| MazdaSpeed 3/6 - Turbo Induction MazdaSpeed 3/6 - Turbo Induction - Have a turbo, intercooler, downpipe question? Anything turbo related belongs here! |
![]() | | #1 | ![]() |
| SPEED PERF6RMANC3 ![]() ![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 2070 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,128
Groans: 273
Groaned at 55 Times in 37 Posts
(Thread Starter) | Not Ranked : 0 score So what i would like to do is create a reference point for different larger frame turbos with different variables to see the impact that different manifolds/ turbos have on the spool characteristics.
Turbo- Manifold- PSI @xxxx rpm IWG/ EWG Please mention what RPM you see xxpsi at as well. If you can think of any other major factors that play a part in the spool characteristics then please feel free to add them. Also if something like this has been done before please let me know. I do know that we had a thread dedicated to documenting different setups and amount of power each different setup makes ect, ect. My main focus is on the spool. doubleflusher NJSPEED3 superskaterxes chimmike Captain KR SPEED6 KILLAH JacksonMS30 cld12pk2go 6oost3d- MS6 GTX3582r SS .82 T3 Steedspeed twinscroll top mount 27psi @ 4k Dual EWG chimmike- Tune still in progress MS3 GTX3076 ATP Hotside Tial MVS EWG Medieval Mani Stock CBE 24psi @ ~3800- 4000rpm Vader- MS3 GTX3071 Stock Manifold 21psi @3500 climbing to 25 @ redline IWG superskaterxes- Current: MS6 ATP GTX35R DNP w/EWG 30psi @4250 RPM Previous: GT3076 DNP w/EWG 27psi @3750 RPM PapaSmurf MS3 Turbo- Divided T3 GT3582R .82 hotside Manifold- Custom Steedspeed stock locaton divided T3 30PSI @4200 rpm, at 5500 feet ASL Duel 38mm EWG's dturboman MS3 GTX3582 T04 Undivided .82 A/R 28PSI @4500 RPM - 34 PSI - 4700RPM - 39PSI - 4950RPM DNP runners, custom flanges at both ends EWG doubleflusher- MS3 HTA3582R Steedspeed 30+ PSI @3900 rpm EWG cld12pk2go MS3 Turbo- GTX3071 (ATP hot side) Manifold- PG V1 20 PSI @3300-3500 rpm (depending on ambient temp) IWG Captain KR MS6 Atp 3076 with ported hotside 30psi @3800 pg v2 manifold ewg Lakespeed6 MS6 Turbo- GTX3076 Manifold- CP-E 24psi @4500 rpm IWG JacksonMS30 Old MS3 Turbo - GTX3071 Manifold - Stock 20psi @3400rpms 26psi to redline IWG PERM Tune Current MS3 Turbo - HTA3586 20psi @4200rpms in 4th gear (3rd gear is 4700rpms) 21psi spring pressure PERM Top Mount Exmani 38mm EWG TiAL MVR Panda Express MS3 GT3076 stock mani stock tmic/tbe 20psi @3700rpm 25psi @4300rpm til redline Alpha MS6 EFR 7163 T25 Prototype Full-Race Manifold/Catless DP/Choked Magnaflow 2.5" CBE 20psi @2600rpm 23psi @2900 and up rfinkle2 MS3 GT3076 24 psi @3,750. RayRay MS3 GTX3076 Stock Mani 25psi @4300rpm IWG SarcasticOne MS3 Turbo- gt3071 Manifold- steedspeed 20PSI @3350 rpm 21PSI @3400 rpm IWG NJSPEED3 Current- HTA3586 T3 single scroll .82 hotside Custom T3 Tubular mani 44mm ewg 20psi @3822rpm 28psi @4200rpm Previous setup MS3 T3 single scroll gt3076 .82hotside custom T3 tubular mani 44mm ewg 20PSI @ ~3800RPM 29psi@4100RPM +/- SilverDemon Old- MS3 T3 Single Scroll GT35r .63 hot side Steed Speed Mani 38MM EWG 20 psi @~3950 RPM 30 psi @~4500 RPM Current setup- ATP GT3582r .82 AR hotside CP-E Atmosphere Catless downpipe / 3.5" intake 21 PSI @ 4300 rpms 30 PSI @ 4800 rpms Realgib3 MS3 Precision 6466 CEA .82 Vband