| MazdaSpeed 3/6 - Turbo Induction MazdaSpeed 3/6 - Turbo Induction - Have a turbo, intercooler, downpipe question? Anything turbo related belongs here! |
![]() | | #1 | ![]() |
Rep Power: 6708 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,343
__________________ 2006 Mazdaspeed 6 P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant |
| Will fuck up ur day ![]() Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 3381 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,744
Groans: 409
Groaned at 205 Times in 121 Posts
Why would you go with a holset after hearing about the massive lag and poor transient response? Sent from my your mom's face on my junk
__________________ 07 MS3 bone stock? The original Genpoo Hater GTX3076r FenderRollerRental Rent a fender roller, or MZR DISI Timing tools! Turismo Vids - Store your car vids and pics here! Blog your builds too!
Because everyone that has used one hasnt matched it to the car, diesels have generally low egts and low exhaust flow and they spool them just fine. This isnt a hokset turbo thread though. I have now basically completely unshouded the wg flapper and smoothed everything out. My thinking is that if you can get the exhaust through the turbine efficiently and through the wg efficiently it shouldnt be able to back up and blow the wg open and make the boost uncontrollable. The turbine itself should be good for 550-600ish but this housing is really a pile.
![]() | | #4 | ![]() |
| Able ![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 3270 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,144
Groans: 124
__________________ ![]() | |
| The Following User Says Thank You to helmetface For This Useful Post: | 06Speed6 (10-28-2012) |
![]() | | #5 | ![]() |
| Must Have Teh 10's! ![]() ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 9977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,722
Groans: 98
Groaned at 122 Times in 91 Posts
the problem is you cant port the flutes inside the housing. thats where the flow really gets choked. theres plenty of people making big power on the ATP hotsides.
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
| The Following User Says Thank You to superskaterxes For This Useful Post: | 06Speed6 (10-28-2012) |
![]() | | #6 | ![]() |
Groans: 124
From his wording though, I'm guessing it's either IWG or EWG on the mani
![]() | | #7 | ![]() |
Its IWG sorry. I looked at the flute and it *seems* ok. I took ALOT of material out of the EM flange/iwg area. In a couple spots im kinda worried about the strength now, but there is really alot of material in some areas that can be taken out with no worries.
![]() | | #8 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Burlington, VT
Rep Power: 2410 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,365
Groans: 188
Groaned at 102 Times in 55 Posts
I posted some pretty decent pics of the porting I had done to mine. I get no creep at all. 3071r build
__________________ '08 White MS3 w/ ported ATP 3071r, fat tires, and other sheit. No Meth or E. hit up NJSPEED3 so he can port yo intake mani! Last edited by 802MS3; 10-28-2012 at 04:15 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to 802MS3 For This Useful Post: | 06Speed6 (10-29-2012) |
![]() | | #9 | ![]() |
Yours is ported just a little more and they smoothed everything out better than mine, maybe ill hit it with a burr again and see if I can make it prettier
![]() | | #10 | ![]() |
| thread killer ![]() Join Date: Sep 2009 Location: Oak Pollen Central
Rep Power: 777 ![]() Thanks: 1,885
Groans: 84
Groaned at 6 Times in 4 Posts
i never ported mine and get reverse creep... :S |
![]() | | #11 | ![]() |
Groans: 409
| This is where extrude honing shines, my friend.
| The Following User Says Thank You to chimmike For This Useful Post: | 06Speed6 (10-30-2012) |
![]() | | #12 | ![]() |
So I figured out that if you port the wg hole enough the flapper gets stuck on it and may not close all the way.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | superskaterxes (11-06-2012) |
![]() | | #13 | ![]() |
Groans: 188
ooooo....that sucks luckily a nice dude on here sold me his for $100 shipped, so I'm sure you can find another one.
__________________ '08 White MS3 w/ ported ATP 3071r, fat tires, and other sheit. No Meth or E. hit up NJSPEED3 so he can port yo intake mani! |
![]() | | #14 | ![]() |
I figured it out, I put a bevel on the flapper itself and it seats fine now.
![]() | | #15 | ![]() |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 513 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
Here is the porting that a buddy of mine did for me. I just picked it up from him on Monday. I also have the gtx3071r. Photos here. http://www.mazdaspeedforums.org/foru...ml#post1729258
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging ![]() 2007 MS3 Sport, gtx3071r, 3" HTP TIP, 3" Treadstone MAF, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E SAFE Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DO Stage 2 Meth, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **411whp/409lb-ft via Mustang Dyno as of 2/25/13** |
| The Following User Says Thank You to Matrix311 For This Useful Post: | 06Speed6 (11-09-2012) |
![]() | | #16 | ![]() |
![]() Join Date: Nov 2010 Location: Houston
Rep Power: 1132 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,568
Groaned at 32 Times in 13 Posts
i ported mine a lot, just stuck some magnets on there to help with the shavings and went to town, no creep on initial set up: UR catted DP - HTP 3" intake - ETS TMIC. However switching to a front mount i did see boost drop a little, as is to be expected, but when i added a 4" intake i was creeping about 2 psi (8 psi wastegate spring but seeing 10-10.5 psi). intake side effects creep just as much as exhaust side it seems.
__________________ GTx3576, 93 + Direct Port Meth - Self Tune in progress... Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar. Limitless Performance and Fabrication Built: K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth. TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN |
| The Following User Says Thank You to Voltwings For This Useful Post: | 06Speed6 (11-09-2012) |
![]() | | #17 | ![]() |
(Thread Starter) | Not Ranked : 0 score Matrix311 that looks like a nice port job, looks like I need to take more metal out!
| HOW TO: Port turbine housing with IWG | chimmike | MazdaSpeed 3/6 - Turbo Induction | 2 | 08-12-2011 05:50 PM |
| .64 or .82 turbine housing? | Jarods7920 | MazdaSpeed 3/6 - Turbo Induction | 12 | 05-02-2009 08:43 AM |
