 Old 09-15-2019, 12:31 PM   #1
grammates's Avatar
Posts: 11   (View Stats)
grammates is an unknown quantity at this point
Default Boost issues/Iím not sure what hose this is
Can anyone help me out Iíve been having boost issues where instead of pushing 18/19 pounds of boost I can only get to 10 psi max 1-4 gear. Iíve changed spark plugs to one step colder and checked them and my turbo. I do have a tune through stratified tuning. Everything is accounted for in the tune ACCEPT the spark plugs. I was removing stuff and found this hose connected to the TIP and it looked like a price had broke off Iím not sure what it does or what itís for if anyone could help it would be appreciated.
grammates is offline   Reply With Quote
 Old 09-15-2019, 01:23 PM   #2
danb's Avatar
Posts: 176   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
it goes to the bcs. Happenes too most everyone.I took a demel and reshaped the end the broke and put the hose back on.
https://cse.google.com/cse?cx=007197...oken&gsc.sort=
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
The Following User Says Thank You to danb For This Useful Post:
grammates (09-15-2019)
 Old 09-15-2019, 01:44 PM   #3
grammates's Avatar
So one side connects to the TIP and the other with the broken piece goes to where..?
Last edited by grammates; 09-15-2019 at 01:44 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-15-2019, 04:09 PM   #4
MSMS3's Avatar
Posts: 2,802   (View Stats)
Groans: 157
That hose goes to a nipple on the electronic boost control solenoid (ebcs). You will have three nipples on it. Two will have hoses. The third will be for that hose, if not broken off. The nipples are plastic and fragile.
 Old 09-15-2019, 06:38 PM   #5
grammates's Avatar
So This is what Iím looking at
 Old 09-16-2019, 06:16 AM   #6
MSMS3's Avatar
Groans: 157
Yes, that is the EBCS. Look for the third nipple on it, replace the hose there and reinstall the clamp. If the nipple is broken off, you'll need to replace the EBCS. Consider getting an aftermarket one like what Grimmspeed sells, as their nipples are metal and will not break like the POS factory solenoid.
grammates (10-11-2019)
Lost boost after sure inlet hose installed please help!!! cdyer603 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 12-28-2011 07:24 PM
Page generated in 0.28029 seconds with 22 queries
