi
6000 RPM - 70 psi
So why do guys put a heavier weight to stop smoking on a k04?
Auto Tech Fuel pump internals #1 Source!
PM Me for Details or call me 303-268-2140
The Following 2 Users Say Thank You to EdgeAutosport.com For This Useful Post:
breakfstincluded (10-17-2012), rfinkle2 (09-25-2012)
 Old 09-25-2012, 11:25 AM   #245
<span style="text-shadow:2px 2px 4px purple; "><span style="color:#6B6B6B; "><span style="text-shadow: 0px 0px 0.2em red, 0px 0px 0.2em red, 0px 0px 0.2em red; ">Axle Breaker</span></span></span>
jmhinkle's Avatar
Posts: 3,959   (View Stats)
jmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the worldjmhinkle is the leader of the world
Groans: 152
60 psi at 3000 rpm is tremendous pressure on any motor. Hence the need for a restrictor. You guys need to stop listening to ATP. It's not an ATP turbo, it is a Garrett turbo. Garrett says restrictor, do it or GTFO. Unsubbing because I'm always right and my turbo has no issues.
jmhinkle is offline   Reply With Quote
The Following 6 Users Say Thank You to jmhinkle For This Useful Post:
atvfreek (09-29-2012), crazyp (09-29-2012), doubleflusher (09-25-2012), Easter Bunny (09-26-2012), rfinkle2 (09-25-2012), Tabasco69 (09-25-2012)
 Old 09-25-2012, 01:10 PM   #246
Posts: 10,145   (View Stats)
Groans: 98
i ran my 3076 for 20k miles with stock lines and zero problems
my GTX35R is currently hooked up identically and i still have no problems. if something clogged the OP's turbo, why should garrett/ATP be responsible? its not their fault it happened, the turbo wasent designed to run with no oil in it.
btw those pressure measurements are probably measured at the oil filter housing. do u think the entire oil system with all its passages operates at the same pressures? do u think theres 60psi coming out of the turbo?
i would never run an inline filter with a turbo oil feed or add a restrictor to an ATP turbo but thats just IMHO
KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust
510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs
WWW.SONICTUNING.COM
Certified RichTune e-Tuner
KILLAH BUILT by SPEED PERF6RMANC3
I could cry right now im so proud of you.
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
86azms3 (09-25-2012), EdgeAutosport.com (09-25-2012), Payne Racing 67 (09-28-2012), rfinkle2 (10-01-2012), rigor (10-18-2012)
 Old 09-25-2012, 02:06 PM   #247
Will fuck up ur day
chimmike's Avatar
chimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the world
Groans: 413
Groaned at 205 Times in 121 Posts
Frankly I think you're going about this with far too much generalization. If you're not absolutely, 100% positive what YOUR engine oil pressure is in the turbo feed line, you're guessing, plain and simple.
This isn't to say that I am.....but generalizing that they all need restrictors is now clearly a generalization that is not necessarily correct. I know you don't like ATP, but they move enough garrett turbos for me to think they know the engineers at garrett and have had conversations before. Aside from the fact that they're familiar with the mzr somewhat (believe it or not)
07 MS3 bone stock?
The original Genpoo Hater
GTX3076r
FenderRollerRental Rent a fender roller, or MZR DISI Timing tools!
Originally Posted by woodfloor View Post
According to Roddiy, A List of Things as funny as fucking with MSF:
  1. Pissing in a bee hive
  2. Bridging the bus bars in an electrical panel with your dick
  3. Running with the bulls
  4. Willingly climbing into the lion habitat at the Zoo
  5. Shooting yourself in the foot on purpose
  6. Jumping up and down on a Fire Ant hill
@kyle undefined loves giving blowjobs to @raider; in truckstop bathrooms
chimmike is offline   Reply With Quote
The Following 2 Users Say Thank You to chimmike For This Useful Post:
86azms3 (09-25-2012), RayRay (09-26-2012)
 Old 09-29-2012, 07:56 AM   #248
RayRay's Avatar
Posts: 3,115   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
I know jmhinkle is going to yell at me next time he sees me! We just needed to test for ourselves. You always WANT to believe what your manufacturer tells you.
