| MazdaSpeed 3/6 - Turbo Induction MazdaSpeed 3/6 - Turbo Induction - Have a turbo, intercooler, downpipe question? Anything turbo related belongs here! |
![]() | | #1 | ![]() |
![]() Join Date: Jun 2010 Location: San Antonio, TX
Rep Power: 828 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,579
Groans: 76
Groaned at 31 Times in 28 Posts
(Thread Starter) | Not Ranked : 0 score I've had my Corksport TIP installed on my car for almost a year now. When I was installing it I was unable to make it fit so that the TIP didn't touch the ECU cover. At the time I contacted Corksport and was told that if I installed it correctly there wouldn't be any rubbing, so I wrestled with it for a while and got it so that it was barely touching and called it good. A while ago, a friend of mine with the same Inlet removed his and found that his had severe rubbing (worse than mine) and a flat spot had been worn into his TIP as a result. After seeing the damage to his TIP I decided to grab a flashlight and take a look at mine. I attached a photo showing the damage, constant engine motion appears to be wearing a flat spot on the inlet. I emailed and spoke on the phone with Kelly @ Corksport and she was very nice about the issue but claimed that she hadn't heard of this being widespread and implied that the damage was due to incorrect installation. Admittedly, my sample size is small, but my friend and I have had the exact same issue and neither one of us are total derps (at least we'd like to think we aren't). Anybody else having this issue? |
![]() Join Date: Mar 2011 Location: Bastrop, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,150
Groans: 273
you didnt push it far enough onto the turbo side coupler... happened with a guy i was helping but his was a radiator line
__________________ 2011 Black Mica - Daily JBR SSP and heavy knob and SSB | Sure RMM | Corksport SRI/TIP/RSB/TMIC | Tanabe FSTB | Cobb AP getting PERM'd | Autotech internals | H&R springs | DDM HID | pussy delete - catless ebay dp and tp |
| Needs GHES ![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 401 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 293
Groaned at 6 Times in 3 Posts
I have to same issue, my tip is backed all the way up as close to the turbo as I can get. The bracket didn't even line up with the stud where it's supposed to secure. Mine rubs on the white plastic though.
__________________ Needs to install the GHES. |
![]() | | #4 | ![]() |
Groans: 76
![]() | | #5 | ![]() |
| The Gimp ![]() Join Date: May 2010 Location: Beaumont, California
Rep Power: 373 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,428
Groans: 32
I've gotten the same rubbing and wear from the Corksport tip.. I recall reading several posts when I got mine way back that complained of the same rubbing issue.
__________________ 2012 MS3 Black Mica : AP, TMIC, HPFP -Waiting: GT3071, 3" TIP, DNP Exhaust Mani, Guardian Angel, 3Bar Map Sensor 2010 MS3 Velocity Red : Traded 2007 Suzuki GSX-R 750 : Crashed & Fixed 2004 Sentra SE-R Spec V : Traded 1995 Nissan Altima : Sold 1987 RX-7 : Sold |
![]() | | #6 | ![]() |
![]() Join Date: May 2011 Location: Bakersfield, CA
Rep Power: 111 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 102
| Not Ranked : 0 score |
![]() | | #7 | ![]() |
![]() Join Date: Nov 2010 Location: Manchester, England
Rep Power: 707 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,201
Groans: 34
| Not Ranked : 0 score Same here, I even bought the cold air box and that doesn't line up with the holes on the front panel in the engine bay so I ditched it.
__________________ Tuned with by ![]() Su tmic/corksport intake/custom 3" tbe/grimmspeed ebcs/forge bpv/jbr ssp/jbr rsb/Jbr side mount/sure tig set/sure r3 rmm/kmd internals/pg sst (tune in progress)/3 gauge pod |
![]() | | #8 | ![]() |
| OG Pu ![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 1277 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38,321
Groans: 385
I always let the tip rub for a little bit first. |
| The Following 2 Users Say Thank You to wolly6973 For This Useful Post: | Kamaril (02-10-2012), sstevens805 (02-10-2012) |
![]() | | #9 | ![]() |
Groans: 76
So I guess those of you that have the same issue aren't too worried about it? Maybe I'm asking too much, but I kind of like my parts to fit correctly. Even the $100 ones.