In/Out Hot side CP-e mani Precision 46mm Wg ~20psi @4200 DISIindahead MS3 ATP GTX3071 Full Race Manifold Grimmspeed 3 port EBCS 22 psi @ 3800rpms IWG S-hendrix MS3 BNR S3 Stock Manifold Grimmspeed 3 port EBCS 20.75 psi @3500rpms IWG atvfreek MS3 BNR stage3 3 port ebcs Stock intake and exhaust manifolds 22psi 3200 rpms BlueStreak; MS3 Turbo- ATP GT3071 Manifold- Stock 20 PSI @3100 rpm ATP EWG /w 21PSI Spring Fully PnP head. XLT_66; 2009 MS3 GT3582r Twinscroll T3 .78 A/R 25 PSI @ 4000 RPM Custom 1.25" Tubular Twinscroll Manifold Teardrop Merged Single 44mm Tial MV-S 1 Bar Spring Pressure COBB 3-Port Ziggo; 2008 MS3 BNR S3 18 PSI @ 3000 RPM Stock Intake Manifold Swaintech Coated DNP Exhaust Manifold & Hotside JBR WP Intake (3.5") Grimmspeed 3-Port himurax13; MS3 BNR Stock Manifold Grimspeed 3 Port EBCS 22psi @3200 dantes5823; MS3 ATP GTX3076 Stock Mani Grimmspeed 3 port EBCS 20 psi @ 3400rpms 24 psi @ 3600rpms EWG sleepyspeed6; MazdaSpeed 3 Hx35 stock exhaust manifold 3.5 intake WMI 91 EWG (38mm) spring pressure is 21psi hit at 3790, 25psi by 4300ish Captain KR; steed speed top mount t3 twin scroll manifold gt3582r minor tuning precision 46mm EWG full boost @3500rpm Matrix311; GTX3071 Internal Wastegate Stock Exhaust Manifold 20psi at 4,000rpm (boo) Downmented; MS6 Precision 6265, T4 TS .84 A/R Steedspeed Top mount manifold 20psi @4000rpm 30psi @4300rpm RichieRichness; MS6 gt3071r IWG DNP mani 21 psi @ 3500 rpm Voltwings; 2010 ms3 ATP GTx3576 .72 AR hotside CP-E manifold / Precision 46mm wastegate (15 psi spring) Catless downpipe / 4" intake 20.5 PSI @ 3800 rpms 25.5 PSI @ 4000 rpms
__________________ //KILLAH BUILT, SPEED PERF6RMANC3// Steedspeed T4 Twin Scroll // Precision 6265 Single 44mm Wastegate. KILLAH BUILT //FREEKPERM // Nuffsaid
| The Following 23 Users Say Thank You to Downmented For This Useful Post: | aggierandy (10-11-2012), alex_speed13 (04-22-2013), anavrinIV (10-17-2012), ASHMS3 (10-11-2012), atvfreek (10-19-2012), BigRedSpecial (12-04-2012), charlesfist (10-11-2012), Easter Bunny (04-22-2013), Funkster777 (04-22-2013), IshiKage (10-11-2012), J'sSpeed3 (10-17-2012), Jh8909 (10-11-2012), Juyoung (12-29-2012), lilred (10-11-2012), mazdafreak (03-11-2013), PapaSmurf (10-11-2012), psychophyr (04-22-2013), RayRay (10-11-2012), Reysal2k10 (10-11-2012), sleepyspeed6 (12-27-2012), uncorked11 (10-11-2012), Vader (10-11-2012), VulgarKyle (04-18-2013) |
| Will fuck up ur day ![]() Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 3388 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,755
Groans: 409
Groaned at 205 Times in 121 Posts
gtx3076, atp iwg hot side (flapper locked shut), tial MVS ewg. Stock cat-back, medieval mani. Tune still in progress. that's about 12* timing and boost not maintaining 24 to redline.
__________________ 07 MS3 bone stock? The original Genpoo Hater GTX3076r FenderRollerRental Rent a fender roller, or MZR DISI Timing tools! Turismo Vids - Store your car vids and pics here! Blog your builds too!
| The Following 2 Users Say Thank You to chimmike For This Useful Post: | Downmented (10-11-2012), IshiKage (10-11-2012) |
Groans: 273
(Thread Starter) | Not Ranked : 0 score What RPM Do you see full boost? Also, as people post their setups, i will update the initial post to keep all of this information in 1 spot.