We installed Hals GTX3071 last week. Started getting some smoking issues at wot. Talked to ATP and they still swear you don't need a restrictor. So to test out, we installed the oil feed, block adaptor and restrictor on his car last night. Instantly the smoking went away. Fortunately Hals car had only gone a couple hundred miles (if that much). There did not seem to be any other issues present. We did not measure pressure, just no time or tools. But whatever it is, its more than the gtx can handle. I sent my findings to George. Hopefully ATP will be able to find some new information!
So in short, never listen to Joel! ! Jk! !
I know Hal will not sell any gtx setup without the oil feed and restrictor included. . .
(Thought. . . I don't know what size restrictor they sent me, I'll find out. )
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline   Reply With Quote
The Following 2 Users Say Thank You to RayRay For This Useful Post:
helmetface (09-29-2012), rfinkle2 (10-01-2012)
 Old 09-29-2012, 12:02 PM   #249
InFeXIoN's Avatar
Posts: 1,174   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
I installed my gtx 3071 a couple weeks ago and the ssp feed line they use a .3 restrictor have had no smoking issues.
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is online now   Reply With Quote
The Following User Says Thank You to InFeXIoN For This Useful Post:
 Old 09-29-2012, 12:40 PM   #250
Eatin' Your Tuna
Haltech's Avatar
Groans: 212
Mazda did issue a TSB to its dealers in mid 2009 to stop using 5/30 and replace with 5/40.
Combination of 925 RPM idle speed and 5/40 oil stopped all smoking for me. I only saw the smoking when i installed the DP.
 Old 09-29-2012, 12:45 PM   #251
bnoon's Avatar
Posts: 1,762   (View Stats)
That information is contradictory, no doubt.
bnoon's bolt also stopped smoking turbos IIRC.
MATT DAMOND has a pressure gauge installed.
bnoon, did you ever measure oil pressure in the mazdaspeeds?
We need to find out the oil feed pressure or there will never be an end to the debate.
I have a feeling we are going to see very high pressure in the feed line...
Mazda even decided to use a hard line for feed.
Yes I did measure it. It was above the recommended pressure but I can't remember by how much. I drilled the top of one of my bolts for 1/8 inch NPT fitting and measured it there. Perhaps I need to start selling bolts again and drill/tap the tops for those NPT fittings and perhaps even kit them out. Hummmmm
2008.5 MS3 GT - Sold!
2011 Ford Flex LTD Ecoboost
1986 Porsche 944 Turbo
bnoon is offline   Reply With Quote
The Following 6 Users Say Thank You to bnoon For This Useful Post:
atvfreek (09-29-2012), Easter Bunny (09-29-2012), EdgeAutosport.com (10-01-2012), InFeXIoN (09-30-2012), Pointless (11-11-2012), rfinkle2 (10-01-2012)
 Old 09-29-2012, 01:17 PM   #252
Hunting for teh Fastz
BlueStreak's Avatar
Posts: 1,408   (View Stats)
Been 1300KMs since I installed the restrictor in my GT3071. Turbo is still fine. I'm going to keep running it knowing that it at least wont do any harm.
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
atvfreek (09-29-2012), rfinkle2 (10-01-2012)
 Old 10-11-2012, 02:45 PM   #253
Posts: 8,038   (View Stats)
Groans: 34
hey I think It might have been covered in here but what size is the turbo oil outlet hole in the block?
putting together a custom oil feed kit so I can swap a pressure gauge around and see what the outlet pressure is, what the restricted pressure is and then back to monitor outlet pressure long term.
PERM
07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
The hardest part of modding is knowing when you've met your goal
I dunno though; it sounds good in my head but I'm mostly talking out of my ass.
 Old 10-12-2012, 07:11 AM   #254
Groans: 98
i dont think u can fit anything back there besides the stock line because its so tight from the alternator.
does anyone know if that changed the CHRA on the new GTX turbos? i cant believe everyone is adding restrictors yet no one has actually measured the pressure..........
just because your turbo is smoking doesent mean it A) needs a restrictor and B) needs the restrictor that you guessed the size of when you installed it.
WWW.SONICTUNING.COM
Downmented (10-18-2012), Easter Bunny (10-12-2012), EdgeAutosport.com (10-12-2012), ms3blackmica (04-27-2013), rfinkle2 (10-17-2012)
 Old 10-12-2012, 07:24 AM   #255
Groans: 34
what about a 90 like this tee if I can find the right threads?
PERM
 Old 10-12-2012, 07:25 AM   #256
I would address crank case pressure before anything to see if that resolves the issue.
