 Old 04-03-2008, 07:09 AM   #1
phailerider's Avatar
Posts: 4,639   (View Stats)
phailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the worldphailerider is the leader of the world
Groans: 49
Groaned at 179 Times in 125 Posts
Default Compressor surge or bpv flutter
Allright all you forge bpv experts. Im getting what i thought was surge(maybe bpv flutter?) on my new turbo running 18psi. I had my old setup with blue spring and one shim in place. Was a nice loud "ting".
I was utterly confused how a gt3071 would get compressor surge at 18psi but the stock turbo would get the ting...
anyway.. i pulled out the shim. Maybe its a tad worse, especially at partial throttle.
When i go wot and release all at once. no ping whatsoever, or if it is i cant hear it with the flutter being so loud.
thoughts? Remember... ive got that stupid vacuum line hooked up to that mani/bpv line too, so that may be affecting it.
Can you mimic compressor surge with a spring that isnt stiff enough? Also... whats up with the forge guidelines for spring stiffness and psi? they claim that the red is for 30+ psi....wth?
phailerider is offline   Reply With Quote
 Old 04-03-2008, 07:13 AM   #2
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
is it surge or flutter ? Forge changed there spring Psi #'s for the speed's the moved the yellow psi#'s to the blue spring claiming the speed's needed a higher spring rate for stock boost
NYpest is offline   Reply With Quote
 Old 04-03-2008, 07:17 AM   #3
Groans: 49
ive gotten 6-7 opinions and its evenly split as to what it is. It got a little worse when I took the shim out, maybe, especially at partial thottle... but it sounds an awful lot like turbo surge as well... its crazy.
the youtube compressor surge videos sound alot like what im getting.
 Old 04-03-2008, 07:18 AM   #4
Groans: 49
so maybe its flutter... I'll go for the red spring on the way into work today... see how it does.
 Old 04-03-2008, 07:25 AM   #5
NYpest's Avatar
From all that i have read flutter means you have a good set up !!!! I always got partial throttle surge anything blue plus 1 shim (on stock boost)
 Old 04-03-2008, 07:26 AM   #6
Jesse MS3GT's Avatar
Posts: 356   (View Stats)
Jesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the world
You guys sure about the spring pressures?
There will always be someone faster than you, smarter than you, or better than you in some way. They key is to maintain a presence beside those lesser than you to appear superior
35psi, super cams, ported head, titanium valve springs, titanium rods/pistons, flux capacitor, 88mph mod, cryogenic tranny with welded differential
Jesse MS3GT is offline   Reply With Quote
 Old 04-03-2008, 07:31 AM   #7
NYpest's Avatar
Originally Posted by Jesse MS3GT View Post
You guys sure about the spring pressures? Because the kit I received came with a blue, green and yellow. The yellow was installed. I took the yellow out and put the blue one in since that was the spring everyone was using, so I should use the yellow spring?? I havent put it on my MS3 yet so I cant comment on how it works with the blue spring.
positive "patt at forge" over at 247 confirmed it my kit came with yellow blue and red...yellow poped off way too soon....
The Following User Says Thank You to NYpest For This Useful Post:
Jesse MS3GT (04-03-2008)
 Old 04-03-2008, 08:29 AM   #8
driver311's Avatar
Posts: 1,769   (View Stats)
driver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the world
I wouldnt run the forge with anything less than the redspring. Works the best and holds boost better. What you are hearing is flutter not surge.
2008 Mazdaspeed3, Fully built then fully parted. Sold
2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily
Mazdaspeed
12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp
11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp
driver311 is offline   Reply With Quote
 Old 04-03-2008, 08:30 AM   #9
Groans: 49
eh... i dont know.. maybe a little better with the red spring. If its blowoff sound Im hearing it. It is COMPLETELY different than the noise I heard before.
The guys the other day were listening and said they heard the ting, and blowoff.they flutter is all very noticeable outside the car... but from inside the car... the flutter is LOUD. Too loud to really hear any blowoff noises that include a "ting"...lol Its either blowoff flutter of surge flutter.... who knows. We're all completely split on what it is.
Is compressor surge loud as shit? I thought alot of times you cant even hear it.
Either way it sounds good as fuck....lol
 Old 04-03-2008, 08:32 AM   #10
NYpest's Avatar
The guys the other day were listening and said they heard the ting, and blowoff... but from inside the car... the flutter is LOUD. Too loud to really hear any blowoff noises that include a "ting"...lol Its either blowoff flutter of surge flutter.... who knows.
lol ......go with the syncronic mines on the way (i hope)
 Old 04-03-2008, 08:34 AM   #11
Groans: 49
How different should I expect the blowoff to sound with this new turbo, bro. Good to hear you too, btw.