![]() | | #4 | ![]() |
![]() Join Date: Jun 2011 Location: Herndon, VA
Rep Power: 160 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
| Not Ranked : 0 score MS6 GTX3582r SS .82 T3 Steedspeed twinscroll top mount 27psi @ 4k (current tune) 30psi @ 4300 Dual EWG - TiAL MVR & MVS
__________________ 2006 Mazdaspeed6 GT GTX3582 T3 .82 A/R // Wiseco Pistons // K1 Rods // ARP Head & Main Studs // Steedspeed Top Mount Manifold // TiAL MVR // TiAL MVS // PERM Top Mount Kit // NGK plugs // Custom FMIC // Cobb AP // Bosch 3 Bar MAP// Magnaflow Exhaust // MSD Dashhawk // RPM Springs //JBR STG 2 OCC // JBR EGR Delete //Autotech Fuel Pump Internals // SU Motor Mount // Prosport Boost Guage // ACT Street Clutch //Fiber Images Carbon Fiber// Hood // Snow Performance Stage 2 WMI, dual 625ml nozzles // Corn Fed 516whp/476tq - Mega Meat 2013 ![]() Last edited by 6oost3d; 10-11-2012 at 09:03 AM. |
| The Following User Says Thank You to 6oost3d For This Useful Post: | Downmented (10-11-2012) |
![]() | | #5 | ![]() |
Groans: 409
3800-4000rpm.
| The Following User Says Thank You to chimmike For This Useful Post: | Downmented (10-11-2012) |
![]() | | #6 | ![]() |
| Stock-ish ![]() Join Date: Nov 2010 Location: Annapolis, MD
Rep Power: 864 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,953
]MS3 GTX3071 Stock 21 by 3500 climbing to 25 @ redline IWG Slow car, is slow ![]() Edit:
__________________ Last edited by Vader; 10-12-2012 at 10:48 AM. |
| The Following 2 Users Say Thank You to Vader For This Useful Post: | bwspeed (10-11-2012), Downmented (10-11-2012) |
![]() | | #7 | ![]() |
Groans: 273
(Thread Starter) | Not Ranked : 0 score No image on work computer Sorry lol
![]() | | #8 | ![]() |
Groans: 273
![]() | | #9 | ![]() |
| Must Have Teh 10's! ![]() ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 9979 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,730
Groans: 98
Groaned at 122 Times in 91 Posts
| Not Ranked : 0 score MS6 ATP GTX35R DNP w/EWG 30psi by 4250 ![]() ATP GT3076 same 27psi by 3750
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Downmented (10-11-2012), rfinkle2 (10-11-2012) |
![]() | | #10 | ![]() |
![]() Join Date: May 2010 Location: Albuquerque, NM
Rep Power: 4594 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,366
Groans: 89
Groaned at 56 Times in 30 Posts
| Not Ranked : 0 score MS3 Turbo- Divided T3 GT3582R .82 hotside Manifold- Custom Steedspeed stock locaton divided T3 30PSI @4200 rpm, at 5500 feet ASL Duel 38mm EWG's
__________________ Twinscroll GT3582R 3M Matte Blue Metallic Wrapped PERM Tuned/Built Genpu Dragon 565whp/543wtq corrected at 5500ft asl 476whp/458wtq uncorrected at 5500ft asl |
| The Following 2 Users Say Thank You to PapaSmurf For This Useful Post: | Downmented (10-11-2012), rfinkle2 (10-11-2012) |
![]() | | #11 | ![]() |
![]() Join Date: Apr 2011 Location: Bucks county (bristol),pa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
GTX3582 T04 Undivided .82 A/R 28PSI @ 4500 RPM - 34 PSI - 4700RPM - 39PSI - 4950RPM DNP runners, custom flanges at both ends EWG |
| The Following 2 Users Say Thank You to dturboman For This Useful Post: | Downmented (10-11-2012), PapaSmurf (10-11-2012) |
![]() | | #12 | ![]() |
Groans: 273
Thanks for the imput folks, keep it coming. Please feel free to mention anyone who is BT that has not already been mentioned/ posted
![]() | | #13 | ![]() |
| Hair by Voltron ![]() Join Date: Feb 2009 Location: Hillsborough, NJ
Rep Power: 146172 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51,078
Groans: 1,404
Groaned at 310 Times in 292 Posts
| MS3 HTA3582R .63 A/R T3 Steedspeed 30+ PSI @3900 rpm EWG This was my old setup. New setup will be slightly different.