I have sold several vented catch cans with people with smoking problems even under wot and it completely fixed their problem. Im guessing oil pressure is fine with the current banjo's. I find it hard to believe the pressure of where it is measured via the sandwich plate is the same all the way on top on the head where the feed is.
rfinkle2 (10-17-2012), superskaterxes (10-12-2012)
 Old 10-12-2012, 07:26 AM   #257
Groans: 98
im pretty sure there is just enough room for a banjo fitting + bolt in there. This is why DJ reuses part of the feed/drain lines for all his kits.
WWW.SONICTUNING.COM
Dano (10-12-2012), EdgeAutosport.com (10-12-2012)
 Old 10-12-2012, 07:36 AM   #258
Groans: 34
thus the reason I want to measure it at the outlet up top
guess I'll get back there this weekend and take a look.
ATP makes a "kit" that replaces the OE oil feed...Earls also makes a banjo to -3an or -4 fitting which might work.
anyone know the thread pitch....dustin things its 14mm or maybe 12.
edit
banjo's in many sizes.
PERM
Last edited by Dano; 10-12-2012 at 07:36 AM. Reason: MSF Database - Automerged Doublepost
 Old 10-12-2012, 07:37 AM   #259
Dano this is the ssp line at the shop for the garrett turbo setups. The part in the picture is the part that threads into le head.
The Following User Says Thank You to EdgeAutosport.com For This Useful Post:
Dano (10-12-2012)
 Old 10-12-2012, 07:39 AM   #260
Groans: 34
and that goes all the way to the block?
if so there would have to be plenty of room.
forget the placement of the restrictor in this pic but you get an idea of what I am trying to do.
I was thinking the restrictor or straight ntp to an would go right into the block which obviously it can't...or can it
PERM
Easter Bunny (10-13-2012), rfinkle2 (10-17-2012)
 Old 10-12-2012, 07:41 AM   #261
Will fuck up ur day
chimmike's Avatar
Groans: 413
the 90 does fit into the block portion (on my speed3) for me.
07 MS3 bone stock?
GTX3076r
Dano (10-12-2012), rfinkle2 (10-17-2012)
 Old 10-12-2012, 07:43 AM   #262
Groans: 34
WTF is the threads in the block connection lol
1/8th NPT
12mm
14mm
que'
PERM
 Old 10-12-2012, 12:42 PM   #263
Dano looks like the ssp is block adapter to 3AN
Includes:
– 3AN Stainless Steel Teflon Coated Hose (Red, Blue, Black or Clear)
– Block Adapter to 3AN with new copper crush washer.
– Turbo Feed Fitting for 1/8” NPT (Precision Turbos) in straight or 90deg.
chimmike likes this.
 Old 10-12-2012, 12:45 PM   #264
Will fuck up ur day
chimmike's Avatar
Groans: 413
My line is -4, fwiw
Sent from my iPhone your mom's face
07 MS3 bone stock?
GTX3076r
The Following User Says Thank You to chimmike For This Useful Post:
Dano (10-12-2012)
 Old 10-12-2012, 12:46 PM   #265
Edit let me measure the block adapter.
Also on the ssp kit the restrictor screws right into the turbo then the line
Dano (10-12-2012), InFeXIoN (10-12-2012)
 Old 10-12-2012, 01:35 PM   #266
Groans: 34
My line is -4, fwiw
hum...so it looks like some ATP "kits" are 3AN while others are 4AN.
The kit I was looking at was a 3AN 22" line.
22" Low profile -3 LINE Kit for GT25R through GT35R turbos : atpturbo.com
PERM
 Old 10-12-2012, 08:22 PM   #267
InFeXIoN's Avatar
You'd be correct as that is what I'm running.
Build Complete!!!!
 Old 10-17-2012, 05:57 AM   #268
rfinkle2's Avatar
Groans: 235
edit
Russell makes makes garrett specific fittings as well.
Russell Performance - Universal Turbo Adapter Fittings
eric@edgeautosport, imma send you a pm sometime today. I think I want to use that SSP kit.
EdgeAutosport.com likes this.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
Dano (10-17-2012), EdgeAutosport.com (10-17-2012), Payne Racing 67 (10-17-2012)
 Old 10-17-2012, 02:55 PM   #269
Groans: 34
yeah...not too sure about that particular banjo as it is for a press on fitting and we all know how much fun that is to do
is there a brotha out there that knows the thread pitch of the turbo oil feed outlet hole in the block?
anyone? I think that is the last piece I need to make up my custom kit.