![]() | | #10 | ![]() |
![]() Join Date: Jul 2010 Location: KCMO
Rep Power: 158 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 310
Groaned at 12 Times in 4 Posts
Mine has rubbed through the powdercoat, I guess I'm not too worried about. I'll try to get a pic if it warms up and I remember. Sent from my SGH-I897 using Tapatalk
__________________ CS SRI+TIP, JBarone SSP+Bushings, CS RMM Inserts, Gutted Stock Midpipe, 3rd Gear Grind |
| The Following User Says Thank You to mdl3v8 For This Useful Post: | Pseud0logik (02-11-2012) |
![]() | | #11 | ![]() |
![]() Join Date: Nov 2011 Location: Corona, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 220
You need to slide the tip into the silicone coupler more. I had the corksport tip before my cpe tip and it never rubbed the ecu cover. also make sure the top bracket is tightened down on the stud. or the top bracket may have gotten a little bent so you can bend that if that helps. in any event, corksport will be sure to take care of you.
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . Last edited by bigriver; 02-10-2012 at 09:55 AM. |
| The Following User Says Thank You to bigriver For This Useful Post: | Pseud0logik (02-10-2012) |
![]() | | #12 | ![]() |
![]() Join Date: Dec 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Same here on my 6... rubs on my battery/battery strap though. It's installed correctly and as snug as it can get.
![]() | | #13 | ![]() |
![]() Join Date: Apr 2009 Location: Kansas City
Rep Power: 55 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 121
Mine too. I also picked up their FMIC/SRI/TIP kit and had 2 welds in the TIP leaking, 2 hole in welds on 2 different pipes leaking and a slightly warped BPV flange.
__________________ ★2008 Mazdaspeed 3 GT★ Cobb AP→ AutoTech HPFP→ CorkSport SRI/TIP→ CorkSport FMIC→CorkSport Downpipe→ Devils Own Stage 2 W/Meth Kit (DO5)→ TurboSmart Dual port → Grimmspeed EBCS→ JBR EGR Blockoff Kit→ JBR TMM, PMM, RMM→ JBR SSP, Base Bushings→ JBR TB TIG→ StopTech Rotors, Hawk HPS→ CP-E Injector Seals→ Denso ITV22→ BC Racing Coilovers→ Corn juice ✖ |
| The Following User Says Thank You to MindCrimes For This Useful Post: | Pseud0logik (02-11-2012) |
![]() | | #14 | ![]() |
Groans: 76
As many others have suggested, I'm going to attempt to re-fit it this weekend in hopes of getting a tighter seal at the turbo. I'll take pics.
__________________ ![]() | |
![]() | | #15 | ![]() |
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . |
| The Following User Says Thank You to bigriver For This Useful Post: | Pseud0logik (02-11-2012) |
![]() | | #16 | ![]() |
![]() Join Date: Nov 2010 Location: northwest arkansas
Rep Power: 1612 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,067
Groans: 103
mine came close to rubbing, so i put industrial velcro loop on the ecu cover and it has prevented wear on the tip.
__________________ 2008 ms3 mit: hypertech tune, pg sri, corksport tip, jbr(80 tmm, 88 rmm, 80 pmm), jbarone bushings + heavy shift knob, diy sts, sure ssp, sensen shocks, jbr rsb, ford transfluid, aura 5 channel amp, jbl gt speakers, 6" bazooka sub, diy mudflaps, DDM 3000k HID fog kit, 6000k lows ![]() ![]() |
| The Following 2 Users Say Thank You to tddvrrn For This Useful Post: | Pseud0logik (02-11-2012), rfinkle2 (02-11-2012) |
![]() | | #17 | ![]() |
__________________ ★2008 Mazdaspeed 3 GT★ Cobb AP→ AutoTech HPFP→ CorkSport SRI/TIP→ CorkSport FMIC→CorkSport Downpipe→ Devils Own Stage 2 W/Meth Kit (DO5)→ TurboSmart Dual port → Grimmspeed EBCS→ JBR EGR Blockoff Kit→ JBR TMM, PMM, RMM→ JBR SSP, Base Bushings→ JBR TB TIG→ StopTech Rotors, Hawk HPS→ CP-E Injector Seals→ Denso ITV22→ BC Racing Coilovers→ Corn juice ✖ | |
![]() | | #18 | ![]() |
Rep Power: 11922 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,919
Groans: 235
IMO, the CS is the best fitting tip. The others are too close to the block on the other side. The lack of room @ that particular spot is exactly the reason for Mazda's pancake design. tddvrrn's idea will keep you from doing damage to either the ecu cover or the tip itself.