 Old 04-03-2008, 08:37 AM   #12
Groans: 49
I googled what the hell syncronic mines was. And this is what popped up...lol
 Old 04-03-2008, 08:54 AM   #13
Bravnik's Avatar
Posts: 383   (View Stats)
Bravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond repute
Groaned at 33 Times in 22 Posts
Flutter sounds just like the name. When you push in the clutch under low boost (say in 5th with just a couple PSI) you will hear air release in a flutter and not a whoosh with ping. Like Flutter-Flutter-Flutter real fast. This is normal.
You should NOT get any flutter when under WOT and you shift. That should be nothing but a whoosh and ping. Flutter should only happen under low boost when you press the clutch or get boost by pressing the gas peddle to pass then let off real quick after you get boost.
I currently use the Blue with 2 shims as I still have not got my Red Spring from Pat even though I told him/her I got the Green one that I should not have gotten. The green one is for a fricken lawnmower or something it so weak
TBH - The flutter worried me on my car until I had a guy that knows a lot about turbo's go for a ride. He explained it all too me and now I sleep better at night
Bravnik is offline   Reply With Quote
 Old 04-03-2008, 09:41 AM   #14
ptperformance's Avatar
Posts: 4,123   (View Stats)
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
I hate to say this but the Forge units are garabage. Check the diaphram and make sure there are no tears in it.
There are some normall flutter noises with most turboed cars, but you have to make sure its flutter from normally occurances or maybe something else is a miss.
ptperformance is offline   Reply With Quote
The Following User Says Thank You to ptperformance For This Useful Post:
whoosh@Realtune (04-03-2008)
 Old 04-03-2008, 09:55 AM   #15
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
AutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond reputeAutoXRacer has a reputation beyond repute
And thats why I love my HKS...no shims or springs to mess with... (just had to rub it in)
Palerider, with the major cash you are dumping in your ride, why are you messing around with such a lower tier BPV...? stop clowning around and get yourself a top notch BPV...whatever that may be.
2008 Stage 3 Roush Mustang
302E 5.0L Stroker 647rwhp-620 rwtq
AutoXRacer is offline   Reply With Quote
 Old 04-03-2008, 09:56 AM   #16
NYpest's Avatar
YouTube - 1JZ Lexus SC300 Turbo Soarer Burnout
synapse BOV
 Old 04-03-2008, 09:57 AM   #17
NYpest's Avatar
Which valve your you suggest ?? I think the Forge is the best out there right now for our cars, till i get my Synapse(then i will see)
 Old 04-03-2008, 10:18 AM   #18
Where is the diaphragm on the MS3 forge unit?? Maybe its cuz im a n00b but I believe its a piston, not a diaphragm.
 Old 04-03-2008, 10:23 AM   #19
NYpest's Avatar
this might help !!!
The design philosophy behind Synchronic Blow-Off valve SB001
 Old 04-03-2008, 10:26 AM   #20
Just as I thought, the Forge is a piston BOV, not a diaphragm.
 Old 04-03-2008, 10:30 AM   #21
NYpest's Avatar
Yeah it uses a piston
 Old 04-03-2008, 10:39 AM   #22
driver311's Avatar
I have to agree. Mine didnt work very well. Even with the redspring and two shims it didnt hold boost like this synapse.
Mazdaspeed
 Old 04-03-2008, 10:41 AM   #23
NYpest's Avatar
can you compare down? if the synapse is not aval what would you say holds better then the forge right now ?
 Old 04-03-2008, 10:53 AM   #24
Groans: 49
yeah what should I get then... I didnt know it was crap. What about the hks hybrid?
Whats the absolute best all money aside? I didnt think it was that big a deal.
Also.... I want to address that vacuum line Ive got hooked into the mani from the wastegate. When I come off throttle.... that mani line goes vacuum. All the air is supposed to shoot off the bpv back into the inlet right? But what if that mani line going vacuum, as opposed to that line being hooked right onto the hotside. What if it is causing the bpv to close prematurely and all the air to surge back at the turbo because its seeing vacuum instead of boost.
Does this make sense?
Im gonna change those lines and play around a little bit this weekend... but I want to understand as well!!!
 Old 04-03-2008, 10:53 AM   #25
Well with the boost pressures Driver was aiming for I wouldnt call the Forge a piece.
Edit. Was Laloosh the person upping the boost in the 20's?
 Old 04-03-2008, 10:58 AM   #26
NYpest's Avatar
I ordered the new synapse valve after talking with them and hearing drivers review confirming what they have said... I think that the new design allows for a much better reacting valve, but i still believe the forge is a good piece.
 Old 04-03-2008, 11:00 AM   #27
NYpest's Avatar
Edit. Was it Laloosh that was upping the boost in the 20's?