PERM
rfinkle2 (10-19-2012)
 Old 10-17-2012, 03:09 PM   #270
BlueStreak's Avatar
Celestspeed3
'07 CWP MS3
Forged.
Dano (10-17-2012), rfinkle2 (10-18-2012)
 Old 10-17-2012, 05:30 PM   #271
Tabasco69's Avatar
The Following 4 Users Say Thank You to Tabasco69 For This Useful Post:
Easter Bunny (10-18-2012), EdgeAutosport.com (10-18-2012), rfinkle2 (10-18-2012), Tokay444 (10-18-2012)
 Old 10-17-2012, 09:11 PM   #272
Celestspeed3's Avatar
Posts: 869   (View Stats)
Celestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the worldCelestspeed3 is the leader of the world
Block oil feed is 12mm x 1.5mm
I used a 12mm x 1.5mm to -4AN fitting, with a -4 to -3 reducer, to a -3 line, to a -3 7/16 banjo with a 7/16" inverted flare restrictor bolt.
Dano and rfinkle2 like this.
Celestspeed3 is offline   Reply With Quote
The Following 5 Users Say Thank You to Celestspeed3 For This Useful Post:
Dano (10-17-2012), Easter Bunny (10-18-2012), EdgeAutosport.com (10-18-2012), Payne Racing 67 (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-17-2012, 10:15 PM   #273
Groans: 34
remind me about the blow job I owe you the next time I see you...
...and a reach around to get things started...k
awesome!
PERM
Celestspeed3 (10-18-2012)
 Old 10-18-2012, 03:58 AM   #274
Does this make me orange? LoL
The Following 2 Users Say Thank You to Celestspeed3 For This Useful Post:
Easter Bunny (10-18-2012), rfinkle2 (10-18-2012)
 Old 10-18-2012, 05:32 AM   #275
Analog Troll
Easter Bunny's Avatar
Posts: 1,506   (View Stats)
Groans: 1,469
Groaned at 45 Times in 34 Posts
Apparently you are destined to remain green, which is better than brown
 Old 10-18-2012, 05:43 AM   #276
rfinkle2's Avatar
Groans: 235
Coming up strong in a lot of threads in my book.
Thanks for the info.
 Old 10-18-2012, 07:13 AM   #277
We can roll you in a bag of cheetos and call it a day eh?
The Following 5 Users Say Thank You to EdgeAutosport.com For This Useful Post:
Celestspeed3 (10-18-2012), Don06speed6 (10-18-2012), EvoFire (10-20-2012), Pointless (11-11-2012), taf0422 (11-11-2012)
 Old 10-18-2012, 07:17 AM   #278
When I'm finished with Fobio's build we'll talk about me being orange. First BT Tial on a MS3 that i know about. Plus all the custom work on my own car. I'm in no hurry, got to earn my place first.
The Following User Says Thank You to Celestspeed3 For This Useful Post:
 Old 10-18-2012, 07:27 AM   #279
Posts: 5,628   (View Stats)
Groans: 121
Wow. Asking to be made orange? Really? It's something that's given, not requested.
DSIT995 (02-05-2013), Payne Racing 67 (10-18-2012)
 Old 10-18-2012, 07:32 AM   #280
JerzyJetJr
Payne Racing 67's Avatar
Posts: 3,619   (View Stats)
Groans: 82
Takes a lot more to become orange, also its a position given by recognition, not request. Just keep working hard and doing what youre doing. Youll get there.
Sent from my GS3
Hypnotic Tuning ftw
Coming Soon: Terminator Cobra
NJ NATOR FOR LIFE
Shitty
Unreliable
Retarded
Engineering
Payne Racing 67 is offline   Reply With Quote
LakeSpeed6 GTX3076 Build Lakespeed6 MazdaSpeed 3/6 - Big Turbo Builds 60 04-12-2013 07:09 AM
Realgib3 - GTX3076 - 400whp Realgib3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 10-13-2011 01:57 PM
Finally let my balls drop! - GTX3076 Realgib3 MazdaSpeed 3/6 - Big Turbo Builds 109 10-04-2011 12:51 PM
Page generated in 0.64557 seconds with 35 queries