__________________ ![]() 11.91 @ 122.48 1.85 60' - 12/4/11 - Atco Raceway 11.85 @ 119.69 1.75 60' - 4/15/12 - Mason Dixon Dragway For Sale Section Rules UPDATED 5-17-2013! Please read before posting! Last edited by doubleflusher; 10-11-2012 at 10:50 AM. |
| The Following 2 Users Say Thank You to doubleflusher For This Useful Post: | Downmented (10-11-2012), rfinkle2 (10-11-2012) |
![]() | | #14 | ![]() |
| Eth/Meth Junkie ![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 2524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,591
This would be a much more apples to apples dataset if everyone posted the RPM they reached a set PSI (say 20 PSI) from a 4th gear roll starting at ~2000 RPMs. My data: MS3 Turbo- GTX3071 (ATP hot side) Manifold- PG V1 20 PSI @ 3300-3500 rpm (depending on ambient temp) IWG Also, I noted a several hundred RPM increase in lag when I ported my IM and removed the VTCS.
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E30 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) |
| The Following 3 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #15 | ![]() |
![]() Join Date: Nov 2010 Location: College Station, TX
Rep Power: 856 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,568
Would it be plausible to plot RPM vs Boost for each setup on a single graph for easy comparison?
__________________ 2010 MS3 Mica Black Tech Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch ![]() |
| The Following User Says Thank You to aggierandy For This Useful Post: | Downmented (10-11-2012) |
![]() | | #16 | ![]() |
Groans: 273
I guess my initial intent wasnt to directly compare apples to apples. More so to just get a general idea as to how spool was affected based on different setups. Granted yes most all of these are different turbos/ manis. But still helpful ![]() Honestly i dont see why not, it would have to be done by each individual user and posted, but sure, could be possible. WOuld be very helpful also
Last edited by Downmented; 10-11-2012 at 09:50 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #17 | ![]() |
Groans: 409
| Captain KR oh wait...........
| The Following User Says Thank You to chimmike For This Useful Post: | Raider (10-11-2012) |
![]() | | #18 | ![]() |
Groans: 273
(Thread Starter) | Not Ranked : 0 score Raider If this continues to get enough attention, would this be a possible sticky?
![]() | | #19 | ![]() |
![]() Join Date: May 2011 Location: Virginia Beach, Virginia
Rep Power: 2238 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,271
Groans: 69
Groaned at 30 Times in 23 Posts
sub'd for reference and thanks everybody
__________________ Roku Built / RichTune In progress 275FWHP/299FWTQ MUSTANG DYNO 4/7/13 Wiseco Pistons - K1 Connecting Rods SPONSORED BY JAMES BARONE RACING JBR-3"WP/SBB/SSP/SSB/RSB/BSD/VTA-OCC/BPV HOSE/SSK MUD FLAPS/TIGS/EGR B-O/CAMBER ARMS/88 TRILOGY/AP MOUNT/OPB Turbo XS-DP/TP;Forge-V2 BPV;BC-BR TYPE COILS;TR MOTOR SPORT-C3 17x9 +32F +40R; DUNLOP ZII 255/40/17;NGK-IRIDIUM X's;GT SPEC-REAR TIE BRACE; COBB-ACCESS PORT; PG-IC PIPING;TREADSTONE-TR8;CPE-HPFP;ACT-PROLITE SPRUNG 6 PUCK; PTP SEALS ![]() |
| The Following User Says Thank You to Rokusek For This Useful Post: | Downmented (10-11-2012) |
![]() | | #20 | ![]() |
Groans: 273
Updated initial post to reflect a more specific comparison between setups per cld12pk2go. If you have this information, please PM it to me and i will update your portion of the initial post. Thank you
![]() | | #21 | ![]() |
| Able ![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 3279 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,149
Groans: 124
| Not Ranked : 0 score I was going to say, what about the other side of the engine?
