  • 1 Post By bcmurphy87
 Old 07-22-2011, 08:22 PM   #1
mrkdspd's Avatar
Posts: 158   (View Stats)
mrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond reputemrkdspd has a reputation beyond repute
Groaned at 20 Times in 6 Posts
Default blow through maf help
So I'm looking at converting my ms6 to a blow-through maf. I have the altered customs fmic kit and am in the process of a gtx3076r build. I guess my main question is if the pipe I put my maf in will have to be the same size as the intercooler piping. The maf pipe I was going to plumb in is 3.5" and my intercooler piping is 2.5". Something tells me this just won't work lol. Figured I would ask some people on here that are a bit more knowledgeable first.
Corn-fed MS6-sold
04 STi-racecar
mrkdspd is offline   Reply With Quote
 Old 07-22-2011, 08:34 PM   #2
kmac's Avatar
Posts: 1,792   (View Stats)
Depending on the power levels u want that will determine the meter housing size . U will need at least a 3 " with a 3076.
The Following User Says Thank You to kmac For This Useful Post:
mrkdspd (07-22-2011)
 Old 07-22-2011, 08:42 PM   #3
mrkdspd's Avatar
Thats why I wanted to just go with the 3.5". I just don't know if its going to cause any issues going from 2.5" to 3.5" back down to 2.75" into the throttle body.
Corn-fed MS6-sold
04 STi-racecar
 Old 07-22-2011, 08:47 PM   #4
kmac's Avatar
Nope , its fine on a push through ,It's done all the time. A 3" would prob be fine. I can't remember the site ,but there's a company that makes them for subbies and It's the same housing for our cars. I'll see if I can find it.
 Old 07-22-2011, 08:58 PM   #5
mrkdspd's Avatar
Thanks alot man! I'll be getting the housing from treadstone. Any idea on what tuning needs to be done when I switch to this? I thought I saw a thread about maf calibration for a larger maf housing a while ago but can't find it.
Corn-fed MS6-sold
04 STi-racecar
 Old 07-22-2011, 09:01 PM   #6
kmac's Avatar
Found it kstech.biz if u call them they will point u to what u need.
U have to re-cal the maf everything else should be the same I would think. Never tuned a push thru.
Last edited by kmac; 07-22-2011 at 09:01 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-06-2012, 06:27 AM   #7
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
Groaned at 4 Times in 2 Posts
just curious if the op ever ended up doing this. Just been researching blow through setups and im intrigued.
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
 Old 08-06-2012, 07:02 AM   #8
dantes5823's Avatar
Posts: 6,576   (View Stats)
I dont think its as easy as just cutting a peace of piping and putting on a maf pipe and calling it down. I think you need much longer 3.5" piping before the maf for it to be more stable. Dustin talks about this and thats where i read it. He actually made a whole ingercooler pipe or at least a good about of it, the size he wanted. Then i think it becomes a normal maf cal at this point.
ESB Jiu JItsu (08-09-2012)
 Old 08-06-2012, 10:47 AM   #9
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
bcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the world
yea its not very easy but if you take your time its very doable. I think that its alot easier on the 3 than the 6. The key to success is to have plenty of the larger blow-thru pipe before the maf to allow the air to properly expand and an air straightener before the maf. At least that's what it took for me on my 6.
ESB Jiu JItsu likes this.
06 Speed 6- EBtec built, FreekTuned and 5862 powered! 540/493
06 Speed6 GT- Sold
just bang out the tight spots.
bcmurphy87 is offline   Reply With Quote
The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post:
dantes5823 (08-06-2012), ESB Jiu JItsu (08-06-2012)
 Old 08-06-2012, 12:02 PM   #10
perfect information thank you! with my new extremely short FMIC pipe kit idea i dont think ill have enough length prior to the maf.
 Old 08-13-2012, 12:59 PM   #11
it actually is that easy well close to it
Blow through MAF
GT35r - Blow through MAF!! Deadman MazdaSpeed 3/6 - Big Turbo Builds 13 07-21-2010 09:47 PM
1.5k to blow on my '09 MS3 M4Nathan MazdaSpeed 3 - How-To's 25 06-11-2010 07:22 PM
Will i blow? Grim MazdaSpeed 3 - Engine, Transmission & Driveline 26 02-20-2009 09:22 AM
Page generated in 0.30600 seconds with 24 queries