Either way amount of PSI doesn't seem to come into effect with (synapse) BOV it can run 6psi or 100psi its the design that makes it more efficient then the legacy. Ill have my answer once its installed tho
 Old 04-03-2008, 11:07 AM   #28
The synpase is the BPV I wanted to go with, but at the time I wanted to order it I thought a custom flange would need to be made.
 Old 04-03-2008, 11:07 AM   #29
AutoXRacer's Avatar
HKS SSQV2!!!!! Synapse and HKS share the same basic design... HKS also handles a wide boost range...
Not trying to sell anyone on HKS, but I am very happy with mine so far!!!!
Here is some info: (sorry, I couldn't upload the original pdf due to size restrictions)
*expand or zoom into picture*
 Old 04-03-2008, 11:10 AM   #30
NYpest's Avatar
cool i haven't come across one ill check it out .... you enjoy it ??
 Old 04-03-2008, 11:27 AM   #31
AutoXRacer's Avatar
I love mine... Its actually a little quieter than the stocker with an intake setup as recirculation, but as VTA its loud...it has a sweet flutter at low boost pressures and an awesome commanding pssshhhooo at high boost. The response compared to stock is also incredible... Thats one of the selling points of Synapse; reaction time of the valve.
I would be curious to see the difference in internals of Synapse and HKS...
These are the only two valves I know that do not require shims, springs, or adjustment. I originally wanted a Synapse, but they didn't have an application for our cars at the time...plus I'm not one to custom fit stuff...I love my direct bolt-on applications...
 Old 04-03-2008, 11:30 AM   #32
NYpest's Avatar
looks expensive ? $350 but that on the hks website
 Old 04-03-2008, 11:42 AM   #33
AutoXRacer's Avatar
I bought mine from PG; the direct bolt-on kit for $275. It came all setup except that I had to convert it to recirculation (2 mins) and rotate the stock recirculation hose (10 mins) and bolt it up...
They have cheaper kits, but I've heard its a pain in the butt to put together...something about a C-clip and orienting the unit properly...
 Old 04-03-2008, 11:45 AM   #34
NYpest's Avatar
I ordered the synapse through them ..... cant wait to test it out ...i still think the forge is a great BPV for the MS3
 Old 04-03-2008, 12:01 PM   #35
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
you will not regret an HKS BOV
the Garrett ball bearing turbos do not come with a compressor housing vacuum port.
ATP should have given you a nipple to install in the silicone coupler off the turbo outlet
run the vacuum line from the wastegate to the nipple installed in the silicone coupler
This will get you a boost level baseline or at least tell you what your actuator is set at
Adjust your actuator rod to the desired boost level
then if you want to raise the boost, add your controller of choice at that point
*info direct from ATP
 Old 04-03-2008, 05:14 PM   #36
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Get the Synapse man.
 Old 04-03-2008, 06:11 PM   #37
Oh hell no. Turbosmart is the best right now. You can get the adapter plates for the HKS or Greedy units but I have stacks of Greedy BOV's with stripped threads and blown diaphrams. I have more then one HKS that has blown off a car under very hard boost spikes (cheap snap rings). Get something that bolts on that will move the amount of air that you are pushing. Like one person said with the amount of money you have spent on this build up when mess around with 2nd rate BOV's. Build a custom unit that has a 50mm gate on it. Never have to worry about venting ever again.
 Old 04-03-2008, 06:37 PM   #38
What about tials newest/largest BPV? The Alpha Q
TiAL Sport.com
 Old 04-03-2008, 06:41 PM   #39
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
looks like a bong...
 Old 04-03-2008, 06:45 PM   #40
^ its been dubbed the bong, for obvious reasons
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f11/compressor-surge-boost-bypass-valve-flutter-2115/
MAZDASPEED 3 - Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-03-2008 10:25 AM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 04-03-2008 07:59 AM
Belkin 4ft 6-Outlet 720-Joule Surge Protector $0.99AR Haltech Hot Deals Section 0 04-08-2008 09:50 PM
Belkin Superior Series 8 Outlet Surge Protector $18.95 Haltech Hot Deals Section 0 04-06-2008 11:20 AM
Panamax MFP500EX Flat Panel Surge Protector/Power Conditioner $79.99 Haltech Hot Deals Section 0 04-02-2008 08:20 AM
Panamax MFP500-EX AC Line Conditioner & Surge Supressor $99.99 Haltech Hot Deals Section 0 03-28-2008 09:10 AM
APC GM6 Game Manager Surge Protector $15.99 Free Shipping Haltech Hot Deals Section 0 03-27-2008 10:00 AM
Page generated in 0.87446 seconds with 29 queries