__________________ ![]() |
| The Following User Says Thank You to helmetface For This Useful Post: | Downmented (10-11-2012) |
![]() | | #22 | ![]() |
![]() ![]() Join Date: Nov 2011 Location: edgewood md
Rep Power: 1915 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,382
Groans: 368
Groaned at 62 Times in 36 Posts
Atp 3076 with ported hotside 30psi at 3800 pg v2 manifold ewg FUCK you you fucking ginger bitch chimmike
__________________ moore automitive 4/13/13 515whp 511 tq Mason Dixon Raceway 11.289 @125 1.845 60" Killah Built Powered By Purple Drank |
| The Following User Says Thank You to Captain KR For This Useful Post: | chimmike (10-11-2012) |
![]() | | #23 | ![]() |
| Scammer Hunter ![]() ![]() Join Date: Mar 2008 Location: Jacksonville, FL
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,832
Groans: 448
__________________ ![]() ![]() ![]() 1) Looking to Buy a used Mazdaspeed? Read this! 2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here. 3) Wanna buy and sell here? DONATE for VIP 4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting! 5) Help MSF grow with FAQ threads!? | |
![]() | | #24 | ![]() |
Groans: 273
I will let you know, i figure this is still new and there are ALLOT more BT people to mention in here. djuosnteisn
![]() | | #25 | ![]() |
![]() Join Date: May 2012
Rep Power: 0 ![]() Thanks: 10
Groaned at 3 Times in 1 Post
| The Following User Says Thank You to Reysal2k10 For This Useful Post: | Downmented (10-11-2012) |
![]() | | #26 | ![]() |
| Unicorn Farts ![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 1073 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,312
Groans: 96
Groaned at 35 Times in 28 Posts
__________________ Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms |
| The Following 2 Users Say Thank You to Deldran For This Useful Post: | Downmented (10-11-2012), Rokusek (10-11-2012) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score S-hendrix you mind commenting on your spool up. Also Downmented could you include on the plot a stock k04 for reference. Sent from my DROIDX using Tapatalk 2
![]() | | #28 | ![]() |
![]() Join Date: Jul 2010 Location: Lunenburg Mass
Rep Power: 906 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 596
| Not Ranked : 0 score MS6 Turbo- GTX3076 Manifold- CP-E 24psi @4500 rpm IWG Tune still in progress. Do I get an award for the worst spooling turbo! FML
__________________ 2006 Black MS6 383WHP 385WTQ GTX3076r -- TIAL 44mm EWG -- CP-E Turbo Manifold -- HTP 4" Intake -- CPE Top Mount JBR TB and IM thermal spacers -- Perrin OCC -- SU Boost Tubes -- Greddy Rec BOV-- CP-E Injector seals 3" Downpipe with hi-flow cat -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS FreekTune -- Snow Performance Meth Injection D10 -- Denso ITV22 -- balance shaft delete -- EGR delete ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob |
| The Following User Says Thank You to Lakespeed6 For This Useful Post: | Downmented (10-11-2012) |
![]() | | #29 | ![]() |
Groans: 273
(Thread Starter) | Not Ranked : 0 score Something is wrong here.
| The Following 4 Users Say Thank You to Downmented For This Useful Post: |
![]() | | #30 | ![]() |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2449 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,551
| Not Ranked : 0 score MS3 Turbo - GTX3071 Manifold - Stock 20psi by 3400rpms 26psi to redline IWG PERM Tune MS3 Turbo - HTA3586 20psi - 4200rpms in 4th gear (3rd gear is 4700rpms) 21psi spring pressure PERM Top Mount Exmani 38mm EWG TiAL MVR Tune fully neutered to save motor for build.
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - ![]() - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - |
| The Following User Says Thank You to JacksonMS30 For This Useful Post: | Downmented (10-11-2012) |
![]() | | #31 | ![]() |
![]() Join Date: Jan 2012 Location: Laruel,MD
Rep Power: 761 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 819
| Not Ranked : 0 score MS3 GT3076 stock mani stock tmic/tbe 20psi @ 3700rpm 25psi @ 4300rpm til redline
__________________ 2011 BLACK MS3 ZZB on GT3076 Rebuild in progress |
| The Following 2 Users Say Thank You to The Panda For This Useful Post: | Downmented (10-11-2012), rfinkle2 (10-11-2012) |
![]() | | #32 | ![]() |
![]() Join Date: Jan 2011 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 411
Let me dig through my logs I have one in 4th, I am getting full boost (22psi) at 4300 with the hx35. If i cant find it I will get one when I get my car back up ms3 Stock exhaust manifold, and stock cat back
__________________ HX35 whore |
![]() | | #33 | ![]() |
![]() Join Date: Dec 2009 Location: Chitown
Rep Power: 1462 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,810
Groaned at 66 Times in 49 Posts
| Not Ranked : 0 score MS6 EFR 7163 T25 Prototype Full-Race Manifold/Catless DP/Choked Magnaflow 2.5" CBE 20psi @ 2600rpm 23psi @ 2900 and up Once the new motor and tune are in, I wouldn't be surprised to see 25-30psi by 2400~ RPM TORQUE FTW!