| The Following 5 Users Say Thank You to rfinkle2 For This Useful Post: | MindCrimes (02-11-2012), Pseud0logik (02-11-2012), SLOWHATCH (02-12-2012), tddvrrn (02-11-2012), wolly6973 (02-11-2012) |
![]() | | #19 | ![]() |
![]() Join Date: Mar 2011 Location: San Antonio
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
I am the other 'derp' that Pseudo is referring to... Here's a pic of mine installed, taken from where the battery box/ECU resides...the damage is pretty significant! It was worn flat at the lower spot, nearest the turbo. Clearly there is an issue. I was shipped a replacement TIP under warranty, but was told a similar response by Kelly that she had not heard of this before. Some of your suggestions (tddvrrn) sound great, as I had similar ideas, but dirt will still get lodged in the velcro (or whatever you use), and damage will be the end result on the TIP as the engine twists under load. There was an interesting end result after installing the replacement I received. Just like the first install, I made sure that I was buttoning up everything nice and tight, expecting the same problem. Pseudo and I had installed the original TIP together on my car. Being aware of his clearance issue at that time, we made sure we had made everything nice and tight. But after installing the battery box with the new TIP in place, the difference was significant! I took everything back off, as I needed to see what, if anything, was different. Because I too was told that I had installed it incorrectly, but did not believe that this was true. There was clearly a size difference on the replacement TIP! I laid them both on a table, weighted the long end down, and took a picture of the height difference of the bend that goes to the turbo. It's about a 1/2"! This is all that is needed to give the proper clearance to the ECU. I returned the original TIP to Corksport with pictures and sent an email as well. CS acknowledged the receipt of the old TIP, but I have not received any response in regards to why the two TIP's are different in size. Just some food for thought...
__________________ Eric Daily Driver 2010 Liquid Silver Mazdaspeed3 Corksport SRI & TIH Cobb AccessPORT - OTS Stage 1 Hawk HPS Pads Track Alignment JBR Rear Sway Bar Corksport Shift plate PTP HPFP 245/35/18 Hoosier A's Autocross DSP |
| The Following 2 Users Say Thank You to mr.panec For This Useful Post: | Pseud0logik (02-12-2012), wolly6973 (02-12-2012) |
![]() | | #20 | ![]() |
Groans: 76
Completely removed and re-installed my TIP this afternoon while taking photos. The damage is more extensive than just scratched powdercoat, but not as bad as the damage in the post by mr.panec I don't think this is the issue. As you can see from the photo below of the silicone coupler, there is only a very small 1/4" line of grime. I can't get them any closer together because of the size difference between the two openings. But I tried anyway, mr.panec supervised and agreed that the pipe was as far in the coupler as it would go.
Reinstalling everything paying very close attention to getting the pipe as far in the coupler as possible and tightening the bracket bolt down as much as possible got me no additional clearance at all. I was able to get a very small amount of extra clearance by loosening the leftmost battery bracket bolt and pushing in the ECU cover before tightening this bolt back down. I doubt that extra clearance will prevent the pipe from rubbing, but it helps. This part just doesn't fit right, bottom line. tl;dr Reinstalled the TIP using suggestions by members, no change, still rubs.
![]() | | #21 | ![]() |
![]() Join Date: May 2011 Location: Portland OR
Rep Power: 1497 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,044
Groans: 173
Groaned at 16 Times in 16 Posts
I had a different rubbing issue with Sure TIP/SRI Didn't want to rotate clamp and make it a bitch to get to later... So reflective tape ftw. Clamp rubbed completely through the stock black electrical tape stuff though. Glad as hell it didn't damage a wire. Silicone FTW I guess, that clamp area is the farthest out the intake goes from the inlet.
__________________ Genwin Individual Throttle Body Webers 20B Swapped 1UZ w/ Hi-Cap Purple Loush and Trigonometric Valve Tumblers. Thetan Core Fogger System. P1@n0 Tuned to Load Burst Limit. Glacier Red '07. |
![]() | | #22 | ![]() |
Another suggestion would be to relocate the ecu with double stick tape to the fuse box cover. = ) But seriously, I may actually end up doing that with 3.5" jbr intake.
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . Last edited by bigriver; 02-12-2012 at 04:12 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to bigriver For This Useful Post: | Pseud0logik (02-12-2012) |
![]() | | #23 | ![]() |
![]() Join Date: Nov 2010 Location: Moorefield, West Virginia
Rep Power: 51 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
Groaned at 48 Times in 7 Posts
Mine rubbed as well on my 6. It fit tight up against the engine and the battery tray still rubbed on the other side. I had to modify the battery tray a bit to give me clearance, then tweek the mounting bracket of the TIP a bit to get it off the engine.
