  • 1 Post By aaronc7
 Old 08-04-2008, 07:49 PM   #1
Boost Whore
Unoriginalusername's Avatar
Posts: 1,757   (View Stats)
Unoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the worldUnoriginalusername is the leader of the world
Groans: 223
Default Boost gauge vs. AP boost reading.. which is correct?
my boost gauge is reading 1-2psi higher then what i see on the ap.. which is right?
"God created turbo lag to give v8's a chance"
Unoriginalusername is offline   Reply With Quote
 Old 08-04-2008, 07:51 PM   #2
aaronc7's Avatar
Posts: 8,036   (View Stats)
Groans: 370
my gauge was lower than the AP...i would probably trust the AP/DH
The Following User Says Thank You to aaronc7 For This Useful Post:
rfinkle2 (05-23-2011)
 Old 08-04-2008, 07:52 PM   #3
Boost Whore
Groans: 223
thats what i thought but then i read a post somewhere which i can't find now that explained where the ap is taking its boost reading from and the poster suggested that actual boost levels might be higher which would explain what i am seeing on the gauge but i am not sure, and like i said can't find that post
 Old 08-04-2008, 07:53 PM   #4
Posts: 12,649   (View Stats)
depends where the gauge is taking the reading from versus where the map sensor that is stock is taking the reading from. I would trust the stock map sensor more.
Bucker (12-03-2011), rfinkle2 (05-23-2011)
 Old 03-15-2011, 12:30 PM   #5
nattun's Avatar
Posts: 260   (View Stats)
nattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond repute
Groaned at 3 Times in 1 Post
Before I installed my gauge I tested it against a NIST certified gauge and it was about 1-2 psi lower. Maybe yours is the same way
2006 Mazdaspeed 6 - Velocity Red Mica - #5129 - Totaled
2006 Mazdaspeed 6 GT - Titanium Gray Metallic - #3820
nattun is offline   Reply With Quote
 Old 03-15-2011, 12:32 PM   #6
Ziggo's Avatar
Posts: 3,843   (View Stats)
+1
Ask Me About My:
 Old 03-27-2011, 06:40 PM   #7
nosaccordh22's Avatar
Posts: 30   (View Stats)
nosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the roughnosaccordh22 is a jewel in the rough
Groaned at 7 Times in 4 Posts
are you running anything like the ATP boost cut killer? that will mess with your ecu and cobb AP readings.
also, where do you have the boost gauge tapped into? that makes a difference too
nosaccordh22 is offline   Reply With Quote
 Old 05-19-2011, 06:19 AM   #8
Dfunk's Avatar
Posts: 25   (View Stats)
Dfunk will become famous soon enough
Where does the the stock boost reading come from?
Dfunk is offline   Reply With Quote
 Old 05-19-2011, 07:53 AM   #9
aaronc7's Avatar
Groans: 370
the MAP (Manifold Absolute Pressure) sensor, which is located in the intake manifold, far passenger side, before the runners. A lot of guys are getting boost gauge signals from same line that runs to the bpv, which is off the number 4 runner. Back of the manifold/stock MAP sensor is probably a better location and a better average number to go off of.
The Following 2 Users Say Thank You to aaronc7 For This Useful Post:
breakfstincluded (10-30-2011), rfinkle2 (05-19-2011)
 Old 05-19-2011, 10:36 AM   #10
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
Yeah i have prosport, same thing but mine reads lower all the time. The highest I've seen the gauge go is like 16ish but then I pull up the ap datalog and shows that I'm hitting 18 or 19, who knows.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 05-23-2011, 03:50 PM   #11
charlie_sheen's Avatar
Posts: 24   (View Stats)
charlie_sheen can only hope to improve
Groaned at 23 Times in 3 Posts
i read that the mechanical prosports are more accurate than the electric ones...which do you have?
charlie_sheen is offline   Reply With Quote
 Old 05-23-2011, 05:06 PM   #12
electrical, go figure
 Old 05-23-2011, 05:09 PM   #13
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
I have an electric pro sport boost gauge, as far as peak boost they match.
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline   Reply With Quote
The Following User Says Thank You to DONOTBUGME For This Useful Post:
 Old 05-23-2011, 05:41 PM   #14
Ziggo's Avatar
If there is a voltage differential between where you grounded the sender and where you grounded the gauge it can cause this. It's best to ground both at the same location.
Ask Me About My:
Install a boost gauge. Demi MazdaSpeed 3 - How-To's 58 06-16-2010 09:10 PM
boost gauge mount phillyb MazdaSpeed 3/6 - Turbo Induction 9 12-24-2008 09:58 PM
My New Boost Gauge kingpin748 Mazdaspeed3/6 General Discussion 8 06-24-2008 02:00 PM
boost gauge install? bombdotcom MazdaSpeed 3/6 - Turbo Induction 5 06-06-2008 08:59 PM
Page generated in 0.34891 seconds with 29 queries