__________________ PERM Tuned - EFR 7163 Street Sleeper ![]() | |
| The Following 2 Users Say Thank You to Alpha For This Useful Post: | Downmented (10-11-2012), silvapain (10-11-2012) |
![]() | | #34 | ![]() |
Rep Power: 11906 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,864
Groans: 235
3076 tune was in progress (member unfortunately had to part out). 24 psi @ 3,750. Atp 3076 w/ grimmspeed 3 port bcs.
| The Following User Says Thank You to rfinkle2 For This Useful Post: | 802MS3 (10-11-2012) |
![]() | | #35 | ![]() |
Groans: 409
Also...did you adjust the preload on the WG arm? I.e. screw it in more? Had to preload the fuck outta my gtx3076 IWG arm. So glad I went ewg tho.
| The Following 3 Users Say Thank You to chimmike For This Useful Post: |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Is the wastegate arm hitting anything? on my 3076 it rubbed against a hose so it wouldn't close all the way.
__________________ 2006 Mazdaspeed6 GT GTX3582 T3 .82 A/R // Wiseco Pistons // K1 Rods // ARP Head & Main Studs // Steedspeed Top Mount Manifold // TiAL MVR // TiAL MVS // PERM Top Mount Kit // NGK plugs // Custom FMIC // Cobb AP // Bosch 3 Bar MAP// Magnaflow Exhaust // MSD Dashhawk // RPM Springs //JBR STG 2 OCC // JBR EGR Delete //Autotech Fuel Pump Internals // SU Motor Mount // Prosport Boost Guage // ACT Street Clutch //Fiber Images Carbon Fiber// Hood // Snow Performance Stage 2 WMI, dual 625ml nozzles // Corn Fed 516whp/476tq - Mega Meat 2013 ![]() |
| The Following 2 Users Say Thank You to 6oost3d For This Useful Post: | Downmented (10-11-2012), rfinkle2 (10-11-2012) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score ![]()
Doesn't hit any thing on the housing and is about 8 turns in. Just had the intake off last night and I noticed quite a lot of shaft play ![]() Maybe I should switch to EWG.
__________________ 2006 Black MS6 383WHP 385WTQ GTX3076r -- TIAL 44mm EWG -- CP-E Turbo Manifold -- HTP 4" Intake -- CPE Top Mount JBR TB and IM thermal spacers -- Perrin OCC -- SU Boost Tubes -- Greddy Rec BOV-- CP-E Injector seals 3" Downpipe with hi-flow cat -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS FreekTune -- Snow Performance Meth Injection D10 -- Denso ITV22 -- balance shaft delete -- EGR delete ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob | |
![]() | | #38 | ![]() |
Groans: 273
If there is shaft play, your wg is the least of your worries bro. Hopefully you get it sorted out.
![]() | | #39 | ![]() |
![]() Join Date: Mar 2011 Location: North Jersey
Rep Power: 205 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 150
Groaned at 54 Times in 17 Posts
my first big-turbo mention whhhhhattttt uppppppp unfortunately, the turbo goes on in two days so give me a little while to get it tuned and ill post logs
__________________ 2011 Black Mica MS3 FREEKTUNE IN PROGRESS, ATP GTX3071R IWG Full Race exhaust manifold CP-e whale peen + 3.25 in. intake COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport SRI + TIP + CBE Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Installation TBD: , H&R springs + Koni yellow shocks + struts |
| The Following User Says Thank You to duappleganger For This Useful Post: | Downmented (10-12-2012) |
![]() | | #40 | ![]() |
| I have candy in my van ![]() Join Date: Apr 2009 Location: N Aurora, IL
Rep Power: 2205 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,485
Groans: 66
I'm hoping to hit 20psi at or before 3k, with a GTX3071 EWG. T3 SS mani, and higher compression should help.
__________________ Current Fail: 2008 Mazda5 DD/Mazdaspeed5 BT project 2006 Mazdaspeed6 Building, soon DD, future track whore 1986 Porsche 944 turbo Listed 2007 Kawasaki ZX-6R DD/Beater |
| Faster spool turbo kit ? | MazdaSpeedThree | 2010 MS3 - Big Turbo Builds | 17 | 10-11-2012 07:20 AM |
| For the big BIG turbo guys who complain about spool time... | phate | MazdaSpeed 3/6 - Turbo Induction | 23 | 10-14-2011 09:21 AM |
| Trouble shooting big turbo slow spool time | Ckmazdaspeed3 | 2010 MS3 - Troubleshoot/Diagnostics | 87 | 06-18-2011 09:58 AM |