__________________ '06 MS6 GTWild Wonderful, West Virginia Cobb AP, Magnaflow Catback, Underbody Cat Delete, ETS TMIC, Corksport SRI & TIP, Spyder LED Tail Lights, HKS BPV, Drilled & Slotted Rotors front and rear w/Ferro Carbon pads, 35% Tinted Glass |
![]() | | #24 | ![]() |
Groans: 76
(Thread Starter) | Not Ranked : 0 score You wouldn't happen to have any pics of the modified battery tray would you? I drilled the screw holes on the bottom out a little bit so I could mount it further away from the pipe. Didn't help much.
![]() | | #25 | ![]() |
Groans: 76
![]() | | #26 | ![]() |
| 500WHP INC ![]() Join Date: Feb 2009 Location: Tampa, Fl
Rep Power: 483 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 389
Groans: 31
Groaned at 51 Times in 36 Posts
pretty much all brand tips rub the area is sooo tight
__________________ 2008.5 White Pearl MS3 474HP/453TQ http://imageshack.us/a/img4/1726/virtualdyno129124thgear.jpg(with CF 1.01 it was more like 425HP) Mods: 3.5 Bar MAP,Wisecos 9:5:1,Pauter Rods,BSD,balanced rotational assembly, ARP Studs,Devils Own Meth Kit DO7 100%, Garret 3076R T3 w/Titanium turbo blanket, CP-E Safe Seals,CP-E FMIC,CP-E CDFP,Cobb AP,DCR VVT,ITTV24,Grounding Kit,Custom 3.5" Intake and MAF, Custom T3 Manifold w/38MM Tial EWG black cermaic coated with Titanium heat wrap,Custom 3" V-Band DP Titanium heat wrapped,Borla Catback,Fidanza 11LB Flywheel,Spec 3+ Clutch,cometic head gasket,ceramic heat barrier on IM, Sure TIG,V.C.T.S. Welded, Kenne Bell BAS,CP-e Triple gauge pod, Prosport Boost Gauge,Glowshift Wideband AFR gauge, Glowshift EGT gauge,Streetunit Engine Mounts ALL 3,PTP BSD-Windage Tray, So Many Little things i cant remember. |
| The Following User Says Thank You to Nitr0EngiE For This Useful Post: | rfinkle2 (02-13-2012) |
![]() | | #27 | ![]() |
| Not Ranked : 0 score That's exactly what I did. I drilled the one over so far that I had to cut a large part of one of the washers off of the bolt so it would tighten flush. Then I bent the bracket just a little on the TIP so I would have a little clearance on both sides.
| The Following User Says Thank You to Noddaford For This Useful Post: | Pseud0logik (02-14-2012) |
![]() | | #28 | ![]() |
![]() Join Date: Jul 2011 Location: Nutley NJ
Rep Power: 0 ![]() Thanks: 2
Hello All. I've got a similar rubbing problem with the corksport intake, where the rubber coupler between the TIP and the MAF housing rubs on the white ECU wire harness. The ECU harness has a sharp corner and really does some damage to the rubber coupler. I've tried to tape it up with electrical tape, in one hour of driving the tape was torn though. I'm going to try some heavier tape tomorrow. It seems to me the best idea would be just to rotate the angled couple until it Isn't close, but there wasn't enough of an angle to make a difference. Does anyone have any other ideas? Thanks in advance, Matt |
![]() | | #29 | ![]() |
| Neutral : +1 score
__________________ 2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. . | |
![]() | | #30 | ![]() |
Beautiful! Thank you so much for the quick response!
![]() | | #31 | ![]() |
![]() Join Date: Oct 2011 Location: Denver,CO
Rep Power: 150 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 506
Groaned at 28 Times in 14 Posts
$10 fix. Buy a peddle pad and zip ties, then fashion the pad to go around the harness and zip tie it. Five min fix for me.
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
Another great idea, Thanks KILLER_VIZ. I've already installed bigriver's heater tubing fix. If it does not work out, I will try yours next.
| Need help with rubbing | jjfam1 | MazdaSpeed 3/6 - Wheels & Tires | 14 | 02-09-2012 10:02 AM |
| Why am I rubbing? | Smily27 | 2010 MS3 - Wheels & Tires | 17 | 07-13-2011 03:18 PM |
| Corksport TIP Rubbing Breather Hose. | BeeZaa | 2010 MS3 - Turbo Induction | 10 | 12-26-2010 02:10 PM |
| Stock and Rubbing (Help Plz) | KayWhy | MazdaSpeed 3/6 - Wheels & Tires | 7 | 08-30-2009 05:44 AM |
| 225-45-18s, who else is rubbing? | 4thStroke | MazdaSpeed 3/6 - Wheels & Tires | 14 | 07-07-2008 10:39 PM |
